rotating14
Alaska's 739 routes?
Tue Jun 19, 2012 4:22 am
I'm curious as to where AS deploys their 737-900's. I'm guessing higher yielding routes like ANC-HNL, SEA-HNL, ANC-ORD, SEA-LAX, SEA-FLL and SEA-BOS but I can't think of any more. Someone care to offer some further info??
mikesairways
Tue Jun 19, 2012 4:25 am
It shows up here in SJC on occasion.
The red zone is for the immediate loading and unloading of passengers only, there is no stopping in the white zone...(Ai
clickhappy
Tue Jun 19, 2012 4:44 am
Almost all of your guesses are wrong
SEA-LAS
SEA-DEN
SEA-PSP
SEA-ANC
SEA-ATL
SEA-AUS
SEA-ORD
SEA-DFW
SEA-LAX
SEA-MSP
BLI-LAS
I'm sure I missed a few
seabosdca
Tue Jun 19, 2012 4:50 am
They don't have the range for either the transcons (without westbound weight restrictions) or Hawaii, and they don't have ETOPS. So they are high volume haulers on shorter routes.
jmc1975
Tue Jun 19, 2012 4:52 am
The 739s don't have the range for Hawaii. Besides, higher-yield doesn't mean more passengers...it means most revenue per passenger per mile.
roseflyer
Tue Jun 19, 2012 4:53 am
They never operate to Hawaii since none of them are ETOPS. Also, AS pulled them off of transcon routes as they often took weight penalties, especially after the FAA increased passenger weights in 2003.
They go to high capacity routes and not high yield routes. SEA-LAX and SEA-ANC are AS' two busiest routes, and likewise get the 739s most frequently. With almost 20 flights a day in the summer season, SEA-ANC needs more 739s.
wedgetail737
Tue Jun 19, 2012 5:32 am
Some of the long-range flights may become 737-900ER routes like SEA-FLL, SEA-BOS, SEA-EWR. Like others said, 739s are not ETOPS. So you won't see them on Hawaii routes. Clickhappy has most of them covered, but I have seen them on SEA-OAK, SEA-SFO, SFO-PVR, LAX-PVR, LAX-SJD, SEA-SAN, LAX-YVR, SEA-PHX and SEA-FAI. On occasion, they have sent them on the SEA-AUS and SEA-JNU routes. Other airports you will not see 737-900's are SEA-SNA or SEA-BUR.
It'll be interesting what kind of airplane shuffling will go on when the 737-900ER's come online. Will some go on the higher-capacity Mainland-Hawaii routes. It has been stated that some will be deployed on East-West routes.
shnoob940
Tue Jun 19, 2012 6:38 am
Occasionally one is placed on #665, the morning service from DFW-SEA
gibbo
319/320/321/332/333/359/388/733/734/735/736/737/738/739/743/744/752/762/763/772/77E/773/77W/788/789/E70/E90/Q400/AT7/DH4/SF3/RJ85
PHX787
Tue Jun 19, 2012 6:42 am
Quoting wedgetail737 (Reply 6):
SEA-PHX
Saw one at PHX the other day.
http://flightaware.com/live/findflight/KSEA/KPHX/
if you look at AS only, you can see that occasionally the flight is operated by a 739.
Like this one: http://flightaware.com/live/flight/A...6/history/20120618/2040Z/KSEA/KPHX
ha763
Tue Jun 19, 2012 6:54 am
Unless they get at least 1 aux fuel tank installed, I doubt it. CO had to heavily weight restrict their 737-900ER when they used them LAX-Hawaii to the point where they need a LF over 100% just to breakeven. CO quickly changed the flights back to the 737-800.
SANFan
Tue Jun 19, 2012 7:20 am
The specific a/c model scheduled for each flight is available on the website thru either the schedule display or the booking engine, but not on the .PDF timetable. (You will generally have to click on "details" or "seats" to see the a/c type but the info is there.) Of course there are, as has been discussed on other threads, substitutions of a/c models all the time.
bb
EA CO AS
Tue Jun 19, 2012 8:42 am
Quoting ha763 (Reply 9):
Quoting wedgetail737 (Reply 6):It'll be interesting what kind of airplane shuffling will go on when the 737-900ER's come online. Will some go on the higher-capacity Mainland-Hawaii routes.
And none will.
yeelep
Tue Jun 19, 2012 10:20 am
No aux tanks from what Iv'e heard, but at least some will be delivered certified for ETOPS. So, if not Hawaii, then where?
roseflyer
RE: Alaska's 739 Routes?
Tue Jun 19, 2012 3:40 pm
The comment about needing a 100%LF doesn’t make sense to me. UA still operates the 739ER into HNL from LAX. If an airplane is weight restricted, how could they have a 100% load factor? Are you talking about a 100% capacity capped load factor? UA has no shortage of cargo capacity to the islands, so they aren’t leaving cargo behind.
If UA was struggling to earn money using the 739ER because of range or fuel tank capacity, then I would think they would use a different airplane. They have ETOPS 738s and ETOPS 757s that they could use.
[Edited 2012-06-19 08:52:09]
BoeingGuy
Tue Jun 19, 2012 4:16 pm
AS had a 739 on all flights to PVR a few years ago, including the seasonal PVR-SEA. That route was so borderline on range that they had to offload a bunch of luggage and route it through LAX for weight reasons. That was no appropriate equipment for that flight. A 738 would have been the right choice.
Problem is they didn't bother to tell anyway so we all had to go wait in an hour long line to claim lost luggage at SEA (it was apparently too difficult for PVR to send a list up to SEA and they page us in the baggage area to inform us our luggage is coming the next day). Off-topic, but I was really unimpressed with AS's PVR station in general. They were a very bad reflection on AS's normally high standards. The baggage fiasco and the fact that they dropped our seat assignments and tried to lie to me about it. Needless to say, AS heard about it the next day.
I'm surprised to see a 739 on BLI-LAS. I knew that flight was reasonably successful, but didn't know it was that good. 739s are not authorized to fly into SNA, AFAIK.
Thomas_Jaeger
Wed Jun 20, 2012 4:55 am
According to our database at ch-aviation based on Innovata schedule data, these routes are served this week:
From ANC: FAI, LAX, PDX, SEA
From LAX: ANC, ZIH, ZLO, PDX, PVR, SJD, SEA, YVR
From PDX: LAX, SAN
From SEA: ANC, ATL, AUS, ORD, DFW, IAH, JNU, LAS, LAX, MSP, PHX, SMF, SFO, STL, TUS
Swiss aviation news junkie living all over the place
ha763
Wed Jun 20, 2012 7:28 am
Quoting Roseflyer (Reply 13):
UA no longer operates the 739ER on any Hawaii routes. I remember reading about the BEP being over 100% LF, but I don't recall where. Since the 739ER had seats blocked due to weight restrictions, I would think it was based on the restricted capacity.
This is exactly what has happened. The only 737NG they use is the 738. LAX-HNL is now a mixture of 752, 753, and 738.
bobnwa
Wed Jun 20, 2012 5:42 pm
Quoting rotating14 (Thread starter):
Flights to and from Hawaii are not generally considered high yield.
BoeingGuy
Wed Jun 20, 2012 6:27 pm
Quoting bobnwa (Reply 17):
That's the popular notion. However, Hawaii must being doing something right for AS considering that a significant portion of AS's ASMs (I think that's the correct measurement) are to Hawaii and their financial results are relatively successful these days. AS are no dummies. They wouldn't be expanding to Hawaii like gang-busters if they weren't profitable.
atct
Wed Jun 20, 2012 7:31 pm
We dont see many -900's up here in Anchorage. The majority are 400s and 800's. IAH has been getting the -900's recently as well.
atct
Trikes are for kids!
usxguy
Wed Jun 20, 2012 8:40 pm
Interestingly enough, I'm booked on a 737-900 on 9/11 SEA-JNU ^_^
xx
kgaiflyer
Thu Jun 21, 2012 6:09 pm
I've flown the ANC-SEA. There's a 2am departure from ANC that meets the 6-7am bank in SEA. Amazing how many people are on that flight.
Years ago there was an IAD-SEA 739, but people tell me that -- given the distance -- they don't know why the plane didn't fall out of the sky.
N770WD
Thu Jun 21, 2012 6:48 pm
Quoting kgaiflyer (Reply 21):
IAD-SEA is relatively short given where AS operated their 737-990s.
They operated IAD-SEA in 2004 and 2005 with excellent operational results - no diversions.
Taking July 2004 for example, AS 739s were assigned to the following transcons:
MIA-SEA 2724mi
MCO-SEA 2553mi
BOS-SEA 2496mi
EWR-SEA 2401mi
IAD-SEA 2306mi
For that month, no diversions en-route, but above-average arrival delays for the fleet.
I have no idea what payload hits were taken though, and what that meant for economics.
roseflyer
Thu Jun 21, 2012 7:26 pm
Quoting N770WD (Reply 22):
From what I remember, AS was taking payload hits and cutting seats over fuel stops. It’s up to the airline if they prefer a fuel stop or a payload restriction. I remember the Florida-SEA routes regularly having 16 seats blocked.
bobnwa
Fri Jun 22, 2012 9:19 pm
Quoting BoeingGuy (Reply 18):
I don't think that seeing a carrier is decreasing or increasing schedules in a particular market taken by itself is any indication of profitability.
seabosdca
Fri Jun 22, 2012 9:38 pm
They ran them BOS-SEA as well, which is quite a bit longer. That one had a few diversions, and it also always had seats blocked off. I flew the route on 739s on several occasions in 2005 and 2006.
as77w
Sat Jun 23, 2012 3:39 am
We see the 739s a lot more in ANC during the summer rush. Lately, they have been running ANC-LAX on the 739 pretty consistently, along with numerous ANC-SEA legs and the occasional ANC-PDX. As mentioned before all AS Hawaiian flying is operated on ETOPS 738s, and ANC-ORD can only be operated on a 739 if it is severely weight restricted. Also the IAH-SEA-ANC flight is consistently on the 739.
ASFlyer
Sat Jun 23, 2012 4:09 am
Quoting Roseflyer (Reply 23):
I'm sure there were times when they blocked seats on MCO-SEA but I flew that regularly for a good year on the -900 and I don't recall many occasions where they blocked seats at all. Those flights were generally always full - every last seat. Not saying that they didn't block them but it was the exception more than the rule.
ASFlyer
Sat Jun 23, 2012 4:11 am
Quoting seabosdca (Reply 25):
It did not "always" have seats blocked off. It, more often than not, went out full to my recollection.
yellowtail
Sat Jun 23, 2012 4:12 am
AS was having a difficult time at IAH..if the 739 is on there now..have loads improved?
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
hiflyeras
Sat Jun 23, 2012 4:36 am
I believe that the 900ER will be debuting on the SEA-DCA route. It's curious that some will be ETOPS certified yet people seem to be saying that it won't be used from CA cities to Hawaii. I think that SAN and Bay Area-Hawaii are the likely routes for the 900ER ETOPS....unless AS is heading south to Central America out of LAX (which I'd love to see!).
coopdogyo
Sat Jun 23, 2012 5:53 pm
Last week I was surprised to find myself on a very full 737-900 from SEA-BOS. So they are still used transcon from time to time.
[Edited 2012-06-23 10:59:50]
