FSDan
AS Summer 2012 Departures By Hub And Aircraft Type
Sun Jun 10, 2012 5:54 am
Similar to the threads for UA, DL, AA, and US, here is data for all (2) AS stations with over 100 departures on Thursday, July 26, 2012. I figured AS is sort of a legacy carrier too... That said, this is obviously a much smaller airline than the other four.
SEA
DH4: 115
CR7: 5
73G: 23
734: 30
738: 62
739: 32
Total: 257
PDX
DH4: 66
CR7: 8
73G: 15
734: 3
738: 11
739: 3
Total: 106
This is my signature until I think of a better one.
steex
RE: AS Summer 2012 Departures By Hub And Aircraft Type
Sun Jun 10, 2012 7:17 am
Thanks for all these informative posts, FSDan. It's very interesting to see the breakdowns for each airline both for comparing hubs within an airline as well as comparing airline to airline.
Since I was curious, I went ahead and tallied the AS flights at the ANC and LAX hubs. Figuring someone is bound to ask about them, I threw in SJC and SAN for good measure. Note that the ANC figures are AS metal only, they do not include the various codeshare flights on PenAir or Era Alaska. Additionally, there is daily variation of a few flights in either direction at all four of these stations - for simplicity sake, I used the same Thursday, July 26, 2012 date as the OP.
ANC
73Q: 9
734: 21
738: 15
739: 6
Total: 51
LAX
DH4: 10
73G: 1
734: 6
738: 10
739: 11
Total: 38
SJC
DH4: 9
73G: 5
734: 1
738: 8
Total: 23
SAN
DH4: 4
734: 4
738: 11
Total: 19
BACCALA
Sun Jun 10, 2012 8:14 am
I thought ANC had more flights for some reason.
737-990
Sun Jun 10, 2012 11:03 am
I remember back in 07-08 LAX peaked at about 57 flights per day. Most of the draw down since occurred with QX reductions which had up to 24 daily LAX departures. Going even further back PDX used to have around 45 mainline AS flights pre 9-11-01. The 32 mainline flights it has now is actually an increase in service since the low about 4 years ago.
Happiest is a man who has his vocation as a hobby
BoeingGuy
Sun Jun 10, 2012 7:11 pm
Interesting that SEA doesn't currently get the 73Q according to the above listing. I've seen one there many times in the past. SJC has often gotten the 739, but also not currently according to the above.
23 daily flights at SJC is still a far cry from AA's past glory of about 77, but it is interesting to note that AS is by far the second most dominating carrier at SJC. As I've mentioned in other posts, I was hoping they'd continue the SJC build up but that seems to have stalled out lately.
Quoting BACCALA (Reply 2):
When you think about it, AS wouldn't have a tremendous amount of flights up there. A lot of onesie-twosie fligths to the various state of Alaska destinations; close to 20 to SEA; a few to PDX; one to LAX; one to ORD; one to DEN seasonally; the one to SFO if it comes back; and one or two to Hawaii. That adds up to about 50 as noted above.
This is really excellent work. Thanks.
On the other extreme, what is AS's smallest station? They have several with just one flight a day (AUS, MCI, etc). My vote goes for ZLO is the least served city in AS's network, which I believe can be down to once-a-week service at non-peak times.
[Edited 2012-06-10 12:12:53]
[Edited 2012-06-10 12:13:58]
steex
Sun Jun 10, 2012 7:59 pm
Quoting BoeingGuy (Reply 4):
I suspect the OP must have rolled the 73Q into the 734 listing. AS 121 on the SEA-ANC route shows up in the schedule as a 73Q. It appears that AS 61 SEA-JNU is also scheduled on the 73Q.
The more detailed breakdown of ANC departures is as follows:
ADK: 1x 734
BET: 2x 73Q, 1x 734
ORD: 1x 738
CDV: 1x 734
DEN: 1x 738
DLG: 1x 734
FAI: 1x 73Q, 6x 734, 1x 738
HNL: 1x 738
JNU: 1x 73Q, 3x 734
AKN: 1x 734
ADQ: 1x 73Q, 1x 734
OTZ: 1x 73Q, 1x 734
LAX: 2x 738
OME: 1x 73Q
PDX: 2x 738, 1x 739
SCC: 1x 73Q
SEA: 1x 73Q, 5x 734, 7x 738, 5x 739
As of now, SFO is not scheduled to return this summer, but LAX is double daily. As you correctly note, many cities are served as milk runs from ANC, which reduces the total departure number. ANC-BRW has no non-stop departures, for example, but has two 1-stops and a 2-stop on a single flight number. Additionally, several cities have a single AS departure and the remainder of the service is filled in by codeshares on PenAir or Era Alaska.
Right on the money. Over the summer, ZLO is down to a single weekly (Saturday) LAX-ZLO-LAX turn on the 739. In terms of capacity, the next smallest appears to be LAP with 3x weekly Q400s from LAX over the summer.
BoeingGuy
Sun Jun 10, 2012 8:15 pm
Great analysis of ANC. How come AS doesn't want to do SFO-ANC? I know they needed the airplane somewhere else last year. AS has briefly tried ANC-YVR, ANC-LAS, and ANC-PHX also. ANC-DEN was done just because F9 started it, but from what I understand that route does surprisingly well for AS.
Does AS have anything else planned for ANC, like maybe ANC-MSP or ANC-EWR? I imagine the latter would probably exceed the legs of the 738.
Quoting steex (Reply 5):
I actually really liked LAP as a place to visit. Much more authentic than SJD. Was there when AS/QX didn't serve LAP so I had to take SEA-SJD and then take the bus back to La Paz. AS did LAX-LAP years ago on a 734 then discontinued it. Then they came back a few years ago with a 734 again, but then turned it over to QX, first a CR7 and then DH4. LTO was a 734 for awhile too, but then turned over to QX.
I'm pretty sure that LAX-LAP is the longest Q400 flight in QX's network. Is that right?
lhpdx
Sun Jun 10, 2012 8:26 pm
Wow I did not realize how much lower Alaska PDX combined serviced was..I remember when Horizon alone had close to 100 flights a day alone.......Is Portland importance deminishing with Alaska over long range plans?
BoeingGuy
Sun Jun 10, 2012 8:33 pm
Quoting lhpdx (Reply 7):
AS has started PDX-ORD flights; just got authority for PDX-DCA and will soon serve every major Hawaiian destination from PDX. That does not indicate to me that PDX is diminishing in AS's long range plans. I think the reduction in flights is mainly due to a reduction in the smaller QX cities, many of which were served from PDX (LMT, SLE, etc).
It will be interesting to see if AS fills in more destinations from PDX like EWR, FLL, AUS, etc. We'll also see if Mexico tourism traffic increases enough that AS will restart their very short-lived PDX-SJD and PVR flights.
OzarkD9S
Sun Jun 10, 2012 9:11 pm
Quoting BoeingGuy (Reply 8):
Spot on. I checked out departedflights.com and checked the totals for AS/QX (1995) and came up with approximately 170-ish weekday departures with reductions on the weekends. Bear in mind QX was still operating Metros and D38's at the time as well as the F28. Upguaging to the Q400 certainly took a toll on frequencies.
As the masters write on walls and the angels eat their grapes, I watched Picasso visit The Planet of The Apes. - Adam and The Ants.
steex
Sun Jun 10, 2012 10:08 pm
Quoting BoeingGuy (Reply 6):
I don't really have any inside information, so I can only speculate. However, it seems that AS has mostly shied away from routes with direct non-stop competition out of ANC, especially if it's seasonal and/or served by a partner. ORD has been a strong year-round performer and can take advantage of AA's hub at the other end, so it makes sense. My understanding is they had more slack in the fleet when they started DEN to defend against F9, but the results were a pleasant surprise and has warranted bringing it back seasonally.
All of SFO/YVR/LAS/PHX suffer from a lack of onward connections and it's likely difficult for AS to compete strictly on an O&D basis against a carrier who can also capture those connections. To that end, I would imagine UA deciding to re-enter ANC and including seasonal SFO service was the nail in the coffin there. They'd also be up against US on PHX and AC on YVR, while LAS may just not be high yielding enough to tie up the aircraft time. Adding a second daily LAX flight in the summer makes more seats available for connections on AA/DL to all of those cities, though, and still allows AS a good opportunity to be in the markets indirectly. I would imagine that they're also trying to protect their market share to the L.A. basin against B6's LGB service, as LAX is a more important market to them than the other cities.
I wouldn't expect them to start MSP for two reasons; A) it essentially serves the same purpose as ORD, and B) DL already has a healthy year-round presence on the route with AS codeshare. As you note, EWR would stretch the legs of AS's equipment, but it also has no hub at the EWR end. I'm not sure NYC-Alaska is a significant enough market to justify tying up the equipment without any connectivity.
roadrunner165
Sun Jun 10, 2012 11:02 pm
Steex, just wanted to clarify Nome and Kotzebue. There are actually three flights per day that serve these two communities.
151 ANC-OTZ-OME-ANC
152 ANC-OME-OTZ-ANC
153 ANC-OTZ-OME-ANC
Adam
edit: I see now you are showing specifically Anchorage departures.
[Edited 2012-06-10 16:04:19]
steex
Sun Jun 10, 2012 11:18 pm
Quoting roadrunner165 (Reply 11):
151 ANC-OTZ-OME-ANC
152 ANC-OME-OTZ-ANC
153 ANC-OTZ-OME-ANC
You're correct. Actually, this is also one of scenarios with day-of-week fluctuation. AS doesn't serve Kotzebue at all on Mondays and Tuesdays, so the result is that the following operate those days of the week:
AS 151 OME-ANC
AS 152 ANC-OME
AS 153 OME-ANC
AS 154 ANC-OME
AS 155 OME-ANC
AS 158 ANC-OME
Essentially, they chop off the OTZ-related sections of AS 151/152/153 and replace them with complementary sections to OME.
SANFan
Sun Jun 10, 2012 11:32 pm
LAP is a destination that I would like to see AS try from SAN (with a Q400.) If they have some spare a/c time at SAN next year, I would expect a few flights a week on that beautiful bird would work very nicely. (What would really be great would be to fly it beyond Baja over to MZT but I don't know if AS would do any intra-Mexico hops...)
I think there are other routes in Mexico as well that AS route development might be looking at from SAN; they seem to be having success with both routes they currently fly. (Especially given the present state of things overall in Mexico these days.)
bb
RWA380
Mon Jun 11, 2012 8:02 am
Not to mention OTH, PDT, RDD & ACV.....
Quoting SANFan (Reply 13):
bb
I think you are spot on with your thoughts here, if AS is indeed in the midst of the "SAN experiment" I fully expect to see more and more transborder flights, plus additional domestic destinations, say TUS?
707, 717, 720, 727-1/2, 737-1/2/3/4/5/7/8/9, 747-1/2/3/4, 757, 767-2/3/4, 777, DC-8-5/6/7, DC-9-1/3/5, MD-80/2/3/7/8, DC-10-10/30/40, MD-11, F-27, F-28, SWM, J31, D38, DH7, DH8, DH4 SD-330, B-146, L-1011-2/500, ATR-42/72, VCV, A-300/310/318/319/320, CR2/7
SkyTeam7488
Tue Jun 12, 2012 2:10 pm
In combining these in a single spreadsheet, I entered the data in my excel and I get a total for SEA at 267. Not sure if there is a miscalculation or just a typo. I am working on adding a few to this collection as well, working on WN now. Then will move on to the AF, LH, BA and so on.
Quoting FSDan (Thread starter):
SEA
DH4: 115
CR7: 5
73G: 23
734: 30
738: 62
739: 32
Total: 257
You only live once... So live the high life.
Tomassjc
Tue Jun 12, 2012 2:27 pm
Quoting steex (Reply 1):
SJC
DH4: 9
73G: 5
734: 1
738: 8
Total: 23
I can tell you that out of SJC, on PDX and SEA departures, equipment varies depending on the load. I realize the data shown is for a specific day, but for example the 6:55pm SEA can go from a 73G one day to a 738 the next. Something AS did not do much of in the past, tailoring the equipment to meet the demand from day to day.
Tom SJC
When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward -Leonardo DaVinci
steex
Tue Jun 12, 2012 3:27 pm
Quoting Tomassjc (Reply 16):
That makes sense, and pretty much every airline does this to some level if they are able. A319/320 swaps are very common for carriers operating both, and I recall at NW, it was a complete crap shoot which DC-9 model would show up at the gate half the time. But at the end of the day, they have to actually schedule something. The figures shown in these threads represent that.
BoeingGuy
Tue Jun 12, 2012 4:19 pm
I've noticed that too the last few years. A given flight will be scheduled as a 737-700, but I'll show up and it's really a 737-400 or 737-800 on several occasions. In one case, an -800 was scheduled to SJC during Christmas, but a -900 was sitting at the gate.
A few have been last minuted maintenance or delay swap-outs, but several seemed to just have been equipment substitutions for the day.
I guess AS can do that when they only fly one major model and every pilot can fly every airplane in their fleet.
SANFan
Tue Jun 12, 2012 4:38 pm
How does AS handle the seat assignments in these cases of last-minute equipment changes? Obviously with a larger a/c subbing for a smaller, there's no problem (except minor cases where indivudual row numbers may not exist in the new plane for a few unlucky souls) but what about downgrades of the a/c? If an -800 is scheduled but it's got a light load and they swap out a -400 that day, wouldn't we see a lot of messed up assignments and even bps as boarding occurs? (Read: angry pax.) Sounds like an ongoing headache to me... (Maybe they hardly ever downgrade aircraft?)
bb
BoeingGuy
Tue Jun 12, 2012 4:48 pm
Quoting SANFan (Reply 19):
I can't speak for AS's official policy but that happened to me once. The 738 I was about to board the last evening flight to SJC went out with a Mechanical problem. So AS substituted a 737-400. I had an MVP Upgrade. A 738 has 16 First Class seats, but a 734 only has 12. So they had to "un-upgrade" four people. I was the last one who didn't get bumped back to coach.
You know, sometimes **** happens. If I got bumped back to coach in a circumstance like this, I'd live with it. AS can only do so much. They still got us to SJC fairly close to on-time. Getting bumped back to Coach or riding in a 734 is a heck of a lot better than a 12 hour overnight delay.
The other thing that has happened to me is when I book the second exit row in a 73G (e.g. Row 13) but they later reschedule the flight to a 734 in which Row 13 is the non-reclining exit seat. That's kind of a pain. I thought I just read that AS is renumbering exit rows so the row number is consistent across each minor model to prevent this.
Tomassjc
Tue Jun 12, 2012 6:28 pm
The equipment swaps are usually programmed far enough out, that there is minimal effect on the customers.
Tom SJC
bayareablue
Tue Jun 12, 2012 6:31 pm
Quoting BoeingGuy (Reply 20):
You are correct on that. All of the aircraft (except the Combi's) have the same row numbers for in front of the exit row and and both exit rows to eleviate the issues with equipment swaps.
RWA380
Wed Jun 13, 2012 11:26 am
(e.g. Row 13)
A bit off topic, but here it goes. Back in 1980 we flew EZ PDX-OGG-PDX, they were using the old sticker method of seat assignments, our family was booked in row 13, when we got on the DC-8 bound for PDX, we find no row 13 at all, and ended up having EZ find us 4 seats together on a packed DC-8. What they did was use HA's DC-8 seating charts that must have been available instead of EZ's own, and we ended up in what would have been called first class, that EZ had blocked out for the charter, only 4 seats up there, exactly 1 row, 2 other people were bumped off the once weekly service.
FSDan
Wed Jun 13, 2012 12:40 pm
Quoting SkyTeam7488 (Reply 15):
Good catch! The total is actually correct at 257. But the number of 739 departures should be 22, not 32. I must not be able to read my own handwriting.
Unfortunately, it looks like it's too late for me to edit the original post.
