G500
Why Alaska Chose DCA Over IAD And EWR Over LGA?
Wed Aug 22, 2012 3:31 pm
In Washington they chose the smaller downtown airport (DCA) over the larger international one( IAD)
In N.Y, they chose the opposite, the larger airport (EWR) over the smaller downtown airport (LGA).. what gives
I assume they chose EWR over LGA because of the perimeter rule?
what about D.C. Why DCA over IAD?
mogandoCI
RE: Why Alaska Chose DCA Over IAD And EWR Over LGA?
Wed Aug 22, 2012 3:36 pm
Quoting g500 (Thread starter):
They only chose EWR because of LGA perimeter rules. If DOT grants LGA exceptions, Alaska would be the first to jump on them.
Unlike IAD vs. DCA (which is far from convenient from nearly any part of DC), EWR is not much worse than LGA from certain parts of Manhattan. By the time you factor in traffic jams and terminal conditions, LGA's advantage is minimal.
spiritair97
Wed Aug 22, 2012 3:38 pm
Well, for starters, it's MUCH harder to get perimeter exemptions at LGA, and when they started NYC service, they were codesharing with CO.
DCA is much more conviently located in the city of Washington D.C., like LGA, except it was MUCH easier to get the permission for their flights.
roseflyer
Wed Aug 22, 2012 3:43 pm
LGA and DCA are preferrable airports but only perimeter exemptions are granted from DCA. AS did operate from IAD for a while after 9/11 before going back to DCA.
BoeingGuy
Wed Aug 22, 2012 3:47 pm
Quoting Roseflyer (Reply 3):
That's partially correct. They started DCA just before 9/11. When DCA was closed, they switched the flight (only one a day at that time) to IAD temporarily.
However, when DCA reopened, AS elected to also keep the IAD flight in addition to DCA. So they did both airports for several years. AS eventually did drop the IAD flight.
FI642
Wed Aug 22, 2012 4:05 pm
Traditionally yields at DCA are also much higher than IAD or BWI. Go where the cash is!
737MAX, Cool Planes for the Worlds Coolest Airline.
steex
Wed Aug 22, 2012 4:22 pm
Quoting mogandoCI (Reply 1):
Quoting spiritair97 (Reply 2):
There is no such thing as a perimeter exemption at LGA. The DEN flights exist because all LGA-DEN service is grandfathered in by virtue of flights being on the route before the perimeter was established. The perimeter also does not apply on Saturdays, allowing service beyond 1,500 miles. However, those are both passages within the rule itself, not exemptions.
Additionally, DOT would not be involved with the decisions at LGA, it is a PANYNJ rule that sets the perimeter. They would be the agency responsible for any relaxing of the rule or granting of exemptions if they so chose.
seabosdca
Wed Aug 22, 2012 4:46 pm
Money. The SEA-DCA flights print money for the airline, even though they're long transcons. LAX-DCA is also a very good flight, although not as strong as SEA because AS doesn't have the same frequent flyer base in LAX.
G500
Wed Aug 22, 2012 5:05 pm
yeah I figure as much
davescj
Wed Aug 22, 2012 6:19 pm
With AS having more code-shares with DL, I wonder if AS would consider a weekend LGA service and have DL do the check-in/boarding....
With the massive numbers of code shares, it could seem like a logical progression, no?
Dave
steex
Wed Aug 22, 2012 6:31 pm
Quoting davescj (Reply 9):
This isn't likely, there just isn't the demand for high-yield traffic on Saturdays to make it worthwhile - especially since AS would have to go to the expense of contracting DL (or someone) to do all the handling for a single flight at a new station.
You'll notice that none of the majors bother connecting their own beyond-perimeter hubs to LGA on Saturdays for the same reason (with the current exception of US to PHX, but that service also ends in a few weeks). The is no AA service to LAX, no UA to LAX/SFO, no DL to SLC, etc. Some of those have been tried at various times, but never work out. The demand just isn't there.
Ezra
Wed Aug 22, 2012 6:45 pm
Would there be any reason for AS to fly to JFK, or does DL have sufficient lift on that route for both airlines?
iowaman
Wed Aug 22, 2012 6:59 pm
Quoting g500 (Reply 8):
Quoting mogandoCI (Reply 1):They only chose EWR because of LGA perimeter rules. If DOT grants LGA exceptions, Alaska would be the first to jump on them.
While LGA probably wins out as the preferred airport, last time I flew into NYC from MSP I actually used EWR - it really isn't much further away from areas such as Manhattan than LGA, depending on what part of NYC a person is traveling to (especially Staten Island). DCA vs. IAD is much more cut and dry since IAD is way out in the western suburbs.
BoeingGuy
Wed Aug 22, 2012 7:00 pm
Quoting Ezra (Reply 11):
AA flies that route also which is the code-share wh*re's other biggest partner. Apparently AS feels that code-sharing with both AA and DL to JFK is sufficient.
kgaiflyer
Wed Aug 22, 2012 10:16 pm
DCA is much more conveniently located in the city of Washington D.C.,
Allow me to nitpick -- geographically, DCA is in Arlington County Virginia -- separated from Washington DC by the Potomac River. Makes no difference -- it's still convenient.
Quoting BoeingGuy (Reply 4):
I remember that -- they shared an IAD gate with BWIA (as it was called at the time)
BoeingGuy
Wed Aug 22, 2012 10:35 pm
Quoting kgaiflyer (Reply 14):
Yeah, it was like a 10 minute Metro ride. I did the AS flight to DCA and it couldn't possibly have been more convenient. It was probably the most convenient airport to any large city that I've ever flown into, given how convenient that Metro connection was.
Yeah, that makes an interesting trivia question that has been posed on A.net before (I think I actually posted it). Name the cities that mainline AS has dropped out of, not counting those that just turned over to QX (e.g. LTO). IAD is one of the less remembered ones (others off-hand are CUN, ACA, Top
gigneil
Wed Aug 22, 2012 11:10 pm
Quoting BoeingGuy (Reply 15):
I have long said so. DCA is by far one of most convenient airports ever.
NS
spiritair97
Thu Aug 23, 2012 12:12 am
You are correct. I should have know, given I actually have family who live in Arlington.
Tomassjc
Thu Aug 23, 2012 1:54 am
Also at the time AS started serving EWR they code shared heavily with CO, which I believe was a major factor.
Tomas SJC
When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward -Leonardo DaVinci
seabosdca
Thu Aug 23, 2012 2:01 am
I'll connect into DCA before I'll take a nonstop into IAD or BWI. That's how much more convenient it is.
I'm on those AS flights quite a bit (including this Saturday)...
wedgetail737
Thu Aug 23, 2012 3:45 am
Quoting seabosdca (Reply 7):
SEA-DCA is more popular because of the connection opportunities, especially to AK. PDX-DCA will perform just as strong as SEA-DCA because of the connection possibilities.
What surprises me is if AS has such a strong alliance with both DL and AA, then why doesn't AS start flying to JFK? Too much competition with AA, DL and B6?
RWA380
Thu Aug 23, 2012 4:57 am
I'm sure that it's impossible, except one day a week.
Quoting wedgetail737 (Reply 20):
I asked this question a few months back, even started a thread about it, and the answer I got over and over, was DL & AA which both code share that route with AS, have more than enough lift to cover it.
707, 717, 720, 727-1/2, 737-1/2/3/4/5/7/8/9, 747-1/2/3/4, 757, 767-2/3/4, 777, DC-8-5/6/7, DC-9-1/3/5, MD-80/2/3/7/8, DC-10-10/30/40, MD-11, F-27, F-28, SWM, J31, D38, DH7, DH8, DH4 SD-330, B-146, L-1011-2/500, ATR-42/72, VCV, A-300/310/318/319/320, CR2/7
gigneil
Thu Aug 23, 2012 5:19 am
Quoting seabosdca (Reply 19):
I used to.
Now I can fly there nonstop from most of the places I desire to go, like from home to there.
NS
