abrown532
Weight And Balance Issues With Hand Luggage?
Tue Aug 07, 2012 10:18 pm
I have been wondering this for a while, when airlines use standard weights such as 70kg Female and 88kg Male, this does include their hand baggage.
Fine.
However, especially with Ryanair and Easyjet, who charge so much for checked baggage, people's hand luggage is becoming increasingly heavy and I would wager that for a majority of times, people + hand baggage will be more than the average weights. And I have noticed on airlines with free-seating systems, people generally tend to like sitting more towards the front.
So my question is:
Should the weight and balance of pax + hand luggage be monitored more carefully to avoid a potentially unbalanced/unpredictable aircraft trim?
longhauler
RE: Weight And Balance Issues With Hand Luggage?
Tue Aug 07, 2012 11:07 pm
Quoting abrown532 (Thread starter):
Most country's governing bodies require an "audit" from time to time, to ensure that estimated weights being used, and actual weights occurring are close.
I have on occasion had to step on a scale, attached to a computer in the bridge (as did all passengers and crew), as a part of that audit.
redflyer
Wed Aug 08, 2012 12:25 am
In this instance, it would be a wash since whatever isn't carried in the baggage compartment will be carried in the cabin instead, so it won't affect W&B.
That's a mistaken assumption. Pax will CLAIM the front of an aircraft first on an open-seating system, but that's no different than on an assigned-seating system where pax will SELECT the front of the aircraft first for their seats. In both cases, pax start to claim/select their seats towards the back once aisle and/or window seats towards the front are filled, with the middle seats going last.
[Edited 2012-08-07 17:47:05]
My other home is in the sky inside my Piper Cherokee 180.
rfields5421
Wed Aug 08, 2012 1:46 am
I'm pretty sure for W/B calculations - they assume all the bins will be filled to the near maximum weight capacity.
smi0006
Wed Aug 08, 2012 2:08 am
Quoting redflyer (Reply 2):
Not exactly how it works, it will be accounted for differently in the hold. When offloading a piece of hand-luggage into the hold it has to be tagged and the hold weight updated. Some airlines use the exsact weight which is added to the total weight other use a standard. For instance QR uses 15kg for any piece of gate checked baggage. Interesting to note in many QR ports they have up to 30 pieces of gate baggage as they confiscate so much at the gate due to oversize and over weight hand baggage.
In Australia we are fortunate hold luggage is reasonably priced and generally our security is pretty good (at least internationally) at stopping anything too heavy or too large.
BlueLine
Wed Aug 08, 2012 2:20 am
For where I work, valet bags are recorded as 20 pounds each. It's not uncommon to get some that would be nearing heavy territory if it was a standard checked bag, but it's balanced out by the backpacks and baby carriers that won't fit onboard. If there are some deadheading crew members, those Luggageworks crew bags that are gate checked aren't light either.
tdscanuck
Wed Aug 08, 2012 3:32 am
Although really outlier hand baggage could throw the weight off by a few thousand pounds, it's very well distributed. The only measurable impact would be a slight shift in takeoff performance (far smaller than the safety factors that are already built in). The CG shift would be pretty benign unless you stuffed all the luggage at one end. Even then, it won't be enough to get out of balance/trim...the flyable envelope is considerably larger than the certified envelope.
Tom.
FI642
Wed Aug 08, 2012 3:51 pm
When handbaggage is stowed in the hold, it goes from 15lb magically to 30lb . These are the approved weights with the FAA.
737MAX, Cool Planes for the Worlds Coolest Airline.
redflyer
Thu Aug 09, 2012 2:32 am
Quoting smi0006 (Reply 4):
Interesting point you bring up and I had to think about it for a moment. But the premise is if a 21" suitcase goes into the baggage compartment, does the weight calculation have to be altered if it instead goes into the overhead bin. On its face, the answer would be no, because all you are doing is taking the 21" bag from below and putting it topside. And the OP's post was asking if W&B have to be recalculated because, in order to get everything into a 21" bag (typical size limit for an overhead bag), people will stuff more into it (make it more dense). All that means is that 50lbs of personal effects will be carried in a 21" bag instead of a 26" bag. The density will be different, but the weight will still be the same. So from an actual W&B standpoint, it should make no difference.
On the other hand, and to the point you make, airlines probably do account for different weights per bag going into the hold vs. overhead bin because the baggage compartment can hold more weight per sqft, and the baggage going into the hold will typically be heavier by virtue of the fact that the reason it's going into the hold is because it is either too big to fit in the overhead bin, or it's simply too heavy for the pax to carry. In other words, on average, the typical bag going into the under-floor hold is heavier - because it's bigger - than the typical bag going into an overhead bin.
That's my story and I'm sticking to it.
