mikey72
Are Mergers Irrevocable? (BA/IB Performance Gap)
Fri Aug 03, 2012 7:07 am
http://www.marketwatch.com/story/iag...economy-worsens-2012-08-03-2485442
With the Spanish economy and the wider Eurozone outlook teetering on the abyss what happens if one half of an airline grouping goes bust ?
We have to consider this under the current circumstances despite all the 'we will do everything to save the....' rhetoric.
Flying is like sex - I've never had all I wanted but occasionally I've had all I can stand.
scbriml
RE: Are Mergers Irrevocable? (BA/IB Performance Gap)
Fri Aug 03, 2012 7:29 am
Well, they're not really merged airlines, are they? They are two separate airlines owned by the same holding company.
PanHAM
Fri Aug 03, 2012 8:01 am
One is always smarter when leaving city hall. Nothing is irrevocable, it just depends on the costs of reversing matters. Contracts have termination clauses.
However, the way airlines are set up these days is that they do not only serve the country they are based in but the European market at least, if not a global market. BA certaonly does and IB is strong in South America.
The goal should be to consolidate and make use of the synergies. LH is a good example, if not a role model.
Was Erlauben Erdogan!!!
Talaier
Fri Aug 03, 2012 8:21 am
I very much doubt it. In terms of IAG specifically, IB loses money in short and medium haul and BA is barely breaking even. The problem with this company is costs on the IB side, whic after the redundacies after the summer will be solved and will take the group to a break even point in Q3. Q4 should bring in profits as synergies kick in and the cost base throughout the company is reduced significantly.
mikey72
Fri Aug 03, 2012 8:35 am
Quoting PanHAM (Reply 2):
Well I hope you're right ! We will have to see how the land lies whatever transpires in the coming months and when the crisis is over.
Yes they are an excellent example.
BestWestern
Fri Aug 03, 2012 8:36 am
Can I start by saying that I am no fan of Iberia.
However, the damage to the Spanish economy has already taken down two major competitors in Madrid - Spanair and EasyJet. Iberia could emerge a stronger more dominant carrier at the end of the crisis. Iberia is also using the crisis to finally get their cost base in order.
LH is a terrible example and not a role model for airline mergers. With the exception of Swiss, LH have seen a litany of poor choices in their mergers and Joint Venture decisions..
Austrian
Bmi
Jade
In comparison the AF/KL and BA/IB mergers seem more calm.
Quoting mikey72 (Thread starter):
Dont get so smug on your little island! If the Eurozone goes over the edge, it will bring the World with it - The UK economy, especially its banks, are so tied to global performance.
FInally - BA were very lucky when they walked away from Olympic.
Greetings from Hong Kong.... a subsidiary of China Inc.
LHRFlyer
Fri Aug 03, 2012 9:02 am
Had BA not merged with Iberia there was a very good chance that it would have been acquired by Lufthansa or Air-France KLM which would have left BA seriously isolated in Europe and oneworld weakened.
Iberia's performance is not good but remember that three years ago BA was very heavily loss-making and has turnaround, partly because of the London market but also the restruturing undertaken at BA.
Also, don't forget that although Iberia is not profitable when it joined IAG it had very little debt and a very high cash balance which has helped BA/IAG overall.
sabenapilot
Fri Aug 03, 2012 9:05 am
The other half takes a knock-out hit and goes down with it: have a look at how Sabena/swissair went down together.
The obvious reason is that merged airlines are so strongly interwoven with eachother that they are pretty much unable to shield their balance sheets from a crash of their sister airline should that ever happen, especially as they will have first propped it up further even to avoid such a crash from ever happening!
No you don't: what's the obsession of wanting to spit everything up again as soon as their's a temporary regional problem occuring, be it an airline group or our currency union?
Folding back onto oneself simply isn't a viable solution, because the idea one is somehow living in a completely different environment unaffected by what is happening elsewhere is wrong to start with: much better to stick together no matter what so as to be stronger together, than allow yourself to be broken up into many pieces which are far more easily attacked by others one by one later and yes, that will require certain cash flows from one entity to the other: do you rather spend all of your money fighting much bigger competitors when they turn to you later?
Indeed: splitting up isn't helping, not for the one left behind, but also not for the one walking away: both will end up weakened and decimated by competitors in no time.
Splendid isolation just isn't something of the 21st century any longer because the world has become our village and so a fire in our neigbour's house can quickly set our roof on fire too, so definitely much better to help them with putting that fire out again, rather than to just close your own windows overlooking their premisses and simply watch how their house goes up in flames: chances are that yours might not be standing for much longer either if you do that, you know?
[Edited 2012-08-03 02:09:29]
r2rho
Fri Aug 03, 2012 9:08 am
Quarterly reports provide an instantaneous photo of the company financials but do not give you the big picture.
IB is currently going through a slump but was very profitable before the crisis. IB long-haul is still profitable and South America is a growth region that is little affected by the crisis. It's only short-med-haul that loses money, and this is already being adressed with IB Express in MAD and VY in BCN. Furthermore with JK bankrupt and U2 pulling out of MAD that's two competitors less to worry about. They are doing a lot of restructuring, and I believe that they will emerge much stronger in a year or two. Next year the A333's arrive to replace the A343's, and the A346's are getting a new cabin. And MAD is a world-class hub that provides plenty of opportunities for future growth. 2012 is being a big transition year for IB, don't expect profits from it.
IMO the IB-BA merger is one of the most "natural" ones that have ocurred in the airline business lately, I would start questioning other mergers before this one.
mikey72
Fri Aug 03, 2012 9:27 am
Quoting bestwestern (Reply 5):
That was a bit uncalled for.
I would like to think I am credited here with enough intelligence to at least recognize that fact.
Believe me....I am all 'too' aware of it.
It is a fact however that the UK is not a member of the Eurozone and can set its own agenda with regard to interest rates etc etc
Quoting r2rho (Reply 8):
Quoting LHRFlyer (Reply 6):
I agree with these comments and others like them but I am increasingly getting the feeling that our beloved 'big 3' are operating in economic times about as stable as a house of cards.
Spain and France are on the brink and Germany is either going to pull out or get stung with the biggest after party bill in history.....and yes the UK is the ship at the end of the anchor chain.
(Maybe we'll all just disappear down the plughole and everyone else will just carry on like we never existed.....if it wasn't so tragic I'd put in a 'rotfl' )
[Edited 2012-08-03 02:54:40]
mikey72
Fri Aug 03, 2012 9:50 am
Quoting sabenapilot (Reply 7):
I am quite literally speechless at that description of what is now engulfing us.
sabenapilot
Fri Aug 03, 2012 10:03 am
That remark was in reference to IB's current result.
The fact you understood it differently is because you seem to be very eager to drag another topic into this discussion which you know very well is embargoed: just reading your posts so far again shows you are not really talking about BA/IB at all, but all rhe more about the euro, including your opening post and the quote. Or can you show me a reference to any IAG member ever having said something along the lines about their company?
Otherwise, I will have to suggest deletion of this topic.
mikey72
Fri Aug 03, 2012 10:11 am
Quoting sabenapilot (Reply 11):
We see this time and time again here.
You cannot ignore what is going on in the greater world and make like an ostrich !
I want to know what people think will happen to an airline grouping if one half goes under.
It has never happened before with groupings of this size.
I'm not just asking out of curiosity but because what is happening in Europe makes it a real possibility. Whether you like it or not it IS connected.
Now deal with it.
Even if one half doesn't go bust completely at what point does the imbalance become unacceptable to the other member/s ?
[Edited 2012-08-03 03:20:41]
JJJ
Fri Aug 03, 2012 10:36 am
That's the key. BA has greatly profited post-merger from IB's huge cash bag, and IB has extremely profitable long-haul MAD-LatAm routes which are an strategic long-term asset.
IB needs to put some order on their domestic and short/med haul operations, but long term prospects are good.
PPVRA
Fri Aug 03, 2012 12:04 pm
A merger is not merely a contractual relationship, so the term irrevocable doesn't make sense. Both airlines are actually owned by the same people.
Of course IAG can always "spin off" IB or BA if it decides.
"If goods do not cross borders, soldiers will" - Frederic Bastiat
Summa767
Fri Aug 03, 2012 1:54 pm
Quoting PPVRA (Reply 14):
That answers the OP question well. Though I understand that this particular merger can also be "untied" at the behest of the individual airlines.
Another matter if, of course, whether there would be any gain in "revoking" the merger. Whereas IB is indeed losing a lot of money, it still has the opportunities that MAD offers as a hub to a growing region as is Latin America, and most of the synergies are yet to be harvested.
As others have said, IB express is dealing with the short haul issues that are hindering Iberia. The A330s will also bring efficiencies in the long haul. I do think that there is scope to grow in the future.
The current economic circumstances in Europe and particularly in Spain, make turning a profit for IB a hard task, but barring a Euro explosion, I trust that IB can at least break even in 2013. BA should have a better last half of this year, continuing next. Indeed, with the new long haul airplanes coming, BA is well positioned to grow, helped by the slots gained from bmi. But for the future, it will be the turn of Iberia and Madrid to be the focus of growth. Before that there is some structural problems to address given the challenging circumstances.
steve6666
Fri Aug 03, 2012 2:35 pm
As Summa767 says, this is a very good very quick answer to the OP. There have been a couple of demergers of businesses listed in London in the last few years that I know of - see Fiberweb out of BBA and EnQuest, which was a demerger of two businesses from Lundin and Petrofac and subsequent merger.
How easy or difficult this is to do will depend on the contracts between the two, but will generally involve a lot of work for lawyers.
In any case, I suspect we are a number of years from breaking point - Willie will do his damndest to restructure Iberia and (I haven't looked) it would be interesting to see what BA's results were, excluding the one-off BMI acquisition and restructuring costs.
A306, A318, A319, A320, A321, A332, A333, A343, A346, A388, B722, B732, B733, B734, B735, B73G, B738, B742, B744, B752, B753, B762, B763, B764, B772, B773, B77W, B787-8, BAe-146, Cessna Something, DC-10, E175, E195, ERJ145, MD-11, MD-80, PA Something
acidradio
Crew
Fri Aug 03, 2012 3:22 pm
I just wanted to jump in really quickly and thank everyone for sticking to the topic - the risk of fallout in airline mergers due to economic instability in the EU! Please stay aimed at this. If you want to make direct comparisons to non-airline mergers or entities that's fine, but make sure you keep the topic airline-related. We had concerns that this was going to become a general discussion about EU market and financial instability which is out of the scope of the Civil Aviation forum but I think everything will work out just fine. Thanks!
Ich haben zwei Platzspielen und ein Microphone
mikey72
Fri Aug 03, 2012 3:44 pm
Quoting JJJ (Reply 13):
Good point.
IB, BA, KL, AF, LH and Swiss all can be proftable companies in the long term with the efficiency programs being put into place but........
Are the relationships between these carriers fluid enough to morph into whatever the pretty bleak 'short to mid term' future may require and are they strong enough to weather the storm ?
Apart from Swiss they are based in countries inextricably linked together and dependent on the survival of the Euro.
http://www.telegraph.co.uk/finance/n...or-Spanish-exit-from-eurozone.html
Mr Walsh said he would be “surprised” if other major companies with operations in Europe hadn’t drawn up similar contingency plans given the deterioration of conditions on the Continent.
Mmm
[Edited 2012-08-03 08:57:01]
[Edited 2012-08-03 08:59:38]
BestWestern
Fri Aug 03, 2012 4:06 pm
Quoting mikey72 (Reply 18):
Again - Switzerland and the UK will go down if the Euro does. But don't worry - your beloved British Airways is safe.
Yes. If the depressing worst case scenario (and your arguements always take extreme cases) picture you are discussing comes to fruituon. who would buy an airline at a fair price anyway?
Anyway, we are going around in circles here.
mikey72
Fri Aug 03, 2012 4:16 pm
Quoting bestwestern (Reply 19):
Depressing it maybe but like the report in the Telegraph today says...it's best to be prepared.
Please don't shoot the messenger...it's not my fault.
Oh for heavens sake !!
BestWestern
Fri Aug 03, 2012 4:41 pm
Quoting mikey72 (Reply 20):
Just like all the other 'end is near' headlines screaming from the press.
I love the Matt cartoons in the Telegraph - the issue of the day in one graphic.
telegraph.co.uk/matt
The article is discussing prepardeness for the worst case scenario - just like safety belts in the car. The Telegraph is also rather eurosceptic too.
As a shareholder, I firmly believe that BA, and IAG are safe.
PHX787
Fri Aug 03, 2012 5:01 pm
Quoting scbriml (Reply 1):
In that case, couldn't IAG just spin off IB?
I honestly think that if one airline is breaking even though it can more or less support the other one via the holding company, right?
scbriml
Fri Aug 03, 2012 5:20 pm
Quoting PHX787 (Reply 22):
I believe there's no reason IAG couldn't sell IB if they wanted to.
PHX787
Fri Aug 03, 2012 5:30 pm
Quoting scbriml (Reply 23):
But how much is IB owned by the spanish government? I'm not familiar with IAG or IB at all but however IMHO such a spinoff would require the spanish government to have a stake claim in IB on top of the spanish government collapsing. What happens next would be chaos for BCN and MAD (both for the airport and the society there)
I'm surprised that Aegeon and Olympic are surviving given their climate but aren't those two privatized?
mikey72
Fri Aug 03, 2012 7:52 pm
Quoting PHX787 (Reply 24):
In the event of some rapid deterioration or contagion within the economies of the continent (because it wouldn't just be Spain) I am sure that whilst frightening for a while nations would do whatever it took to keep their infrastructure at some sort of operational level.
I am also convinced we would all be surprised by how quickly we would all emerge.
Under those circumstances national institutions (vital to any hope of a recovery) like IB, AF, LH, BA, KL, etc whether private or public would not be allowed to fail.
(In my view anyway)
[Edited 2012-08-03 12:59:01]
