Tupolev160
Airbus 332HGW And Boeing 787 - Comparable?
Mon Feb 20, 2012 2:21 pm
Airbus states that its new version of the 332 is a competition that outmaches the first series of the 787 yet we've heard almost nothing about that aircraft. It was supposed to start being delivered in 2010. Any info on the real performance and whether it is a real match for the B787 or not? Thanks.
"In a time of universal deceit, telling the truth becomes a revolutionary act."
Daysleeper
RE: Airbus 332HGW And Boeing 787 - Comparable?
Mon Feb 20, 2012 4:01 pm
Quoting Tupolev160 (Thread starter):
Where have you seen Airbus saying that?
I'd imagine that on the early frames there isn't the double digit percentage improvement that was expected, but given the 787 is 20 years newer then it should still have better fuel consumption despite being slightly over-weight.
fpetrutiu
Mon Feb 20, 2012 4:07 pm
Well that's Airbus for you...
Korean Air was the first airline that took delivery of the A330HGW when the 787 was falling way behing schedule (they took delivery in 2010). A few month after, they renegotiated their commitment with Boeing for the 787 and as recently as last week they converted to the B789. According to Korean, the A330HGW (6 of them) are a stop-gap measure and will in term be replaced by the "more fuel efficient" B787-900.
Florin
Orlando, FL
Daysleeper
Mon Feb 20, 2012 4:13 pm
Quoting fpetrutiu (Reply 2):
Is it? As I asked the OP where is the press release or statement where Airbus say the A330 HGW beats the 787?
Tupolev160
Mon Feb 20, 2012 4:46 pm
Right - it contained no data => therefore i asked your opinon/knowledge on it, not to be asked as by children "where is the link, where is the link, where is the link" you can put it in your neck the link...oh God.
Daysleeper
Mon Feb 20, 2012 5:07 pm
Quoting Tupolev160 (Reply 7):
All I have done is point out that you were incorrect in your initial post. Airbus has NOT stated the A330HGW out-matches the early 787 therefore the entire basis of the thread is flawed.
If you just want comparative data for the 787 and A330 HGW, fair enough. Ask for that. There is no need to make false statements to encourage responses such “well that’s Airbus for you” As no, it isn’t Airbus at all.
roseflyer
Mon Feb 20, 2012 5:27 pm
This thread is a bit vaguely worded. I believe the premise is that the A332 in its highest takeoff weight form will have more range than the first new build 787s. I don't think that the term outmatches is very appropriate. The low MTOW early build 787s have less range than the competitor they are trying to surpass.
This isn't surprising at all. It's relatively normal. The first 777 had less range than the DC10 that it was intended to replace. The 777 will have more range than the early build A350s.
The word outmatch implies some other criteria, which I don't think are applicable in this case, so I think that is what set off the confusion.
The forum rules require a link as it helps the discussion and reduces confusion. Next time you post, I'd suggest you include a reference when when stating facts, statistics or newsworthy bulletins,.
The 238T A330-200s are being used regularly on transpacific routes. They open up smaller long haul routes and allow the A330 to operate routes that were previously the territory of the A340, 777 and 747.
A 5ton weight increase is great for airlines that need it, but isn't going to get a lot of press since it is impossible for the customer to know about it.
CM
Both Boeing and Airbus list the ranges capability of their passenger aircraft at "full passenger payload". This means every seat full, including passenger baggage, but with no revenue cargo. Also included will be assumptions about winds, reserve fuel, etc. There can be a little bit of gamesmanship on the part of both manufacturers in the analysis. Both manufacturers use a seat count is unrealistically high (which actually penalizes airplane range), but a passenger weight and baggage allowance which is unrealistically low (boosting range). The interior weights, winds, reserve fuel etc, also tend to be unrealistically favorable to the airplane for range.
For the reasons above, a simple statement of "our airplane flies 6,840nm and theirs 6,720nm" is really meaningless, unless they are also providing you with all the assumptions which are behind the numbers.
As for the airbus claim of more range, I would suspect the 238t A330-200 has more range than the first 20 787s produced. All other things being equal, those first 20 787s will carry 18,500 lbs less fuel than 787s built at line 21 or later. That's quite a bit of range the early 787s leave in the fuel truck.
The real fallacy of the Airbus statement is not in the range numbers, it is in the fact Airbus wants to compare the A330 they are offering for sale against the earliest of 787s, which is hardly what Boeing is out in the marketplace offering to airlines.
[Edited 2012-02-20 09:37:01]
[Edited 2012-02-20 09:37:40]
rotating14
Mon Feb 20, 2012 5:31 pm
Tupolev160, I guess we can fairly say that the A332 HGW and the current B787 have no comparison as the B787 continues to garner orders and the A332HGW is...(cooked). You could probably say that you answered your own question by knowing of the fact A is trying to extend the longevity of the A330 by offering the A330S to buffer the competition from the B787.
http://www.latribune.fr/entreprises-...les-performances-de-son-a330-.html
Hello Fpetrutui, do you know how many other airlines ordered this version of A330 and how many were delivered?
fpetrutiu
Mon Feb 20, 2012 6:07 pm
Quoting rotating14 (Reply 8):
I only know of Korean, but some of the features are also found in the F version. I do not think the HGW was a particular successful one when it comes to sales, its fuel burn is nowhere near where the 787 promised to be, especially the 787-900. In my opinion it was a stop-loss attempt to buy more time for the A350 (same as it is the A330S now). They are trying to keep Boeing to add more to the 800+ planes backlog for the 787.
Florin
Orlando, FL
roseflyer
Mon Feb 20, 2012 6:17 pm
Quoting CM (Reply 7):
That's not actually true. The maximum range quoted by Boeing is the range with full standard tanks at MTOW. This is not the same as range with full passenger payload. With full passenger payload, that's maximum operating range. The range quoted for exampe for the 777-300ER is 7930 nautical miles. If you look at the range vs payload charts, this is the second kink in the range payload curve which corresponds to full tanks and not a useful operating payload as the payload useable payload is far less than full passengers.
UALWN
Mon Feb 20, 2012 7:49 pm
Quoting fpetrutiu (Reply 9):
And so far being pretty successful at it! Net orders for 330 / 787 in 2009: 45 / -59; in 2010: 60 / -4; in 2011: 81 / 13. Total for the last three years: 330: 186; 787: -50, for a difference of 236 units.
AT7/111/146/Avro/CRJ/CR9/EMB/ERJ/E75/F50/100/L15/DC9/D10/M8X/717/727/737/747/757/767/777/787/AB6/310/32X/330/340/380
sweair
Mon Feb 20, 2012 8:18 pm
The range of the 787 that Boeing has shared, what is it really? LN90?LN20? 8000nm is that with very few passengers?
8000nm seems to be the distance every modern widebody aims for? Why is this?
Flying Belgian
Mon Feb 20, 2012 8:25 pm
One thing is sure, the 787 should have been serviceable since 2008, up to now only 3 frames have been delivered.
Meanwhile, the A330 soars. MSN 1300 is due to be delivered soon. And it remains by very far the best in its category.
Looking at the orders backlog, the A330 has still some arguments for a 20 years old lady...
Life is great at 41.000 feet...
roseflyer
Mon Feb 20, 2012 8:27 pm
Quoting sweair (Reply 12):
It is full tanks at MTOW, so the amount of payload differs drastically based on fuel quantity. In reality airplanes almost never dispatch with full tanks, so it is more of a theoretical limit. That is why outside a few outliers (like Copa long haul 737 flights), you never see an airline operating at maximum range. On the A330-200 the maximum range if calculated by Boeing's method would have no passengers at all on it since the airplane can't dispatch at full tanks because of the huge center tank. So comparing manufacturer numbers is hard. The A330-200IGW has 9,200nm if calculated like Boeing does for the 787.
[Edited 2012-02-20 12:31:59]
BEG2IAH
Mon Feb 20, 2012 9:35 pm
Quoting Flying Belgian (Reply 13):
I bet you meant to say that 5 were delivered. I borrow the list from another thread: 787..only Three Deliveries Thus Far? (by HNL-Jack Feb 18 2012 in Civil Aviation)
L/N 8 - JA801A - 9/25/2011 - NH (ANA)
L/N 24 - JA802A - 10/13/2011 - NH (ANA)
L/N 31 - JA805A - 12/30/2011 - NH (ANA)
L/N 41 - JA807A - 1/12/2012 - NH (ANA)
L/N 9 - JA804A - 1/13/2012 - NH (ANA)
BEG2IAH
[Edited 2012-02-20 13:40:39]
[Edited 2012-02-20 14:30:34]
Aviation is not so much a profession as it is a disease.
rotating14
Mon Feb 20, 2012 10:25 pm
Upon further review... ANA has 5 in service. 787..only Three Deliveries Thus Far? (by HNL-Jack Feb 18 2012 in Civil Aviation) Also, do you agree in part that the success of the A330 was due to the nonavailability of the 787?
Daysleeper
Mon Feb 20, 2012 10:52 pm
Quoting rotating14 (Reply 16):
How can that be possible as the A330 existed before the 787? If we assume that Airlines actually needed a 787 sized aircraft and didn’t just order them because Boeing were selling them at narrow body prices then had the 787 not existed they would have bought the A330… So no, they bought the A330 because they needed them.
rotating14
Mon Feb 20, 2012 11:16 pm
Quoting Daysleeper (Reply 17):
I beg to differ on the basis of the obvious, nonavailability. Suppose I run a fleet of cargo ships and my fleet can handle my current volume. I anticipate more contracts for freight and my current vessels are good but there is a better newer styled vessel that I ordered a few years ago that is not on the market yet and my volume is increasing thus stretching my capacity. Do I wait and wait and wait on something that is uncertain?? Or do I accept what is available (Boeing or Airbus) to stop gap the delays with newer, delayed yet better overall vessel??
HeeseokKoo
Mon Feb 20, 2012 11:29 pm
KE ordered first 6 HGW at early 2009, added 5 more at early 2010 (total 11) and started delivery from July 2010. After KE got 4 of them, in March 2011, KE converted 10 788 orders to 789 and deferred delivery from 2012/2013 to 2016. Yes, KE chose 332HGW as an alternative to the delaying 788, but it seems to me that KE satisfied with it and sort of replacing 788. For KE, 788 and 332HGW do similar mission with similar size, and 789 is little bit bigger than both (correct me if I'm wrong). 332HGW is doing what 788 would do - thin long hauls such as LAS, MEL, and soon NBO.
I don't recall Korean ever mentioned that 789 will replace 332HGW, although 789 may replace some of older 332s. There should be some reason behind the fact that only KE operates this type, though.
trex8
Tue Feb 21, 2012 2:09 am
Quoting HeeseokKoo (Reply 19):
Because most operators of a 233K A332 find it more than adequate already?? Lets face it, Japan to most of N America west coast can be done comfortably by a 233K A332 vis DL etc, Korea is just a little further making a few more tons TOW just that more useful. You need more than 5000nm and 250 pax against strong headwinds you'd better find something else.
I see on their acaps Airbus A332F still does not have a higher than 233K WV. You'd think thats where it would be really useful.
Flying Belgian
Tue Feb 21, 2012 8:06 am
Of course I do, at least for the orders concerning the last five years.
And I do say the 787 is a superb airplane.
astuteman
Tue Feb 21, 2012 8:58 am
Please be careful about statements like this.
The only thing Airbus ever said about the 238t A330 was that it would match, or beat, the range/payload of the first 787's off the line. They never even compared the operating costs, much less claimed that the A330 would be better. And rightly so.
But it's entirelty possible that the 238t A330 is at least the equal of the first 20 or so 787's in terms of range/payload, for the reasons given by others above. So Airbus's comments could well be entirely plausible. Because of course..
Presumably because the 238t A330 has now filled the gap that the 787's would have occupied, thus removing the need for the 787-8's ...
In the same way that continuous upgrades to the Boeing 747, 767, and 777 have been, and are, "stop-loss attempt to buy more time", presumably ...
For obvious reasons. See above
Are you sure about this?
I'm fairly sure that QF also ordered 238t A330's to stand in for their early 787-8's.
Whilst on the subject, I'm also pretty sure that the 238t upgrade is "retro-fittable" to in-service A330's anyway. In which case I suspect you'd be hard pressed to compile a list of who uses the capability and who doesn't.
scbriml
Tue Feb 21, 2012 9:37 am
Boeing certainly made a significant contribution to the continued success of the A330. But, what is somewhat shocking, is how little the 767 gained in comparison.
imiakhtar
Tue Feb 21, 2012 10:11 am
Quoting astuteman (Reply 22):
Correctamundo:
Qantas's Jetstar opts for higher gross weight A330s
The option provides an extra 3.4t of payload or 610km (330nm) in range compared with the traditional 233t A330-200. Airbus began offering the heavier A330 in 2008, aiming to take advantage of 787 delivery delays, and Buchanan confirms its availability was a key factor in Qantas's decision earlier this year to defer its Boeing 787 deliveries.
I was not aware of a retro-fit for the HGW. Do you have a link?
Whatever happened to Leon Trotsky?
EPA001
Tue Feb 21, 2012 10:14 am
And with that statement this thread could be closed imho. Because it has a high risk of fierce debating which easily could go off-topic.  . The A330-HGW is what it is, a very good offering from Airbus which at some point can keep up very well with the earlier B788's. And is part of the still extremely successful and strong selling A330 family.
But as time and developments will progress, the B788 will widen the performance gap in her favor. Which is only normal with new aircraft, since they will never reach their full potential right of the mark.
[Edited 2012-02-21 02:15:26]
Tupolev160
Tue Feb 21, 2012 11:17 am
Thank you all for your answers despite the approximate description of the topic, special thanks to Roseflyer whose answer was the most clarifying.
Daysleeper
Tue Feb 21, 2012 1:09 pm
Quoting rotating14 (Reply 18):
Okay, sticking with your example and assuming that Boeing had never produced the 787 then when the shipping company anticipated the new contracts they would have ordered the most suitable vessel for their business, which would have been the A330.
My point in this is, Boeing produced the 787 because they saw a demand in this market sector. A demand which would have been met entirely by the A330 had they not produced the 787.
SEPilot
Tue Feb 21, 2012 5:06 pm
Quoting Roseflyer (Reply 14):
Why does the A330 have such a huge center tank? I would think that it would have been more valuable to make it smaller and use the space for cargo. Does it have something to do with commonality with the A340 and using the space not needed for the center landing gear? If so, I still do not understand why it could not have been made cargo space; after all, the A340 needed much more fuel than the A330. Having more fuel tank capacity than can ever be used seems to me to be a poor choice, unless it is in the wings where there is no other use for the space. But the center fuselage area is very useful.
seabosdca
Tue Feb 21, 2012 5:30 pm
Quoting imiakhtar (Reply 24):
http://www.flightglobal.com/news/art...-boeing-777-remain-popular-333971/
A332s built after sometime in 2004 can be upfitted to 238 t.
roseflyer
Tue Feb 21, 2012 5:38 pm
Quoting SEPilot (Reply 28):
The center tank is the wing box, so the space can't be used for cargo. I don't have detailed access to the A330 system description, so I can't add more than that.
The large center tank is only on the A330-200 and not A330-300 and does have commonality with the A340 which needed more fuel. Essentially the A330-200 can take almost as much fuel as an A340-300 for commonality purposes, but it does not need that much fuel, which throws off the range charts a bit.
packsonflight
Tue Feb 21, 2012 5:40 pm
The center tank is normally inside the center wing box which is a gigantic torque box and otherwise unusable since the front and rear wing spar goes right through it and determine the front and rear of the box.
The wheel well is right behind the wing box.
trex8
Wed Feb 22, 2012 2:14 am
Correctamundo:
Every production list I have seen shows Jetstar and Qantas A332s in recent years being -202 models which would indicate they have the 80E1--A4 engine which has a lower thrust than the A3 on some earlier QF A330-203s. If they are increasing TOW and still using the less than most powerful GE engine variant isn't that "odd"??
CM
Wed Feb 22, 2012 4:47 am
Quoting trex8 (Reply 32):
isn't that "odd"??
It may not be odd, particularly if they are using the airplane at airports near sea level and without a requirement for immediate climb. For example if they were flying the airplane SYD-NRT, they may be able to fly at a high MTOW with less than max thrust. On the other hand, an operator flying out of Addis or Bogota would need the thrust because of the field elevation. An operator flying out of Santiago to Europe would need the thrust in order to quickly climb to get over the Andes. The route will make as much difference as the airplane weight.
gigneil
Wed Feb 22, 2012 4:53 am
Lets see that source, please. I believe you to be making it up.
Also, show me that breakdown for the 238t sales vs the others? I bet you don't have that.
NS
redflyer
Wed Feb 22, 2012 5:54 am
Quoting scbriml (Reply 23):
What's really shocking is that the 767 is getting any orders at all on the commercial side, 50 in just the last 25 months.
My other home is in the sky inside my Piper Cherokee 180.
SASMD82
Wed Feb 22, 2012 6:05 am
Quoting redflyer (Reply 35):
I agree with you. With the 787 and the 332 available I do not understand any new 767order. Although the ANA and LAN orders may be plausible owing to their existing B767 fleet.
Flyglobal
Wed Feb 22, 2012 7:57 am
Shouldn't we assume that the 767 orders are to a high degree (except fed ex of course) part of the compensation settlements Boeing negotiates with its costomers for the late late late 787 deliveries? Kind of (ceap) Planes instead of cash.
regards
Flyglobal
thegeek
Wed Feb 22, 2012 8:04 am
Quoting Roseflyer (Reply 10):
I also don't believe this is correct. 77W is fuel volume limited at MTOW with a full passenger load. Your formula would require some revenue cargo to be included. 233t A333s have the same "feature".
CM was correct AIUI.
SEPilot
Wed Feb 22, 2012 11:20 am
Quoting packsonflight (Reply 31):
But the implication is that the A330 center tank is much larger than in other, comparable airliners. Is that because the A330 uses all of the available space in the wingbox whereas other planes do not?
Daysleeper
Wed Feb 22, 2012 11:24 am
Quoting flyglobal (Reply 37):
regards
Flyglobal
ANA and JAL both received 9 767’s each as compensation for the 787 delays, but the majority of these were added to the order book more than 2 years ago with only 5 being included in the OP’s 50.
It is worth mentioning however; of the 45 remaining 32 were freighters or tankers, meaning the 767 has only sold 13 passenger frames in 25 months that haven’t been part of a compensation package. This isn’t just a statistical blip either, going back as far as 5 years then you still only get 28 passenger frames sold, in the same time period the A330 has sold ten times that amount!
roseflyer
Wed Feb 22, 2012 5:05 pm
Quoting thegeek (Reply 38):
With full tanks, the 77W has only 45,000lbs of available payload left with 320,000lbs of fuel. With the current FAA regulation of 225 pounds per passenger including luggage on an international flight, that's only 200 passengers. The 77W just like just about every other Boeing plane will take practical payload hits before being fuel volume limited. Longer range 747s and 772LRs have optional auxiliary tanks.
The 77W takes payload cuts at around 5,800 nm. At Boeing's nominal full passenger load of 365 (which is on the high side), it's range is 6,600nm. At more practical capacity of 300, range is closer to 7,400nm.
My point is that the range quotes given by the manufacturers are hard to use realistically since you need to use the two dimensional range charts. The A330 is a bit of an outlier, so comparing the A330 and 787 on max range alone is not a very good comparison.
thegeek
Wed Feb 22, 2012 11:01 pm
Quoting Roseflyer (Reply 41):
How do you figure? I get (sorry, metric):
181283L fuel tank
density @ 15 degrees C (ISA) = .8086 kg/L
Fuel weight = 146.4t
OEW = 167.8t
MTOW = 351.5t
Payload with full tanks = 37t / 81822 lbs
Passengers @ 225lbs = 363
Perhaps you have a heavier OEW?
Hmm, I guess its still coming up with not being fuel volume limited on those figures. I was basing it on Boeing range charts. Recomputing at zero degrees C gives another 3.5t of fuel with full tanks so I wonder if that is what the range chart is based on.
thegeek
Thu Feb 23, 2012 12:20 am
225lbs? You have weighed the luggage, you know how much it is. I believe lifts work on 68kg (150lbs) average per pax, but perhaps that is somewhat too low for the US.
roseflyer
Thu Feb 23, 2012 1:32 am
Quoting thegeek (Reply 43):
That's the number in the AC that the FAA instructs US airlines to use for weight and balance. 195lbs for the passenger and personal belongings and 30lbs for luggage (in the winter).
I believe the discrepancy may be furnishings and minimum reserves.
thegeek
Thu Feb 23, 2012 2:56 am
Quoting Roseflyer (Reply 44):
Furnishings should be included in OEW, and min reserves (assuming fuel) would be included in the full fuel tank.
trex8
Thu Feb 23, 2012 3:01 am
Over 2/3 the US adult population are overweight (Body mass index >25) and 1/3 are obese - have a BMI >30
