ghifty
Mid-Air Collision.. No Fatalities
Tue Sep 11, 2012 4:57 am
I'm honestly not quite sure what happened, and how no loss of life occurred.
"Two single-engine planes, flying side by side in the Netherlands, collide and become stuck together at the wings. Nobody was injured, but one plane was forced to crash land on the beach while the other safely landed at the airport."
Video link: http://www.youtube.com/watch?v=7Jkj63Vez98&feature=player_embedded
Can anyone determine type of aircraft? I assume it's a Cessna..
[Edited 2012-09-10 21:58:52]
Fly Delta (Wid)Jets
PH-BFA
RE: Mid-Air Collision.. No Fatalities
Tue Sep 11, 2012 8:52 am
Quoting ghifty (Thread starter):
Correct, the aircraft is a cessna 172. It looks like they never saw the aircraft flying in front of them.
Indeed quite a miracle that everyone escaped unharmed.. could have had a much different outcome..
PH-BFA
Tue Sep 11, 2012 11:35 am
Whats the TCAS requirements for the Aircraft type out there.....
Semaex
Tue Sep 11, 2012 12:10 pm
Somebody's up for a very big pay check....
Quoting HAWK21M (Reply 3):
There's no TCAS requirement for such small aircraft, and I doubt there really is a requirement at all for any aircraft, except when operating in certain airspaces, eg A/B/C/D in North America or Europe, but that's just my guess.
TCAS is an equipment that helps, but mustn't be used for relying on.
// You know you're an aviation enthusiast when you look at your neighbour's cars and think about fleet commonality.
PH-BFA
Tue Sep 11, 2012 12:16 pm
Quoting Semaex (Reply 4):
I assume you are talking about VFR / GA? Commercial airliners are certainly relying on TCAS, that is the whole purpose of it...
jgarrido
Tue Sep 11, 2012 1:45 pm
Quoting PH-BFA (Reply 5):
I suppose it depends on your definition of "relying", but in my experience and opinion as an air traffic controller if comercial aircraft were relying on (as in they are dependent on) TCAS to keep them safe then something is wrong.
je89_w
Crew
Tue Sep 11, 2012 1:51 pm
There's no TCAS requirement for small aircraft (less than 30 pax) not operating in RVSM airspace.
And even if these guys were equipped with some form of TCAS, it looked pretty intentional (and stupid) to me.
These guys are lucky.
PH-BFA
Tue Sep 11, 2012 1:54 pm
Quoting jgarrido (Reply 6):
Yes I agree it depends on the definition. What I mean is that when traffic conflicts occur, commercial airliners need to rely on the information given by the TCAS system. However I fully agree that in a perfect world there should not be any TCAS warnings  . Unfortunately that is not the case as we all know..
Semaex
Tue Sep 11, 2012 2:58 pm
Regarding TCAS and Mode S Transponders... isn't there some kind of legislation coming up (at least in JAR countries) where soon all aircraft have to be equipped with Mode S?
I know Mode S doesn't have anything to do with TCAS, but maybe someone can provide clarification whether TCAS will then also be a requirement? After all it's a hefty expensive piece of equipment.
Sorry if this is too off-topic.
MountainFlyer
Tue Sep 11, 2012 3:26 pm
It's absolutely amazing no one was killed, but this isn't the first time for something like this. It seems there are numerous stories out there of mid-airs with few or no fatalities including one from WWII with two B-17 bombers become stuck in mid-air.
Probably one of the most famous ones that I'm aware of happened in 1999 in Florida when a Piper Cadet collided on top of a Cessna 152 and they became stuck but still landed with no fatalities.
This was the best non-member link I could find for that story.
http://www.premierflightct.com/newsl.../TrainingArticles/AvoidMidair.html
SA-227; B1900; Q200; Q400; CRJ-2,7,9; 717; 727-2; 737-3,4,5,7,8,9; 747-2; 757-2,3; 767-3,4; MD-90; A319, 320; DC-9; DC-1
zanl188
Tue Sep 11, 2012 11:34 pm
A very gentle mid air...
pliersinsight
Wed Sep 12, 2012 12:26 am
Newer G-1000 equipped 172s may have TIS (Traffic Information Service) but it requires you to be in an area where ASR-7, 8 or 9 radar is operating. You will see other traffic on your display, but no avoidance information is supplied. It will alert you with a TRAFFIC indication on the display and a voice through the headset which says, you guessed it TRAFFIC. You will also see if the target is above, below or at your altitude. You can also fake it out, if your rate of turn is fast enough you will see a ghost target at your altitude chasing you. (Freaked me out the first time it happened while practicing steep turns, especially since I hit my own wake just as the target showed up) However, it will not show everything....and does not work outside of the radar coverage areas as discussed.
Having used it myself a number of times, it is nice to have, but in areas where it works, you are in a relatively controlled environment to begin with so it is not going to save you during most of the flying one does outside of a coverage area, but any extra information that increases the level of safety is always welcome.
RickNRoll
Wed Sep 12, 2012 12:37 am
IANAP, but shouldn't aircraft, even light planes like these, have some sort of seperation distance, with the primary responsibility resting with the pilot of the following plane?
Maverick623
Wed Sep 12, 2012 3:34 am
Quoting RickNRoll (Reply 13):
The correct terminology is "see and avoid". I don't know what type of airspace they were in, but even in controlled airspace (except for Class A and B), in VFR conditions, the responsibility is on the pilots to not hit anyone else.
That being said, that looked intentional.
"PHX is Phoenix, PDX is the other city" -777Way
RickNRoll
Wed Sep 12, 2012 3:56 am
Deliberate on who's part? It looks to me like the passing plane went too close to the plane in front.
Wed Sep 12, 2012 12:27 pm
TCAS helps when someone errors....
rcair1
Crew
Wed Sep 12, 2012 3:07 pm
Quoting MountainFlyer (Reply 10):
Interesting - but a search of the NTSB database for accidents in Plant City Florida shows nothing. Any ideas if this is real?
rcair1
