Liverpoola380
BA - BMI Domestic T1 And T5
Wed Jun 27, 2012 11:31 am
Since the integration of BMI to BA I have flow from both T1 and T5 and as I am sure most of you will be aware T5 is a far superior experience.
Is it likely that BA will retain any domestic ops in T1 impacting on connections or will all domestic be transfered to T5?
With the introduction of a new route to Leeds what kind of impact will this have on an already full T5 are we likely to see Euro flights or Long haul moved to other terminals?
LHRFlyer
RE: BA - BMI Domestic T1 And T5
Wed Jun 27, 2012 11:41 am
The latest terminal moves have just been confirmed:
http://press.ba.com/?p=2343
A number of existing British Airways routes including Basel, Dusseldorf, Luxembourg, Lyon and Toulouse will move from Terminal 5 to Terminal 1 on October 28.
All flights to Aberdeen, Edinburgh and Manchester will operate from Terminal 5 from the winter season.
Belfast is to stay in Terminal 1 and Leeds Bradford is reported to be staying in Terminal 1.
[Edited 2012-06-27 04:50:54]
Liverpoola380
Wed Jun 27, 2012 11:52 am
Perfect timining.
Thats good that domestic will be retained in T5
Does anybody know what BMI load factors from MAN to LHR have been like will there be an upgauge are we more likely to see a number of 321's or will they pile us in to 319's and 20's
eicvd
Wed Jun 27, 2012 12:45 pm
Quoting LHRFlyer (Reply 1):
I take it DUB will stay in T1 aswell then?
COYBIB
Liverpoola380
Wed Jun 27, 2012 1:00 pm
I doubt they would put Leeds Bradford into T1 that will surely be counter productive!
vv701
Wed Jun 27, 2012 1:06 pm
Quoting liverpoola380 (Thread starter):
It is likely that some domestic BA operations will remain at T1 at least until T2 is completed. This is because the facilities for domestic arrivals and departures and those to and from the CTA (Common Travel Area - Republic of Ireland and the Channel Islands) are different to those used for international arrivals and departures. As far as I know T5 does not have sufficient facilities to handle all the new BA domestic and CTA flights and T1 would be more than half empty with no domestic / CTA flights and far from full if EI was the only operator of domestric and CTA flights there
If this situation will change when or after T2 is completed I do not know.
To illustrate the above according to the table on page 3 of the " LHR S12 Start of Season" report here:
http://www.acl-uk.org/reportsStatistics.aspx?id=98&subjectId=33
T! has the capacity to handle up to 1,500 domestic and 930 CTA but only 1,600 international passengers an hour. I very much doubt BAA would be prepared to see T1 domestic and CTA flights reduced to those only operated by EI any time soon.
AIR MALTA
Wed Jun 27, 2012 1:42 pm
Quite some exicting news from BA with the addition of Leeds and Zagreb... And there might be more to come.
From what I see, they are starting to conolidate domestic services which is good. The question is, are they already releasing the slots that are needed by the competition to start routes to Scotland?
I am also suprised they are keeping Agadir al LHR but moving RAK to LGW...
Other than that, it seems that BA is counter attackiing easyJet on routes to NCE and BCN? What about other routes to Spain? And what about TUN and ALG. They do deserve a LHR connection IMHO.
The next months are going to be exciting. I am looking forward to see what's going to happen to all ex BMED routes.
Next flights : BRU-ZRH-CAI (LX)/ BRU-FCO-TLV (AZ)
madhatter
Wed Jun 27, 2012 2:03 pm
Has it been confirmed that Marrakech is moving from LHR to LGW (it would explain why Gatwick is going from 3w to daily).
Also it seems a bit weird to move Agadir to T5 but to have Casablanca remaining at T1.
Is there any announcements re the current dual terminal flights (Edinburgh, Aberdeen, Manchester, Nice). Will they remain in T1 and T5 or all move to T5 in their entirety?
LHRFlyer
Wed Jun 27, 2012 2:14 pm
Quoting madhatter (Reply 7):
As above Aberdeen, Edinburgh and Manchester will all operate from Terminal 5 next season.
You can check each destination here:
http://www.britishairways.com/travel...nter-flights-schedule/public/en_gb
AIR MALTA
Wed Jun 27, 2012 2:17 pm
Edinburgh is getting some 767s... Yaaay... Time to head to Edinurgh then!!!
AIR MALTA
Wed Jun 27, 2012 2:34 pm
You should may be change the tiopic name to BA/BMI Integration: next step!
Liverpoola380
Wed Jun 27, 2012 2:41 pm
Quoting AIR MALTA (Reply 9):
I think they are more likely to be utilising the 7 A321's coming across from BD
skipness1E
What stands at T5 have access to UK Arrivals? Is it 501-506 only? Also skytrax is full of moans about passengers arriving on these stands and being bussed to International Arrivals, I thought they were multi use and passengers could be streamed to the required arrivals route and still remain sterile. ( in the security sense, not eugenics!)
AIR MALTA
Wed Jun 27, 2012 2:46 pm
Quoting liverpoola380 (Reply 11):
That's what is mentioned on ba.com
"From 28 October 2012 all flights to Edinburgh will operate from Heathrow Terminal 5. There will be up to 12 flights per day, and larger Boeing 767 aircraft will be used on selected services.
Your flight number may also be changing, in which case you will be contacted soon with more information."
aidoair
Wed Jun 27, 2012 2:53 pm
Quoting liverpoola380 (Reply 4):
It is currently showing in the booking system as operating to/from LHR T1.
From what I have seen so far the majority if not all BA flights from T1 from the 28th October will operate on A319. I guess this standardises the operation from this terminal and thus the freed up larger A320/1's move over to ex-A319 routes over at T5.
mikey72
Wed Jun 27, 2012 2:56 pm
Quoting AIR MALTA (Reply 13):
That's worth a 'wow'
767 on UK domestic...who'd have thought !
Flying is like sex - I've never had all I wanted but occasionally I've had all I can stand.
TCX69K
Wed Jun 27, 2012 2:59 pm
The bmi A321's are in the process of having flatbeds put on so they will be used predominantly or exclusively on midhaul routes only.
rutankrd
Wed Jun 27, 2012 3:00 pm
Quoting aidoair (Reply 14):
I suspect the reason for the ex bmi 319s remaining within T1 is that they a bulk loading rather than containerised machines making T5 operations a headache.
AIR MALTA
Wed Jun 27, 2012 3:02 pm
Quoting mikey72 (Reply 15):
I hope one of the morning flights will get it so that you'll enjoy the 767s and the full English Breakfast
fcogafa
Wed Jun 27, 2012 3:20 pm
Why has it gone so quiet on who will be getting the relinquished slots?
Tobias2702
Wed Jun 27, 2012 3:28 pm
Quoting VV701 (Reply 5):
T1 has the capacity to handle up to 1,500 domestic and 930 CTA but only 1,600 international passengers an hour. I very much doubt BAA would be prepared to see T1 domestic and CTA flights reduced to those only operated by EI any time soon.
Am I missing something here? I've just done a rough capacity check by counting passenger seats offered per day on flights departing from Terminal 1. The result is: 8,800 domestic/CTA and 22,000 international. The above post implies that both numbers should be approximately equal.
PA, AF, UK, BA, AB, DL, LH, FR, BD, A3, EZY, DY //// A319/320/346, B733/735/73G/738/744/763, AT4, 146, CR2, DH4
rutankrd
Wed Jun 27, 2012 3:32 pm
Quoting fcogafa (Reply 19):
Because the terms and framework of the bidding process hasn't been formalised.
And how many competitors have actually expressed an interest in
LHR-DME
LHR-NCE
LHR-EDI
LHR-ABZ
LHR-CAI
None formally and only waffle from VS and perhaps something from the new owners of bmiRegional
This may be something for the autumn timeframe with 2013
Liverpoola380
Wed Jun 27, 2012 3:37 pm
Quoting TCX69K (Reply 16):
I didnt know this was going to happen are they similar to the 318 beds ?
rutankrd
Wed Jun 27, 2012 3:39 pm
Quoting liverpoola380 (Reply 22):
No they are Swiss design i believe and are at Donnington in a shed.
Wed Jun 27, 2012 3:40 pm
- Since bmi dropped GLA, BA have been using 767's on selected services, so nothing new here.
Pe@rson
Wed Jun 27, 2012 3:46 pm
I have been meaning to return to EDI.
Does anyone yet know when the 763 will operate on the route?
bwaflyer
Wed Jun 27, 2012 3:49 pm
Quoting rutankrd (Reply 23):
Yup - Swiss business seats (23 x Thompson Aero). First aircraft (G-MEDU) is in the hangar and will start operations on 14th July. All new slim line economy seats (131 x Geven “Piuma”) and Thales IFE. New lighting, galleys, carpets and curtains as well. Rumours are they will operate a mix of bmi mid haul routes and current BA routes. Daily AMM, BEY, GYD (continues 3x week to ALA), EVN/IKA, replaces BA metal on CAI and 3x daily TLV. Although by my reckoning that needs 8 aircraft rather than the 7 moving across.
sq_ek_freak
Wed Jun 27, 2012 4:50 pm
Quoting bwaflyer (Reply 26):
Any chance we can get pictures of the seat designs posted? For the Biz seats, I don't believe I've seen any of that model fitted on a narrow body! Will be a very nice ride for sure. With the staggered seating, does that make the arrangement effectively 1-1?
Thales IFE
Is this the same system on the BA 77W?
[Edited 2012-06-27 09:53:48]
Keep Discovering
skipness1E
Wed Jun 27, 2012 5:22 pm
Quoting ba319-131 (Reply 24):
They were pulled from the summer schedule as they are pushed through a cabin refresh as they are really looking tired inside.
Why are some BMI A319s not containerised? Incidentally the A319/A320 /A321 split on ba.com is notoriously unreliable. I only really know at online check in.
rutankrd
Wed Jun 27, 2012 5:35 pm
Quoting skipness1E (Reply 28):
Perhaps bmi didn't see think the additional cost of equipment and weight of containerisation was worth it on their network.
The general split of A32x models and routes is surely intentional to allow scheduling flexibility across the network.
ScottishLaddie
Wed Jun 27, 2012 5:47 pm
Quoting Pe@rson (Reply 25):
Rumoured to be 2 flights a day, don't know specifics beyond that yet though.
Tristarsteve
Wed Jun 27, 2012 5:56 pm
Quoting ScottishLaddie (Reply 30):
About two a day to EDI and GLA, including nightstops at both.
The same flight number will change from A319 to A320 to A321 on a daily basis. Not surprising that ba.com can't catch up.
But ba.com will shoe A319 on all flights more than 4 months ahead.
It appears that all the ex-BMI A319 and A320 will stay on T1 and operate their own routes, like a separate little operation.
BritishB747
Wed Jun 27, 2012 6:20 pm
Quoting AIR MALTA (Reply 18):
Got this when I was on a morning flight from Glasgow back in January. Altered my plans to fly from Glasgow rather that Edinburgh just to go on a B767.
AT7 AB6 319/20/21 33V 343 346 AR8 737/3/4/6/G/8 744 752 753 763 77W 788 BET D10 D38 DHT DH4 E70 E75 F70 J41 M83
raffik
Wed Jun 27, 2012 6:53 pm
The A321s J cabin will be configured 1 -2 rather than 2-2
- Alec
FlyingHollander
What's BA's plan for the coming years concerning terminal use, as BA's ops are only likely to grow? One thing that's nice about T5 is that it is a dedicated terminal. Kind of a shame that it can't handle all ops though.
If it ain't Dutch, it ain't much.
vv701
Wed Jun 27, 2012 8:01 pm
Seat Guru at:
http://www.seatguru.com/airlines/BMI/BMI_Airbus_A321_B.php
says that of the seven BD 321s , four had IFE systems in the seat back "not all with Audio Visual on Demand" while the other three had "overhead video projects [sic]" .
Does anyone know which aircraft has (or, in the case of G-MEDU, had) which IFE system?
raffik
Wed Jun 27, 2012 8:16 pm
All of the new A321s will be fitted with AVOD Thales system. I flew to Beirut with GMEDJ and that had inseat monitors but not AVOD.
Does anyone know if Beirut flights will continue in and out of T1?
- Alec
steve6666
Wed Jun 27, 2012 9:12 pm
Quoting FlyingHollander (Reply 34):
By 2015, BA will have exclusive use of Terminals 1, 2, 3, 4 and 5. All other airlines except American, Iberia and Qantas will move to a new terminal, called Gatwick. Or Stansted.
Erm. Seriously, I suspect that this is the subject of some fairly serious discussions at the top level in BAA and BA. Presumably one of the difficulties at the moment is that the future state of the fully integrated business with the right fleet/route network/frequency (more long haul replacing BMI short haul aircraft etc) is not yet final so exactly what gate capacity they need where may not be settled.
A306, A318, A319, A320, A321, A332, A333, A343, A346, A388, B722, B732, B733, B734, B735, B73G, B738, B742, B744, B752, B753, B762, B763, B764, B772, B773, B77W, B787-8, BAe-146, Cessna Something, DC-10, E175, E195, ERJ145, MD-11, MD-80, PA Something
LH121GLA
Wed Jun 27, 2012 9:16 pm
Not really a new concept. 767 used to operate both routes 15-20 years ago as well as GLA more recently.
Tristarsteve
Wed Jun 27, 2012 9:33 pm
Quoting raffik (Reply 36):
Not announced yet, but extremely unlikely.
Beirut will be operated by the ex BMI A321s, which will also operate TLV and CAI, so I would expect them to be in T5
Eljonno
Wed Jun 27, 2012 9:45 pm
Quoting steve6666 (Reply 37):
Wow! Can't wait to see that!! Would make immigration queues at the South Terminal very unpleasant indeed, I should imagine....
Theoretically though, would LGW have the available infrastructure and capacity for this to be possible? Would such an arrangement actually benefit anyone (apart from the accountants and shareholders of GIP)? I am no expert, but I should imagine the value of LHR comes from having BA there as a hub carrier, along with the feed from other airlines; that is, a situation which would not exist at either LGW or LHR if this scenario was played out.
[Edited 2012-06-27 14:45:58]
[Edited 2012-06-27 14:46:50]
bwaflyer
Wed Jun 27, 2012 9:50 pm
Quoting VV701 (Reply 35):
G-MEDF/G/H/J
Rockwell Collins 8 channel video based PTV in business, overhead flip down screens in economy
G-MEDK/L
Thales AVOD PTVs in business, looped films and TV programmes on PTV in economy
G-MEDM/N/U
Thales AVOD PTV in business and economy
New IFE system on G-MEDF/G/J/L/M/N/U is Thales i5000. A320s G-MEDH/K changed to short haul configuration
Captaindoony
Thu Jun 28, 2012 1:24 am
BA actually pulled the 763 off the GLA run not too long after introduction.
Just as a quick question - could BA put a 763 on the likes of MAN/ABZ on a one off basis?
vv701
Thu Jun 28, 2012 2:54 am
Quoting bwaflyer (Reply 41):
Many thanks.
BritMidFokker
Thu Jun 28, 2012 4:19 am
Quoting CaptainDoony (Reply 42):
IIRC BA 767's did used to fly LHR-MAN in the mid 90's. Not sure if they were simply positioning aircraft between long haul flights ex MAN (we had at least MAN-JFK running back then) or if they were used due to loads. BD didn't operate LHR-MAN back then. I guess it would be possible in the future if loads required.
ABZ again would be possible, but BD used to use the E145 quite a lot on this route, jumping to a 767 would be a huge leap in capacity.
djb77
Thu Jun 28, 2012 5:47 am
ABZ has seen BA 763s in the past on the LHR run. Not often but it has happened. I flew one once, back in 1998 - first morning flight out to LHR, it had overnighted. At LHR, I got back on the same BA 763 with some of the same crew and flew to FRA.
adg737800
Thu Jun 28, 2012 7:04 am
BA did use 767s in the mid 1990s between LHR and MAN on a mid morning round trip. I flew a few times on them and they were almost always full. The crew also did a full meal and bar service too - hard work on a 35 minute flight! They were short haul configured 767s so I think it was purely based on demand rather than for rotating the MAN based 767.
thijs1984
Thu Jun 28, 2012 7:14 am
Quoting AIR MALTA (Reply 6):
I expect the flights to RTM to be announced shortly. Slots (and flight schedule) have been allocated at Rotterdam - The Hague Airport previous week.
3 x Daily A319
AIR MALTA
Thu Jun 28, 2012 7:32 am
Quoting Thijs1984 (Reply 47):
3 x Daily A319
That's a lot of capacity for RTM...
Sydscott
Thu Jun 28, 2012 7:59 am
I would have a thought a terminal 5D would be in order either way?
