bioyuki
When Will NH Downgauge SEA-NRT To 787?
Fri Jul 20, 2012 9:09 pm
I found this article stating that NH is planning to downgauge SEA-NRT from 77W to 788 sometime in October:
http://seattletimes.nwsource.com/htm...ology/2018559995_dreamliner30.html
Is this still holding true and feasible with the current 787 production schedule? Does anybody have a hard date for the switch? All the flights are currently loaded as 77W...
Next flight: TK 80/864: SFO-IST-TLV
Stitch
RE: When Will NH Downgauge SEA-NRT To 787?
Fri Jul 20, 2012 9:14 pm
NH has 11 787-8s already with more on the way, so I see no reason why they would not have a 787 available when it comes time to pull the 777-300ER.
That being said, losing First Class will be a bummer when the 77W goes.
bioyuki
Fri Jul 20, 2012 9:21 pm
Quoting Stitch (Reply 1):
I thought most of the current and future deliveries were domestic config, not international config frames? I'm about to book SFO-TPE for late October and would consider SFO-SEA-NRT-TPE to get my first 787 flight in
lightsaber
Crew
Fri Jul 20, 2012 10:25 pm
There should be enough delivery slots in there.   I count three that are about to be delivered, so with 14 in the time frame of interest, I think ANA will pull it off.
http://nyc787.blogspot.com/2012/07/u...87-delivery-info-for-july-and.html
Neither SEA nor NRT is famous for a large premium market. IMHO, NA will make more money without paying to haul 1st seats where there is low demand.
Lightsaber
Correction,
ANA has FOUR 788s that could be delivered in August and possibly one or two more in September.  biggrin
[Edited 2012-07-20 15:32:40]
SANFan
Fri Jul 20, 2012 10:53 pm
Interesting. There's also the SJC-NRT route to be considered in this discussion, right? If NH has a 787 available for trans-Pac flying this year, why would they put it on SEA rather than deploy it to SJC and get that route started? (AFAIK, the expected start date is still March/April 2013?)
I assume the down-gauge of SEA is due to less traffic in the fall, or is it because they need the T7 elsewhere at that time? Otherwise, I don't quite get the holding off of SJC...
(Actually, won't it take 2 birds to get either route -- SEA or SJC -- up and running daily?)
bb
[Edited 2012-07-20 15:55:38]
Viscount724
Sat Jul 21, 2012 11:50 pm
Do you know how many of the 11 delivered to date have the longhaul configuration vs. the higher-density domestic/regional configuration?
ATLFlyer323
Sun Jul 22, 2012 1:03 am
Quoting lightsaber (Reply 3):
Tokyo, really? The largest single urban GDP city in the world with over 30 million people doesn't have a large premium market? Surley you have to be making that up. While I could see most premium traffic wanting to use HND because of it's location compaired to Tokyo, HND does not have service to all the international cities that NRT does.
-Brandon
IrishAyes
Tue Jul 24, 2012 6:39 pm
We are booked outbound from SEA to NRT on October 25th on NH. Crossing my fingers....
personal page: rohananand.com
wedgetail737
Wed Jul 25, 2012 4:16 am
@IrishAyes...just make sure you check your seat reservations periodically so you don't lose your optimal seat.
Carpethead
Wed Jul 25, 2012 6:28 am
Quoting Viscount724 (Reply 5):
Just two in the long-haul configuration. (JA805A & JA806A)
Four are in a temporary domestic configuration. (JA801A, JA802A, JA804A, & JA807A)
The rest are all domestic configuration. (JA808A, JA809A, JA810A, JA811A, & JA812A)
The domestic aircraft cannot be used for long-haul because of the obvious seat set-up.
The current two long-haul 788s are based out of HND for the HND-FRA flying.
To reasonably fly NRT-SEA daily, NH would need two 788s to be based out of NRT. The NRT-SEA has a turnaround of approximately two hours at each station and would leave very little slack in scheduling for maintenace and irregularities. I have no ideas on what configuration are planned for future deliveries.
bikerthai
Wed Jul 25, 2012 2:45 pm
Quoting atlflyer323 (Reply 6):
With Ichiro traded to the Yankees, I would think there will be fewer Japanese tourist coming to Seattle.
bt
ANA787
Wed Jul 25, 2012 2:53 pm
My prediction: NH or UA on this route will bite the dust in 6 months.
Quoting bikerthai (Reply 10):
JerseyFlyer
Wed Jul 25, 2012 3:57 pm
Let's all use upgauge / downgauge in future in place of upgrade / downgrade - its a much more accurate descriptor for an airline decision to deploy a larger / smaller aircraft.
roseflyer
Wed Jul 25, 2012 5:58 pm
Quoting ANA787 (Reply 11):
I suspect UA may not last since it is one of the few non hub international routes on the airline. Yields are better than LAX - NRT but they may drop some.
However I don't think it is guaranteed to fail. SEA-NRT briefly sustained two 747s and a 777 in the late 90s. An A330, 787, and 777 may be manageable in the summer but u would not think three flights per day could be sustained in the winter. It is good ANA will downsize to the 788.
bioyuki
Wed Jul 25, 2012 7:42 pm
Quoting JerseyFlyer (Reply 12):
Did you even bother to read the thread? You're the only person using the phrase 'upgrade' or 'downgrade' in here...
izbtmnhd
Thu Jul 26, 2012 12:49 am
Deleted post by self
[Edited 2012-07-25 17:56:55]
