KarlB737
IAH Installs Boarding Bridge For A380 Flights
Sat Jun 30, 2012 3:42 pm
In a previous A-Net thread titled "LH A380 FRA-IAH To Begin In August" it was pointed out the fact that new LH A-380 flights would begin on August 1, 2012. The link for that thread which is now archived and can't be replied on is here:
IAH+A380+#ID5327236" target="_blank">http://www.airliners.net/aviation-fo...chid=5327236&s=IAH+A380+#ID5327236
Obviously the date for the A-380's arrival is rapidly approaching. A specific A-380 boarding bridge is now under construction to meet this need. The writeup on this installation is here:
Courtesy: Aviation Pros
"A specially designed jet bridge that makes a curving sweep to reach the upper deck, 26 feet from the ground, arrived at Bush Intercontinental on Wednesday from a factory in Fort Worth and was installed immediately."
http://www.aviationpros.com/news/107...s-boarding-bridge-for-a380-flights
Lastly, I wonder if some of you could list what US airports have A-380 capable jetways and what other US airports that will be getting that capability. I fully realize that at this point the list will be extremely short.
aznmadsci
RE: IAH Installs Boarding Bridge For A380 Flights
Sat Jun 30, 2012 3:50 pm
Quoting KarlB737 (Thread starter):
There's a YouTube video of it being built via computer graphics: IAH's Terminal D is Getting Ready for the A380
While the new jetway is for upper deck passengers, I'm excited I get to check this out at the end of August when I take the LH A380 flight!. Am surprised they're using D12 instead of D4/D4A/D5, unless that took too many gates out during a busy time at Terminal D.
jporterfi
Sat Jun 30, 2012 3:59 pm
Airports with A380-capable jetways:
ATL
IAD
JFK
LAX
MIA
SFO
I'm sure there are some that I'm missing, so please add to this list if necessary.
Max Q
Sat Jun 30, 2012 10:54 pm
They will need more than one for IAH now UA is pulling out of Paris.
I could see AF with the A380 in there quite soon.
EK413
Sun Jul 01, 2012 12:25 am
Quoting aznmadsci (Reply 1):
I've noticed the US boarding gates for A380s only have 2 bridges as opposed to 3 in SYD, MEL and other International ports which service the A380 on a daily basis...
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
nra-3b
Sun Jul 01, 2012 1:21 am
The new Tom Bradley (West) International Terminal A380 capable gates at LAX will have 3 jetways. One for the upper deck and 2 for the lower. Not sure exactly how many gates in total will be A380 capable, but certainly a bunch more that the 2 we have now.
http://www.earthcam.com/clients/lax/?project=cam1&page=pano
click panorama to get it to load......
looks like some are already installed.
Bob
as739x
Sun Jul 01, 2012 1:47 am
Quoting EK413 (Reply 4):
SFO has two gates with 3 jetways. I'm sure other US city's have the same.
Josh32121
Sun Jul 01, 2012 2:33 am
Quoting jporterfi (Reply 2):
ATL
Which gate(s) at ATL is/are A380-capable? Right now, I don't know of any gates with more than one jetway--even at F.
In general, it seems that non-U.S. airports are far more likely to have multiple jetways for single aircraft than U.S. airports.
ua767400
Sun Jul 01, 2012 2:53 am
Quoting Max Q (Reply 3):
I doubt we will see the A380 by AF...mostly because we only have one gate that is capable of handling the A380
drerx7
Sun Jul 01, 2012 3:24 am
Quoting UA767400 (Reply 8):
And AF 380s as well as 744s are more Y heavy. If anything you would see the 2nd AF flight back.
Third Coast born, means I'm Texas raised
SurfandSnow
Sun Jul 01, 2012 3:32 am
WOW! LH's A380 flights are already 70% booked through October?!? Clearly the Houston market is ready to support this service. LH can probably expect to make a killing off those last-minute (oil/energy) IAH business pax...
Interesting that IAH is LH's 4th U.S. market to see the A380, but the first to receive year-round service while JFK, MIA, and SFO only see it seasonally. It still amazes me that ORD has yet to see any 748 or A380 service from LH...
TWA772LR
Sun Jul 01, 2012 3:45 am
I go by Terminal D every day and construction really went by fast. Last I saw they had the entire jet way built so I guess they were hooking all the electronics and other systems up for testing. Also, they tore up some concrete at D12, most likely to support the immense weight. Great times ahead!
aznmadsci, thanks for the video!  Smile LH comes in at a huge peak time for Terminal D, and most of the heavies wings' spread into other gates. D12 is like a corner lot in the average suburb, so it has the most ramp space.
[Edited 2012-06-30 20:50:59]
"The only man who never makes mistakes is the man who never does anything." ~~Theodore Roosevelt
EK413
Sun Jul 01, 2012 4:27 am
Quoting nra-3b (Reply 5):
Quoting as739x (Reply 6):
Cheers... I do recall SFO was one of the 1st US ports to have A380 capable bays...
EK413
Gemuser
Sun Jul 01, 2012 4:29 am
What do you mean by this? IAH only has one B744 capable gate? Or do you mean only one gate with multiple bridges? In the later case I would to point out that multiple bridges are NOT NECESSARY, although they are convenient to have.
Quoting TWA772LR (Reply 11):
The A380 actually requires LESS concrete strength than the B744, A346 & B777, because its greater weight is spread over more wheels. The B77W /A346 actually require the strongest concrete for airliners today.
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
ua767400
Sun Jul 01, 2012 4:46 am
Quoting gemuser (Reply 13):
Only one gate that is capable of handling the A380 as of now talking about ground markings and being able to get the other international aircraft lined up, butI am not referring to having the multiple bridges.
aznmadsci
Sun Jul 01, 2012 6:57 am
I had mention D4/D4A/D5 as the possible A380 gate because LH used to dock there and they had tried to extend D4A to reach the upper deck. Despite the distance between D3 and D4 is a ways, I guess the wingspan of the A380 and the position of the plane to use those 3 gates would occupy too much space during a heavy time. But it would be nice to drive through to see that big boy while driving up to IAH.
Quoting SurfandSnow (Reply 10):
Is the IAH service year round? I thought it was from August to October and would then return to SFO/IAD.
Is ORD or LAX the airport to see the 748?
ua767400
Sun Jul 01, 2012 1:11 pm
Quoting aznmadsci (Reply 15):
LH A380 service is year round. They just announced we are going to get year round
Also, you are correct it would occupy way too much space during rush hour as there will be 1-2 747s (I can't remember what BA is), and 4 777s that can overlap all at one time.
AVENSAB727
Sun Jul 01, 2012 2:30 pm
I cant wait, I thought it was going to be seasonal but year round service is even better, I hope to fly on it soon. When should the construction on terminal D for the A380 be completed?
Always look on the bright side of Life!
ua767400
Sun Jul 01, 2012 2:38 pm
Quoting AVENSAB727 (Reply 17):
There is a chance that it could always go seasonal as it will depend on demand.
I believe I heard mid July or so, but there is a lot of prep that needs to be done that includes widening taxiways.
AVENSAB727
Sun Jul 01, 2012 3:58 pm
Lufthansa said it will be year round, there is a reason for that, market here is ready for that.
airbazar
Mon Jul 02, 2012 2:30 pm
Just about every airport has A380 capable jetways. I suspect you're refering to uppder deck jetways, specifically.
When the A380 diverts to BOS for example, they block an adjacent gate and use the standard lower deck jetways.
NW
Mon Jul 02, 2012 3:33 pm
Delta is trying to secure the first few D gates.
iahflyer
Mon Jul 02, 2012 3:45 pm
Speaking of sort-of rare things coming to IAH. If UA were to bring a 747 into IAH, mentioned for use to NRT, where would it go to, D or E? More importantly, how would it affect things, if were to go to E? I know D can handle it, as long as there is room of course.
Little airports with the big jets are the best!! Floyd
drerx7
Mon Jul 02, 2012 3:55 pm
Quoting iahflyer (Reply 22):
Well...if it came on a NRT routing then there is room at D for it at that time of day. Now E...it would have to be on E7 or something along those lines and it may block an adjacent gate. It definitely would pose a problem in the alley.
Josh32121
Mon Jul 02, 2012 4:44 pm
Quoting NW (Reply 21):
Um, why does DL want gates on D at IAH? Am I missing something? Is this some new theory that DL wants to build an Int'l operation out of IAH to recapture those LOS customers lost to UA?
AVENSAB727
Mon Jul 02, 2012 4:50 pm
Quoting Josh32121 (Reply 24):
Could this mean the DL is taking up the void left by these so called 10 percent cuts to IAH?
drerx7
Mon Jul 02, 2012 4:57 pm
NO
Quoting AVENSAB727 (Reply 25):
NO
This is because DL actually has a decent sized Skyteam operation...as far as spoke cities go. They feed alot onto Aeromexico, KLM, and AF at IAH. Moving into D1-D4 makes for seamless Skyteam connections. This would also leave A to UA's disposal which will come in handy during the Terminal B reconstruction. Air Canada is already at A. If they do move to D this would leave Alaska over on A North and UA Express dominating the rest of the north side. IIRC there was some contention between UA and DL on this matter...that could be different now though.
FedExFlyerPHL
Mon Jul 02, 2012 4:59 pm
I believe LH's 748s will be coming to LAX this summer sometime if I remember correctly.
Jeff
Home base: SNA, LGB, LAX
Josh32121
Mon Jul 02, 2012 5:01 pm
Quoting drerx7 (Reply 26):
I don't have any data to dispute your statement, but where, oh where, do these connecting passengers come from?? LAX? SLC? ATL? I'm honestly stumped.
If anything, it sounds like they'd move because it made financial sense--not to improve the SkyTeam connection situation at IAH.
AVENSAB727
Mon Jul 02, 2012 5:04 pm
Now since the A380 comes in less than a month, how many spotters will be at the airport to see it arrive? I plan on going there hopefully.
drerx7
Mon Jul 02, 2012 5:07 pm
Quoting Josh32121 (Reply 28):
Why would it make financial sense to move from one side of IAH to the other...?
They come from CDG/AMS and beyond. Skyteam from IAH flies to MEX, SEA, CDG, AMS, SLC, ATL, MSP, MEM, LGA, CVG, DTW, and not to mention the interlining that happens, but specifically from Skyteam they carry a healthy amount of transfer traffic at IAH.
[Edited 2012-07-02 10:16:28]
Josh32121
Mon Jul 02, 2012 7:11 pm
Quoting drerx7 (Reply 30):
If DL got a good deal for swapping out its gates in A for the ones in D...lower lease rates, a swap for UA gates at another airport, etc.?
Yes, I realize there are a number of SkyTeam destinations to/from IAH, but very few of them turn IAH into a logical connection point--particularly when DL is the only US domestic carrier to carry those passengers onward. You really mean to tell me someone would fly AMS-IAH-CVG or CDG-IAH-MSP when connections via numerous other cities in DL's network or nonstop service make far more geographic sense. Perhaps MEX-IAH-, but how many people is that, really? I don't doubt that it happens; I just think the argument that it justifies DL relocating its IAH ops. is far-fetched.
Regardless, it sounds like LH will have no trouble filling up an A380 to FRA every day since it is a *A to *A hub flight. It should be a no-brainer and does underscore the question of why it hasn't shown up on FRA-ORD yet.
drerx7
Mon Jul 02, 2012 9:24 pm
Quoting Josh32121 (Reply 31):
They aren't.
I'm sorry, you confused my statements on the matter as opinion. I am telling you this is the case, its not debateable. We can debate about the numbers of pax that do transfer and if it is logical and what not about transfering at IAH...but the reason why DL wants to move is fact...not opinion. This was discussed over at Houstonspotter's about 6 months ago and there was an issue because DL wanted those gates and UA was beginning to have some objection to it. The whole point is for connectivety to KL/AM/AF.
aznmadsci
Mon Jul 02, 2012 11:08 pm
HAS (Houston Airport System) manages D since it's a common-use terminal so DL can try to get a deal with HAS and not UA.
AVENSAB727
Tue Jul 03, 2012 12:58 am
So I wonder if the A380 that will go to Houston, will be named after the city, since LH is still taking A380 deliveries.
NW
Tue Jul 03, 2012 1:08 am
Delta wants to be one with joint venture partners KL and AF. The plans call for one ticket counter for all three carriers plus Alaska. AF is currently accepting bids for oursourcing the above wing work; currently a mix of AF employees and contract employees. All KL and AF flights can be worked in the Delta system thus synergies and cost savings. Delta only wants to pick up the KL and AF work if they are in the same terminal. With the joint venture, Delta pays for the KL lounge in D but the Delta domestic customers don't have convenient access to the lounge. Number one complaint post merger was the loss of lounge access that NW had in terminal A when CO moved NW to A. United has told Delta they want their gates in A and Delta has said only if we can move closer to our partners.
Josh32121
Tue Jul 03, 2012 2:58 pm
Quoting NW (Reply 35):
Thank you for the more thorough explanation instead of just "I'm right; you're wrong." Indeed, there is a financial motive. DL and its JV partners will reduce their overall costs to operate at IAH by consolidating some ground ops.
drerx7
Tue Jul 03, 2012 4:05 pm
Quoting Josh32121 (Reply 36):
LOL, whatever helps you sleep at night.
But thanks NW for the clarification for myself as well. Since DL handles AS I would assume they would move to D as well. Is there a timeframe on this move? Like I said before those rumors surfaced about 6-8 months ago about Delta wanting to move to D.
[Edited 2012-07-03 09:16:39]
AVENSAB727
Wed Jul 04, 2012 2:39 am
Can we go back on topic please, I hope the A380 that LH uses is named after Houston, LH named named A380s after New York,Tokyo.
aznmadsci
Wed Jul 04, 2012 3:26 am
Quoting AVENSAB727 (Reply 38):
It will be nice if they did. Wish KL named had a plane Houston as well.
AVENSAB727
Wed Jul 04, 2012 5:05 am
I wonder how much news coverage will the A380 have on August 1
FlyingSicilian
Thu Jul 05, 2012 3:45 am
D-1 through 3 are really just as much C gates as D gates it seems.
Who uses the D-1-3 now? I use the USO often (which is in front of those gates) and I never see any aircraft or activity other than civil rights abusing TSA yahoos taking a break and using profanity amongst themselves.
As for the A380, I remember LH noted they might cancel that if Southwest were to start int'l ops at HOU, UA presented a letter by them on the subject IIRC. I presume that was just bluster and the LH 380 flights are indeed going to happen?
“Without seeing Sicily it is impossible to understand Italy.Sicily is the key of everything.”-Goethe "Journey to Italy"
AVENSAB727
Thu Jul 05, 2012 3:49 am
Quoting FlyingSicilian (Reply 41):
It is bluster, nothing but smoke and mirrors, The A380 will arrive in IAH on August 1st.
aznmadsci
Thu Jul 05, 2012 5:03 am
So far it's still showing A380 for my flight late August. I do not remember LH saying they would cancel A380 service, but that they support UA and keep IAH as the sole international airport for Houston.
cruiseshipcrew
Thu Jul 05, 2012 9:15 am
Was talking to my Purser on my LH A380 flight last night and they are not very excited about having IAH as a connection city. Doesn't live up to par with South Africa, SFO, Tokyo etc.
The new jet bridge looked good when we used it on Tuesday.
Road Warrior
drerx7
Thu Jul 05, 2012 12:45 pm
Quoting aznmadsci (Reply 43):
Not only is the service commencing, it will be the only A380 service to a U.S. city that will be year round...this has been covered at length in this thread and others related to IAH and the UA/WN/HOU debacle. In regards to the purser...meh, they'll have to get use to it.
AVENSAB727
Thu Jul 05, 2012 2:03 pm
Quoting cruiseshipcrew (Reply 44):
They'll get used to it.
thomasphoto60
Thu Jul 05, 2012 8:30 pm
Poor ol' Houston, we are truly the Rodney Daingerfield of cities......."We can't get no respect".
That said, that's why the get paid the big bucks, they'll get over it.
[Edited 2012-07-05 13:59:39]
"Show me the Braniffs"
N14AZ
Thu Jul 05, 2012 8:52 pm
Unbelievable. I spent one night in Houston back in March 2000 on my way to Belize. Had a fantastic dinner in a restaurant near the airport, constructed like a wooden blockhouse. Didn't understand a single word the waiter said to me but the steaks were fantastic. How I would love to come back there. Maybe I should become an A380-purser...
ozglobal
Thu Jul 05, 2012 9:31 pm
ATL
IAD
JFK
LAX
MIA
SFO
I have to smile at the thousands of lines on this forum a few years ago devoted to arguing as to why no US airports other than JFK and LAX would EVER invest in A380 adaptions....
When all's said and done, there'll be more said than done.
