mikect
What's Going On Here? T-6 In Anchorage
Sun Aug 12, 2012 8:37 pm
Does anyone know if there was a story behind this picture? I imagine it was during an airshow. The wing seems to be about 6 inches off the ground and they seem a bit pitched-down as well. It just seems a little too close for comfort.
Photo © C.L. Weldy
AA737-823
RE: What's Going On Here? T-6 In Anchorage
Sun Aug 12, 2012 11:52 pm
I wasn't able to go to the show, sadly, but I suspect it's a carefully cropped optical illusion. I don't think the photo encompasses the surface of the earth quite the way our eyes are perceiving it.
But I definitely did a double-take when I saw it, too!
flyboyseven
Mon Aug 13, 2012 12:45 am
I definitely saw the same illusion. I think that what appears to be a shadow is just a darker patch on the runway behind. If you look at it, there is no way that it can be the shadow of the plane as it is just a simple rectangle.
Graham
As long as the number of take-offs equals the number of landings...you're doing fine.
757luver
Mon Aug 13, 2012 9:43 am
Quoting flyboyseven (Reply 2):
It definately looks like a patch in the runway, also looks like the plane is actually over the grassy part of the field too.
Long live the 757!
mikect
Mon Aug 13, 2012 12:47 pm
Wow. I had to stare at it for a while, but I see what you mean. It looks like there is probably telephoto compression adding to the illusion.
