AirAfreak
Skyteam And Code-share Usage In Los Angeles
Fri Aug 10, 2012 7:17 am
*Alitalia at Terminal 2 (as per the database photo pictured with KLM 744 Combi), but check-in at Terminal 5?
*Air France at Terminal 2 and Tom Bradley International Terminal (departures from two different terminals for A380 and 772/3)
*Virgin Australia departures from Terminal 3, but arriving at Terminal 5?
*China Southern departures from Terminal 5, but arriving at Tom Bradley, and then both departures/arrivals from Tom Bradley when A380 from Canton/Guanghzou commence service?
*Aeromexico no longer at Terminal 5?
*Air France at Terminal 5 (ground handling from Delta) some years ago and now at Terminal 2/TBIT?
*Some years ago, China Southern check-in at Delta Terminal 5.
For us a.net users, we can follow instructions as to where to check-in, however, this can be quite confusing for Skyteam Passengers not familiar with Skyteam connections in Los Angeles. This does not seem to be seamless travel as Skyteam advertises.
Why can we not have a single Skyteam Terminal with a Skyteam Lounge as in for example, Heathrow? Why does Delta no longer do the ground handling for Air France? Why can't KLM operate from Terminal 5? Why can we not make the Delta SkyClub a Skyteam Lounge in Terminal 5? Is gate usage so restricted, that we cannot have all Skyteam flights departing from the Terminal 5? Why cannot we convert one gate to an A380 gate?
These are many questions that run through my mind because it seems LAX Airport Authorities have greater flexibility than we are led to believe.
So, why all the changes????
Economy Class. You vision of loveliness; Prince Charles called and he wants you to fill in for him next week.
deltal1011man
RE: Skyteam And Code-share Usage In Los Angeles
Fri Aug 10, 2012 8:10 am
Quoting AirAfreak (Thread starter):
Space. no where to put them. Same reason why Star and OW are in at least 2 different terminals.
few reasons.
1) T5 is terrible for 747 opps. Delta's own 747 flights always use T6.
2) I don't think AF was to happy with the Delta operation in LA.
3) Delta doesn't have the space for AF as is.
4) AF's LAX-PPT flight would have to have PAX from CDG deal with customs. In T2 They have a holding room so they don't have to re-clear and such.
space.
You could but that seems pointless with only Delta flying into T5 and it staying that way for the foreseeable future.
Yes. Delta is having to remote park because of space. No room at all at T5 for any more carriers.
Nope. T5s only 744 gate shuts down the one next to it. (and i'm pretty sure the aft end of the 380 would be sticking out on the taxiway.
Don't think so. AFAIK AZ is totally in T2.
Yeah....Pleases Delta and VX i guess. (this one seems stupid to me too. pick a target)
Not that I know of. I believe CZ is 100% in TBIT with KE.
No moved to T2 due to space and the fact that FIS at T5 has sorry hours. They were having to bus to TBIT more than they used the T5 FIS.
I don't understand why this site even has moderators anymore.
AirAfreak
Fri Aug 10, 2012 11:47 am
@DeltaL1011man...
*it's funny you mention AF was not too happy with DL at T5. I happen to personally know a former AF agent that now works for DL and for the period AF operated flights from T5, this agent (French Speaking and Former AF Agent) also happened to mention the same that AF was not happy with DL but without specific reason. As of now, the station manager for AF @ LAX, her name is Veronique and she has been managing the station for many years and even she cannot give an answer as to why DL was not up to AF standards. I happen to know DL scheduled French Speaking Agents to check in the Paris and Papeete flights and the service was better than expected and also DL was the operator for tour packages to Tahiti.
*Re KLM 744 gate usage, it has been shown from time-to-time, based on unscheduled equipment changes, the Boeing 747-400 has operated from Terminal 5 at the very end of the concourse closest to the taxiways so this has not been an issue. DL has operated unscheduled 744 flights from LAX @ T5 to Narita and the unscheduled MSP flights - very rare, but this has been done. T5 can handle 744 at the very end of the T5 Concourse as it can also handle A330 and 772 flights. It has also operated 772 operated by China Southern from LAX to Canton nonstop via Terminal 5. So, clearly, T5 does not have operational restriction, only, the issue could be timing.
LAXintl
Fri Aug 10, 2012 3:45 pm
Yes A380 ops are at TBIT. T-2 has not A380 compatible gates.
AF will be moving full time to TBIT in next year.
VA is not in Skyteam. They use the DL FIS facility, but have their own ticket counter and handling next to Virgin America in T-3 for departure.
CZ has been at TBIT for years --- 2007.
Yes they left for a better home in T-2 in 2009.
Yes AF left DL and moved to T-2 under a single roof with KLM in 2005.
Well there is a master and large Skyteam branded lounge at LAX -- its at TBIT.
Simply put DL is not the best handler. Same reason why Swissair left Delta for handling. US carriers are not quite known for being detailed oriented or willing to modify the way they do things to meet standards of others. When things go wrong DL will cover its own flights, and leave the customer waiting.
Over the years many airlines have come and gone from Delta handling...
Anyhow T-5 was not practical for the Tahiti transit flights, so no matter what DL needed to split operations, with the PPT flights being at TBIT.
Ultimately the AF-DL relationship at LAX was stressful, with DL at the end serving notice that it no longer had the staffing to work AF flights.
T-5 is a small place, that was built for mostly all 727 ops. Even today DL has issues with fitting its own widebody flights.
KLM is joined at the hips with AF. Anyhow KLM has been home in T-2 since the early 1990s.
No plans for a T-5 A380 gate. It would frankly be a waste as it would cause the loss of adjacent gates.
Quoting AirAfreak (Reply 2):
AF LAX manager is a male.
NW
Fri Aug 10, 2012 4:58 pm
Quoting LAXintl (Reply 3):
KL is a little more joined to Delta, KL still uses DLTerm for ground handling at LAX. Left over from the NWA days of using PARS/AOP.
LAXintl
Fri Aug 10, 2012 5:03 pm
Quoting NW (Reply 4):
Delta has no interest in T-2.
Following the NW merger, in 2010 DL dumped its ownership stake in T-2 (LAX-Two Corp).
EddieDude
Fri Aug 10, 2012 5:15 pm
Wasn't it in 2010 or 2011? I recall checking-in for AM at T5 as late as 2010.
Upcoming AF MEX-CDG-DEL-CDG-MEX A380, A332, 77W. Old J.
LAXintl
Fri Aug 10, 2012 5:23 pm
Quoting EddieDude (Reply 6):
November 20, 2009.
See
Terminal 2 @ At LAX (by 767ER Oct 15 2009 in Civil Aviation)
and
Aeromexico Moving To LAX T2? (by EddieDude Dec 2 2009 in Civil Aviation)
Your own thread above
steex
Fri Aug 10, 2012 5:30 pm
Just to expand on this point a little for the OP - T-3 doesn't have a connection to an FIS facility. As LAXintl notes, Virgin Australia has its own infrastructure at T-3, but is forced to bring arriving pax to a terminal that has FIS. Virgin America similarly takes arriving pax from its CUN flight to the T-2 FIS.
[Edited 2012-08-10 10:38:15]
EddieDude
Fri Aug 10, 2012 5:37 pm
Thanks LAXintl. I suppose my perception of time is kind of f'ed up haha, unless they had split departures and arrivals during a transition period?
Braniff747SP
Fri Aug 10, 2012 11:22 pm
Quoting DeltaL1011man (Reply 1):
Confirmed; flew to FCO a little more than a month ago and AZ check-in and departure is indeed from Terminal 2.
The 747 will always be the TRUE queen of the skies!
AirAfreak
Sat Aug 11, 2012 2:01 am
It must have been recent as Veronique has been the station manager for quite some time...
deltal1011man
Sat Aug 11, 2012 4:25 am
Yeah...uh thanks. I know what gates can handle what at LAX. It shuts down both gates next to the 747 when it flys into T5. So yes they could and then Delta would lose three gates at its already super packed T5.
and the sae goes for the 332 or 777 opps its shuts the end gate. T5 is a good for 767 and smaller. Its also why you see most of Delta large aircraft at T6.
