EK413
SQ A380 Wing Repairs?
Sun Aug 19, 2012 8:33 am
Hello All,
Just stumbled across a photo of a SQ A380 @ LAX and was curious if the aircraft suffered any damage to the wing?
Reason I ask is the fact a large section of the wing has obviously been painted...
Photo © Sam Chui
Any idea what happen...?
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
9vswr
RE: SQ A380 Wing Repairs?
Sun Aug 19, 2012 8:55 am
I don't have any answers, but I noticed this phenomenon some time ago in another picture on the database and am curious to learn more too.
Photo © Kavin Kowsari - AirTeamImages
EK413
Sun Aug 19, 2012 9:02 am
Quoting 9vswr (Reply 1):
Glad I'm not the only one which noticed...
EK413
oldeuropean
Sun Aug 19, 2012 9:15 am
This looks more like an experiment with some different paint than a repair – but who knows.
Wer nichts weiss muss alles glauben
breiz
Sun Aug 19, 2012 9:36 am
Quoting EK413 (Thread starter):
Singapore found that two of its A380s had the famous small cracks in the wing skin brackets and had then repaired.
Says Airbus:
"The European airframer confirms that if airlines choose to undertake the repair "nose-to-tail" it will require around eight weeks to implement. However Airbus says that it expects most operators would opt to adopt the phased approach spread out over three two-year heavy checks which is less disruptive. In this case, it expects the repair would extend each two-to-three week heavy check by "a few days".
" An Airbus wing specialist on the A380 said the airframer's investigations indicated that parts were being stressed at some point during the manufacturing process, which involves drawing the wing skin over the built-up rib and spar assembly before attaching it."
"Rib feet are L-shaped brackets, about 9in (23cm) tall, which connect the wing skin to composite rib structures. There are some 30-40 on each rib spanning the wing."
I do not know yet which A380s are involved.
oldeuropean
Sun Aug 19, 2012 10:44 am
Quoting breiz (Reply 4):
But these cracks, inside the wing coudn't be a reason to paint the upper surface of the wing.
breiz
Sun Aug 19, 2012 10:49 am
Quoting oldeuropean (Reply 5):
I assume that to replace the faulty brackets, they had to remove the skin of the wing. They have then replaced it by a skin plate of a different shade of colour.
I understand the repair was done in Singapore, not in Toulouse. Aluminium plates come in all sort of grey colour shades.
Correcting myself: it is actually 6 Singapore aircraft which have/had cracks.
[Edited 2012-08-19 06:03:35 by SA7700]
AngMoh
Sun Aug 19, 2012 11:26 am
Note that this photo is dated 12 July 2011.
The first repairs for cracks were done in Jan 2012.
If it were the cracks, shouldn't there be repairs at both sides?
So I don't think this is related to the cracks.
727 732 733 734 735 73G 738 739 739ER 742 743 744 752 762 772 773 77W 789 A300 A310 A319 A320 A321 A332 A333 A343 A345 A346 A359 A388 DC-9 DC-10 MD11 MD81 MD82 MD87 F70 ERJ145 E175 E190 E195 ATR72 CRJ200 CRJ700 CRJ900 BAE146 RJ85
Sun Aug 19, 2012 11:43 am
Quoting breiz (Reply 6):
As far as I am aware, the repair work is done from inside the tank.
breiz
Sun Aug 19, 2012 12:17 pm
Quoting AngMoh (Reply 8):
Ouch, good point!
Nothing to do with the cracks then
xdlx
Sun Aug 19, 2012 4:11 pm
On the outside edge you can read .... "we know about this"
my235
Sun Aug 19, 2012 6:33 pm
I wonder what the Qantas 380 wing loks like after getting repaired from the uncontained engine.?
flyingcello
Sun Aug 19, 2012 7:12 pm
AFAIK, the A380 skins are single milled pieces...so this change in colour is not a separate panel, but a painted or treated area of the main skin.
22886
Sun Aug 19, 2012 10:53 pm
my235: this is what the repairs look like on VH-OQA
my235
Mon Aug 20, 2012 1:15 am
Quoting 22886 (Reply 13):
Thanks for those!
kanban
Mon Aug 20, 2012 6:00 pm
definitely no skin removal required
looks like the repairs were done in a cheap body shop.
blowing up the second wing picture, it appears to have a non aerodynamic surface.. however it may just be irregular painting in small blocks by hand vs. airgun.
bikerthai
Tue Aug 21, 2012 3:57 pm
You know,
It looks like they are performing some sort of paint experiment. Note that one patch is white and one patch is dark.
I wonder if it have to do with laminar flow experiment and they are trying on different finishes?
bt
