PHX787
Future Of 4-engine Widebodies?
Wed Apr 11, 2012 2:11 am
I ran a search on this, couldn't find anything within the last few years.
If you put the 748 and 380 aside, it seems like the direction Boeing and Airbus are moving, with the 787, 777X (most likely), and A-350 being dual-engine aircraft, and the A340 line being shut down, do you think that the proposed "Y3" project by Boeing has any business being a 4-engine aircraft?
What stands as the future of widebodies with 4 engines, given the apparent sluggish sales as of late with the 748?
Do you think that the 777 replacement, which is supposed to bridge an apparent gap (according to wikipedia) between the 777 and 747, would have 4 engines?
What are the advantages and disadvantages of 4 engines as opposed to 2?
I ask this simply out of curiosity, as the 340 happens to be one of my favorite aircraft to spot.
Thanks, Zach
tdscanuck
RE: Future Of 4-engine Widebodies?
Wed Apr 11, 2012 2:56 am
Quoting PHX787 (Thread starter):
Yes, if the weight band that Y3 eventually ends up in is high enough.
The 748 is probably the last of the 747 line, but if you want 900,000+ lbs MTOW aircraft, you need 3 or 4 engines. 3 has its own issues so, unless we switch to blended wing bodies, that weight class will probably be quads for the forseeable future.
If it's between the 777 and 747, I don't think you'd need 4 engines. Between the latest GE90-115B's and the bigger wing Boeing has proposed for the 777 upgrade, you can nicely fill in this area with a twin. However, if you want to actually replace the 747 mission you can't do with with twins with any engine that's currently supposed to be around.
4 engines requires considerably less installed thrust, so for a particular MTOW you need a lot less engine. It also used to have a significant advantage in flying far from diversion airports but the regulators have pretty much blown that distinction away and the twins have reached such high ETOPS ratings that it doesn't really matter.
Against that you've got double the systems, double the complexity, double the engine maintenance, etc., etc. You only really want a quad if you can't get engines big enough to make it a twin.
It's possible that other economic factors might bring a big trijet back (three GE90-115B's is enough thrust for well over 1,000,000 lbs MTOW) but I'm not going to hold my breath.
Tom.
planeguy727
Wed Apr 11, 2012 11:08 am
There are still two areas for long haul fights where ETOPS rules prevent twins from being the norm - Australia/New Zealand to S. America and Australia to Africa. As long as non-stop flights are planned in these areas there will be need for 3 or 4 engine aircraft.
I want to live in an old and converted 727...
jfk777
Wed Apr 11, 2012 11:20 am
Will engines get bigger then those on the 777 ? 747, A380 and future 500 passenger planes will probably be 4 engines. Can you imagine a 2 engine double decker A380. Hard to see.
tsnamm
Wed Apr 11, 2012 12:09 pm
fuel burn... with the cost of fuel continually going up, efficiency will be a main driver...4 engines will only be used where fewer is impossible....with fuel costs being the largest expenditure for airlines now and going forward, getting by with fewer more efficient engines will be the norm.
PHX787
Wed Apr 11, 2012 6:48 pm
Ok so....
Quoting jfk777 (Reply 3):
Quoting tdscanuck (Reply 1):
What you're saying here is that a certain weight requires more engines. I can see that. Like you all said, I too can't see a 747 or an A380 with 2 engines (even though IIRC the GE90 testbed was able to fly with just the GE90
Quoting tsnamm (Reply 4):
I see. So 4 engines aren't fuel efficient, then. What about (bear with me here) a larger aircraft with 4 GEnx engines?
Quoting planeguy727 (Reply 2):
Explains QF and LA's choice of aircraft.
I thought the whole blended wing body idea was scrapped because it would never work at certain airports, like JFK or CDG or LHR, because of its sheer size?
Even though the A380 is large, the modifications required weren't that serious. That plane landed on 18L at CVG with no issue back in 2007, but a blended wing body would never be able to land at CVG (to give an example)
sweair
Wed Apr 11, 2012 6:52 pm
Even Boeings BWB test aircraft went from 3 turbojets to 2
dennys
Wed Apr 18, 2012 9:13 am
The last quads will be the 748 and the A340s left I guess ; I always fancied about a 777 four engined , but this deam will not come true
cheers
RWA380
Wed Apr 18, 2012 10:14 am
I think Air Force One and the other aircraft like Japan One and so forth are going to be 4 engined as far in the future as I can see. The 4 engines mean if something so tragic came up that (with mid-air refueling) was staying in the skies for extended period of times, the possibility of an engine failure would be higher, and 4 is better than two if you loose an engine.
707, 717, 720, 727-1/2, 737-1/2/3/4/5/7/8/9, 747-1/2/3/4, 757, 767-2/3/4, 777, DC-8-5/6/7, DC-9-1/3/5, MD-80/2/3/7/8, DC-10-10/30/40, MD-11, F-27, F-28, SWM, J31, D38, DH7, DH8, DH4 SD-330, B-146, L-1011-2/500, ATR-42/72, VCV, A-300/310/318/319/320, CR2/7
sweair
Wed Apr 18, 2012 10:23 am
I cant see aircraft larger than the 77W-9X being a twin even in the future. One engine out at take off will set the limit.
The current record is 127,900 lbf not a normal thrust setting. Tubes with wings limit the size as well. Maybe if you put them above the fuselage like on the BWB..
The energy problem of mankind will make life interesting, how do we go on without cheap fuel?
jfk777
Wed Apr 18, 2012 11:27 am
Quoting RWA380 (Reply 8):
Its likely the next Air Force One, probably a 748, will be the last 4 engine Presidential plane. IF the one after that comes in 2035-2040 it will probably be a twin. But at some point Boeing could make a 747 & A380 replacement, so a 797, 808 or 818 could have four engines. Then who knows there may be an entirely new technology by then.
RWA380
Wed Apr 18, 2012 11:39 am
Quoting jfk777 (Reply 10):
I have to agree the next two planes will be 748's, but after that I'd expect twin technology will be far advanced.
unityofsaints
Wed Apr 18, 2012 11:47 am
Quoting dennys (Reply 7):
The A380 will easily outlast the 748i.
babybus
Wed Apr 18, 2012 1:14 pm
The long haul future will be exclusively A380. People will expect that amount of space and comfort. They won't want to be stuck in a seat with their knees round their ears for 22hrs as the twin jets force you to do.
The twin jets will be the low cost airline and charter airline type long haul aircraft. The long thin route expectation doesn't seem to have materialized.
That's my opinion anyway.
and with that..cabin crew, seats for landing please.
tdscanuck
Wed Apr 18, 2012 1:32 pm
Quoting PHX787 (Reply 5):
One GE90 is plenty to move the mostly empty 747 test bed, absolutely. Just as one GE90 is plenty to move a completely full 777-300ER. But it's after one engine failure that things get interesting, and the 747-8i and A380 are too big to fly safely, fully loaded, on one current engine.
4 engines are less fuel efficient than 2 for an equal sized airplane. But, with the current airplane sporting 4 GEnX engines, you'd need a ~180,000 lbs engine if you wanted to build it as a twin. And that doesn't exist today.
That depends on how big you make it. The BWB configuration has several issues (evacuation, airport infrastructure, load/unload connections, etc.) that aren't insurmountable but have to be worked out.
4 is just like 2 if you lose an engine (there is a subtle difference in the required climb gradient but they both "work"). It's only after two engine failures that things diverge. And two independent engine failures basically don't happen on the same flight (dependent failures do, but they impact quads just as much as twins).
Quoting babybus (Reply 13):
What does comfort have to do with aircraft size? You can put 30" pitch in an A380 and you can put 60" pitch in a 737.
Tom.
Stitch
Wed Apr 18, 2012 1:42 pm
VA flew SYD-JNB with a 777-300ER when they were V Australia.
cchan
Wed Apr 18, 2012 9:37 pm
Comfort has very little to do with how many engines the plane has, it all depends on the airline's interior config. I can't see how the long haul future would be "exclusively" A380: for a lot of present long haul routes, demands and economics just don't justify an A380.
Quoting tdscanuck (Reply 14):
I can think of a few examples here: BA's 318, HX's all J 332, NH low density 73G. These are probably more comfortable than an A380: at least you don't see a big crowd on board.
steex
Wed Apr 18, 2012 9:59 pm
Quoting Stitch (Reply 15):
They flew it with a significant northern detour to stay within ETOPS limits, though.
Edit: Didn't pay close enough attention at first, but thought I'd also note that V Australia flew MEL-JNB, not SYD-JNB.
[Edited 2012-04-18 15:05:19]
tdscanuck
Thu Apr 19, 2012 4:03 am
That's why ETOPS-330 was invented. Once that's approved (and it's coming) there will no longer be any need for 3 or 4 engines on any currently viable route.
Tom.
Gemuser
Thu Apr 19, 2012 4:25 am
Quoting tdscanuck (Reply 18):
Unless there is a MAJOR political change in Australia there will be NO ETOPS > 180 operations into Australian airspace by any airline. No Australian PM or their political party will take that risk to their political future.
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
tullamarine
Thu Apr 19, 2012 4:30 am
The routing of the VA 77W ended up being 3 hours longer than if the route had been undertaken by a 747 or A340. I assume SA will probably codeshare with VA on these routes in future now the competition authroities have deemed the QF/SA JSA as monopolistic.
For the forseeable future VLA will remain 4 engined. This is because there is no engine available (or proposed) that would pass the requirement for a fully laden plane to take off in an engine-out scenario.
717, 721/2, 732/3/4/5/7/8/9, 742/3/4, 752/3, 762/3, 772/E/W, 300,310, 319,320/1, 332/3, 359, 388, DC9, DC10, F28, F100, 142,143, E90, CR2, D82/3/4, SF3, ATR
tdscanuck
Thu Apr 19, 2012 4:44 am
Quoting tullamarine (Reply 20):
I'm not following you here; all current airliners (2, 3, or 4 engines) can take off fully loaded with an engine out.
Tom.
garpd
Thu Apr 19, 2012 7:08 am
Quoting unityofsaints (Reply 12):
How do you know this for sure?
arpdesign.wordpress.com
RWA380
Thu Apr 19, 2012 7:34 am
As far as longevity? I seriously doubt that. The 747 has been a work in progress for Boeing since the late 60's and the 748i is all of that knowledge learned, plus all the new technology combined. The A-380 is new technology, and already having stress cracking issues. I doubt the last 748i flying many years from now (cargo or not), will be sharing the skies with the A-380.
Burkhard
Thu Apr 19, 2012 8:18 am
You can buy it, and I look forward to see it daily in a few days. This aircraft is called B748I, and expected to be at least 10% more fuel efficient than the most efficient twin, the 77W.
We know that the market for VLA is not very big, maybe 1000 aircraft over 25 years. While a 180,000 lbs trust engine isn't impossible, it would be extremely expensive to design, certify and build the first - I doubt any of the companies wants to invest that money.
sweair
Thu Apr 19, 2012 8:31 am
Does the BWB have any merit as an airliner? It´s a lot wider than a tube with wings but shorter, up to 30% more efficient than a tube with wings I read somewhere, is this at the same size or what?
Windows and exit limitations seems to be a big hurdle for a passenger model, windows is not that hard to replace I would imagine, as people in the middle row in a WB already fly without a window close to them. But the emergency exits might be a problem with say 6-8 aisles in width.
But as a freighter with no usual gate clearance issues it might shine, g-forces in turns wouldn't be a problem for most cargo either.
2-3 mega sized turbines above the fuselage and in the rear, shielding noise to the ground as well.
This would be a huge project designing a BWB, sort of like the 747 was in its day, however I think its even bigger challenge then the first WB. Maybe a project funded partly by the military is doable or a cooperation between Airbus and Boeing like the 380 started as.
qf002
Thu Apr 19, 2012 10:26 am
VA's flights to JNB were canned because the necessary detours made the flight horribly uneconomical. Quads are absolutely necessary for flights across the bottom of the Indian and Pacific Oceans, but the A380 should sort these out until at least 2040 given QF is getting more in 2019-20.
Fabo
Thu Apr 19, 2012 11:02 am
I was under impression a 4 engine is nominally more fuel efficient compared to a twin on longer sectors, since 4 less powerful engines work more efficienty than 2 comparable more powerful engines on a comparable airframe, due to simple fact that jets are most efficient at higher thrust setting.
eg. say 330/340, were it the same size, and weight (barring extra engines).
A 340 will need to take-off with 75% of take-off thrust, therefore less extra power is needed compared to an A330 with 50%.
Therefore each engine in A340 will have to produce of 33.3% of required thrust at TO power, while each engine in 330 will have to produce 100%. (this is of course only considering portion after V1). Lets say higher climb requirements for 4 holer are insignificant.
Now lets say take-off thrust required for TO would be 100K. That means each engine could be say 40K on A340 (compensating for extra drag) and 100K on A330.
If for cruise you need 100K of altitude-corrected thrust, each A330 engine in cruise will only deliver 50% power, while each A340 engine would produce about 85-90% of power (again, compensating for drag, from 83%)
Wouldnt the efficiency of engine producing 90% of power be better than that of engine producing 50% of power?
(of course, climb would be somewhat less efficient on 4holer, but since we are talking primarily long-haul, it should not be that much of a deterrent)
I have read, that, in effect, this was the reasoning of SQ for originally choosing A340 over B777, but since there was usually a bottleneck of traffic between Singapore and Bankok, it was forced to stay low, unable to climb due to traffic, while 777 would already be at the cruise level, therefore negating the positive effect of 4holer, and thereby in the end resulting in SQ going for 777 in the end.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
StickShaker
How many aircraft are required here - about a dozen or so ?
Not really enough to influence Boeing or Airbus to continue a line of quads if there is no other demand. It eventually will be a case of using whatever is available - 380/748i.
StickShaker
Joost
Thu Apr 19, 2012 11:40 am
I certainly think it has. The 330-200 made airlines open up plenty of long, new routes (> 11 hours) that didn't see direct air service before. The 787 will continue this evolution.
tdscanuck
Thu Apr 19, 2012 1:28 pm
Quoting RWA380 (Reply 23):
When the 747 was new technology, it had lots of issues too (including cracking). The A380, so far, is just going through normal teething of a new design. I don't see any particular reason the A380 isn't also destined for a good long run; that's certainly more likely Airbus ever designing a new VLA.
Quoting sweair (Reply 25):
Yes, lots, primarily around efficiency/cost. In return, as you listed, there are a lot of obstacles to be overcome.
Tom.
steex
Thu Apr 19, 2012 2:50 pm
Quoting tdscanuck (Reply 21):
I think his point is that none of the current 4-engine VLA airliners would be able to take off on a single engine if they were instead 2-engine airliners. The amount of thrust necessary from each engine to make something like the A380 a 2-engine machine isn't feasible at the moment, so a frame that size will likely have four engines moving forward.
Stitch
Thu Apr 19, 2012 2:51 pm
Quoting qf002 (Reply 26):
A non-direct routing is required for ETOPS-180 and ETOPS-240, but if they flew ETOPS-330, they could do it non-stop per GCM:
http://www.socialwelfareagency.org/Public/Graphics/Aviation/MELJNB.png
Light Shading: ETOPS-180
Medium Shading: ETOPS-240
Heavy Shading: ETOPS-330
unityofsaints
Thu Apr 19, 2012 3:53 pm
Quoting garpd (Reply 22):
I don't know it for sure but it's a solid prediction given that:
1. The A380 has 145 more outstanding orders from 15 more customers
2. The A380 is a base design which is roughly 30 years younger than that of the 748
3. The A380 is, imho, more likely to get new customers
4. The A380 is, imho, more likely to get new variants (e.g. a -900)
I could go on but those are the most obvious ones.
PHX787
Thu Apr 19, 2012 6:07 pm
Quoting Burkhard (Reply 24):
I completely forgot about that >
Gemuser
Thu Apr 19, 2012 9:38 pm
Quoting Stitch (Reply 32):
But they can't and it's unlikely they will be able to do so in our life time. That was the point replies 20 & 26 were making.
Gemuser
DocLightning
Thu Apr 19, 2012 10:18 pm
What do you mean? The 77W can fly more cargo and only about 1/8 fewer passengers as far as the 747-400. It is almost a 1:1 replacement for the 747-400.
The 747-400's engine-out thrust is about 175-180,000 lbf. Part of the reason that it needs so much engine-out thrust is because it's got four big, heavy engines. The 77W's engine-out thrust is 115,000 lbf and yet it carries roughly the same payload.
With advances in aircraft design and materials, aerodynamics, and engine design, it would certainly be possible to upgrade the GE-90 successor to generate well over 130,000 lbf. By sheer extension, such an aircraft would already outperform the 747-400.
Two engines are lighter than four, so wouldn't you need less than 180k lbf?
Is it more fuel-efficient than the A350 or 787? comparing an engine that went into service in 2011 to an engine that went into service in 2003 is not quite fair.
-Doc Lightning-
-Carl Sagan
dennys
Fri Apr 20, 2012 2:20 am
Well , have a try from EZE to SYD , the flight is about 15 hours above the Antartic aeras , then you will probably feel safer on board a 4 holer !
DocLightning
Fri Apr 20, 2012 2:28 am
Quoting dennys (Reply 37):
A 4-holer is twice as likely to suffer an uncontained failure than a twin. I wouldn't want an uncontained failure in the middle of nowhere.
-Doc Lightning-
-Carl Sagan
thegeek
Fri Apr 20, 2012 3:59 am
Quoting DocLightning (Reply 36):
I submit that the difference in the climb requirements is another part of the reason for this. The MTOW difference doesn't account for the 1 engine out thrust difference!
Seems to bias against quads, but perhaps that is a good thing for this reason:
Quoting DocLightning (Reply 38):
qf002
Fri Apr 20, 2012 4:03 am
As previously discussed on other threads, the Australian CASA is the most conservative in the world (perhaps with good reason), and is unlikely to ever allow any further ETOPS/EDTO allowances over what exists today. Flights to NZ would be possible with twins, but flights departing from or arriving in Australia on these routes will be quads for the long term future (ie until the post-A380/787/A350 generation).
Stitch
Fri Apr 20, 2012 4:18 am
Quoting qf002 (Reply 40):
I suppose it will depend on how much traffic QF and VA end up losing to other carriers who have hubs that can connect passengers via twins (EK at DXB comes to mind) on those missions within ETOPS-180.
[Edited 2012-04-19 21:23:31]
SCL767
Fri Apr 20, 2012 4:37 am
Would the Australian CASA permit certain carriers to operate twins between South America and Australia via New Zealand since CASA's rules are vague in that area?
YULWinterSkies
Fri Apr 20, 2012 5:00 am
Yes, in your dreams!
Quoting joost (Reply 29):
I agree, but the 787 will almost certainly not be the Revolution some hoped. Just an evolution.
Back to the op question: future of 4-engine widebodies? A380 and 748. Period. Yes they will be there for a long time and will keep being built for a while, but I do not think any brand new clean sheet design will ever be a 4 engine again. A and B have the VLA market covered for many decades to come. (yes, I do expect the A380 to undergo many evolutions as the 747 has done and keeps doing)
When I doubt... go running!
Gemuser
Fri Apr 20, 2012 7:54 am
Quoting SCL767 (Reply 42):
In that case I don't think CASA has any say as the flight into Australian airspace is only from NZL which only requires 90 min ETOPS.
Gemuser
Burkhard
Fri Apr 20, 2012 9:17 am
All numbers I know show the 787 to be near to the 77W in fuel per seat, which is a great achievement for a much smaller bird, so it is still about 10% below the 748I and 20% below the A380. Once the 787-1000 or the A350-1000 are in the air, things might look different, but currently these are still more dream planes than real paper planes...
... but then I prefer a failure ove a 70000lbs engine over a 140000lbs engine due to the far larger damage it makes to the wings structure....
qf002
Fri Apr 20, 2012 11:48 am
Quoting Stitch (Reply 41):
QF is sorted until 2040, so won't be making a fuss any time soon. VA has shown very limited interest in flying internationally at all and would be far more likely to partner with SA and AR than go the route by themselves. VA would also stand to benefit from flying pax via AUH and EY, so I doubt they care much either way.
Very difficult question I think... On the one hand:
Quoting gemuser (Reply 44):
but the flight is still departing from/arriving into Australia as a direct flight, and CASA is probably involved in the entire flight beyond the Tasman crossing... It could be argued that QF/LA are anticipating the day when this exact situation arises (ie LA using 787's on their flights to NZ/Australia), with QF gradually taking over those flights that involve Australia using 744ER's (and A380's down the road), with LA to cut back to just flying into AKL (connecting to QF to MEL, BNE etc) to utilise the 787.
But really, we won't know until this actually happens.
Gemuser
Fri Apr 20, 2012 1:33 pm
Quoting qf002 (Reply 46):
Not sure, but I don't think so. The flight to/from & within Australian air space is below ETOPS180. I could see both NZL & Chile getting involved saying a flight between NZL & Chile is none of Australia's business.
Except that EDTO requirements apply to quads from 2015 or 2017, depending on what source you read. I could maybe see CASA granting EDTO 240 to quads (which they currently have, in effect). Their requirements are so loosely written that that could happen.
Gemuser
tdscanuck
Fri Apr 20, 2012 2:05 pm
Quoting Burkhard (Reply 45):
It makes no meaningful difference to the amount of damage. For analysis purposes, rotor burst fragments are treated as having infinite kinetic energy. They're going to go through everything in their way whether the engine was 30k, 70k, or 115k. The only difference will be the size of the holes. I'm not sure that a slightly bigger hole should be considered "far larger damage.". With a 4 engine, not only are the odds of a failure twice as high, there's twice as much systems stuff for the fragments to hit.
Tom.
qf002
Fri Apr 20, 2012 2:07 pm
Quoting gemuser (Reply 47):
I'm really not sure either, it certainly seems to be a grey area that's unclear in terms of the jurisdiction of the various groups. I tend to agree that the Australian authorities would have a limited say over operations via another port, but that's not to say that they couldn't argue for a say if they seriously believed that there was a significant risk to a flight to/from Australia...
Agreed. They've made it clear in their current policies that they are fine with quads, so I'd expect them to allow the more extended operations for quads beyond their inclusion in EDTO.
I think that's the whole problem with all this -- there is no solid policy or literature outlining what CASA's position is, so we can't really hope to predict their future policy moves... They might make a total u-turn and say okay to EDTO 330 for all aircraft overnight...
