ckfred
Southwest 737 At ORD Tonight, 3-31
Sun Apr 01, 2012 4:24 am
I arrived at ORD tonight on AA 2364 a little before 7pm CT. The plane landed on Runday 10, and the pilots did what seemed like hard breaking. When we cleared the runway, I saw why. A Southwest 737 was sitting on Taxiway M, east of where Runway 32L used to cross M, facing to the east, with emergency vehicles parked both ahead and behind the aircraft.
So, why was the Southwest plane on the ground at ORD? Was this an MDW departure that had a problem and landed at ORD, rather than return to MDW? Or was this a diversion?
QANTAS747-438
RE: Southwest 737 At ORD Tonight, 3-31
Sun Apr 01, 2012 4:49 am
Quoting ckfred (Thread starter):
That's correct. It was a MDW outbound flt that had to divert to ORD for MX reasons.
swafa
Sun Apr 01, 2012 6:24 am
Was supposed to land at MDW. Apparently had some sort of flap malfunction. Overheard some pilots talking on the employee lot bus.
737tdi
Sun Apr 01, 2012 7:16 am
The "out of service list shows a slat indication problem". Not a big deal, with the NG's it is almost always a switch problem, not actually a problem with the slat.
Did you know that almost all 99.9999999% of all cockpit fault indications are due to bad switches, Not an actual failed component? Flight crews can tell if a slat or spoiler is hanging out...This one must have been felt for them to divert. Slat actuators do fail/lock. It is the nature of all actuators. It is not a safety of flight as far as airworthiness but you don't want to fly with a slat hanging out. JMO. of course
B757capt
Sun Apr 01, 2012 3:47 pm
Still interesting that ORD was chosen vs. MKE.
The views written by this user are in no manner the views of my employer and should not be thought as such.
johnmke
Sun Apr 01, 2012 5:10 pm
Quoting b757capt (Reply 4):
lets see fly 67 miles north to MKE, when they already to aviod the 15 mile flight south BACK to MDW. Something tells me that the pilots didn't think interesting they thought get this plane on the ground safely and as soon as possible.
ORD longer runway, more activity=more fire/emergancy response. I'll take ORD.
ScottB
Sun Apr 01, 2012 6:12 pm
Quoting johnmke (Reply 5):
I doubt it's even that; Southwest has line maintenance at MDW, so fixing the problem involves maintenance staff driving across town to ORD rather than the extra 75 miles up to MKE. But you can bet they went into ORD vs. MDW for the longer runway, of course.
B757capt
Sun Apr 01, 2012 7:01 pm
Quoting ScottB (Reply 6):
If this was a slat issue odds are they needed a longer runway. This could be why they did not go back to MDW.
As far as ORD vs MKE, I only mentioned that because WN has resources at MKE and not at ORD. If it was truly a slat issue, the 12 minute hop to MKE would not have made a difference but would have saved time and money.
ckfred
Sun Apr 01, 2012 9:33 pm
What was the flight number? I looked on Flightaware and couldn't find an WN flight number showing as having arrived at ORD.
chrisair
Sun Apr 01, 2012 9:37 pm
Quoting 737tdi (Reply 3):
Like this?
Photo © Emile Myburgh
thebatman
Sun Apr 01, 2012 11:50 pm
The longest runway at MKE is 1/19 at 9,690' while 10/28 at ORD is 13,000'. That is the reason they go into ORD. It's not the first time, and probably won't be the last. WN has used our hangars for engine changes, flight control problems, etc...
Aircraft mechanics - because pilots need heroes too!
Cubsrule
Mon Apr 02, 2012 1:12 am
Quoting b757capt (Reply 7):
Right, but WN has far more m/x resources at MDW than at ORD, and if MDW m/x was going to have to drive to "rescue" the airplane, it's a much shorter drive to ORD.
syncmaster
Mon Apr 02, 2012 1:24 am
Quoting Cubsrule (Reply 11):
Not to mention presumably busing the passengers back to Midway.
vatveng
Mon Apr 02, 2012 4:07 am
Quoting syncmaster (Reply 12):
Would that be easier than ferrying a 737 to ORD to pick them up and continue on? If it was a full flight it would take a few buses to get everyone back across town.
KBUF
Mon Apr 02, 2012 4:26 am
Quoting ckfred (Reply 8):
Don't know if this is it, but it's the only SWA flight involving ORD I can find: http://flightaware.com/live/flight/S...4/history/20120331/2322Z/KORD/KMDW
"Starting today, the Buffalo Sabres' reason for existence will be to win a Stanley Cup."-Terry Pegula, February 22, 2011
737tdi
Mon Apr 02, 2012 4:37 am
Quoting chrisair (Reply 9):
Like this?
Exactly!!!
syncmaster
Mon Apr 02, 2012 7:13 am
Quoting vatveng (Reply 13):
Depending on the loads I would imagine that is correct. It is probably easier to compensate them and/or rebook them on the next available flight.
deltal1011man
Mon Apr 02, 2012 8:53 am
And it helps that AMR and UAL both have large maintenance bases
I don't understand why this site even has moderators anymore.
ckfred
Mon Apr 02, 2012 2:54 pm
If you look at Flightaware for the flight from CMH to MDW, the flight track shows the flight in the MDW arrival pattern from the southwest. Then, it climbs on the approach, turns to the west, and then gets into the ORD pattern for Runway 10.
It looks like the plane landed around 5:53pm CT. I was on AA2364 that landed at 6:49pm. At that time, there were still emergency vehicles parked well behind and ahead of the aircraft. There were no ground service vehicles near the aircraft, and the starboard engine was still running.
ScottB
Mon Apr 02, 2012 4:40 pm
It's probably much, much cheaper to put people on buses or even in taxicabs. And I'd imagine that a fair number would just get on the el and make their way back to MDW themselves if the buses were going to take more than an hour.
