RyDawg82
Alaska Airlines Adding Pulsating Landing Lights?
Wed Aug 29, 2012 4:23 am
Howdy,
I noticed a Alaska Airlines B737-700 landing at DFW the other night with the landing lights pulsating (wig-wag). It was similar to what several classic B737 operators added in the 1990s here in the US -- and can still be seeing on many of the Southwest Airlines classics.
I noticed an article from August 2010 talking about AS doing an evaluation for pulsating landing lights to reduce bird hazards. I take it the evaluation was a success and FAA approval was obtained?
Does anyone have further information on this program? Also, what are the general operating parameters for this system? It appeared that the lights returned to steady on short final.
Ryan
atct
RE: Alaska Airlines Adding Pulsating Landing Lights?
Wed Aug 29, 2012 4:52 am
Ive used them a bunch in small planes. As a controller in the tower, they are awesome. Up here in Alaska there is a high percentage of GA planes with such lights and over time I think the mid-air rate up here will diminish. It makes a plane that is hard to see immediately spottable.
atct
Trikes are for kids!
RyDawg82
Wed Aug 29, 2012 5:10 am
I think the interesting thing is that in the 90's, 737 operators added them to increase visibility to other aircraft. As that article reads, airlines are now adding the pulsating lights to keep birds away.
alasizon
Wed Aug 29, 2012 5:42 am
Both AS and QX added these lights to their aircraft for both greater spatial awareness with regards to other operators along with wildlife. PDX and SEA both have large wildlife populations that live around the airport (PDX more so) and as such, these lights are beneficial.
Customer Operations Manager & Tower Planner
AirframeAS
Wed Aug 29, 2012 5:14 pm
Quoting RyDawg82 (Thread starter):
Are you sure you did not mistake it for a WN airplane? They are/were famous for those landing lights back in the day.
Why would you need approval is WN has been doing it already?
AFAIK, WN is the only U.S. Carrier that I know of that actually had those landing lights done that way.
Quoting RyDawg82 (Reply 2):
Got a source to all of that? Because WN is the only 737 operator that I know if that has actually had the lights done that way, as I stated before.
yeelep
Wed Aug 29, 2012 5:42 pm
They have been installed on some of the AS planes for a year or so. They had some issues and were deactivated until a few months ago. Horizon also has pulselites on the Q400's, but I don't know if they are currently activated.
Quoting AirframeAS (Reply 4):
Because the system AS and QX is using is not the same as WN's. http://preciseflight.com/commercial/
AirframeAS
Wed Aug 29, 2012 5:45 pm
Quoting yeelep (Reply 5):
So?? Got the FAA docket or the AS application for this, that is if it really does need to be approved for flight?
alggag
Wed Aug 29, 2012 6:00 pm
Why did WN stop doing this? I recall this being kind of a well published thing then it seems like they just stopped doing the conversions all of a sudden. Also, I'm fairly certain that the NGs do not have pulsing lights.
dtwmtx330
Wed Aug 29, 2012 6:07 pm
i saw a WN 737 (not sure which variant, but i know it wasnt a 700) land a DTW a couple days ago with the pulsating lights under each wing comming out of a flap track fairing.
AirframeAS
Wed Aug 29, 2012 6:15 pm
Quoting alggag (Reply 7):
Don't know. Maybe WN thought it was not necessary to use anymore or did not want to adopt the system in their NG's?
I think some of their older -300's still do this.
   I have never, ever seen a 737NG do this either.
yeelep
Wed Aug 29, 2012 6:18 pm
Quoting AirframeAS (Reply 6):
I only have the STC # ST11453SE
Quoting dtwmtx330 (Reply 8):
That would be a Classic, the NG's don't have any landing lights attached to the flap fairings, only at the wing root and the bottom of the fuselage.
AirframeAS
Wed Aug 29, 2012 6:24 pm
Quoting yeelep (Reply 10):
That is not even in the FAA database. I just checked for that. Unless if you wrote down the wrong STC number.....
RyDawg82
Wed Aug 29, 2012 9:12 pm
I can safely say that I did not mistake an Alaska B737 for a Southwest B733/B735 -- especially considering it was at DFW and the aircraft in question was operating ASA663.
Again, this was for the classic 737s whereas Alaska is doing this on Next Gen 737s
United Airlines did this in the mid-late 1990s too. Also, Shared Services Aviation who flew Oil charters from Anchorage on B732s had the system installed.
The ultimate difference being, the 1990s experiment was to increase aircraft visibility to other aircraft. Alaska and other airlines (Qantas) are now using such a system to mitigate bird strikes.
Ryan
AirframeAS
Wed Aug 29, 2012 9:14 pm
Quoting RyDawg82 (Reply 12):
Does anyone know if AS sends a 734 to DFW anymore? I thought this route was on a 738.
hatbutton
Thu Aug 30, 2012 1:56 am
Quoting AirframeAS (Reply 13):
No. According to T100 data the last time a 734 went to DFW was March of 2008.
AirframeAS
Thu Aug 30, 2012 2:06 am
Quoting hatbutton (Reply 14):
So then RyDawg82 confused himself that the aircraft he saw was a different 737 and that was NOT an AS airplane. This is what I thought.
steex
Thu Aug 30, 2012 2:22 am
Quoting AirframeAS (Reply 15):
Or maybe he saw exactly what he thinks he did. Pulselite initial tests were performed on both 734 and 738 aircraft, and the information below is a quote from the Precise Flight website ( http://preciseflight.com/commercial/ ).
Alaska Airlines
Alaska commenced a fleet-wide fitment of Pulselite on their Boeing 737 series aircraft in 2010. The system was endorsed by their safety, maintenance & engineering groups, and the senior pilot corps. The cost analysis they performed exceeded their internal criteria warranting fleet-wide implementation. With a business case based on known operating/damage costs and a conservative 25 - 30% bird strike reduction proved by Qantas, Horizon, and USDA research, they successfully demonstrated to management the justification (a less than a 2 year ROI) for installing the system.
In fact, AS has had some 73Gs outfitted and operating with Pulselite for over a year and is making the move fleetwide.
N766UA
Thu Aug 30, 2012 2:23 am
46 times a minute is a lot faster than WN's casual wig-wag...
This Website Censors Me
hatbutton
Thu Aug 30, 2012 2:31 am
It feels like you are coming down hard on this thread but I'm not sure why. I'm only confirming that the only airplanes that have been to DFW for AS were NGs. I don't see how someone could confuse an AS 737 with anything else. The livery is pretty distinct. Especially at DFW.
steex
Thu Aug 30, 2012 2:39 am
Here is some pretty strong supporting evidence for the OP's observation; video of an AS 738 at MSP with flashing landing lights. You'll notice the video was posted to youtube almost a year ago on 6 SEPT 2011.
http://www.youtube.com/watch?v=6Cc_VVnq9yY
[Edited 2012-08-29 20:02:03]
steex
Thu Aug 30, 2012 2:44 am
Quoting N766UA (Reply 17):
I think it seems about right to me, that's less than one flash per second.
N766UA
Thu Aug 30, 2012 2:48 am
Quoting steex (Reply 20):
Hmm, I dunno maybe. I'm just imagining them in my head and figured each light probably flashes once every 3 seconds, so more like 20 times a minute, but maybe you're right.
3DoorsDown
Thu Aug 30, 2012 3:34 am
Airframe, what's up? Why are you harshing on RyDawg. You of all people should know AS livery is nothing like WN. I and RyDawg and probably half the population in the Amazon can tell from 3 miles away that an AS plane is not a WN plane even from the front.
Quoting N766UA (Reply 21):
I've watched a lot of WN planes come in to SEA-TAC and 46 times a minute seems too many. But maybe in all the excitement of another 737 coming in I lose track of time.
N766UA
Thu Aug 30, 2012 3:48 am
Quoting 3DoorsDown (Reply 22):
That must be it. Nothing like having that jet come into view and realizing it's another blue 737…
They're everywhere!!
RyDawg82
Thu Aug 30, 2012 4:19 am
Since you would like to go there....I can safely say I saw exactly what I stated above. I can say this as I was the one who cleared said aircraft to land. I would hope I would be able to tell the difference between an Alaska Airlines and Southwest Airlines aircraft. Further, I would hope I could tell the difference between an B734 and B737.
Thank you for the others who have provided some great information on this program, much appreciated!
[Edited 2012-08-29 21:33:53]
AirframeAS
Mon Sep 03, 2012 12:59 am
That was never the issue.
Quoting RyDawg82 (Reply 24):
LOL! They're the same airplane, unless you meant 73G, then they're different.
Plus, the AS 734 hasn't been flown to DFW since 3/2008 according to Hatbutton.
OB1504
Mon Sep 03, 2012 1:19 am
Quoting AirframeAS (Reply 25):
It depends on whether you're using IATA or ICAO codes. The IATA code for a 737-700 is 73G, but the ICAO code is B737, so he's correct.
RyDawg82
Mon Sep 03, 2012 2:24 am
I most certainly meant B737 = B737-700, I have worked the airline side of things and realize what a 73G is. I specifically listed B734 and B737, not 734 and 737 (which would have been incorrect for Alaska -- or just a generic IATA code). I guess my consistency went unnoticed.
While I respect Hatbutton's input, N705AS has rolled through DFW a time or two since being put into the Alaska Statehood paint which wasn't unveiled until 2009. Other websites have photos of AS B734s here in 2009 as well. This of course is off topic as the aircraft in question was a B737.
Quoting OB1504 (Reply 26):
Thank you!
-R
jr
Mon Sep 03, 2012 2:32 am
I was on one of the 738s that had the pulsating lights just a few weeks back on SEA-DFW. I thought it was strange too and actually took out my camera and took a short video. Will have to upload it to youtube.
I've flown on 9V-SPK.
ZKSUJ
Mon Sep 03, 2012 5:39 am
We use it on the Q300s here in NZ. I've been told they reduce bird strikes quite significantly (I can't remember the exact figures but here was a big percentage in the reduction of incidents). The pulse is used during the day and non pulse at night
JoeCanuck
Mon Sep 03, 2012 7:36 am
We'll probably see them a lot more with the increasing certification of LED aircraft lights, improving the reliability. They draw significantly less energy than incandescents and they can take the cycling better than just about anything else.
Anything that increases the visibility of aircraft, from birds and each other, is a good thing.
What the...?
yvphx
Mon Sep 03, 2012 11:10 pm
Would the LED lights be something simular to what are now on the B788 wintip strobe lighting? I was siting infront of my computer the day it was broadcast on boeing.com the maidan flight. Could this be the possible future for all aircraft for energy savings, and to save costs of bulb replacement?
http://www.youtube.com/watch?v=Fucq5BoEfEI
JoeCanuck
Mon Sep 03, 2012 11:35 pm
Quoting yvphx (Reply 31):
I believe the strobes are LED's on the 787. A characteristic of LED's is their abrupt switching, going from on to off to on without fading in or out like incandescents. One can easily note the difference when following a vehicle
They are better in just about every way....except price, and that's getting better too. Unlike Xenon gas discharge strobes, they don't require a high energy ballast to excite the gas. The lack of a filament make LED's orders of magnitude cooler, more reliable and more energy efficient than incandescents.
As Martha Stewart might say; "It's a good thing".
What the...?
RyDawg82
Tue Sep 04, 2012 2:25 am
Those strobes may also be seen on the B748. Although, it's interesting that Boeing placed LED strobes in the wingtips, but left the red anti-collision and white tail strobe as incandescents. You can tell it's a B748 coming in versus a B744 from miles away for this very reason.
-R
cbphoto
Tue Sep 04, 2012 5:12 am
You know, I was sitting in SEA a few years ago and saw an Alaska 737 (not sure if it was a 700 or 800 type) land and taxi off with the landing lights pulsating. I meant to post something on here back then to find out if this was a test subject, or if the entire fleet was getting them. Thanks RyDawg82 for posting this thread!
ETOPS: Engines Turning or Passengers Swimming
JoeCanuck
Tue Sep 04, 2012 11:28 am
Quoting RyDawg82 (Reply 33):
I wonder why they'd do that? Maybe LED's aren't quite up to all tasks yet.
What the...?
AirframeAS
Wed Sep 05, 2012 12:05 am
Quoting jr (Reply 28):
Do you have this video up yet??
RyDawg82
Wed Sep 05, 2012 3:55 am
Quoting AirframeAS (Reply 36):
Quoting steex (Reply 19):
-R
AirframeAS
Wed Sep 05, 2012 4:02 am
Quoting RyDawg82 (Reply 37):
Interesting. Thanks, now I am convinced....
GSPSPOT
Wed Sep 05, 2012 10:44 pm
I've only seen this in smaller/corporate a/c. Interesting that commercial a/c would do that... WHY?
Finally made it to an airline mecca!
steex
Wed Sep 05, 2012 11:13 pm
Quoting GSPSPOT (Reply 39):
Quoting steex (Reply 16):
Alaska Airlines
