BobMUC
Russian Jet Takes Off With "hole In Wing"
Wed Mar 21, 2012 12:37 pm
Hello,
couldn't find it posted:
http://www.channelnewsasia.com/stories/afp_world/view/1190398/1/.html
It wasn't a hole, but still a kind of strange story...
khpn
RE: Russian Jet Takes Off With "hole In Wing"
Wed Mar 21, 2012 3:21 pm
The story leaves much room for speculation.
Anybody able to dig up which UN 737 this was?
UN has 737-300/400/500/800 so this would seem like the first step to identifying (by A.net standard) what exactly was missing.
BobMUC
Wed Mar 21, 2012 4:17 pm
News video with picture of the missing part:
http://rt.com/news/prime-time/transaero-plane-wing-hole-018/
Shouldn't be a problem for the 737-experts here to identify it by "A.net standard"...
DualQual
Wed Mar 21, 2012 5:01 pm
There are a bunch of different access panels on the wing. If a cover was missing you might be able to go depending on which cover/panel etc. I don't have an MEL/CDL in front of me but if it says you can go without you can go.
There's no known cure for stupid
Clydenairways
Wed Mar 21, 2012 5:19 pm
Well they could have at least covered it over with speed tape, it would have saved them a lot of hassle.
yeelep
Wed Mar 21, 2012 6:21 pm
Yep that's a missing access panel from a 737classic. I don't think that is a CDL item. They obviously do things a little differently in Russia. Either replace the panel with a spare, rob one from another plane or have an engineering disposition to make a temp. panel out of aluminum sheet and speed tape or speed tape alone. Another potentially interesting item in the article is the first refused takeoff due to a indication problem connected to the A/C system. Its possible the panel was loose and then blown out due to a duct leak in the strut that also caused the flight deck indication. There is a blow out panel in the strut, but if the panel was already loose, it may have been the path of least resistance. Of course it probably was unrelated but its fun to speculate.
deltaffindfw
Wed Mar 21, 2012 6:44 pm
I've had that happen on a DL 732 about 7-8 years ago - PDX-DFW. Missing access panel. Pilot talked with maintenance, he added more fuel to compensate for drag, and we took off.
Ty134A
Wed Mar 21, 2012 10:51 pm
Russians are getting spoiled... I remember some years ago you would have been happy if it wasn't more than just a missing panel. I already had a whole cowling missing on an A28, and the pilot ment that the plane only goes up to 3500m. That made me then feel better.
I have seen a machanic with a 200 rub tool bolting (replacing 2 bolts) on the intake on a YK2 while I was sitting on seat 18f... But that was rather funny, he was so friendly and smiled to me from minus 35 degrees to the warm 7 in the plane (yes, staircase open).
I remember a flight on a YK4, on which the airline painted the toilet and refurbished it. The paind was wet and on the floor the remainders of drilling holes were to be found. Holes were drilled into direction of fuselage  for the toilet paper holder.
And a navigator I know told me they could only go up to 7500m with a certain TU3, as it can't hold the pressure much higher.
So what was the trouble on the UN flight? Hahaha, slava russkoj aviazii!!!
flown on: TU3,TU5,T20,IL8,IL6,ILW,IL9,I14,YK4,YK2,AN2,AN4,A26,A28,A38,A40,A81,SU9,L4T,L11,D1C,M11,M80,M87,
AB4,AB6,318,313,342,343,345,346,712,703,722,732,735,741,742,743,74L,744,752,753,763,772,J31,F50,F70,100,ATP,
142,143,AR8,AR1,SF3,S20,D38...,738,320
tdscanuck
Thu Mar 22, 2012 2:58 am
Quoting DualQual (Reply 3):
Deferable under CDL 54-20-02. Up to 4 panels are allowed to be missing per strut. For just one missing there is no takeoff/landing penalty. The crew was completely within procedure to continue the flight.
Quoting clydenairways (Reply 4):
That would be worse; the CDL already covers the panel missing. It doesn't cover the hole being sealed up with speedtape...the latter would require an engineering disposition.
Quoting yeelep (Reply 5):
That is the blowout panel.
Tom.
737tdi
Thu Mar 22, 2012 4:32 am
Quoting tdscanuck (Reply 8):
I don't think you would call that a blowout panel. It is an access panel to the bleed air duct, wiring harnesses, pressure sensors, fuel line, hydraulic line, etc.. We have had them come off in flight due to incorrect installation, they use a type of wing nut that engages the flange on the pylon panel, if the nut doesn't rotate the 90 degrees you should see it due to the indexed collar that is marked on top. Kind of a crappy set up but in no way a safety of flight issue.
yeelep
Thu Mar 22, 2012 7:58 am
Nope, not a blow out panel. The blowout panel is located on the fwd strut fairing.
Thu Mar 22, 2012 9:29 am
The picture is not displaying,but sounds like an access panel....Could be deffered under CDL.
transaeroyyz
Thu Mar 22, 2012 11:07 am
One of four Boeing 737-300s, ranging 11-25 yrs old, http://www.planespotters.net/Product...e=737-300&fleet=3697&fleetStatus=1
tdscanuck
Thu Mar 22, 2012 2:13 pm
Quoting 737tdi (Reply 9):
I was calling it a blowout panel because that's what the CDL called it, at least as I looked at the drawing.
Quoting yeelep (Reply 10):
Isn't that what's shown in the video? I stared at the CDL drawing for several minutes trying to locate the panel from the video against the drawing. It seems to fit the blowout panel location best.
Quoting HAWK21M (Reply 11):
If it's an access panel the same CDL rules apply (different CDL item from the blowout panel but same restrictions).
Tom.
737tdi
Thu Mar 22, 2012 6:19 pm
Don't quote me too closely but I believe there are 5 total of these panels on the pylon, 2 on the side and 3 on top. I tried to find my panel book but it must be at work.
yeelep
Sat Mar 24, 2012 1:16 pm
Quoting tdscanuck (Reply 13):
In the picture below, the missing panel is the one on the right, the blowout panel is the one on the left with the stencil on it.
Quoting 737tdi (Reply 14):
Eight total of this type of access panel per pylon. Three on top, two inboard and three outboard. One inboard and two outboard panels are hidden by the C-ducts.
[Edited 2012-03-24 07:16:14]
Alnicocunife
Sat Mar 24, 2012 1:24 pm
Maybe their Engineering department allowed the aircraft to fly one or two cycles to get to a maintenance station. Would not be in the CDL. Still Legal.
Sat Mar 24, 2012 2:04 pm
Quoting Alnicocunife (Reply 16):
True....But can special permission taken from Regulatory that is Not documented in the CDL be permitted.
yeelep
Sat Mar 24, 2012 2:15 pm
Check Tom's reply #8. In this case the missing panel is a CDL item, no engineering or special permission required.
tdscanuck
Sat Mar 24, 2012 5:53 pm
Quoting yeelep (Reply 15):
Thanks for that; my mental picture of where the leading edge was relative to the strut was way off. It would be nice if the CDL diagram included the leading edge.
It is on the CDL.All the strut access panels and the blowout door are on there.
Tom.
737tdi
Sun Mar 25, 2012 7:23 am
I was just referencing the top of the pylon. The ones under the reversers (C ducts) can't be lost even if left unscrewed (unattached), they are captured. LOL. I forget that sometimes I have to be absolutely specific. WOW.
Been working on CFM-56-2's and 3's and 7's since 1990, kinda sorta familiar to me. You can go on but ??? Oh, not the 7 at that time.
Come on, You knew exactly what I meant but you had to be smarter. Not cool. I have removed those panels hundreds of times, gotten dirt and crap in my eyes from it. They are under the hottest spot on the engine. Takes a 1/4" dr. ratchet with a shortened bit to remove or your ratchet buries itself in the hi temp goo on the TR. Get some, buddy. Have a nice Marine Corps Day.
737tdi
yeelep
Sun Mar 25, 2012 7:42 am
Just making a clarification, not trying to one up you. From reading other post's you have made I am aware of your knowledge/familiarity of the 737. My own length of experience with the CFM's is similar to your's, except the -2, never had the pleasure.
