Byrdluvs747
AA In T6(In Theory)?
Wed Sep 12, 2012 1:27 am
Since T6 is a CUTE terminal(mostly) and open to other carriers, what would prevent AA from scheduling a flight or two from T6? I know that AS has preferential priority, but from previous posts I thought they were not using the total capacity of the terminal.
The 747: The hands who designed it were guided by god.
airliner371
RE: AA In T6(In Theory)?
Wed Sep 12, 2012 1:36 am
I assume you are talking LAX.?.?
Support Net Neutrality, Support airliners.net!
YankeesFan
Wed Sep 12, 2012 1:37 am
What airport uses "T6"? LAX???
[Edited 2012-09-11 18:49:40]
I hope you stand by your promises Obama. I will be really mad if you don't
iFlyLOTs
Wed Sep 12, 2012 1:46 am
well if it is LAX then aren't there also problems with UA? I thought this is where the majority of their mainline left from.
"...stay hungry, stay foolish" -Steve Jobs
gigneil
Wed Sep 12, 2012 3:05 am
The majority of United leaves from T7.... but post merger there are a fair number of flights from all three of their concourses - 6, 7, and 8.
NS
RyanairGuru
Wed Sep 12, 2012 3:15 am
Quoting Byrdluvs747 (Thread starter):
I'd suggest that the main problem is distance from T4. DL are OK because T5 and T6 are next to each other. Ditto UA with T6/7/8. For AA, however, there is a very real chance for passenger confusion if - say - a flight arrived at T6 and then you had to pick through Delta to try and find your case. It isn't really practical.
Worked Hard, Flew Right
apodino
Wed Sep 12, 2012 4:15 am
I know the gates aren't cute in that Terminal, but at JFK, T6 is used by OW partner BA.
cws818
Wed Sep 12, 2012 4:16 am
Quoting apodino (Reply 6):
That is T7. JFK's T6 has been demolished.
volgende halte...Station Hollands Spoor
Byrdluvs747
Wed Sep 12, 2012 6:05 am
Sorry. I can't believe I forgot to mention LAX in the title. That said I thought part of the deal between LAWA and AS was that T6 gates were CUTE(other than UA), but that AS had priority when it comes to scheduling.
With regards to practicality, I can't see operating flights in T6 as being any worse than using the Eagle's nest. The bus ride is shorter and the terminal is far less claustrophobic.
