axelesgg
? Regarding Aeroflot's IATA Code: SU
Sun May 13, 2012 10:27 pm
Hi I was thinking about a thing...
IATA codes doesn't usually mean something (i think).
But Aeroflots SU just have to be Soviet Union?
Could it be so?
Fly Draganair
tymnbalewne
Sun May 13, 2012 11:25 pm
I imagine during the beginning of IATA codes airlines could choose what they want, for example AA for American Airlines, PA for Pan American and so forth. So, it's not a stretch to think that Aeroflot would ask for, or just be given SU for Soviet Union.
Dewmanair...begins with Dew
Viscount724
Sun May 13, 2012 11:27 pm
Quoting axelesgg (Thread starter):
But Aeroflot's SU just have to be Soviet Union?
Could it be so?
As far as I know, that's correct.
Aeroflot777
Sun May 13, 2012 11:32 pm
I'm not sure what your question is, since it's kind of all over the place. But here's my try at answering:
Everything that could fly in the Soviet Union, from small corn field turboprops to helicopters to large passenger jets, were all operated under the name of Aeroflot. The name literally translates to "air fleet". Since anything that was capable of flight in all Soviet Union republics were under one umbrella, why not have the code stand for Soviet Union? It's a pretty simple concept. Then, the main branch of Aeroflot inherited the name after the breakup.
Aeroflot777
EK413
Mon May 14, 2012 5:43 am
Quoting Aeroflot777 (Reply 3):
Interesting as I was never aware Aeroflot represented any flying aircraft in Russia... thanks for sharing...
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
einsteinboricua
Mon May 14, 2012 12:54 pm
Quoting tymnbalewne (Reply 1):
How true is it that AA wanted either US for its IATA code or USA for its ICAO code? I remember reading that somewhere...
Quoting EK413 (Reply 4):
EK413
Haven't you noticed that many aircraft back then had the Aeroflot livery?
"You haven't seen a tree until you've seen its shadow from the sky."
DarkSnowyNight
Yes, it was at one time the largest airline in the world, hence everyone else trying to be # 1 in the western world.
I do not, however, believe that Aeroflot encompassed anything in the Soviet Army, Navy, or Air Forces. Others may know better though.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
smbukas
Mon May 14, 2012 1:55 pm
Quoting einsteinboricua (Reply 5):
In 1990-1992 Aeroflot operated about 10,000 aircrafts. In 1970-1980s Aeroflot always had more aircrafts then all USA airlines combined.
In the end of 1980s regional companies got more autonomy (but still it was the same Aeroflot), so I am not sure was it a constant livery on all the aircrafts.
In 1992 Aeroflot was splitted to many airlines. Independent countries took regional Aeroflot assets and created local airlines, such as Lithuanian Airlines, Air Moldova and other. Russian assets were also splitted to something like 200 regional airlines.
Now Aeroflot AFAIK is becoming "one airline" again, some local Aeroflot subsidiaries were integrated to Aeroflot in last 3 years and now Rossiya and Aeroflot is becoming one company (but still, different brands, AOCs).
Fabo
Mon May 14, 2012 2:42 pm
Quoting DarkSnowyNight (Reply 6):
Not as such. But there were many military or semi-military operations flown in Aeroflot colors (e.g. a good part of Soviet Air Force transport fleet was in Aeroflot marking)
Quoting smbukas (Reply 7):
Apart from Polar Aviation (red markings ISO blue) it was all same basic livery until dissolution of Aeroflot.
Then airlines got different looks and different names, based by airport they were based on (Pulkovo, Domodedovskie, Vnukovskie), city (KMV Avia (Kavkazskie Mineralnye Vody), Krasnoyarskie (later KrasAir), Tyumenskie (later UT Air), Omsk Avia, Vladivostok Avia), area (Sibir, Tatarstan, Dalavia - Dalnovostochnye - Far East, SAT Sakhalin Aero Transport).
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Burkhard
Mon May 14, 2012 2:43 pm
A lot of Air Cargo, also for the armed forces, was operated by Aeroflot.
mogandoCI
Mon May 14, 2012 3:24 pm
The codes assigned earlier were perfect mappings (BA, AF, AC etc), or not too far from the airline name (CX, SQ, KE).
Once they started running out of the good ones, many of the new ones mean absolutely nothing. G4, FM, D7 ....
LY777
Mon May 14, 2012 4:03 pm
I now that El Al code is LY because it was based in Lydda (Lod was previously called Lydda): so they took the first two letters of Lydda (LY)
ilyag
Mon May 14, 2012 4:41 pm
Actually the SU IATA code was really used for Aeroflot international ops - all USSR domestic flights just had a 3 or 4 digit flight number, as far as I recall. The crew would typically announce which Aeroflot unit (or base) is operating the flight, but otherwise it would be difficult to tell (at least from passenger standpoint).
rampart
Mon May 14, 2012 5:25 pm
Quoting Fabo (Reply 8):
Not that different from the trunk carriers, supplemental carriers, and cargo airlines that used to transport personnel and cargo in the USA for the various military operations, war and non-war. Except that these USA civilian airlines were many, not just one, and usually didn't use aircraft with glazed nose cones for "navigators" .
Photo © Robert Roggeman
-Rampart
EK413
Mon May 14, 2012 6:48 pm
Sorry what meant I wasn't aware the name Aeroflot represented "air fleet"...
I flew Aeroflot back in 1989 from KUL-BOM-SVO-LIS & when I arrived in SVO first thing I noticed was the vast fleet of aircraft operated by SU...
EK413
Viscount724
Mon May 14, 2012 7:17 pm
Quoting ilyag (Reply 12):
Domestic flights also used the SU code. I recall it clearly. Without an IATA code flights can't be booked in reservations systems, or even manually in the old days before computerized reservations systems.
RWA380
RE:? Regarding Aeroflot's Iata Code: SU
Tue May 15, 2012 11:19 am
AA got first choice I think, they have AA and 001 for their ticketing code. I imagine they went alphabetical, as CO was 005 and UA 016, I know the ticketing code is as important as the two letter code, but don't know if they were all put into place at the same time.
Quoting mogandoCI (Reply 10):
I remember when Aloha Airlines was TS, and it made no sense, then I guess an A came up free, and they went with AQ.
707, 717, 720, 727-1/2, 737-1/2/3/4/5/7/8/9, 747-1/2/3/4, 757, 767-2/3/4, 777, DC-8-5/6/7, DC-9-1/3/5, MD-80/2/3/7/8, DC-10-10/30/40, MD-11, F-27, F-28, SWM, J31, D38, DH7, DH8, DH4 SD-330, B-146, L-1011-2/500, ATR-42/72, VCV, A-300/310/318/319/320, CR2/7
