tim
A340-500/600 Power
Wed Oct 11, 2000 10:08 am
Howdy all,
Are the new A340-500/600 series engines going to be a lot more powerfull than the powerplants on the 200/300 series?
The 500/600 will be a great aircraft im sure, but if it can have a faster cruise speed than the 200/300 series that would be a bonus.
It seems to me, going by other peoples opinions on this forum that the A340-200/300 series is a very well liked aircraft, except for its engine power. If the 500/600 series comes with a more beefier powerplant, it should be very well recieved in the market.
I am yet to fly a A340-200/300 but I flew a CX A333 last year in Perth, which was an awesome aircraft.
Also, is it true that the new A340-500/600 will be the longest COMMERCIAL passenger aircraft in the world? Taking over the 773 in length?
Tim
Perth, Australia
flyf15
RE: A340-500/600 Power
Wed Oct 11, 2000 10:15 am
Yes, they will have almost double the power of the -200/300. The -600 will be about 2ft longer than the 777-300 if I remember correctly.
CPDC10-30
Wed Oct 11, 2000 10:34 am
The -500 will be powered by the RR Trent 500 engines with 53,000 lbs thrust each. MTOW = 804,700 lbs.
The -600 is powered by RR Trent 500 engines with 56,000 lbs thrust each. MTOW = 804,700.
It may be surprising to some, but the MTOW is the same because the -600 is much longer but carries signifigantly less fuel than the -500. In this the case, the -600 will have better performance than the -500.
Thrust/weight ratio for -500: 0.263452218
Thrust/weight ratio for -600: 0.278364608
For comparison:
Thrust/weight ratio for A340-300: 0.224311397
Thrust/weight ratio for A330-300: 0.280319252
Thrust/weight ratio for 777-300ER: 0.305769742
Thrust/weight ratio for 747-400: 0.289371429
In both cases, I assumed max thrust engine available and highest MTOW model. Information is from Airbus and Boeing website.
So, yes it will have much better power than the A340-300 but still is lacking compared to Boeing products.
tim
Wed Oct 11, 2000 10:38 am
Thanks for the info!
exactly what I was after
One more thing. Will they (500 & 600) cruise faster than the 200/300
Tim
gerardo
Wed Oct 11, 2000 3:39 pm
YEP, the -500 and -600 will be cruise at about M0.815 to M0.82, compared to M0.8 for the -200/-300, or the M0.78 for the B767.
Gerardo
dominguez(dash)online(dot)ch ... Pushing the limits of my equipment
RIX
Wed Oct 11, 2000 11:37 pm
Even if A340-500/600 still have less thrust/weight ratio than Boeing I think they are absolutely all right now. But: aren't they too thirsty?
Wed Oct 11, 2000 11:45 pm
Airbus should add the higher thrust P&W 4000 series and GE CF6 as options for the A340-500/600.
BOEING747-700
Thu Oct 12, 2000 6:56 am
I think the TRENT sould be fine. Rolls Royce is top notch for the job and I could not be happier with the RR symbol on the engine cowls. I love Rolls Royce and I think they sould be on all of Air Canadas Airplanes ie the 747's and IAE on the A319/320/321s too. It will be nice to see some more of AC's 340/330 with RR's.
If anything Boeing needs to place the TRENT 800 on the NG 777's with Higher Thursts.
Thu Oct 12, 2000 8:41 am
If Boeing added the Trent 800 on the 777NG models you will see a lot more airlines like American, Delta, BA, CP & maybe Air Canada ordering them.
BOEING747-700
Fri Oct 13, 2000 10:55 am
Oh yeah. It is just stupid that they did not think of that when they made the GE 90 the Only choice of power on the 777 NGs. Maybe they will come to their senses and put the Trent where it sould be as well as a PW choice.
Fri Oct 13, 2000 11:09 pm
This is a situation where GE paid off Boeing to have their powerplants exclusively on their aircraft. A good example is the CFM56 powered 737NGs, they should have had IAE market their V2500 as an option like on the A320 family.
