How Many FL 73Gs Converted To WN?
Thu Jun 28, 2012 9:04 pm
Hi !
How many FL 73Gs have been converted to WN ? Are they flying any specific routes or any WN route ? Any difference in configuration ?
Thanks for any info !
zippyjet
RE: How Many FL 73Gs Converted To WN?
Thu Jun 28, 2012 9:07 pm
I know of one so far but that was as of a few weeks back.
I'm Zippyjet & I approve of this message!
sunking737
Thu Jun 28, 2012 9:09 pm
Quoting The777Man (Thread starter):
Hi !
IIRC about 5 with new Evo interior??
Just an MSPAVGEEK
QANTAS747-438
Thu Jun 28, 2012 9:21 pm
Hard to say... basic answer is no, it's a -700 and will fly any route to any city needed. It can be swapped out with any plane, except for an -800. However, it does hold 143 and may get special treatment to be placed on certain routes such as LAX-MDW, LAS-BWI, etc, where WN can fill every seat no matter how many seats they put on a plane.
Nope, it'll be 143 seats on board with the new Evolve interior. A WN 737 with the new interior will look the same as a converted FL 737.
Thu Jun 28, 2012 9:47 pm
Thanks for the info!
So only one so far ? Any idea how many that will be done by the end of the year ?
These converted 73Gs are flown by any crew or mainly ex-FL crew ?
Thenks !
n471wn
Thu Jun 28, 2012 9:49 pm
I show 4 FL 737's now converted
QANTAS747-438
Thu Jun 28, 2012 9:54 pm
Quoting The777Man (Reply 4):
They are now WN planes flown by WN pilots on WN routes. The converted plane's life with FL is over once it goes into the hangar.
southwest737500
Thu Jun 28, 2012 10:55 pm
Quoting QANTAS747-438 (Reply 6):
What happens to the pilots are they now WN pilots
Next flight: TUL-ATL-CLT CRJ900 and MD88
Caspian27
Fri Jun 29, 2012 3:37 am
Quoting southwest737500 (Reply 7):
My question as well. Is there anything contractually that prevents WN from possibly moving every FL aircraft over and then just furloughing FL pilots? Moving planes over before you have the lists integrated seems like a bad deal for FL pilots.
Meanwhile, somewhere 35,000 ft above your head...
Atlwest1
Fri Jun 29, 2012 3:45 am
They use a formula for each plane it takes x amount of crew fa and captain to operate that plane. There is 1-2 classes in Dallas training now who are former FL. As they take over more planes more will go over. F/a's is 375 for this year (though rumor has it maybe more possibly) and more pilots are going over as the MKE pilot base closes they will head over which is causing a bit of hub bub with pilots in other bases.
Quoting Caspian27 (Reply 8):
List is "integrated" they just haven't all moved over yet as FL has to continue operating for the near future. Also if any Airtran Pilot or flight attendant is furloughed then they cannot hire anyone new from the street into those respective positions till all the FL people are back so it would hamper the expected growth not to mention go against everything they have said since this deal has been announced
ALL views, opinions expressed are mine ONLY and are NOT representative of those shared by Southwest Airlines Co. or Airt
bmibaby737
Fri Jun 29, 2012 9:16 am
Courtesy of Planespotters the four aircraft that have so far transferred over are:
N126AT -> N7714B fn7714 Y143 lsf GECAS, rr 15 March 2012
N166AT -> N7702A fn7702 Y143 rr 11 April 2012
N288AT -> N7726A fn7726 Y143 rr 14 June 2012
N292AT -> N7730A fn 7730 Y143 rr 13 June 2012
Mon Jul 02, 2012 5:41 am
Quoting bmibaby737 (Reply 10):
How many are expected to be transferred by the end of the year ? When is the process supposed to be complete ?
Thanks !
Lars
Josh32121
Mon Jul 02, 2012 12:43 pm
So they're changing the registration numbers, too? Sheesh...really making a point to bury any trace of FL's identity, eh?
lucky777
Mon Jul 02, 2012 1:02 pm
What on GOD's green earth is taking this merger/acquisition so much time to get rolling....at this point in the process Delta had all of the former NWA planes repainted and all of the signange changed out. I realize more often than not airline mergers are a slow and tedious process, but this one seems to be moving at a glacial pace.
usflyguy
Mon Jul 02, 2012 1:22 pm
Quoting lucky777 (Reply 13):
DL and NW were very similar airlines with very similar products, WN and FL not so much. The integration of the two companies is moving right along. Just about all of the work groups have single senority lists and a good chunk of HQ employees are WN employees now.
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
Josh32121
Mon Jul 02, 2012 1:31 pm
lucky777
Mon Jul 02, 2012 2:14 pm
Quoting usflyguy (Reply 14):
I'm really speaking of the things the general public see on a daily basis...planes/signage specifically.
wwtraveler99
Mon Jul 02, 2012 3:06 pm
Quoting lucky777 (Reply 16):
Because FL and WN will each be run separately until all planes are converted. A big reason for it slowing down is that the WN and FL reservation systems cannot talk to one another. This will be corrected with the help of Amadeus. Also WN needs the current FL res system to continue to make and operate international reservations and flights.
WW
ADent
Mon Jul 02, 2012 4:25 pm
While there are many issues, it seems to be computer reservations systems are the main problem.
Neither system allows code sharing/interlining. So you can't book a FL flight and have it show up in WNs system (or vice versa) - like CO/UA operated until March of this year.
WNs system is old and antiquated and publicly admitted to being a hindrance in a lack of international flying and even international code shares.
FLs system is much more modern, but from what I hear here a down level (older, less features) version of a modern res system. Several people has asked why can't FL just upgrade to the newer version - but I have not seen a good reason.
My guess is they would have to upgrade FL to the later system, then migrate all of WN to FLs system, then move the data center from ATL to DAL - I think the folks in DAL want to upgrade their system, then migrate all of FL on to WNs system.
It has been publicly announced that code sharing won't happen until 2013 - and until then FL and WN need to be stand alone airlines.
Josh32121
Mon Jul 02, 2012 4:54 pm
Quoting ADent (Reply 18):
That's the most unacceptable part. I know IT systems can't be integrated overnight, but the fact that it's taking years and that it seems no one in charge of the deal realized what a big deal that was is truly mind-boggling. I really can't believe more heads haven't rolled because no one seemed to ask enough questions on that front when the deal was being hammered out.
aeroblogger
Mon Jul 02, 2012 5:03 pm
Not true. FL's system does.
Once again, not true. CO and UA were codesharing long before March.
Airports 2012: IXE HYD DEL BLR BOM CCU KNU KTM BKK SIN ICN LAX BUR SFO PHX IAH ORD EWR PHL PVD BOS FRA MUC IST
lucky777
Mon Jul 02, 2012 5:12 pm
That's the most amazing part of all this. It will be around 3 years since the buyout was announced before there's even code sharing between the 2 (or is it 1?) airlines....we're probably looking at sometime into 2015 before the former Airtran ceasese to exist for all intents and purposes. For an airline that seemed to be so efficient and well-run before this buyout, i can't help but think Southwest didn't do enough due dilligence ahead of time regarding this apparent boondogle.
727LOVER
Mon Jul 02, 2012 5:58 pm
Just curious, why is WN changing the regs? The only mergers in the USA that I can recalll that did that was any of the multiple USAir/US Airways mergers.
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
aeroblogger
Mon Jul 02, 2012 6:22 pm
It's a buyout, not a merger.
INFINITI329
Mon Jul 02, 2012 6:58 pm
Quoting 727LOVER (Reply 22):
Some registrations numbers were duplicated. Such as N949AT & N949WN. Internally we track our planes by the tail number and the tail number up until recently matched the registration. But that system is now changing due to the acquisition along the amount of aircraft coming online.
-Infiniti
