BACCALA
Terminal Maps At LAX
Sat May 19, 2012 12:14 am
Is United still in terminal 6 at LAX or are these maps just not updated? http://www.lawa.org/welcome_lax.aspx?id=246 it's the same on UA.com as well https://www.united.com/web/en-US/content/travel/airport/maps/lax.aspx
ikramerica
RE: Terminal Maps At LAX
Sat May 19, 2012 12:17 am
The answer is: yes UA is still in T6 and will remain there, yes UA premier check-in is in T6, and no, those maps are not up to date in any way shape or form.
BACCALA
Sat May 19, 2012 12:25 am
I thought Alaska took over the entire Terminal?
United1
Sat May 19, 2012 12:42 am
Quoting BACCALA (Reply 2):
DL, UA and AS all have operations in T6.
UA has around 20 flights a day out of T6 still.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
Byrdluvs747
Sat May 19, 2012 3:40 am
Quoting United1 (Reply 3):
How are the gates split between AS, UA, and DL?
The 747: The hands who designed it were guided by god.
United1
Sat May 19, 2012 3:46 am
Quoting Byrdluvs747 (Reply 4):
The gates on the connector building between the satellite and the terminal are used by UA on the T7 side and DL on the T5 side. The satellite itself is mostly AS but DL and UA use those gates too at certain times of the day.
Byrdluvs747
Sat May 19, 2012 4:23 am
Quoting United1 (Reply 5):
I know, but I was looking for a detailed breakdown of gates in T6. which gates are solely used by AS, UA, and DL? Which gates are shared?
AlnessW
Sat May 19, 2012 5:30 am
Wow! Didn't realize UA had that many flights out of Terminal 6.
What satellite...?
Quoting Byrdluvs747 (Reply 6):
Same here. Does such a thing exist for LAX? (Not just Terminal 6, but all the others, too.)
Also, doesn't F9 use Terminal 6? That LAX map also says NK is in Terminal 6; aren't they in Terminal 3 now?
United1
Sat May 19, 2012 5:38 am
Pretty much all of the gates in the satellite/rotunda are shared...T6 has some very complex usage rights/prefered use and priority rights on the gates.
Quoting AlnessW (Reply 7):
What satellite...?
The rotunda/satellite used to not be connected to the terminal.....
Think they are all moving to T3 or T2.....CM also uses T6.
AlnessW
Sat May 19, 2012 5:48 am
Quoting United1 (Reply 8):
Interesting to know, I suppose that would make sense with all of its shared usage. It sounds like it is almost like a "common use facility?"
Though I do recall once departing out of LAX on DL and our flight was at Terminal 6, gate 61. The podium and gate area was definitely painted in DL colors.
I don't think I was aware of that. Shows you how little I know!
Never heard of such plans. Is there room in Terminal 2 or 3?
CM also uses T6.
RyanairGuru
Sat May 19, 2012 5:50 am
Is T6 connected to T5 and T7 airside? Or if you are connecting with UA and arrive in one and depart from the other do you have to go and out and back through security?
And is it true that PMCO still only use T6, or is UA all mixed up together?
Worked Hard, Flew Right
AlnessW
Sat May 19, 2012 5:55 am
Quoting RyanairGuru (Reply 10):
Yes.
No, Terminals 5-8 are all connected post-security.
I am not sure, however I think it is all mixed up together now through Terminals 6, 7, and 8.
RyanairGuru
Sat May 19, 2012 6:00 am
Quoting AlnessW (Reply 11):
Thanks for that
FL787
Sat May 19, 2012 6:27 am
Actually UA is now the only airline using the connector building gates 60-63. The satellite gates are now mostly AS and DL. I've only seen a few UA flights use the satellite gates since AS moved in. F9, CM, and G4 also use the satellite gates.
FL787
Sat May 19, 2012 6:32 am
60 through 63- UA
64 and above- AS/QX, DL, F9, G4, and CM
aklrno
Sat May 19, 2012 6:43 am
Except by a tunnel. In some terminals that tunnel is still open (or it was the last time I used one of those terminals.) I mostly use T-1, T-2, T-8, and TBIT which never had tunnels. T3-7 did. There were also tunnels connecting the satellite buildings from T-4 to T-7. I think one of those tunnels is still open.
Byrdluvs747
Sat May 19, 2012 7:30 am
Quoting AlnessW (Reply 9):
Yes the tunnels are a remnant of the early jet age when all the gates at LAX were separated from the ticketing buildings.
Vintage Aerial LAX
Quoting FL787 (Reply 14):
60 through 63- UA
Yuck, it sounds like T6 is all CUTE. I hate generic gate counters.
pgtravel
Sat May 19, 2012 3:47 pm
Here's how it breaks down as of now.
UA has the "neck" gates - 60, 61, 62, 63 as its own.
The remaining gates are all common use, however AS has preferential use of 8 of them.
DL usually uses 68A or B at certain times of the day but not exclusively. I see today that it has a flight at 66, for example.
F9 squeeze in wherever there's room when the flights arrive.
CM usually uses 66, I think it is, but it doesn't have to. It simply has to be in one of the gates at the top of the stairs in the back because those have sterile corridor access to the FIS.
G4 and NK are now in Terminal 3.
LAXintl
Sat May 19, 2012 5:02 pm
One correct to above.
G4 now uses T-5 gates. While their ticket counter remains in T-6, Delta very recently began to do their ground handling.
As for United, they are a heavy users of T-6 and will continue to do so as part of their master lease. As an example on Friday they had 29 flights utilize T-6 gates including the rotunda gates.
DTWLAX
Sat May 19, 2012 6:23 pm
Quoting pgtravel (Reply 17):
How long was NK in T-6? I remember NK being in T-3 just about 4-5 years ago.
I do not think they can move to T-2. T-2 is currently being used by KLM, AF, Air NZ, VS, Hawaiin, VA(?) and Aero Mexico. T-2 cannot accomodate all those domesctic carriers.
deltacto
Sat May 19, 2012 7:41 pm
duplicate post
deleted
[Edited 2012-05-19 13:12:09]
AlnessW
Sat May 19, 2012 9:44 pm
Quoting RyanairGuru (Reply 12):
Thanks for that
Anytime.   It should also be noted that Terminals 6 and 7 actually share the same security checkpoint.
Quoting FL787 (Reply 13):
60 through 63- UA
Interesting to know, though it sounds like this has not always been the case? See my post below:
   (This was in December of 2010.)
Thanks.
Quoting aklrno (Reply 15):
Yes, Terminals 4-8 are connected airside via a tunnel, but the Terminal 4-Terminal 5 tunnel was blocked off a couple of years ago. (I think.)
Quoting Byrdluvs747 (Reply 16):
I was not aware of this. Thanks for sharing that image!
I'm not crazy about them either, but they seem to be becoming more common these days. Take a look at the international Terminal E in BOS. ALL the ticket counters and gate podiums are common-use.
Cool, thanks for the info.
I hear DL also often parks 747s at Terminal 6 and uses the FIS facility there.
So only the rotunda gates have access to the FIS facility? If that's the case, does UA ever send any international arrivals to Terminal 6? I know Terminals 6 and 7 share the same FIS facility...
Quoting LAXintl (Reply 18):
I was not aware of this. Thanks!
Once again, I didn't realize Terminal 6 was so heavily used by UA. By comparison, do you know how many flights go in and out of Terminal 7 (and 8)?
Quoting DTWLAX (Reply 19):
Same here.
That doesn't surprise me. Terminal 2 does seem petty full...
VA(?)
If I am not mistaken, VA sends departures out of Terminal 3 (gate 38?) and arrivals into Terminal 5, using the FIS facility there.
laca773
Sat May 19, 2012 11:13 pm
Quoting AlnessW (Reply 21):
This is because it's difficult if not impossible for them to park the 744 in T5 without having to close nearby gates. I don't know even if they changed the position of the jetways they could fix this situation. I believe the 744 will soon be gone and the NRT flight will be going back to 77E/77L for the summer.
I think some might not be aware CO had all their flights out of T6 prior to the merger. They ran quite a few flights and with the amount UA has out of LAX, I don't think it would be logistically possible for them to only use 7 & 8. UA has been using 8 for quite sometime now for the A319/A320s which eases some of the congestion in T7. However, I believe UA can't use the T8 gates for their 73NGs. With the winglets, they would have to close the gate next to them because of safety clearance, or re-align them in which they would lose a few gates so it makes sense to leave as is.
More and more PMCO flights have been departing from T7 and PMUA flights have also are now going out of the T6 60-63 gates. If a UA flight is using a gate in the rotunda portion, there's a gate open long enough they can deplane the a/c before AS needs it. It seems DL has been using the rotunda gates during high traffic periods, especially for redeye and noon time departures.
LAXintl
Sun May 20, 2012 12:38 am
4-5 years. Essentially since VX took home in T-3.
Yes UA can and does use T-6 gates for FIS as needed.
Well UA has about 100 mainline, and 100 express flights at LAX.
flyua
Sun May 20, 2012 2:54 am
FYI regarding United's operations in Terminal 6:
As of May 15, United has designated the western end of the Terminal 6 check-in area as the "Aloha Lobby" with a special section for customer check-in for Hawaii flights. (This area is adjacent to the current "Premium Customers' Lobby.") All United departures to HNL, ITO, KOA, LIH, and OGG are being assigned to Terminal 6 gates 60, 61, 62, and 63 whenever possible, and customer service agents assigned to work in Terminal 6 are encouraged to wear Hawaiian shirts and accessories.
AlnessW
Sun May 20, 2012 3:24 am
Quoting laca773 (Reply 22):
   I have heard of this.
Can Terminal 5 take a 777 without closing adjacent gates?
I was aware of this; I hear that AS now uses the ticket counter position where CO was.
Looking at the numbers and at how much they use Terminal 6 I wouldn't doubt that for a moment.
I have heard of this, too.
So Terminal 8 can only take RJs and A319s/A320s?
Interesting to know.
Quoting LAXintl (Reply 23):
I thought the FIS hallways in Terminals 6 and 7 all lead to the same facility?
Wow! Thanks for that data.
Quoting flyua (Reply 24):
I was not aware of this. What is the reason for this change?
teneriffe77
Sun May 20, 2012 3:45 pm
I was looking at the Vintage Aerial LAX link from reply 16 and found from the same source (Los Angeles Fire Department Historical Society's photo stream) an very good pic of the March 1, 1978 CO DC-10 accident @ LAX
http://www.flickr.com/photos/lafdhs/...15012172/in/set-72157627245492095/
In the upper left side of that pic there appears to be ironically a billboard ad w/ an image of a CO DC-10.
AlnessW
Tue May 22, 2012 2:52 am
Quoting teneriffe77 (Reply 26):
How ironic... I had not noticed that before.
FlyASAGuy2005
Tue May 22, 2012 4:19 am
FWIW, last time I flew throuh T6 on DL (don't remember the exact date but within the last 6 months, flew out of 6 on a 763 to Atlanta and the podium was DL branded. Of course there was still a bunch of construction and the place looked a complete mess.
What gets measured gets done.
AlnessW
Tue May 22, 2012 6:32 am
Quoting FlyASAGuy2005 (Reply 28):
What was the gate number, do you remember?
I'm just curious as to when gates 60-63 became UA gates:
