1337Delta764
AS To Move To Terminal 3 At PHX?
Mon Aug 06, 2012 8:45 pm
I have heard rumors that at PHX, AS plans on moving out of Terminal 2 and into Terminal 3 with DL, leaving UA and ZK as the only airlines at T2. Does anyone know the status of those rumors?
I don't think T3 is at capacity, so it could be quite possible for AS to move into T3 with DL. Once the new concourse at T4 is built, UA and ZK can move in, thus eliminating the need for T2.
FRNT787
RE: AS To Move To Terminal 3 At PHX?
Mon Aug 06, 2012 9:02 pm
Quoting 1337Delta764 (Thread starter):
when I took operations tours last summer at PHX, that was the plan at the time. Eventually, they want to totally eliminate T2. AirTran moving to T4 should have spared approximately one gate at T3.
"We have a right to fail, because failure makes us grow" --Glenn Beck
treebeard787
Mon Aug 06, 2012 9:27 pm
Quoting FRNT787 (Reply 1):
AirTran used gate 19 on the North concourse of T3 but Delta has taken over use of that gate. Currently the only free gates on T3 North are 24, 25, 26 (Old Northwest gates) Gates 15, 16, 17, 18, 19, 23 are used by DL and gate 20 is used by F9. F9 will also RON aircraft at gate 26. So there are plenty of open gates that AS could use. There is also a possibility that HA could move from T3 South to T3 North, either gates 24 or 26 could handle a B767 or A330.
Allons-y!
