haveasafeflight
Another Mahan Air Iran Tyre Explosion
Fri Apr 06, 2012 7:18 am
In what is becoming an increasingly common occurrence, another Iranian aircraft has been involved in an incident caused by a tyre failure/explosion:
http://pda.trend.az/en/2011231.html
Fly Safe
cedarjet
RE: Another Mahan Air Iran Tyre Explosion
Fri Apr 06, 2012 1:57 pm
A burst tyre on touchdown is hardly cause for concern. Iran is a massive country, number 17 by area and 18 by population in the world, with hundreds of flights operating daily.
Just look at the FIS online for the smaller Tehran airport, Mehrabad, to get an inkling.
http://213.207.200.11/daily.asp
So if a couple of flights have a tyre burst in a couple of days, it's pretty much business as usual.
Enjoy browsing that board btw. You will also note, if you click soon, the 20h00 departure to Ahwaz by 707 - nice. Wish all online FIS showed aircraft type.
haveasafeflight
Fri Apr 06, 2012 5:24 pm
Quoting cedarjet (Reply 1):
I am aware of Iran's geographical size and the size of it's population - however that's not the issue here. The issue is that the number of instances of exploding tyres on Iranian aircraft appears to be relatively high, and it is cause for concern when it's happening as often as this.
Iran Air Isfahan Burst Tyre On Landing - 747SP? (by haveasafeflight Mar 4 2012 in Civil Aviation)
Counting the incidents in the link above this is the THIRD such case of exploding tyres suffered by an Iranian airline in the last 6 WEEKS. Very concerning.
Fly Safe
Spacepope
Fri Apr 06, 2012 6:31 pm
Who's supplying the tires/doing the retreads on their Airbus' tires?
haveasafeflight
Fri Apr 06, 2012 7:25 pm
Quoting Spacepope (Reply 3):
That's a great question - I honestly don't know the answer, but I'm pretty sure it's not the likes of Dunlop and Bridgestone. Time for Mahan Air and Iran Air to start looking for new sources?
Fly Safe
Fri Apr 06, 2012 7:28 pm
It should not be....Unless the reason for the same points out to bad assembly due to quality reasons.
haveasafeflight
Sat Apr 07, 2012 6:11 am
Quoting HAWK21M (Reply 5):
Unfortunately, Iran's aviation regulator, the Civil Aviation Organization (CAO) has yet to launch any sort of inquiry to find out why this is happening. But then we can't expect too much from the CAO, when they don't even bother with investigating the cause of accidents like the Iran Air Boeing 727 crash which claimed 77 lives last year.
In the history of modern aviation I know of no other serious incident in which an aviation regulator has been as lazy and ignorant as the Iran Civil Aviation Organization has been with their NON-INVESTIGATION of the crash of Iran Air Flight 277. Interestingly, President Ahmadinejad personally ordered an investigation to be carried out on this incident, so it's amazing that the CAO has been able to get away with ignoring it this long.
I find it truly amazing that ICAO continues to tolerate the CAO's appalling standards.
Fly Safe
IR800
Sat Apr 07, 2012 11:14 am
Quoting haveasafeflight (Reply 4):
Why not?
Take a look at this photo. It shows EP-IBZ (Iran Air A300) tires which exploded about 8 months ago at THR:
(Photo by Majid Hasankhani)
Absolutely a Bridgestone!
[Edited 2012-04-07 04:16:52]
dandaire
Sat Apr 07, 2012 1:03 pm
Quoting IR800 (Reply 7):
Looking at that tyre, it has been retreaded by Thomson Belgium which I think is owned by Bridgestone so I don't think its a quality problem. Looking at the size of that flatspot it looks more like an anti-skid problem?
Old age and treachery will triumph over youth and skill.
haveasafeflight
Sat Apr 07, 2012 3:18 pm
Why not?
You've misunderstood my point. As a result of sanctions, companies such as Dunlop and Bridgestone are prevented from working directly with Iranian airlines such as Iran Air. That's what I said. Are you suggesting that they are working directly together? That doesn't mean that they aren't sourcing tyres and re-tread services through other companies however to sidestep the sanctions, but that does mean that they won't receive the same after sales supports that say American Airlines or British Airways would.
Quoting dandaire (Reply 8):
That's an interesting observation for that particular case, but what about all the other cases of tyres exploding on Mahan Air and Iran Air aircraft over the last few months?
Fly Safe
aeroblogger
Sat Apr 07, 2012 3:45 pm
I wonder how runway conditions are in Iran...
Airports 2012: IXE HYD DEL BLR BOM CCU KNU KTM BKK SIN ICN LAX BUR SFO PHX IAH ORD EWR PHL PVD BOS FRA MUC IST
IR800
Sat Apr 07, 2012 3:58 pm
Quoting haveasafeflight (Reply 9):
Thanks for clarifying.
I don't have much information about that. What kind of supports or services do airlines receive from the provider?
haveasafeflight
Sat Apr 07, 2012 4:43 pm
Quoting IR800 (Reply 11):
As it's the OEM, they guarantee the quality of their parts and overhaul/refurb services, and in many cases provide express replacements should a defect exist with one of their products. If on the other hand a reseller is being used as a front to bypass sanctions, they simply can't offer the same kind of support.
Also if you buy directly from the OEM, you know you are getting the real McCoy - I couldn't say the same about the integrity of the products and practices of some of the shady resellers out there.
For there to have been this many cases of tyre failures in a relatively short period of time, there has got to be a quality issue somewhere at play.
Fly Safe
roseflyer
Sat Apr 07, 2012 5:27 pm
Tire explosions happen but if they are frequent they are a sign of poor maintenance. There are many causes but poor tires and tire inspections cause blow outs. If mahan is not doing a good job of the daily tire inspection and looking for cuts or flat spots that exceed limits.
Other problems are failing anti skid or low quality retreads or exceeding recommended cycles.
In general unscheduled tire replacements are normal but blow outs are not.
solarflyer22
Sat Apr 07, 2012 7:25 pm
Quoting haveasafeflight (Reply 6):
That is truly appalling. What is the CAO working on if they aren't investigating crashes?
Is it possible the pilots are landing too hard or the planes are landing overweight? The flat spots on the picture dont look like an ordinary tire blowout though I am not an expert. Seems like there are multiple points of failure from tires, to inspections to CAO enforcement. Not very impressive.
a300
Sat Apr 07, 2012 8:57 pm
Quoting solarflyer22 (Reply 14):
The crashes are investigated, though the results are not often public. The Caspian Tu-154M crash was investigated, with the assistance of the Russian experts. The probable cause was an engine disk failure. Recommendations were made to the Russian oversight authorities. The authority of Iranian carriers flying the Tu-154s was revoked, effective early 2010 (late 1389 AP).
The ability of Iranian CAO to investigate crashes involving American and Western European types is greatly hampered by (mostly) unilateral American sanctions. Boeing and the NTSB are not allowed to be involved as far as I can tell. The Swedish air investigation board had a similar problem when they were investigation an uncontained engine failure of an Iran Air A300 that occurred in Stockholm Arlanda.
That the Iranian CAO is not functioning properly is not in dispute. The reasons are multiple and not all are immediately fixable. I fully expect for the matters to get worse due to the recent political posturings.
Does anyone know whether the national investigative authorities are required to file a copy of their findings with ICAO in Montreal?
Boland Aseman Jayegah Man Ast.
Avianca
Sat Apr 07, 2012 11:56 pm
is this airport really smaller in terms of passengers? amazying how many flights are leaving in the ealry morning hours!
a300
Sun Apr 08, 2012 12:09 am
Quoting Avianca (Reply 16):
Mehrabad (THR) is by far the busiest airport in Iran in terms of aircraft movements. I recall the next busiest one is Mashhad (MHD). The greater Tehran's IKA is a distant third I believe, as the latter is serving international flights only.
Quoting a300 (Reply 15):
I should correct myself: the correct date for grounding all Iranian Tu-154s was 20FEB2011 (01 Esfand 1389 AP).
Sun Apr 08, 2012 4:51 am
Looking at the pic....It does look like an Antiskid malfunction locking the wheel momentarily.
MD11Engineer
Sun Apr 08, 2012 6:24 am
Why not?
Quoting HAWK21M (Reply 18):
I fully agree. I´ve seen such damage before. It was most likely caused by a locked brake dure to an antiskid malfunction.
Jan
haveasafeflight
Sun Apr 08, 2012 11:27 am
Quoting MD11Engineer (Reply 19):
Lets not forget, the picture kindly supplied by IR800 refers to an incident from 8 months ago:
Since then there have been multiple cases (at least 6 that I can think of) of tyre explosions occurring on Mahan Air and Iran Air aircraft. I'm therefore more inclined at this stage to think this is an issue with the tyres themselves, rather than anti skid or other items.
I'm not certain anyone can say what the cause is for sure at this stage. Unfortunately I really don't think the Iranian aviation regulator, the CAO, is going to make any announcements with regards to this ongoing ongoing problem anytime soon if at all, so I guess all we can do is speculate. As usual they will probably wait for people to lose their lives before they consider doing something about it, and even then I wouldn't hold my breath.
Why not? Surely the loved ones and friends of the 77 people who lost their lives in the Iran Air Boeing 727 crash last year have a right to know what caused the accident? Just as all air passengers traveling in Iran have a right to know.
If the CAO is deficient in it's ability (for whatever reason) to investigate crashes to a point of identification of the cause(s), then they really shouldn't be approving those aircraft types for operation. Period. You've surely got to question the ethics of an aviation regulator that continues to approve the operations of aircraft types that it is unable to competently investigate in the event of a serious accident. If the CAO can't properly investigate the crashes of certain aircraft types, what effective actions can they possibly take to prevent the cause(s) from reoccurring? If they are genuinely incapable of conducting investigations into crashes involving Western aircraft then they are simply making a fool out of people by pretending to be able to:
http://en.wikipedia.org/wiki/Iran_Air_Flight_277#cite_note-FG351690-11
"Iran ordered an inquiry into the crash.[14] A day after the accident, searchers at the location had obtained both the flight's cockpit voice recorder and the flight data recorder.[12] Iran's Transport Ministry stated that the investigation will comprise several working groups which will include specialists in various areas, including aircraft structure, engine parameter recordings and pilot operations. The investigation will be overseen by the Iran Civil Aviation Organization.[7] The flight data recorder and cockpit voice recorder were taken to Tehran for analysis.[12]"
In the Aljazeera video link posted on youtube below, it states clearly that the Boeing 727 pilots reported a "Technical Failure" and the aircraft crashed soon thereafter:
https://www.youtube.com/watch?v=hgHx7rGsht8
http://www.presstv.ir/detail/159994.html
So what's the point in calling for an investigation into the crash if the regulator (CAO) does nothing about it and hides away from it's responsibilities? If anyone has information to the contrary with regards to the CAO, i.e. evidence showing that they have actually DONE SOMETHING to try and identify the cause of the accident then please share. I however know of no other case like this anywhere in the world where an aviation regulator has shown such little interest and utter disregard for the value of human life. Disgraceful.
Fly Safe
roseflyer
Mon Apr 09, 2012 3:31 pm
Quoting haveasafeflight (Reply 20):
FOD is the number one reason for tire cuts and tread separations, so it could be a case of FOD control at airports. Excessive tire wear is caused by skidding and anti-skid not functioning properly. Combine the two and you have tire tread separation.
globalflyer777
Mon Apr 23, 2012 6:09 am
If we contrast this with active precautions that have been taken by the Pakistani aviaton officials after just one case of a burst tire, it is clear to see that the Iranian CAO has serious problems functioning correctly under Reza Nakhjavani:
http://www.pakistantoday.com.pk/2012...scape-disasters-in-karachi-lahore/
http://tribune.com.pk/story/368645/s...ers-prompt-scrutiny-of-air-fleets/
732 Crash In Pakistan (by cabso1 Apr 20 2012 in Civil Aviation)
I can't even say that it seems that the CAO are waiting for a serious accident to occur before they actually do something about identifying the cause of these explosions, because as we have seen with the example of Iran Air Flight 277, the CAO has done nothing there either.
bennett123
Mon Apr 23, 2012 6:14 am
IMO, the problem is simple.
If they looked at the tyre issue the real issue is buying parts under the counter.
The "correct" solution would mean closing most/all of the Iranian fleet down.
globalflyer777
Mon Apr 23, 2012 7:04 am
Quoting bennett123 (Reply 23):
For sure that's an important issue as the quality/safety of those "under the counter" spares is "suspect" to say the least.
But what about the regulator, surely the CAO must be expected to live up to their responsibilities, especially since the Iranian Civil Aviation Organization is a member of ICAO?
You would imagine that the CAO would at least be obligated to investigate air accidents of the magnitude of Iran Air Flight 277?
Just look how differently (and professionally) the Pakistani aviation authorities are handling the recent air incidents in Pakistan, compared with the Iranian CAO. The bosses of the Iran CAO, especially Reza Nakhjavani should hang their heads in shame.
bennett123
Mon Apr 23, 2012 7:09 am
Perhaps the Iranian CAO does "know" why these things are happening.
If "under the counter" parts are the problem, or a big part of it, then their hands are tied.
globalflyer777
Mon Apr 23, 2012 7:29 am
Quoting bennett123 (Reply 25):
Surely the very purpose of having a regulator is for them to maintain oversight and prevent these very things from happening. Exactly of what use is an impotent regulator?
The CAO could easily withdraw airworthiness approval in instances where they find this to be the case, the fact that they don't, also makes them responsible when things go wrong.
aeroblogger
Mon Apr 23, 2012 7:34 am
Quoting globalflyer777 (Reply 26):
Iran has no choice but to get under the counter parts - too many sanctions against them..
This means that problems due to under the counter parts cannot be feasibly solved by the CAO, and therefore it is in the CAO's interest to avoid the topic.
I'm sure that even with these safety issues in aviation, flying is still significantly safer in Iran than taking a car, train, or bus.
ljupco
Mon Apr 23, 2012 11:28 am
Very interesting catch   the entire table is like early '90 in Europe
thanks for sharing....
globalflyer777
Mon Apr 23, 2012 12:31 pm
Quoting aeroblogger (Reply 27):
So if as you say the CAO is actually turning a blind eye to unsuitable aircraft parts, how can they be considered to be a regulator if they aren't properly regulating one of the most fundamental and risk sensitive aspects of aircraft operations?
If what you say is true, what do you think ICAO thinks about this?
aeroblogger
Mon Apr 23, 2012 3:49 pm
Quoting globalflyer777 (Reply 29):
I have no clue what the ICAO thinks.
My point is simply that the CAO has no better option - and the ICAO probably recognizes this. If any other regulator was in the CAO's place, I still think you'd get the same result.
roseflyer
Mon Apr 23, 2012 4:09 pm
Some civil aviation authorities are charted to promote aviation within a country in addition to ensure safety and compliance. That dual mandate for the FAA caused many problems in the 1970s. The CAO has to promote the safety of aviation in the country. However how they do that is up to them. If Iran is willing to accept major safety problems within its carriers since the cost or ability to reduce the safety problems is preventative, then that is its choice as a sovereign nation to do so.
They do not think very highly of them. However ICAO is only a UN charter organization and has no authority regarding domestic operations in Iran or domestic operations in any country. In reality, ICAO doesn't have much authority to do anything.
ICAO certainly knows of the problems in Iran, which is why many Iranian operators are blacklisted in various forms around the world. There are two known highly population countries that constantly never meet ICAO standards. Those are Indonesia and Iran. A significant number of countries in Africa also do not meet the standards, but as flying is less common in that part of the world, fewer accidents happen.
haveasafeflight
Mon Apr 30, 2012 7:05 am
Quoting aeroblogger (Reply 30):
Now that Reza Nakhjavani has been dismissed as the head of the Iran CAO, hopefully his successor can start to address some of the problems that were unaddressed during Nakhjavani's time in charge and help rebuild Iran's air safety record and reputation:
Reza Nakhjavani Dismissed As Iran CAO Chief   (by globalflyer777 Apr 24 2012 in Civil Aviation)
Fly Safe
rlwynn
Mon Apr 30, 2012 7:47 am
You guys are way off base in the thinking it was an "anit skid" problem. Look at the tire. The carcass is busted. It was a blowout. When that happens there is no grip on the tarmac, he brakes are apllied but there is no grip on the busted tire so it locks up and scrapes across the ground. Anti skid does not help in this instance as it is not like the newer abs systems.
I can drive faster than you
haveasafeflight
Thu May 03, 2012 6:57 am
Quoting rlwynn (Reply 33):
I'll second that.
Fly Safe
