WN787
Short Leash For Boeing's MAX Design
Tue Jun 19, 2012 6:56 am
http://www.aviationweek.com/Article....e-xml/AW_06_18_2012_p54-465857.xml
An interesting article on how Boeing plans to roll out the MAX.
Interesting highlights....
"Boeing will spend the rest of this year “getting the final concept done” before marching on to a firm configuration in mid-2013, Teal says. Design will take place in 2014, assembly in 2015 and first flight in 2016. The 737-800-sized MAX 8 is to be produced first."
"By the time the MAX enters production in Renton, Boeing expects the factory to be producing 42 airplanes per month from the plant's two final assembly lines."
And lots more in the article. Do you think that Boeing has learned from the countless delays the 787 had?
Is it even possible that Boeing can make all of these changes to the 737 and expect the factory to be able to seamlessly continue production on a "different" airframe?
If Boeing can keep a "short leash" on the development like they think, it could be possible, but are they selling the MAX short of upgrades?
What do you think......
scouseflyer
RE: Short Leash For Boeing's MAX Design
Tue Jun 19, 2012 7:28 am
Quoting WN787 (Thread starter):
You'd like to hope that they can avoid the mission creep that dogged the 748 and the the A350XWB programmes but there's always a balance between doing a tightly defined, well executed incremental upgrade and the temptation of "It'd be so much better if we also did this and this and this........."
tdscanuck
Tue Jun 19, 2012 11:21 am
I certainly hope so. If they put all the upgrades onto the MAX that it's capable of taking then it will never be on time or on budget.
Derivatives take an enormous amount of discipline to only let on that which was planned at the beginning or is absolutely necessary as discoveries happen in the middle.
Tom.
SEPilot
Tue Jun 19, 2012 11:55 am
It is very dangerous to let designers loose on an existing product (I speak from experience.) There are very few things that cannot be improved, and good designers can always see ways that they think will make the product better. They are seldom concerned with the costs and other implications; they are motivated solely by the thought that "it would be so much better if we just did THIS." But budgets and schedules are harsh realities that designers like to ignore; and management has to maintain them. But there is another reality, and that is that any project (especially one as massive as designing, or redesigning, an airliner) will always have surprises. Nobody can foresee all of the problems that will arise, and planning for them is an art. Boeing management failed spectacularly on planning both the 787 and the 748; we will see whether they learned the appropriate lessons, whether they now err in the other direction by not doing enough, or whether they do the same mistakes again. The stakes are very high; let's hope they get it right.
frigatebird
Tue Jun 19, 2012 12:52 pm
Quoting SEPilot (Reply 3):
Boeing has an excellent example how not to do it, which is the 747-8. However, they also have an excellent opposite example: the 777-300ER.
Some people believe cannot take much weight out of the 777 in the 777-9 design, mentioning if it had been possible Boeing would have done so in designing the 77W. But I believe Boeing deliberately didn't go that way, it would have caused way too many complications and it already was behind the A346 in development. I think Boeing will apply the lesson lesson regarding the 737MAX.
Still, there's enough that still can mess things up. Look the A350XWB, everyone (including, and especially, John Leahy) believed EIS in 2013 was an example of realistic planning. Still, the unexpected ate more away from the schedule than they had foreseen. The lesson Airbus learned however, was not cut corners in realising the original schedule. And that will pay off in the end.
146,318/19/20/21, AB6,332,343,345,388, 722,732/3/4/5/G/8,9, 742,74E,744,752,762,763, 772,77E,773,77W, AT4/7,ATP,CRK,E90,F50/7
lightsaber
Crew
Tue Jun 19, 2012 2:21 pm
Quoting scouseflyer (Reply 1):
The enemy of 'good enough' is better. Boeing has to rush schedule or lose customers. They'll have time later for other improvements.
Quoting tdscanuck (Reply 2):
Quoting frigatebird (Reply 4):
   But what if the 787 had been on time?    If there were already 200+ 787s in the global fleet by now, Airbus customers would be singing a different turn about A350 delays. It is fortunate for Airbus that Boeing gave them the time.
Not the Boeing stress and design engineers I talk to. They *know* of weight that should be out of there. The 777 was rushed to market and certain joint weight, in particular in the wing, is ready to come out. However, Boeing didn't want to be forced to re-break the wing, so much was left along. If the 777-X does indeed receive a new wing... Time to go all out in weight reduction (it won't just be material changes).
Lightsaber
ODwyerPW
Tue Jun 19, 2012 5:32 pm
Some very nice contributions to the discussions. Thanks for sharing them guys.
learning never stops.
SEPilot
Tue Jun 19, 2012 6:09 pm
Excellent point; the 77W is probably the most successful aircraft upgrade ever, and was done very expeditiously, with results that exceeded all expectation. It is surprising that the same company could do such a superb job, and then just a few years later fall so flat on its face with the 748. But to be fair, the problems with the 748 were probably a side effect of the massive cock-up with the 787 in that the 787 sucked up all of the engineering resources. Had that not happened perhaps the 748 would have gone much better.
ODwyerPW
Tue Jun 19, 2012 7:05 pm
So we won´t know basic things like whether or not the flat bulkhead is being retained or seating configuration. What is interesting is the 8MAX is being treated as the baseline..... then the 9MAX the stretch and finally the 7MAX as the shrink.
I have always thought the leap from 73G to 738 was rather large, considering the leap from 738 to 739 was pretty small. I wonder if Boeing will take the time it has with the 7MAX to stretch it just a tiny bit, one plug or so, to make it a true 149 pax plane. That could put come CASM pressure on the new entries (Bombardier, Mitsi, Sokhoi, AVIC, etc..). One could imagine the ranges of the planes, in truly comfortable (32" pitch) 1 class seating, at 149, 175, 199.
Alas, we won´t begin to know these figures until mid 2013 (Final Concept-Config).
What is also interesting is that Boeing is resisting incorporating so many of the things from the Eco Demonstrator and the NGPlus Studies/Programs.
They have also been very quiet on the materials front. So, I am looking forward to clarification on that in 2014 (Design).
Peter
Stitch
Tue Jun 19, 2012 7:14 pm
Quoting lightsaber (Reply 5):
Grab the low-hanging fruit (engine improvements, MTOW boost) up front to make EIS and then tweak it afterwards. The MAX should be in production for decades (just as the NG did) and will consistently improve over that time just as the NG has.
Quoting SEPilot (Reply 7):
But that was mostly an MTOW boost with some wingtip modifications for longer range missions.
rotating14
Tue Jun 19, 2012 7:23 pm
odwyerpw,reply=8
I believe its because it's the model that a majority of the carriers (current and/or new) will want to have in their fleet. With the -8 you have the base to build around, where the -9 is a step above as far as short to medium haul for heavy loads and the -7 being for smaller carriers or start ups who just want a new model but don't need the extra seats or range in the -8 and the -9.
SEPilot
Tue Jun 19, 2012 7:36 pm
Quoting Stitch (Reply 9):
Plus a nearly new engine.
roseflyer
I appreciate the article and the insight that it provides into how specific design changes are being made. The general strategy of if it ain’t broke, don’t fix it, makes a lot of sense to me. The 737NG is probably the most perfected design in production since it has been redesigned and fixed for decades. It has spectacular reliability, so not changing parts if there is not a measurable benefit makes sense to me. There’s benefit to fly by wire spoilers, but not fly by wire for the whole aircraft. Obviously they are calculating where they will get benefit and where they will not and not changing parts just because they can.
I hope the MAX program goes well and it appears Teal might be the right guy for the program having learned from the 747-8.
SEPilot
Tue Jun 19, 2012 7:44 pm
Quoting Roseflyer (Reply 12):
Provided that he doesn't overcompensate and end up with an inferior aircraft to the NEO. It is not easy to make the decisions as to what to change and what to leave alone; if it were easy anyone could do it.
lightsaber
Crew
Tue Jun 19, 2012 7:56 pm
What I would like to know is if the 738MAX will gain the flat bulkhead and what other improvements to try and put in one more row of seats (or more?)?
   For example, I've heard noise about changing the layout of the aft hydraulics to cut maintenance bills. Unless required for the new tailcone, I say do that work a few years after EIS of the 738MAX.
Quoting odwyerpw (Reply 8):
As already noted, the 738 is already the best selling length of the 737. This isn't like the 737NG where sticking wtih a known length cut risk on the 73G. Instead, the 'low risk' model will be the 738. That 'leap' will depend on mission. I expect the 73G to be stretched by a frame or so. I would also like to know if it is possible to stretch the 739 a little...
But for EIS concerns, get the 738 first.
Not per my rumor mill. New aluminums are being seriously considered to cut the weight. What and when it is put in is for a later decision. For now, unless the part must be change, consider when (later) it may be changed.
Lightsaber
ckfred
Tue Jun 19, 2012 8:11 pm
Remember that Boeing had no trouble moving from the 737 Classic to the 737 NG. In fact, there was a span of a few years in which a carrier could order any series from the -300 to the -800. IIRC, the last Classics came off the line in late 1999, while the various NG series went into service in 1998.
roseflyer
Tue Jun 19, 2012 8:49 pm
Quoting ckfred (Reply 15):
I am not sure I agree with that. The 737CL to 737NG ramp up turned into a mess and resulted in the production line being shut down for over a month to catch up on traveled work. That shutdown was very costly as it caused the contractual delay of every airplane that was in the production system. Delays with weeks of notice are very costly as they force the airplanes to miss contractual deadlines that become more firm as an airplane approaches delivery. It ended up costing Boeing $1.6 Billion.
[Edited 2012-06-19 13:50:30]
Stitch
Tue Jun 19, 2012 9:20 pm
Quoting Roseflyer (Reply 16):
And yet it was because of that snafu across all of Boeing Commercial's product lines that resulted in them implementing the processes in place today and instills caution when they make production rate increases.
ckfred
Wed Jun 20, 2012 3:50 am
Didn't Boeing shut down both Renton and Everett? I seem to remember that Boeing was running every line (737/747/757/767/777) faster and faster, to catch up with the backlog and wound up having to shut down everything, because the production lines were getting ahead of the supply chains.
It wasn't so much an issue in trying to build both Classic and NG aircraft on the same line as it was trying to push the limits of assembly process. If Boeing had ended production of the Classic series, it still would have production problems because of the unsustainable production schedule.
Stitch
Wed Jun 20, 2012 3:55 am
Quoting ckfred (Reply 18):
Yes. All of the lines face-planted due to inventory shortages.
Revelation
Wed Jun 20, 2012 11:22 am
Quoting Stitch (Reply 17):
Yet their European competitor has come out of nowhere to outproduce them without such a snafu, with every bit as complicated a supply chain (if not more complicated!).
Just sayin'...
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
astuteman
Wed Jun 20, 2012 3:43 pm
Quoting SEPilot (Reply 13):
Inferior in what way?
From my seat, I can't see how "tinkering" to get the last couple of percent is going to materially affect the saleability of the MAX. Demand is just too great (IMO)
Quoting Revelation (Reply 20):
Again, to be fair to Boeing, my recollection is that what REALLY screwed them up is that they'd ramped up hugely to satisfy all these huge "sole source" orders from the US majors, that evaporated into the mist overnight after 9/11.
Output went from 600+ frames to 250 frames within 2 years.
Airbus have NEVER had to face a disruption anything like that.
And to be honest, although their output has risen dramatically viewed over a decade or more, year-on-year the increases have been quite small..... (IMO)
Stitch
Wed Jun 20, 2012 3:44 pm
Airbus face-planted rather spectacularly in 2006 with pushing the A380-800 out the door and it can be argued their still trying to get back on their feet. And the jury is still out on how smoothly the A350 program will shift from development to serial production.
That being said, Airbus' rise from 3% to 30% of the market in two decades was one of the factors that pushed Boeing to ramp production so hard in the late 1990s. The other factor was the 60-fold increase in worldwide orders (from 15 in 1993 to 898 in 1996). Also not helping was the huge staff draw-down Boeing did as the 777 program moved from development to production (almost 10,000 senior engineers and machinists were given early retirement) and the introduction of the disaster that was the DCAC parts-tracking system.
roseflyer
Wed Jun 20, 2012 4:32 pm
I don’t want to get into an A vs B war, but both Airbus and Boeing have had challenges with new designs. It’s part of what happens with large scale new projects. The 777 was overbudget, the 737NG increased rate too fast, the 787 was late, the 747-8 was late, the A380 was late and has design defects, the A330 had a flight test crash, the A320 had serious teething issues with pilot error causing 3 crashes within 4 years of EIS. There’s always problems during programs. What Boeing is trying to do with the 737MAX is put a limit on change to only what is necessary to get efficiency improvements. They are trying to avoid all the problems that have happened on essentially every new model in the last 3 decades.
For what it is worth, Airbus seems to be using the exact same design approach on the A320NEO.
tdscanuck
Wed Jun 20, 2012 5:55 pm
Airbus outproduces Boeing primarily on scale...they're using something like double the factory space to produce nowhere near double the aircraft. Boeing's narrowbody production system is considerably more efficient on capital.
Tom.
SEPilot
Wed Jun 20, 2012 9:49 pm
Quoting astuteman (Reply 21):
Clearly neither Airbus or Boeing is capable of fulfilling 75% of the narrowbody demand, as you say. But if one outperforms the other on total cost of ownership by more than 5% I do think that the better plane will gain market share, and over time could claim 60% of the market. I do think that Airbus has an easier job and potentially greater gains to realize, primarily because of the fan size issue, and the fact that the 737 already has winglets. On the other side of the equation, the 737 is lighter. This is why I am concerned that Boeing does enough to maintain parity. But you are probably right that it will not matter that much.
WarpSpeed
Wed Jun 20, 2012 10:01 pm
Quoting tdscanuck (Reply 24):
Does this consider Boeing's outsourcing to Spirit Aero for fuselage fabrication?
DaHjaj jaj QaQ Daghajjaj !!!!
tdscanuck
Wed Jun 20, 2012 10:11 pm
Quoting WarpSpeed (Reply 26):
I was thinking of it in terms of final assembly space (i.e. not including Airbus's fuselage fabrication either) but I think the result would be pretty similar if you included it in both cases.
Tom.
Stitch
Thu Jun 21, 2012 12:41 am
Airbus does have A320 FAL buildings in three separate cities, so they must have a significantly larger amount of space allocated to A320 production.
astuteman
Thu Jun 21, 2012 5:02 am
Quoting SEPilot (Reply 25):
I don't disagree, but I don't think we're in that space. the last 2 or 3% of fuel burn will make not much more than 1% difference in TCO. In this particular situation, that should be accommodateable in the pricing strategy and still leave room for healthy margins.
Thr 737NG is alleged to make 20% gross margin today.....
(quite rightly exploding the myth that narrowbodys are the low profit product lines by the way.......   )
XT6Wagon
Thu Jun 21, 2012 5:50 am
Quoting lightsaber (Reply 14):
I'm betting its the reverse. The new tail will have a dome for all versions removing the flat bulkhead from the 900ER. Only it will be smaller and farther aft than current. The flat bulkhead extracts a penalty in wieght. It appears that they are redoing the tail and the taper to the main fuselage cross section. This gives them the freedom to put a dome bulkhead where they want to instead of trying to make more room in the pressure vessel for passenger space with the current fuselage structure like they did with the 900ER. This may have had more do to with the need for adding the extra doors on the 900er since the frame was extremely space limited there for adding such structuraly intensive items.
regardless I can't wait to see what the new tail brings. I'd put money on three things.
1. Its going to be ugly
2. Its going to save truckloads of wieght and money
3. Airlines are going to love it.
ODwyerPW
Thu Jun 21, 2012 7:37 pm
Quoting XT6Wagon (Reply 30):
I wonder the same myself, put the pressure bulkhead further back in the taper...thereby regaining space and still have all of the advantages the flatbulkheat yielded for additional galley space, which enabled another row of seats. This would be adopted accross the 8 ,9 and 7. Would that subject the new taper to additional pressurization than the current one needs to endure? Perhaps the new tapered back end isn't just to clean up aerodynamics, but also servers to help with better interior space utilization too?
SEPilot
Thu Jun 21, 2012 7:57 pm
Quoting astuteman (Reply 29):
True; however I believe that both Boeing and Airbus are aiming for more than just improvements in fuel burn, which is why I said 5% total ownership costs instead of just fuel burn. As I understand it, right now the 737NG enjoys a fuel burn advantage over the A320 for short flights but the A320 has better fuel burn on longer flights. I have heard that the 737 is better on maintenance, but I do not know if this is true. What I do know is that since the NG's were introduced the sales race has been just about dead even, which says to me that the TCO is very close as well. While I do believe that this parity will ultimately be maintained by the NEO and the MAX, Boeing has lately shown an extraordinary ability to cock things up (although they have done very well with the 77W/L), and the 787 does appear to be on its way to being an outstanding plane. I am just hoping that they do better this time.
lightsaber
Crew
Thu Jun 21, 2012 11:00 pm
Thank you. I appreciate the heads up on the new tail.
Quoting SEPilot (Reply 32):
I've heard both. It depends on what is the high cost for the maintenance shop and which maintenance strategy is employed.
   But how much was driven by sales discounting? I suspect the profit pendulum will move a little between the two parties, but both will make a profit.
Lightsaber
WN787
Fri Jun 22, 2012 5:35 am
Ok so I'm still learning. What exactly is TCO?
astuteman
Fri Jun 22, 2012 6:19 am
Quoting WN787 (Reply 34):
Apologies WN787. Total Cost of Ownership...
Asiaflyer
Fri Jun 22, 2012 6:35 am
There will be a performance creep in Airbus favour over coming years, as firstly A320 sharklets will reduce fuel burn and secondly it looks at this moment like the larger fan diameter for the NEO will be favorable for Airbus as well.
Expect Boeing to counter with lower price in order to keep the 50/50 balance in market share.
SQ,MI,MH,CX,KA,CA,CZ,MU,KE,OZ,QF,NZ,FD,JQ,3K,5J,IT,AI,IC,QR,SK,LF,KL,AF,LH,LX,OS,SR,BA,SN,FR,WF,1I,5T,VZ,VX,AC,NW,UA,US,
XT6Wagon
Fri Jun 22, 2012 7:03 am
Quoting Asiaflyer (Reply 36):
Or you can say the reverse as the lower OEW per seat, newer wing design, more advanced winglet design, lower drag engine nacelles, and other advances weigh in for Boeing.
Really its going to boil down that for 99% of the carriers out there both would work just fine and one would be better than the other by such a small margin that it wouldn't pay to switch brands unless the price difference is higher than Boeing or Airbus SHOULD be offering.
That said I expect the A319NEO and 737MAX to be crap (and frankly shouldn't be offered). Their bigger brothers will be far better use of capital both for the manufacturers and the airlines. The 738MAX will wreck the A320NEO on short haul, with the A320NEO managing a modest margin at longhaul. The main advantage for the 738MAX being in its extra passengers bringing more money each trip that really can't be countered by a little difference in fuel burn. The A321 will reverse this with its larger size over the 739MAX making it the better choice. Long range economics are also more important here as this brings more of the 757 market to it which also helps the NEO more than the MAX. Yet it doesn't matter. It won't pay to switch horses in this race. I'm not sure it will even pay to stop having a split fleet for the airlines that already operate both.
tdscanuck
Fri Jun 22, 2012 12:05 pm
Expect Boeing to counter with incremental technology improvements; that's been the path of the 737 for the last 40 years and it's not going to stop now. Airbus, naturally, will do the same.
Tom.
NYC777
Fri Jun 22, 2012 1:50 pm
Check out this link as it is eye opening regarding this discussion:
http://www.strategicaeroresearch.com/2012/06/18/a321neo-737max9/
That which does not kill me makes me stronger.
seabosdca
Fri Jun 22, 2012 2:24 pm
Quoting NYC777 (Reply 39):
Subscribers only. Can you summarize the interesting bits?
Stitch
Fri Jun 22, 2012 3:20 pm
There will be a performance creep in Airbus favour over coming years...Expect Boeing to counter with lower price in order to keep the 50/50 balance in market share.
Airbus has enjoyed a performance edge over the 737NG on missions over 1000nm for the life of both programs and yet Boeing has consistently been able to sell 737NGs into those missions and command a higher average sales price while doing so.
Yes, much hay has been made about Boeing's 737 MAX launch discounts to their largest and most-influential customers, but Airbus has been equally aggressive in discounting the A320neo to their largest and most-influential customers.
The clear trend has been that while each platform has advantages over the other, it also has disadvantages and overall, the market generally has held steady at 50-50, with a few percentage points shift to either OEM from time to time.
WarpSpeed
Fri Jun 22, 2012 5:44 pm
Quoting Stitch (Reply 41):
While I tend to agree, the NEO was effective in busting the Boeing monopoly at American and Norwegian Air. These were huge victories in terms of the A vs. B narrow-body rivalry. While not announced, the expected narrow body order at United is said to be all Boeing, but one that will be won based on price (albeit a quote from John L.). If true, this would tend to bolster Asianflyer's assertion.
At any rate, winning based on price is no disgrace as long as the profit hurdle is maintained. Perhaps producing 737's at a higher rate has led to lower unit costs that allows Boeing to maintain profits at a lower unit price.
The upcoming JetAirways narrow-body order will be telling as it is an all 737 fleet that is considering the MAX vs. the NEO.
imiakhtar
Fri Jun 22, 2012 6:19 pm
Quoting seabosdca (Reply 40):
I wouldn't bother. StrategicAero is ran by our friend Saj Ahmed, formerly of Fleetbuzz Editorial. I would take anything he says with an Antonov-225 full of salt.
After all, he is the "analyst" who said the A330 was dead and Boeing was going to run Airbus out of the twin widebody market    .
Does anyone know what the current 737 production rate is?
Whatever happened to Leon Trotsky?
Stitch
Fri Jun 22, 2012 6:20 pm
Quoting WarpSpeed (Reply 42):
I still say American went with the A320 based on availability. They wanted to roll-over their entire MD-8x and 757 fleets in a short period of time and there was no way Boeing (nor Airbus, for that matter) could offer them the slots they needed. I expect the same is true of Norwegian, since they also placed a large 737 MAX order.
If the A320neo is so inherently superior, neither American nor Norwegian would not have ordered the MAX, to say nothing of adding more 737NGs. DL also would not have ordered the 737-900ER and UA would not have eliminated Airbus from their latest narrowbody RFP.
That appears to be the case. And Airbus' historically higher production rate has most likely helped them win orders on both price and availability while still protecting their cash flow (which has always been solid).
And industry speculation is that Airbus is offering a deep discount to win it, so Boeing will likely have to offer a deep one to keep them.
Quoting imiakhtar (Reply 43):
35 per month, trending to 38 next year and 42 by 2014.
[Edited 2012-06-22 11:48:46]
LAXDESI
Fri Jun 22, 2012 6:38 pm
Quoting Stitch (Reply 44):
Congested Indian airports, average stage length of less than 600 nm, and 12 seat advantage(2 class) of B738 Max should give it an edge over A320 NEO for domestic operations.
KDAYflyer
Fri Jun 22, 2012 6:53 pm
Sounds to me like both Boeing and Airbus have learned a thing or two from the issues arising from the A-380 and 787. This good news. Perhaps the NEO and MAX will both be on time and within budget. I give these two a far better chance of getting to market with much fewer problems than the A350.
yeelep
Haven't heard that, but it could very well be required to accommodate the new tailcone.
I'm betting its the reverse. The new tail will have a dome for all versions removing the flat bulkhead from the 900ER. Only it will be smaller and farther aft than current. The flat bulkhead extracts a penalty in weight. It appears that they are redoing the tail and the taper to the main fuselage cross section. This gives them the freedom to put a dome bulkhead where they want to instead of trying to make more room in the pressure vessel for passenger space with the current fuselage structure like they did with the 900ER.
Quoting odwyerpw (Reply 31):
I wonder the same myself, put the pressure bulkhead further back in the taper...thereby regaining space and still have all of the advantages the flatbulkheat yielded for additional galley space, which enabled another row of seats. This would be adopted across the 8 ,9 and 7. Would that subject the new taper to additional pressurization than the current one needs to endure? Perhaps the new tapered back end isn't just to clean up aerodynamics, but also servers to help with better interior space utilization too?
I don't see were they would get the room to move a domed pressure bulkhead further aft than the current one. The horizontal stab jackscrew is only a foot or two aft of the current one. I could post a pic. of the area tomorrow if anybody is interested.
It'll be interesting to see how far Boeing goes with the changes. Hopefully my company buys some.
Hamlet69
Fri Jun 22, 2012 7:09 pm
Only if your assumption is that Airbus's wins at AA and DY wasn't based on price and financing. Which, at best, is naive.
Hamlet69
All gave some. Some gave all.
WarpSpeed
Fri Jun 22, 2012 7:11 pm
Put in context, let's remember that American ordered the MAX on promises because it was effectively launched at the press conference announcing the split order.
Note, I did not say or imply that the NEO was inherently superior. Rather, I explicitly noted that it was "effective" in busting open some all Boeing fleets. Perhaps this would not have happened if Boeing had had greater clarity about the MAX's actual performance and availability during those campaigns.
Besides, as you note about the AA order, the DL order may have been more about price/availability than capability. But, it is very interesting that it came shortly on the heels of the AA split order. I believe Delta is on record saying that it received a very good price.
UA is really Continental management; which has always favored Boeing and will likely receive Boeing's best deal. Again, pricing can undercut an apples to apples capabilities assessment. Further, until announced, who knows what will happen with this order.
I understand these campaigns are not clear cut, but I don't think we've seen a case in which the 737 has penetrated an all A320 fleet on such a scale as AA and Norwegian. That, is a telling statistic. Boeing to this day is playing catch-up. Advantage Airbus in the narrow-body market...for the time being...
