VC10er
How Long Will The Jury Be Out On The 747-8i?
Sat Mar 31, 2012 1:28 am
How many 747-8i's flying for how long before it's determined that it meets or exceeds performance expectations or not? I have read here that there is a "wait and see" element to the 747-8i and that "IF" it does meet the performance targets set by Boeing - and - if it does we would all see more orders.
So, how long before Lufthansa claims that this aircraft performs greatly and will become an important aircraft type for Lufthansa (or it stinks)?
AND: does the performance of the 747-8F count for the 8i? Or are they different animals?
I do indeed wish the beauty who has done so much for aviation for 40 years continues on!
The world is missing love, let's use our flights to spread it!
Stitch
RE: How Long Will The Jury Be Out On The 747-8i?
Sat Mar 31, 2012 2:21 am
Well the true performance metrics won't be known until GE has the necessary PiPs in place on the GEnx2B-67 to bring it to (or better than) the original spec SFC.
In terms of OEW, I would expect the first 747-8s to be closer to spec than the first 747-8Fs due to the longer development period allowing Boeing to slipstream lighter components into the design. That being said, I am pretty sure I have read the initial 747-8 airframes are heavier than Boeing originally projected.
I expect what will "make or break" the 747-8 Intercontinental is how many airlines can find a role for it between the 777-300ER / A350-1000 / 777X and the A380-800 more than perfectly hitting her numbers.
kanban
Sat Mar 31, 2012 4:27 am
The jury will be out as long as there is an A.net to ask the question.. an even 10 years after the last is out of service some knucklehead will ask "was the 747-8i ever a viable fleet member?"
alitaliadc10
Sat Mar 31, 2012 5:16 am
I'm pretty sure LH will very pleased with this fine machine...and as an added bonus Boeing will deliver them without either type 1 or type 2 cracks...
IAD is suddenly on my must fly to place
Orbis non sufficit
liftsifter
Sat Mar 31, 2012 5:50 am
Honestly, I don't see many more orders for the plane. I see Boeing has had quite a lot of "the first planes may be heavier than sold." lately, and that all smells fishy to me. Looks like Boeing may have been spewing off numbers in an attempt to make the aircraft more sellable. I think LH will love the plane though, and even if they don't meet specs, I'm sure their better than the -400s by a mile!
A300 A310 A319 A320 A321 A332 A333 A342 A343 A346 A380 B736 B737 B738 B744 B763 B77L B77E B77W B788 E190
kanban
Sat Mar 31, 2012 6:14 am
Boeing first of a model have always been heavy.. so have the Airbus planes.. It's life. The big difference is we never used to announce it in bold type in the headlines. Then consider that while some parts weight can be computed, mechanics don't weight out sealants and lubricants.. they just slap them on until the area is covered. A lot of things are approximate until you actually have a plane to put them in..Wire bundles may have an extra inch or two initially that's a couple ounces to a couple pounds. Dimensions are typically plus or minus 0.01.. for example. if you get all plus sized parts, you have weight, if you get all minus, you have a short airplane.. the rule is tolerances stack to the most inopportune place.
AS far as more orders... read the past threads on this same subject.. 500 planes probably not in the next ten years but then again it's a freighter first and a passenger plane second.
flyingcello
Sat Mar 31, 2012 9:33 am
There is a thread on Pprune at the moment, talking about what the 748F is doing in service. In that thread, one pilot suggests the aircraft is bettering Boeing fuel predictions by 2-3%. If that is the case, then the 748i may turn out to be quite an aircraft.
gunsontheroof
Sat Mar 31, 2012 9:55 am
Quoting kanban (Reply 5):
Kind of strange that what is surely the final incarnation of this great aircraft might ultimately fill its original intended role...
The 747-8 will surely sell more frames as a freighter than as a passenger airliner. I'd love to be proven wrong, but I think the airlines (i.e. LH, KE) that can find a role for an aircraft between the A388 and B773/A346 are few and far between. The 747-8 is a great airplane, but I'll be surprised if it sells more than 500 frames. VLA haven't exactly been flying off the shelves in the last decade or so and I suspect that most of that market will probably go to the A380...another aircraft that we're still waiting to see blow up the order books years after its entry into service. Boeing stands to make some money off this program if they can move the freighter in large numbers, but the passenger version is never going to see the popularity enjoyed by its predecessors given the current market conditions...
Picked a hell of a week to quit sniffing glue.
SeJoWa
Sat Mar 31, 2012 10:47 am
Quoting FlyingCello (Reply 6):
Wow, that was a highly instructive read! Recommended to everyone remotely interested in the Boeing 747-8! Thank you for the heads-up! And truly encouraging!
[Edited 2012-03-31 03:48:05]
AAplat4life
Sat Mar 31, 2012 11:12 am
At the moment, the A380 is having reliability problems. The larger operators such as EK, SQ, and QA have had several problems. Will that turn them to the 748I? Doubtful, but they might take a second look. However, I agree that they will wait for the 777-9.
flyingcello
Sat Mar 31, 2012 1:42 pm
Quoting Gunsontheroof (Reply 7):
We're getting used to wide bodies selling in large numbers...the 777 reaching the 1000 so quickly is almost overlooked now.
So if the 748 sells 500 units, then I suspect Boeing would be delighted! I personally think 200-300 is possible, and even then I think Boeing would be satisfied.
flylku
Sat Mar 31, 2012 3:15 pm
Quoting AlitaliaDC10 (Reply 3):
I had the same thought. The two aircraft fill different niches, granted, but at the upper end of the size market, if the cracks in the 380 turn out to be more than media hype and add significantly to the overall cost of ownership, this would open the door a tiny bit for the 747-8. But I doubt it will play out this way.
...are we there yet?
rotating14
Sat Mar 31, 2012 4:12 pm
Hey guys & gals,
Correct me if I'm wrong but wasn't the real reason Boeing introduced the 747-8 was to take market share from the A380?
dennys
Sat Mar 31, 2012 4:38 pm
Quoting rotating14 (Reply 12):
Yes certainly ! Not to mension that the 747-8 project did not cost a lot to Boring to what the A380 did cost to Airbus
nycdave
Sat Mar 31, 2012 4:46 pm
I doubt Boeing is too upset about the program so far. Even if they never get another single customer for the 748i, they've at least managed to sell SOME of them, to defray the cost of the program. That's a bit of a better position than AB, who have yet to sell a single 380F.
The 748F is a given -- while I'm sure Boeing would love to sell more 747i's (and well might, yet), it's not make-or-break for them. In terms of orders at this early stage, I don't think they have much reason to worry. Still plenty of time for it to break out.
kanban
Sat Mar 31, 2012 5:36 pm
One could say that, however I think the 747-8f was the driver and an effective block to Airbus deciding to enter the large cargo plane market.
dennys
Sat Mar 31, 2012 9:30 pm
Quoting nycdave (Reply 14):
Do not worry to much .
1/ Airbus froze its A380F ( i cannot understand why )
2/ CX has to decide btwn A380-900 or 747-8i , i think The 747-8i has a serious chance.
3/ but the real danger for the 747-8i is not comming from Airbus , but from Boeing itself : the 773ER and now the 777-800X/-900X might be born as the 74KILLERS !
Conclusion : take the ones built . Some more are comming.
dennys
speedbird128
Sat Mar 31, 2012 10:36 pm
Yeah ok that took long. So i'll bite :-P
Will there be a convertible edition then?
Back to topic.
I am sure those airlines that wanted the 748 would likely have ordered by now. LH group will likely expand their order...
I would like to see though, is a bigger 748i fleet. I just wonder how big it will grow to...?
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
Flyingsottsman
Sun Apr 01, 2012 7:53 am
Will airlines like United and Delta be interested in the 748i as they are 744 operators even though Delta got their through the NW merger. Their 744s are getting on now will they replace them with the 748i?
sweair
Sun Apr 01, 2012 9:46 am
How much better is the 748F compared to the 744F? Boeing has no range charts with 748F on their page..
Stitch
Sun Apr 01, 2012 3:40 pm
Quoting Flyingsottsman (Reply 18):
UA and DL have both refurbished / are refurbishing their 747-400 fleets so they look to be keeping them around until the end of the decade when they will have the option of going bigger (A380-800 / 747-8) or going smaller (777X / A350-1000) with their replacement.
mham001
Sun Apr 01, 2012 4:31 pm
"Fuel burn is about the same or slightly less than the 400 for a greater weight. We had 8tonnes/hour in the cruise the other night at around 385t. The 400 was a fairly constant 10t/hr.
Seems to be a huge clue there...
lhcvg
Sun Apr 01, 2012 4:56 pm
Quoting Stitch (Reply 20):
I still think this is more of a possibility than often gets recognized. I realize that UA at least has been adamant about the A350 replacing the 747s, but at the right price and terms I don't believe a VLA order is entirely out of the question.
nycdave
Sun Apr 01, 2012 6:58 pm
Quoting mham001 (Reply 21):
Solid 20% improvement over the -400? And on an early production/test model? That's pretty impressive... could make the 748i attractive if, in a more expensive environment, an airline is worried about filling an A380 at capacity and full fare...
Although, of course, that's why UA said they're getting out of the VLA business and taking the A350 to replace the 744s...
packsonflight
Sun Apr 01, 2012 7:52 pm
Here is a clue.... The Cargolux birds where burning 2.7% more than promised and they where 7t overweight. Possibly Boeing is trimming the extra weight as we speak. but the extra burn has not bin solved yet and it will not be until GE issues a PIP
Viscount724
Sun Apr 01, 2012 10:21 pm
Quoting sweair (Reply 19):
See the first chart in the following Boeing document.
http://www.boeing.com/commercial/airports/acaps/7478sec3.pdf
Link to equivalent document for other 747 models here (the "Airplane Performance" link):
http://www.boeing.com/commercial/airports/747.htm
Thrust
Sun Apr 01, 2012 10:27 pm
I can't imagine why the 747-8I might not end up doing a little better in the future...it is slightly more flexible than the A380, which is always going to be severely restricted in terms of which routes it can support. Not to mention, I would imagine the 747-8I is more fuel efficient than the A380 due its being newer. Regardless, I thought Boeing has plans to develop a rival to the A380 in the future and also to replace the 747.
Fly one thing; Fly it well
rotating14
Wed Apr 04, 2012 4:18 pm
http://www.marketwatch.com/story/new...h-six-months-in-service-2012-04-04
Looks as though she isn't doing all that bad. Granted until we hear from an actual spokesperson from the carrier themselves, we may never know but it sounds good from here!!
SYfan100
Thu Apr 05, 2012 2:57 am
There will be always a demand on select routes for a aircraft like the Boeing 747-800 size. Remember this is not way back in the 70's and 80's era where you had just the Dc-10 and Boeing 747 aircraft types that did most of the international flying.
Now days you have the 767 that can handle those international routes that do not require a 300 seat to 400 seat airplane.
Throw in a dose of 777 and Airbus 330 aircraft and what is your comfort that you know your airline can really do well with picking these various different aircraft?
It's almost like a guessing game because it all comes down to both Boeing and Airbus to put a product out that will do well for everyone in the overall end!
Do they make money when you have these various different aircraft part of your fleet on different routes?
Do they like these aircraft with how they fly?
These questions will get asked time and time again by many people, and will once again over the course of the next several years when new aircraft start flying different various routes.
You can not tell in one day if a new Airplane will work or not. It takes babysteps with looking at how your monthly operation did every month for one year since that new aircraft arrived into your fleet.
How many times has it had to get taken out of service unexpected because a mechanic needs take a good look at why something is not working right?
SEA
Thu Apr 05, 2012 3:23 am
Quoting kanban (Reply 2):
So true!
The -8i is a difficult question to consider, specifically because Boeing never expected it to be wildly successful, for several reasons.
1) The main seller of the new -8 is, was designed to be, and always will be the -8F.
2) The market for passenger VLAs has been diminishing over the past few years, and if it weren't for a few airlines (EK, AF, LH, and a couple others), the A388 likely wouldn't have been the sales strength that it's been.
3) If Boeing had thought there was a huge long-term market for a 748-sized aircraft, it's very likely they would have invested in a brand-new aircraft, ala 787-style. This I know for sure from some contacts at Boeing. Boeing expect the 748i to attract more sales in the next couple of years, but I know for a fact that they never expect, or even really intend (due to physical manufacturing constraints) for the 748i to sale in massive numbers. The 777 family will continue to be the bread and butter for Boeing for the next decade at least.
Stitch
Sun Apr 08, 2012 3:52 pm
As Randy T Says 748-F Better Than Expected (by ER757 Apr 4 2012 in Civil Aviation) has been locked due to personal attacks against a member, maybe those of us who were interested in discussing the topic can keep it going here, but as it applies to the 747-8 Intercontinental.
Boeing Commercial Airplanes marketing head Randy Tinseth recently posted on his official blog that the 747-8 freighter "is performing as well or better than we predicted".
Now, for the sake of (preventing an) argument, let us agree that this statement means it is better than Boeing expected for an overweight airframe with sub-par engines and that this performance, while welcome, does not mean the 747-8 freighter is as good as Boeing said it would be back in 2005 ("Brochure Level Performance" and "Airline Nominal Performance") and that this performance likely does not meet the contractual "Airline Guarantee Performance" written into the sales contract.
With the 747-8, Boeing was aiming for a 15% fuel burn reduction and 10% lower seat-mile costs compared to the 747-400. We have one data point from a pilot on PPRUNE.org stating that at 385t flying weight, fuel burn on his 747-8F was 8t per hour - 20% lower than a 747-400F. However, that is the only data point the pilot provided so it should not be considered representative of the 747-8F in all situations. An 8t per hour average fuel burn would be similar to the 777-300ER and while it doesn't offer the cargo volume, in terms of payload over range at the far end of the chart, a 747-8 will outperform a 777-300ER so you'd think we'd see more interest in it from A340-600 / 747-400 / 777-300ER operators.
So we're probably looking at something more in the range of 9.0 to 9.5 tons per hour, which is some 2 tons better than the 747-400 and (on the low end) similar to the A340-600, but still a ton higher than the 777-300ER. Which is likely why the 747-8 is not making much of a dent with 777-300ER customers.
pnwtraveler
Sun Apr 08, 2012 4:32 pm
Quoting Stitch (Reply 30):
Thanks Stitch your comments are always well thought out and factual.
And to be fair to Randy, he made a statement that is true. He just didn't spend the extra time to qualify it and provide charts to prove that in every situation it applies. IIt might take pages of that to satisfy some posters and other still others wouldn't believe it. That just isn't necessary. The extreme parsing and doubting of his statement, ignores the big fact that if he was outright misrepresenting the facts, he would have SCC *(oops SEC) problems. And give me a break he is in sales and marketing for goodness sake. Yes you take his and Leahy's statements in context of their sales positions, but give me a break already.
I have no doubt the 748F will, once the economy shows signs of stabilizing, continue to garner orders. I also think the 748i will get additional orders as well. I am skeptical though, that until things change dramatically, and possibly even not then, there won't be big orders for North American carriers. Perhaps some niche orders for slot restricted airports. So I am still skeptical that UA will order the 748i at this point in time. Every North American airline of size however, should be carefully looking at the aircraft and its capabilities to do due dilligence and ensure it doesn't fit their fleet and routes.
[Edited 2012-04-08 09:33:54]
nycdave
Sun Apr 08, 2012 4:42 pm
Wait, so, I'm just kind of curious... how is ONE data point unreliable and ignorable, but unsubstantiated speculation based on ZERO data points is... your post?
Frankly, marketing is marketing, and B isn't going to go saying "holy moses this thing is performing terribly, and well below expectations" if it is... but more importantly, they're also not going to outright lie and say "this is going GREAT!" when it's actually going terribly. Fudging and exaggeration is acceptable sales practice, but outright lying is not.
But regardless of how anyone wants to parse an isolated data point, or a statement from B sales, THIS IS ALL BASICALLY UNINFORMED SPECULATION UNTIL ACTUAL SOLID FIGURES COME OUT OF TESTING.
mham001
Sun Apr 08, 2012 5:07 pm
Where did those numbers come from?
Sun Apr 08, 2012 5:48 pm
The huge clue is to take the reality test, that fuel burn is lower than the 77W. I did some more calculations today, at that sort of weight, the 747-8F is between 11-12 t/hr. I sent the numbers to two other members that can verify them.
Let us see how reasonable this is in relation to what Boeing has previously said back in 2005 in Farnborough, they said in the 747-8i with 450 seats will burn 15% less fuel per seat than the 744 with 416 seats. That was also for a 6000 nm trip, not at design range (around 8000 nm) where fuel burn per seat is even higher.
If as you say the 744 is burning 11 t/hr, then the fuel burn should be 10.1 t/hr for the 747-8I on a 6000 nm trip ?
Do you think Boeing would have kept another additional double digit improvement over their 2005 predictions quiet for the last 7 years ?
Does this seem reasonable ?
Stitch
Sun Apr 08, 2012 9:16 pm
Quoting nycdave (Reply 32):
Boeing has completed testing for both the 747-8 and 747-8F so they have "solid figures" and those have been used to generate the Airline Nominal Performance and the Airline Guaranteed Performance (even if that guarantee at delivery is not the same guarantee when the original sales contracts were signed with whatever compensation that entails).
Quoting mham001 (Reply 33):
Zeke provided block hour fuel burn figures for the CX fleet: the 747-400 averaged 11,100kg an hour.
Quoting zeke (Reply 34):
If as you say the 744 is burning 11 t/hr, then the fuel burn should be 10.1 t/hr for the 747-8I on a 6000 nm trip?
I just deducted 15% from the figure - 11 * 0.85 = 9.3 - but on reflection, that wasn't the way to do it. Boeing claims the overall trip costs between a 747-400 and 747-8 are nearly equivalent, so there must be a fuel burn savings. And if it's 10%, well, that's still something.
trex8
Sun Apr 08, 2012 10:06 pm
Quoting Stitch (Reply 35):
So for those of us who are technically challenged, if trip costs are "nearly equivalent" and except for landing charges,which would be higher for the --8, assuming same costs for crew/mx, seems fuel savings are not great unless landing charges go up that much for a few extra 10,000lbs!
Daysleeper
Sun Apr 08, 2012 10:34 pm
Where does the A380 fit into this? I thought it also had the same trip costs as the 744.
Stitch
Sun Apr 08, 2012 10:37 pm
Quoting trex8 (Reply 36):
Before certification, the 747-8 at MTOW and MZFW (975,000 and 642,000 pounds, respectively) was projected to fly 6250nm on 333,000lbs of fuel. The 747-400ER, with an MTOW and MZFW of 910,00 and 555,000 pounds, could also fly 6250nm, but needed 355,000 lbs of fuel.
Per the latest post-certification ACAP, at 987,000 pounds MTOW and 651,000 pounds MZFW, the 747-8 can fly 6000nm on 336,000 pounds of fuel.
So even though it's a fait bit heavier at MZFW and MTOW, the 747-8 can fly about as far as the 747-400ER on less fuel.
travelhound
Sun Apr 08, 2012 11:00 pm
My understanding is the aerodynamics of the 748 are better than first envisaged and as such there is fuel burn advantage associated with this. This is separate to engine performance and OEW of the plane.
If I remember correctly Boeing asserted during flight testing the aerodynamics were better than they expected. Again, if I remember correctly Boeing used the data from flight testing to redetermine the performance characteristics of the aircraft before entry into service. My understanding is the 1% as mentioned in Randy's blog is over and above this, so in real terms aerodynamic performance could be anywhere between 1% and 3% better than originally fore-casted in 2005.
Now, if we still have 2.7% to come from engines and 1%(?) to come from reductions in OEW, than we have an aircraft that is going to be 2% better than the original advertised spec. If we throw in the revenue advantage associated with the increase in MTOW than I think it is fair to say the 748 is going to be a better aircraft than first envisaged ... and by a fair margin.
Of course the bulk of my analysis is largely unqualified and based upon media reports that are open for interpretation, so only time will tell.
Stitch
Sun Apr 08, 2012 11:22 pm
Quoting Daysleeper (Reply 37):
Boeing says the 747-8 is more economical than the A380 and Airbus says the A380 is more economical than the 747-8, which is what you'd expect them to say.
LH gives a fuel burn of 3.7 liters per passenger per 100 kilometers for the 747-8 (386 seats) and 3.5 liters per passenger per 100 kilometers for the A380-800 (526 seats). I have not seen any fuel burn projections by KE for their A388 and 748.
Daysleeper
Sun Apr 08, 2012 11:51 pm
Quoting Stitch (Reply 40):
Boeing compare CASM using a 467 seat three class 748, which is a total joke.
What I was interested in though, was how they compare in terms of trip costs not CASM.
Stitch
Mon Apr 09, 2012 12:12 am
Quoting Daysleeper (Reply 41):
SQ have said something, but I don't recall what it was. Astuteman has the figure, so when he drops by...
Back in February 2006, Airbus claimed the A380-800 has 12% higher trip costs than the 747-8, while Boeing put the figure at 22%. So if the 747-400 has the same trip costs as the 747-8, then Airbus would say the A380-800 is 12% higher and Boeing would say it's 22% higher.
trex8
Mon Apr 09, 2012 12:31 am
Quoting Stitch (Reply 42):
IIRC it was @5% more for the A380
sunrisevalley
Mon Apr 09, 2012 12:49 am
How about explaining the joke for those of us who don't get it
Daysleeper
Mon Apr 09, 2012 1:09 am
Quoting sunrisevalley (Reply 44):
The Airbus standard three class layout for the A380 has 525 seats, just 11% more than the 467 Boeing quotes for the 748i.
This of course would be fine, if the A380 only had 11% more cabin space.......
PVG
Mon Apr 09, 2012 5:02 am
So if LH decided to go slightly higher density with 747 and slightly lower density with 380, then these aircraft would be essentially equal in terms of consumption, right? Not bad for an old dog!
Stitch
Mon Apr 09, 2012 5:42 am
Quoting PVG (Reply 46):
When LH was considering 405 seats in the 747-8 and 549 in the A380-800, the respective figures were 3.5l and 3.4l.
IndianicWorld
Mon Apr 09, 2012 5:55 am
Don't be sure sure.
Its hard to acurately pinpoint anything at this stage. Wait a couple of years of flying to accurately measure that.
[Edited 2012-04-08 23:03:04]
PVG
Mon Apr 09, 2012 8:12 am
Quoting Stitch (Reply 47):
Thanks! So, then the decision is basically how many seats they think that they can fill regularly and price. If a route can only support 350-400 seats a day and there aren't slot restriction issues then 747/777W/X and 350 or smaller X2 is the way to go. If you can fill 500 seats then you go 380. There's really nothing else to think about other than fleet commonalty and need for cargo volume maybe? They seem to be evenly matched more or less.
Why do you guys get so emotional on this stuff?
