PHX787
CVG Terminal 3 Future?
Thu Mar 15, 2012 8:01 pm
Hi all, this is my second overall post on A.net (first topic) but I've been a regular visitor for some time now. I ran a search and couldn't find anything on this recently.
Is there any news coming from CVG on when the renovations to Concourse A will be finished and opened? Also are there any airlines considering taking over from where DL left?
Obviously with the economy being in the tank, I'm sure CVG is probably one of the last places airlines would want to start additional ops, but what do you think?
IIRC, DL has the lease on Concourse C (the former OH hub) until 2025. Do you think that could be given back to the airport, like Concourse A was?
Thanks, Zach
rafflesking
RE: CVG Terminal 3 Future?
Thu Mar 15, 2012 8:29 pm
Welcome to a.net!
The renovations on Concourse A are slated to be finished this summer. The concourse will also be expanded to about 20 gates (I can't remember how many prior).
At least in the foreseeable future, I can't imagine the Kenton County Airport Authority pushing Delta to return Concourse C to them. There is just too much vacant space that they may as well keep collecting lease income while they can.
I don't expect you'll see too much of a ramp up from any airlines at CVG. WN seems just fine serving the market from neighboring cities (DAY, IND, CMH and SDF). US just added DCA service - and little adds like this are probably the best they can hope for.
rockyracoon
Thu Mar 15, 2012 9:08 pm
Airports: CVG PIT MWO PHL PIT PHX ORD DCA MIA TPA MCO ATL DTW DFW SJC LAX DEN SLC LAS HNL LIH OGG YVR MUC ICN NRT PVG SHA SZX MNL PPS CRK BKK DMK KBV EOH MDE CLO CTG SMR BOG ACD MEX CUN MID
seatback
Thu Mar 15, 2012 9:20 pm
First, concourse C should be torn down. It was progressive for its time, but completely outdated and serves no use anymore.
For concourse A, it totally makes sense for all non-Delta aligned carriers to move and close terminal 2. However, as a side note, I love the convenience of terminal 2, but hate the windows!!
What I am surprised about is that they felt they needed to update concourse A. It was nice before. Add some paint and new carpet and call it a day.
With the economy in the tank and airport finances stretched as thin as they are, was spending milliions of dollars worth it? Luxurious bathrooms?
BTW, it looks like in the sketches UA is running a 777!!
PHX787
Thu Mar 15, 2012 9:59 pm
Quoting rafflesking (Reply 1):
Yeah that's been the general conversation for a while, unfortunately.
Quoting seatback (Reply 3):
So two differing opinions I see. IMO, I think Concourse C could be upgraded/used for regional jet traffic from US / UA, given those two expand more into mainline service. By renovating, I mean decreasing the number of gates down, constructing jet bridges, etc. Except, in reality, that sounds way too expensive for Kenton County to want to handle.
Perhaps this is to make CVG more attractive to other carriers?
DeltaRules
Fri Mar 16, 2012 12:56 pm
How many gates will the non-Delta carriers use in Concourse A? There's not close to enough service from the others to fill even half of A, is there?
rockyracoon
Fri Mar 16, 2012 3:41 pm
Terminal 2 is a tight squeeze with 8 gates right now. If I recall correctly, AA has three, UA three, and US 2. I believe AC flies out a UA gate. Granted only one daily flight is mainline, but each airline could do with a little extra space. I've seen multiple flights using the same gate (which isn't necessary wrong in and of itself). CVG also has a fair amount of overnights. Point in fact, there is absolutely no room for growth following the status quo. The renovated concourse A will have about 20 gates, which is overkill for 2012 traffic.
boeingavionics
Fri Mar 16, 2012 7:02 pm
I have first hand knowledge of the following information in terminal 3 concourse A American eagle is planning on having 6 gates. the will be three on each side closest to the underground tram side of the concourse. the opening date is scheduled to be mothers day 2012. the new jet ways are being installed and all work is scheduled to be done by the end of April. terminal 3 concourse C the one Comair used to use is to be torn down due to lack of up keep and the fact that the underground fuel system has not been maintained. I do not know how many gates USAir or United are scheduled to get at this time. also i should be noted there are currently no American main line flight in or out of CVG. that might change after American comes out of bankruptcy. PS there is a long stand rumor that south west might acquire Comair but its just a rumor at this point. (most likely wishful thinking on Comair's part.
seatback
Fri Mar 16, 2012 7:36 pm
Quoting boeingavionics (Reply 7):
So I was totally believing your info until you posted this. I would imagine AA won't need anymore than 4 gates.
rafflesking
Fri Mar 16, 2012 8:35 pm
Quoting seatback (Reply 8):
Seriously - if WN doesn't want to keep the 717s, why would they even spend more than 3 seconds talking about acquiring a whole bunch of CRJs.
And I also still can't imagine Kenton County even touching Terminal 3 as long as DL's lease payments offset any existing maintenance costs.
PHX787
Sat Mar 17, 2012 12:22 am
Quoting RockyRacoon (Reply 6):
So I take it once the economy ramps up again, we might see an increase in flights out of CC-A again?
Quoting rafflesking (Reply 9):
Because CRJs are so much more manageable, right?
CIDFlyer
Sat Mar 17, 2012 1:31 pm
I'm wondering if the exisitng airlines might pick up a few more gates in the new terminal. There will be plenty of room for expansion and some new entrants. Perhaps maybe NK, F9, or B6 might come in with a few flights too now that there will be the gate space. Did I hear at one point they want to tear down both Terminals 1 and 2?
the last time I was through CVG back in 2009 you could really tell a difference between A & B. A to me seemed like it had more of a dated 80's, early 90s look while B seemed more modern so I am glad they are overhauling A. Wasnt A built before B? I agree though C needs to be torn down, there really is no functional use for it unless some puddle jumper / commuter operator like Great Lakes comes in there with a substantial operation and I dont see that happening at all.
PHX787
Sat Mar 17, 2012 7:41 pm
Quoting CIDFlyer (Reply 11):
Yes you heard correctly and I'm currently struggling to find the source which I heard it from (possibly local news in Cincinnati.)
Yes it was, but I'm not 100% sure about the difference in time between the two.
with 79 gates (i think) for CRJs/other RJs, if the city had a large O&D ops, other airlines AND DL could share Concourse C for RJ ops. But 79 gates, and the fact that you had to have taken that shuttle bus, is quite a bit. Perhaps (this could be far off in the future) a separate Concourse for RJs, or, renovate one end of Concourse A or B so it's specifically built for RJs, instead of using Jet Bridges?
just some thought
lhcvg
Sat Mar 17, 2012 7:51 pm
Quoting PHX787 (Reply 12):
just some thought
I remember seeing some airport master plan or something around 2005-6 that planned for a new RJ Concouse D oriented north-south roughly where T1 or T2 is now. I remember that the train was supposed to be connected via an L turn, but I don't remember where I saw that or whether it is still in the works.
FWAERJ
Sat Mar 17, 2012 8:28 pm
Concourse A was built in 1974 as part of the original Terminal 3, while Concourse B opened in 1992 along with the train and the current Terminal 3 ticketing hall.
"Did he really need the triple bypass? Or was it the miles?"
b727fa
Sat Mar 17, 2012 8:48 pm
It would be entirely feasible to use the west side of A (the former A1-A12) for the short term and the east side could be shuttered for a time until which time it would be worth having services and gates there. It could even be done in stages...sort of "push it out" as needed. At the top of the escalator to the left is A1--and a gate house big enough for a barn dance. To the right at the "crossing" you have 2 & 3 to the left and 4 & 5 to the right. Then up the ramp you would have access to another set of double gates on either side. That would more than accommodate the current users and still leave most of the east side open for future tenants.
From when I am on the employee bus and it passes A, the new jet bridges look to be further apart--though that could be a trick of the eye b/c for so long they were turned sideways and the ramps were added for the RJ ops. There are some gates where new jetways have not been installed.
There was talk of a "New T1" on the footprint of T1/T2 when DL was still running a hub at CVG and the "New T1" was going to simply replace the two older buildings. It was intended to be RJ favorable per se with a limited number of "full size" gates for ML sized a/c as the vast majority of other airlines in CVG were RJ ops. (Though UA tends to throw a 737/320 in on an RON at times. It was initially going to be stand alone and have landside access but not airside. That may have changed at some point.
My comments/opinions are my own and are not to be construed as the opinion(s) of my employer.
point2point
Sat Mar 17, 2012 8:54 pm
I took sort of a look at this situation, and one of the things that are sticking out to me is that CVG only has the four major legacy airlines, and AC Jazz, that provide service there. This is 5 airlines there, and I would think this is probably the least amount of carriers at any major airport in the U.S.?
This then leaves me thinking that....... do they really need to do anything there?
PHX787
Sat Mar 17, 2012 10:04 pm
Quoting FWAERJ (Reply 14):
How were pax transported to concourse A back then?
Quoting point2point (Reply 16):
Ask the Cincinnati business community (especially Chiquita up until recently) what they think about this
b727fa
Sat Mar 17, 2012 10:57 pm
Ask Cincinnati why they deserve a hub at all. They hated Delta with the hub; they hate Delta when the hub is gone. They have never understood the requirement for O&D and that they can't go to outlying cities "just to connect in CVG--Delta is sooooo stupid" and expect the company to not redeploy assets where it can make money.
Reap what you sow...
PHX787
Sat Mar 17, 2012 11:01 pm
Quoting B727FA (Reply 18):
A lot of us really were upset with the excessive fares they charged, which is why for a long time, a lot of us went to SDF, DAY, and IND. When DL lowered the fares in 2009, that's when they started cutting flights.
you do raise a good point, however.
flyguy89
Sat Mar 17, 2012 11:12 pm
   exactly. It may sound ridiculous with all the empty space after the DL cuts, but there currently is no room for expansion in T2. Things will get much more interesting regarding future air service by other carriers once concourse A opens and there's room for growth/additions
Quoting PHX787 (Reply 17):
Basically the old T3 was identical to T2, and when DL hubbed CVG, they built the concourse A extension perpendicular to the original pier of gates. When T3 was completely overhauled, they tore down the old check-in area and original pier of gates connecting it to concourse A, built the current land-side terminal, concourse B and the underground train connecting everything.
meh...ignorance of local media and politicians. The same thing is going on in MEM and many other hub cities. When the hub is thriving, it's just a populist position to stand back and criticize the high airfares necessary to sustain the hub, and when the airlines cut service, to criticize the airlines for reducing flights.
seatback
Sun Mar 18, 2012 12:07 am
79 gates makes it sound huge and that CVG should try to attract another airline. The facility was one of the first terminals built for regional jet/airline use. Like I stated, it was progressive at the time. Today, it's a dinosaur. Two huge departure holding areas gave you the feel of a bus station with a Brooks Brothers thrown in.
I may be wrong, but separate regional terminals seem to be a thing of the past. Now days, you frequently see a CRJ sitting next to a 767 etc... Airlines have seem to meld the ops together in many places (i.e. SLC).
I'd be surprised to see terminal one torn down with the admin offices and the FedEx gates.
CIDFlyer
Sun Mar 18, 2012 2:02 am
Quoting seatback (Reply 21):
this is very true, at the time C opened at CVG it was a one of a kind facility. But then came along terminals like the C concourse at DTW (NWA now DL), Concourse G at ORD (AA), C, A & B at MSP (NWA now DL), and Terminal B at DFW (AA) etc etc and Concourse C at CVG quickly became outdated. These newer facilities allowed jet bridge boarding and their own gates for ERJ's and CRJ's and kind of blended in the mainline/express experience to make it more seamless. C at CVG very much felt like a bus station kind of experience.
PHX787
Sun Mar 18, 2012 3:22 am
Quoting CIDFlyer (Reply 22):
you guys have a point, often times I'd find myself getting lost at C trying to find a gate which was simply across the hall.
Quoting flyguy89 (Reply 20):
That's why I don't watch the news anymore (even with me living in PHX)
I see, but what was it that made CVG so expensive, especially for DL to operate out of?
I see, Thanks. I was born before all of this stuff happened.
flyguy89
Sun Mar 18, 2012 9:49 am
Quoting PHX787 (Reply 23):
Well I have my own opinions on that whole issue which I won't go into extreme detail about. I understand that the hub carrier requires a certain premium on airfares at the hub city which I accept, but DL got totally out of hand at CVG. Airfares on DL were usually triple what other carriers offered and they really created the current travel dynamic in the Cincinnati area sending people fleeing to the surrounding airports, often times it was cheaper to drive to DAY or SDF and connect back through CVG to the flight you wanted which is just financially ridiculous. DL finally started getting more reasonable about airfares when FL in DAY nabbed one of their P&G contracts to shuttle employees to BOS. Of course the rest is history though as a few years later DL merged with NW.
It was kind of before my time as well, but departedflights.com has some old diagrams of the airport layout which are interesting.
Quoting RockyRacoon (Reply 2):
I'm not overly optimistic with regards to commercial flights, but DHL is expanding!!!
I just saw the news about it, this is excellent! DHL is a tremendous asset to CVG and has definitely softened the blow from all the DL cuts.
PHX787
Sun Mar 18, 2012 9:55 am
Quoting flyguy89 (Reply 24):
   it's really great seeing 744s at CVG, even if they are cargo jets.
And thanks for the info on pricing. Makes a whole lot more sense now, unfortunately. Just a bad situation CVG got itself in with DL.
slcdeltarumd11
Sun Mar 18, 2012 10:43 am
Delta has leases till 2025 and the airport should make them pay until then so they have to keep concourse C up. I guess in the big picture it was a good idea to move the other carriers to concourse A so they can save money and close terminal 2 since concourse A is so much better equiped and nicer looking.
The ironic thing is that delta actually needs more mainline gates and newer facilities at a few hubs and is paying for all this space at CVG they are not even using.
The real problem is attracted someone to CVG when all of Deltas leases expire. I cant see them renewing for more than a handful of gates and destinations so they better be stock piling cash and trying to attract more service to concourse A before that happens. The move to A also gives them space to attract someone so just in case they are ready to pounce but as others have said the real problem is so many airports have empty space or are underutilized as is RDU, COS, PIT, IND, STL, MKE (soon F9), MEM, CLE (if you belive the people on here) so there is alot of competition out there unfortunitely. These cities all have some similarities and are not
Delta is still flying a decent CVG schedule but i think thats just to minimize expenses and to loose as little as possible. They are paying for CVG so they have to try to reduce loses as much as possible. When deltas leases end is when i bet we really see them send routes to the chopping block but until then its trying to reduce loses i would guess more than actually wanting to be there. CVG is still high fare and low competition so since delta is paying for the space they mine as well fly planes where they can make money
rockyracoon
Sun Mar 18, 2012 11:43 am
Quoting PHX787 (Reply 25):
And ironically 9/27's 2000 ft extension will be put use after all.
CIDFlyer
Sun Mar 18, 2012 4:28 pm
here is a link to an article that has some good info on how the CVG hub ran with the high airfares, and how it began to decline
CVG-lost-half-all-flights" target="_blank">http://news.cincinnati.com/article/2...0393/Why-CVG-lost-half-all-flights
msp747
Sun Mar 18, 2012 5:20 pm
Looking at the layout of the airport, I think it is smart to consolidate into Concourse A. Honestly, I think they should tear down terminal's 1 and 2 and just focus on terminal 3. Maybe even rename it the "main terminal." With 1 and 2 gone, I'm sure you could build out terminal 3 if you needed more counter or security space in the future. It also appears that Concourse A could easily be built out, if the demand was there. Then again, that might never be necessary, especially if Delta officially pulls the plug, freeing up most of Concourse B. As for C, I say tear it down. But if Delta is still paying for it, then I guess you leave it there to rot.
FWAERJ
Sun Mar 18, 2012 5:58 pm
When I looked at some old CVG terminal maps, it looked like there was a walkway of some sort between the original Terminal 3 and what is now Concourse A.
PHX787
Sun Mar 18, 2012 6:12 pm
Quoting msp747 (Reply 29):
These days, it's more "when," not "if."
Quoting CIDFlyer (Reply 28):
Thanks! quite informative. Looks like the combination was slated to fail from the beginning.
Quoting slcdeltarumd11 (Reply 26):
What I'm really disappointed to see is businesses not stepping up and demanding more out of Delta. At the same time, They haven't demanded anything out of US, UA, AA, or any other airline, for that matter either. it seems like the business community is more focused on keeping DL "The Official Airline of ______ in Cincinnati" and not focusing on what they need to do to be more profitable. As I mentioned before, Chiquita, who has been in the Tri-state for quite some time, threatened and lived up to the threat of moving from Cincinnati to Charlotte, where US has its main hub. The reason being was simply lack of destinations. But at the same time, according to that article, there simply isn't that much of a market.
rafflesking
Sun Mar 18, 2012 8:54 pm
Quoting PHX787 (Reply 31):
Fair...but it's manageable. I work for the Cincy's largest multinational corporation and DL still serves all of our key domestic locations nonstop from CVG. Locations are obviously an issue - but the only two true non-stops we miss are CVG-LGW and CDG-FRA. We were 1-stopping to all key Asian destinations already, or using CDG or IAD as a connection point to Europe.
CIDFlyer
Sun Mar 18, 2012 10:17 pm
no problem! I thought it was a pretty well written article and informative to what happened at CVG.
I always liked CVG as it was less congested and further south from the snow belt so the weather was always pretty decent when flying through there in the winter time, but I guess gone are the days of inflated hubs that have 500-600 daily flights in cities that cant support them. I remember back in the late 90s always seeing ads at the DL counter here at CID that touted "FlyCVG" and highlighted how it was all jet and specifically pointed out how it was a good alternative to ORD. Guess it was nice while it lasted, but once DL and NW combined it was pretty much in the cards that DTW would take over the role that CVG was used to playing with its beautiful terminal and higher O&D. MSP also took away traffic flows that allowed CVG not to be needed as well.
Hopefully DL is happy with CVG as it is now, I think they have around 150 ish daily flights and plus have kept their CDG flight, enough to keep B fairly busy I would imagine. I bet PIT and STL would have been happy to have kept that from their former hub airlines (US & AA respectively). Guess time will tell though what will eventually happen there.
