dtwmtx330
Air France Leases 343 To Air Madagascar
Mon Apr 23, 2012 1:57 am
Air France has leased F-GLZL to Air Madagascar. i have be told another 343 air frame is going from AF to air madagascar as well.
Anyone know which is the other registration?
ETinCaribe
RE: Air France Leases 343 To Air Madagascar
Mon Apr 23, 2012 3:10 am
Some discussion on this topic on a separate thread: African Aviation Thread Part 7 (by ETinCaribe Apr 19 2012 in Civil Aviation)
Don't know the answer to your question, perhaps others on the thread do.
AF Cabin Crew
Mon Apr 23, 2012 3:37 am
Ia Orana !
Next on the list to join Air Madagascar is F-GLZT.
The planes will be leased with AF pilots and cabin crew. F-GLZL is used for TNR-CDG and TBR-MRS-CDG. The next plane will be used for TNR-BKK-CAN.
Happy Flying,
AF Cabin Crew
Ia Maitai to tatou tere !
Thenoflyzone
Mon Apr 23, 2012 9:38 pm
Jeez. those A343s have a horrible performance as it is.
Add an airport altitude of 4,100ft (TNR's altitude) and a runway lenght of only 10,171ft, and you get even more horrible results in terms of TOW.
At ISA conditions, meaning a temperature of 7 Celsius at TNR, the best TOW and A343 can achieve is 520,000 lbs, a full 100,000 lbs less than MTOW.
At ISA + 15 Celsius, TOW drops down to 510,000 lbs.
Pretty horrible.
Have a friend of mine who travelled CDG-TNR-CDG a few years ago with AF on the A343. On the return leg, he mentioned that they were lined up on the runway for about an hour, waiting for the headwinds to pick up for takeoff. Which explains why they stopped sending the A343's there.
TNR was supposed to increase their runway length by 500m. Does anyone know if this was done?
Thenoflyzone
[Edited 2012-04-23 14:41:48]
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
Alitalia744
Mon Apr 23, 2012 9:43 pm
it is interesting that AF leases a bird that was recently reconfigured with NEV4 vs. using the NEV4 seats on a different airplane.
Some see lines, others see between the lines.
Pihero
Mon Apr 23, 2012 10:49 pm
Tnfz
Figures are strange as mine go from 618,000 lbs for sea level ISA to 552,000 at ISA 4100 ft and 540,000 at ISA +15°C .
Interesting exercise : do the same calcs with an A330 or a T7.
You could have a surprise there.
Sometimes, chief pilots know their jobs and give good advice to their CEO and financial VPs.
The red herring of the 340 performance is getting tiring, especially when nobody ever mentioned the 747 in these same conditions, and frankly, if the 340 doesn't perform well, the 747 was a pregnant sow, queen of the skies or not.
Quoting thenoflyzone (Reply 3):
Your friend must be a straight-faced joker as it is just a load of bullsmell : If that crew were so severely limited, they'd had to take min fuel for the trip... an hour's wait would have put them below min, therefore they'd have needed to return to the ramp for more...and they would have come to some interesting exercise in crew duty time (!) - and btw, the same would have applied to an en-route alternate like MRS.
The fleet captain and the OPS manager would be very very angry... but I've never heard of such a Mickey Mouse performance.
[Edited 2012-04-23 15:52:40]
Contrail designer
Thenoflyzone
Tue Apr 24, 2012 12:41 am
Quoting Pihero (Reply 5):
My figures are straight from airbus.com. (it does state that it's for information only, but it's still surprising to see such a big difference between your figures and the ones on airbus.com)
http://www.airbus.com/fileadmin/medi...C/Airbus-AC_A340-200_300_Dec11.pdf
772ER, which is what AF is sending to TNR now...
ISA - TOW of 575,000 lbs
ISA+15 TOW of 565,000lbs
Now granted, the 772ER's OEW is 18,000 lbs more than the A343, but it's still pretty clear that the 772 is a better aircraft for the route.
i said 100,000 lbs, but that's wrong, it's 90,000 lbs, as the MTOW of the A343 is 610,000 lbs.
Thenofyzone
[Edited 2012-04-23 17:55:17]
dtwmtx330
Tue Apr 24, 2012 2:55 pm
Quoting AF Cabin Crew (Reply 2):
When will Air Madagascar get ZT?
tom355uk
Tue Apr 24, 2012 4:43 pm
I think you have looked at the wrong table - The RTOW you have quoted is for the -5C2 version rather than the higher thrust -5C4's that F-GLZL is equipped with   Take a look at page 99 of the .pdf and you will see that Pihero is bang on at 540,000lbs (244.9t)
From what I can see, an A332 with GE CF6-80's would have a RTOW of aaproximately 450,000lbs (or 204.1t in proper money  ), a reduction of 60,000lbs (or approx 29t) from its MTOW.
A 772ER as you say is 565,000lbs (256.2t), a loss of 91,000lbs (41.2t)
Interestingly, as a percentage the 772ER loses the most from its MTOW - nearly 14% whereas both the A332 and A343 lose slightly less than 13%. The extra 25,000lbs of payload offered by the 772 is only useful if you have cargo and pax demand to fill it, otherwise you are carrying more empty weight for no reason at all
on Twitter @tombeckett2285
Thenoflyzone
Tue Apr 24, 2012 7:24 pm
Quoting tom355uk (Reply 8):
Yes yes....that makes sense now. Sorry about the mistake.
That's probably why AF is sending the B772.
Thenoflyzone
fodar
Tue Apr 24, 2012 11:12 pm
Quoting dtwmtx330 (Reply 7):
The plan is for it to arrive in TNR on 26 June 2012.
苦海無邊,回頭是岸
Thenoflyzone
Wed Apr 25, 2012 1:07 pm
Interestingly enough, AF still has 3 A340-311's in the fleet, the ones with the -5C2 engines, and so does LH, with 8. IB has one.
Thenoflyzone
Burkhard
Wed Apr 25, 2012 1:13 pm
Up to now Euroatlantic flew 777 for Air Madagaskar, I assume this ends now or has already ended?
skipness1E
Wed Apr 25, 2012 1:27 pm
Will these aircraft get new colours?
tom355uk
Wed Apr 25, 2012 1:29 pm
Quoting thenoflyzone (Reply 11):
Correct, ZC, ZH & ZI.
These tend to be used on shorter routes (DTW, DEL, YYZ, YUL), but ZC seems to be exclusively assigned to ORY-CAY-ORY this year!
I bet they are pretty economical to run as well, being fully amortised
