MEA-707
Boeing 787; No Customer Codes
Wed Apr 18, 2012 2:20 pm
According to the latest Aviation Letter magazine, Boeing is not assigning curstomer codes to 787s, so they will remain referred to as simply 787-8 and 787-9s.
In captions and production lists so far, the 787s flying are already reported as 787-881 (ANA), 787-846 (JAL), 787-837 (Air India) and l/n 2 and l/n 6 have been reported as 787-83Q. Should these customer based numbers be removed from photo captions and other references to 787s ?
nobody has ever died from hard work, but why take the risk?
skipness1E
RE: Boeing 787; No Customer Codes
Wed Apr 18, 2012 2:26 pm
Bit like none of those B777-200IGWs ever being called B777-236ERs?
zanl188
Wed Apr 18, 2012 2:57 pm
All the "N" registered 787s are appearing in the FAA database as "787-8", so far anyway. No customer code.
A388
Wed Apr 18, 2012 4:01 pm
Quoting ZANL188 (Reply 2):
Strange as all 787's delivered so far still use the customer codes which I think should be kept as well. It's an easy way as reference. Airbus should also have done this but I don't think they want to use the Boeing customer codes as their customer codes   to have a uniform way of identifying airlines and the aircraft they initially used when originally delivered.
A388
GCPET
Wed Apr 18, 2012 4:05 pm
If the 787 won't have any customes codes will the 747-800 be the same because it seem's to be referred to as the '747-8I'?
GCPET
If it's not Boeing, I'm not going!
EY460
Wed Apr 18, 2012 4:12 pm
Quoting A388 (Reply 3):
I believe Airbus numbering system is much better as it allows to determine the engine manufacturer and the engine version. I think this information is much more useful than the original customer of the airframe.
B2468
Wed Apr 18, 2012 4:16 pm
While we are on the topic of Boeing customer codes, why does/did Boeing use this system of putting a customer code on the aircraft model number? While it is useful and informative for folks like us who might be interested in the history of an airframe, I can't see how it is useful for the airlines.
I think Airbus' system is better, since they use the additional digits in the model number to identify both the model and engine selection (I think...or it identifies something technical about the airframe that might be useful for dispatchers and maintenance personnel).
Maybe someone here can explain the benefits of Boeing's system? I just never understood it.
CNC/DH4/ERJ/306/310/319/320/332/333/343/346/388/72S/731/732/733/734/73G/738/741/744/74E/752/762/763/77E/77W/D95/D1C/M82
DfwRevolution
Wed Apr 18, 2012 4:25 pm
Quoting B2468 (Reply 6):
It is useful to know the original owner of the airframe because it communicates the airline-specific options and configurations of the particular airframe. Sometimes these options can be sigificant. We all know the case of TWA opting to have their switches throw a different direction than AA's in their 757 cockpits.
They serve the same purpose, Boeing's just allows a greater resolution in that the customer code can imply more information than just model and engine.
B2468
Wed Apr 18, 2012 4:45 pm
Quoting dfwrevolution (Reply 7):
Very interesting...thanks for your response! I remember a discussion of some of the weird options TWA got on their 757s, but I forgot about them. Did AA change the switch directions after they took over TW?
So, is there a database out there that can be accessed by the dispatchers and maintenance personnel of second- and third- hand owners of Boeing aircraft that can identify the specific quirky features of each airframe (since I assume some of the later owners might not know the specific options ordered by the original customer)?
cargolex
Wed Apr 18, 2012 4:57 pm
But those are aircraft either yet to be delivered (UA will get the first N-reg 787s) or on the pool of test registrations. A registration like N1786B wouldn't have any code attached to it because it used again and again on during pre-flight testing (typically assigned to a 737-800).
I haven't actually seen a build plate, but I expect that all 787s will be delivered with customer codes except for perhaps frames 4-6 - which are in a special position.
A388
Wed Apr 18, 2012 5:33 pm
Quoting EY460 (Reply 5):
Yes, I know this but I find the history of an aircraft itself more important compared to which engine it is. Maintenance track record wise and crash investigation wise, I find the airline more important than the engine type.
A388
larspl
Wed Apr 18, 2012 5:36 pm
If Boeing doesn't put a customer code on the aircraft papers it makes it the same as an other 787-8 thus making it easier to certify and register.
Besides, I don't think Boeing allows so many options as a switch in a different direction as before.
facebook.com/ddaclassicairlines
AA777223
Wed Apr 18, 2012 7:29 pm
I wonder if it has something to do with the adaptability of the airframe. One of the biggest options that an original carrier might choose is engines. The 787 is one of the first aircraft that can swap the engine type pretty easily. Just remove the everything from the pylon down, and swap 'er out! A little computer work, and it supposed to be a 24-48 hour job. Originally, it was designed to not even require a pylon replacement, but the ultimate complexity of the engines precluded it. Pylon down is still pretty slick. Previously, changing engine type was a pretty huge deal, ie 777 ln#1.
I am just throwing it out there as a thought.
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175, DH-8, ATR-72, DO-328, BAE-146
gigneil
Wed Apr 18, 2012 7:34 pm
Correct.
Since there ultimately are no customer-defining options available for the 787, the resolution of initial customer is no longer required.
NS
RobK
Wed Apr 18, 2012 7:49 pm
According to whom?
Quoting Cargolex (Reply 9):
Boeing has their own code of 3Q so if they were using customer codes in the sub type as some here like to believe then why do they not show as 787-83Q on the FAA register? Your comparison with 737 test reg N1786B is invalid because that is only a temporary registration that is never officially assigned to a specific airframe, unlike the six test 787s which are all fully assigned to individual airframes.
The reason my Boeing source gave for the dropping of the customer code was a combination of a management change and the desire to make data administration easier for those that have to deal with it on a day to day basis.
Viscount724
Wed Apr 18, 2012 8:14 pm
Quoting Robk (Reply 14):
Isn't 3Q only for the Boeing leasing operation? I thought "20" was the primary Boeing customer code. When the 707 went into service the customer code of the first operator (Pan Am) was 21. Codes then continued through 99 and then started from 01 to 19, leaving 20 as the Boeing generic code. When they ran out of 2-digit codes the began using alpha-numeric codes.
N14AZ
Wed Apr 18, 2012 8:52 pm
such as planespotters   A considerable part of my time required for keeping my logbook up-to-date was to find out the production code for the Boeings.
hOMSaR
Wed Apr 18, 2012 9:33 pm
Quoting A388 (Reply 10):
I'm not really sure these explanations really make the Boeing customer code useful.
For example, I believe TWA had both 757-231s and 757-2Q8s. What's the difference between the two, other than one set happened to be bought by TWA, and the other set happened to be bought by ILFC and then leased to TWA?
Didn't United pick up a couple of 747-451s that Northwest ordered and never took delivery of (or maybe I have that backwards, and they were 747-422s that went to Northwest)?
Likewise, an airline can buy the same type of plane with different options and still get the same customer code. British Airways bought their first 777-200s with GE engines, and their next batch with RR engines. They are both called 777-236s (or -236ER, or whatever).
Northwest's first batch of 757-251s were different from their second batch of 757-251s.
Even when the engines are the same, there can be a number of differences. A newly delivered AA 737-823 with the latest refinements and the Boeing Sky Interior is going to be a bit different from a 737-823 delivered in 1999 or 2000 or whenever they received their first batch.
The customer code doesn't tell you anything about the maintenance history of a plane. You could hypothetically have two Boeing 737-3XXs delivered to the same airline 20 years ago. One of them stayed with that airline and is still flying with them to this day. The other was sold after five years and wound up flying for some startup airline in a third-world country with minimal safety regulations and oversight. They're both still technically 737-3XXs.
In the end, the only thing that a Boeing customer code tells you is who originally bought the plane (and sometimes, from what I understand, it doesn't even tell you that).
[Edited 2012-04-18 14:35:56]
The plural of Airbus is Airbuses. Airbii is not a word.
There is no 787-800, nor 787-900 or 747-800. It's 787-8, 787-9, and 747-8.
A321neoLR is also unnecessary. It's simply A321LR.
Airplanes don't have isles, they have aisles.
cargolex
Wed Apr 18, 2012 9:46 pm
3Q is Boeing Equipment Leasing - usually for BBJ's or other specialty items as far as I know.
Interestingly, five of the six test 787s have only 787-8 on their registration. But one, N787EX, uses 787-83Q. I don't know how to look up a Japanese official registration.
bralo20
Wed Apr 18, 2012 10:16 pm
Quoting Cargolex (Reply 18):
Apparently NH's 788's are registered with the Civil Aviation Bureau in Japan as type -881's...
bueb0g
Wed Apr 18, 2012 11:20 pm
Quoting GCPET (Reply 4):
The new 747 won't have customer codes either, as it's officially the 747-8, or -8F for freighter and -8I for passenger, not -800.
Roger roger, what's our vector, victor?
sphealey
Wed Apr 18, 2012 11:26 pm
Ah, the age old argument over significant vs. non-significant part numbers. Probably first held among the designers of the Pyramids (although perhaps the designers of the Babylonian irrigation system), never has been and never will be resolved!
sPh
Personally I side with the non-significant argument.
cargolex
Wed Apr 18, 2012 11:37 pm
Quoting bueb0g (Reply 20):
Except that they do.
http://www.caa.co.uk/application.asp...e=detailnosummary&fullregmark=GSSD
RobK
Thu Apr 19, 2012 12:17 am
That's actually incorrect. Boeing has continued issuing the customer codes as the base model number is still the same.
PM
Thu Apr 19, 2012 12:30 am
Agreed.
Not always. See below.
Oftentimes it will not even be able to identify the engine.
Quoting homsaR (Reply 17):
Indeed. And what of all the other ILFC, GECAS and whoever codes?
Quite.
kanban
Thu Apr 19, 2012 1:23 am
In the Spares dept. these were extremely useful in the pre computer, pre leasing and pre service cetner days for determining whether a part was applicable to the airline ordering.. they were very helpful in matching serial number controlled parts in manufacturing and BFE. They started to become a problem when the leasing companies bought large numbers and when airlines like Air France started performing maintenance for other customers. Illustrated parts catalogs were sorted by customer codes.. sometimes a customer "x" would forget to tell Boeing that they were performing maintenance for carrier "Y" and we would not process the order because because the it wasn't applicable to the planes carrier "x" had.
That has since changed..
I think the numbering has hung on long after it was needed because "we've always done that" ... and today people are questioning non productive processes and procedures.
tdscanuck
Thu Apr 19, 2012 4:02 am
I haven't seen a customer code on any 787-8 from Boeing (as opposed to come foreign regulator adding one)...is there an example out there?
Quoting B2468 (Reply 8):
Boeing has the master database. Airlines can choose to order customized manuals that will document exactly which airframe has what (this comes included for first-tier customers, it's a paid extra for 2nd+ customers). If an airline choses not to order customized manuals that's legal but they have to convince their regulator that they have adequate documentation to maintain continued airworthiness, which could be tricky.
Quoting gigneil (Reply 13):
Correct.
Incorrect. There are customer-defining options even on the 787. There are just way less of them than there were before.
Tom.
bralo20
Thu Apr 19, 2012 6:37 am
Quoting tdscanuck (Reply 26):
N787EX is registered with the FAA as a Boeing 787-83Q (3Q = BCC Equipment Leasing), the other US-registered testplanes are registered as 787-8's.
gatechae
Thu Apr 19, 2012 7:17 am
Quoting Viscount724 (Reply 15):
This is very interesting. Did they assign an airline a customer code on order or on delivery of the first frame? If it was on order, were there any cancelled orders such that an airline had a Boeing customer code but never flew any Boeing aircraft?
Gipsy
Thu Apr 19, 2012 9:13 am
Airbus has it's own numbering system. You can only read out engines and model from it's name but there still is the fleet serial number (101, 102, 401, 402 etc..) and the version (DLH01 /DLH02 etc). You can also look up the standard it's built to and all it's owner and user history. If an aircarft gets sold to another airline all it's documantation will get migrated to his new version. As an example hawaiaan buys 5 used airbus aircraft, and they are their first ever Airbus aircraft for them. They get FSN HAL01 and everything gets adapted to how things are right now on that particular aircarft. The customer gets a HAL documentation just done for him delivered with the aircraft and exclusively representing this aircaft.
Eagleboy
Thu Apr 19, 2012 9:22 am
Thats what I had been told by an airline mgnr about 18 montha ago. By not having individual interior configs Boeing maintains the second hand value of the B787 airframes. And with so many B787 being owned by leasing companies perhaps they had a bit of influence here?
MEA-707
Thu Apr 19, 2012 10:01 am
Quoting gatechae (Reply 28):
They were assigned on order (at least quite a while before delivery), there are some interesting ones, 63 for Ghana Airways (cancelled 707-400s), 39 for Cubana (707-100s were assigned as such but went to Western Airlines), 99 for British Caledonian (cancelled 737-200s) X4 for Supair Germany (cancelled 737-200s) and many more.
skyhawkmatthew
Thu Apr 19, 2012 10:15 am
Back in the 707 days, there could be massive differences in airframes, beyond just interior and avionics fit-out, between different customer codes: Qantas' short-bodied 707-138 variant is a prime example.
Even through to the '80s there were still significant variations - some 767s (e.g. BA's -336ER) were built with four full-size exit doors per side, while others (QF's -338ER) instead have overwing exit hatches.
With different airlines operating with increasingly similar configurations (and, nowadays, near-identical avionics/instruments), the need to differentiate between different original customers becomes less important.
Qantas - The Spirit of Australia.
tdscanuck
Thu Apr 19, 2012 1:29 pm
Quoting Eagleboy (Reply 30):
Something sounds fishy about that; the interior configuration is one of the things that absolutely is individual to each airline.
Tom.
kanban
Thu Apr 19, 2012 2:38 pm
several were noted above, plus all those sold to leasing companies carried a the owners code not the operators.
Birdwatching
Thu Apr 19, 2012 3:50 pm
The customer codes have no purpose at all and should have discarded a long time ago.
Exactly identical aircraft at different airlines have different model numbers.
Completely different aircraft at the same carrier have the same model number.
What's the whole point?
Soren
All the things you probably hate about travelling are warm reminders that I'm home
Eagleboy
Thu Apr 19, 2012 4:45 pm
Quoting tdscanuck (Reply 33):
It was referring to toilet and galley placement rather then seating config.
flyPBA
Thu Apr 19, 2012 6:05 pm
Delta has (or had) a bunch of 767-324s that Continental had once ordered then cancelled before delivery
bikerthai
Thu Apr 19, 2012 9:57 pm
Quoting kanban (Reply 25):
I agree. Boeing tends to change it's processes really slow. The 787 and to some extent the 777 were revolutionary planes, not necessarily because of the advances in technology but the mind set and procedural changes that needed to happen within the company in order to push them though.
The merger with MD did stir things up a little - whether it was helpful can be up for debate.
bt
Viscount724
Thu Apr 19, 2012 11:16 pm
Quoting flyPBA (Reply 37):
Not a bunch. DL has never had more than one of the 5 763s ordered but cancelled by CO. Three others are with Thomson Airways in the UK and one is with North American Airlines. The one with DL (N394DL) below
Photo © Johannes Kreutzer
PM
Fri Apr 20, 2012 1:13 am
I suppose the interesting thing will be to see if Boeing issue new customer numbers to new customers.
Purely hypothetically, what would happen if Kingfisher ordered a dozen 737-800s? Would they be assigned a Kingfisher code? I assume so.
But what if Kingfisher ordered a dozen 787s...?
kanban
Fri Apr 20, 2012 2:54 am
Quoting PM (Reply 40):
gradually customer codes will cease for all models.. the 737 probably at the switch to the MAX.. 777 at the switch to the X.. 767 probably not because it's a limited production nearing the end.
antoniemey
Sat Apr 21, 2012 8:59 am
Quoting skyhawkmatthew (Reply 32):
This was my first thought when I saw the topic...
The customer codes started, it seems, with the 707... on the 707 Boeing was willing to make nearly any modification that could be certified to sell the frames (whether that was a good policy or not is a different debate, but it seems to have worked out in the end). Thus, back then, the customer code could tell you exactly how the plane was configured because each airline had their own quirks and they ordered all their planes of the same model identical, or at least very similarly.
These days there's far less in the way of major differences between planes bought by different airlines and far more difference in the cabin fittings and galley and lav placements... which can all be changed without a huge amount of difficulty when the aircraft changes owners...
Add in huge fleets of aircraft owned by leasing companies and it is now logical to drop the customer codes on new models. It's still somewhat sad, from the perspective of something unique to Boeing going away.
Make something Idiot-proof, and the Universe will make a more inept idiot.
N1120A
Sat Apr 21, 2012 6:53 pm
Exactly.
No. They sold the planes to Delta.
Correct.
Also, engine configuration no longer matters, because of the easy interchangability.
UA did buy 2 -451s and I believe is still flying one, with another parked somewhere.
Quoting Birdwatching (Reply 35):
That is completely untrue.
Viscount724
Sat Apr 21, 2012 11:26 pm
Quoting N1120A (Reply 43):
This is the -451 still with UA, N105UA.
Photo © Cheolmin Shin
Latest A.net photo of the other former UA -451 (N106UA when with UA). It was disposed of around 2003, possibly returned to the lessor as part of the UA bankruptcy filing. Apparently now owned by Phuket Air. It was operating for SV in the photo.
Photo © Shahram Sharifi - Iranian Spotters
And when it was with UA:
Photo © Frank Schaefer
kanban
Sun Apr 22, 2012 3:08 am
There was a time they assisted tracking customer configurations, however they were not the only method. They came about before computers and were a nightmare to maintain. Drawing parts lists had pages devoted to them and so many flag notes mistakes were more common than correct first reading. Engineering release process and format changes as well as other documentation advances rendered them no value added. They could have disappeared 15-20 years ago however the 757/767/777 were to far along to make the change. So the 787 today, 737 Max tomorrow, the 777X after that have new drawing trees and configuration controls that allow the deletion of the customer code.. The 747 is the old drawing system and will probably keep them even if not published until a new design replacement appears.
I'm not sure from an outsider's standpoint where your absolute statement comes from however it is untrue.
