727LOVER
This US@DCA Pic
Wed Sep 12, 2012 3:38 am
I guess this is sometime between 1979 & 1989. Where was this gate area?
http://www.ebay.com/itm/PRINT-of-US-...efaultDomain_0&hash=item4cfc4254de
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
apodino
RE: This US@DCA Pic
Wed Sep 12, 2012 4:29 am
I could be mistaken but I do believe that gate was from the Interim terminal that USAir was in for a while. It was Hangar 11 that was converted into a terminal for USAir, that they later shared with Delta, and was converted back into a Hangar after the new terminal was opened.
rktsci
RE: This US@DCA Pic
Wed Sep 12, 2012 7:05 am
Quoting apodino (Reply 1):
I don't think so. I lived there for the beginning of the period of the Interim Terminal and I never recall BAC 1-11 aircraft (or that colorscheme) at that terminal.
donindc
RE: This US@DCA Pic
Wed Sep 12, 2012 12:58 pm
This is definitely not the interim terminal. All the boarding bridges connected from the upper level. I believe this is the old North concourse that was demolished in the early/mid '90s to make room for the new terminal.
SeeTheWorld
RE: This US@DCA Pic
Wed Sep 12, 2012 1:30 pm
This was an area close to the old Eastern and Pan Am Shuttle .. It was a dreadful part of the terminal that was south of the Interim Terminal and North of the original Main Terminal Building. This area was demolished at about the same time the Interim Terminal was being constructed.
deltacto
RE: This US@DCA Pic
Wed Sep 12, 2012 11:40 pm
Prior to US Air moving to the Interim terminal, they used gates 15,16,17 in the Main Terminal
These gates were on the lower level of the AA concourse
http://www.departedflights.com/DCA0584.html
Delta Shuttle took over these gates aftern US moved to the Interim Terminal
http://i28.photobucket.com/albums/c2...Historic%20Files/DCAMap-1-2004.png
[Edited 2012-09-12 16:46:03]
Good info on DCA history NWA.com's Decade-old DCA Map (by Cactus742 Aug 11 2007 in Civil Aviation)
[Edited 2012-09-12 16:47:26]
N202PA
RE: This US@DCA Pic
Thu Sep 13, 2012 6:33 pm
Quoting deltacto (Reply 5):
http://i28.photobucket.com/albums/c2...4.png
Hey cool! I remember scanning in that map and posting it to A.net years ago.
One thing..when the North Terminal was demolished (located where the southernmost pier of the B/C terminal now exists), Pan Am took over these gates (lower level of the gate 9-17 pier) - 15 and 16 were used by mainline Pan Am and Express while the Shuttle used 17. At about the same time, US Air and Delta/Delta Connection moved to the Interim Terminal. I assume Delta took over the 15-17 gates when they bought the Shuttle from Pan Am. Anyway, this pier was demolished in the mid-90s.
727LOVER
RE: This US@DCA Pic
Thu Sep 13, 2012 6:45 pm
OK, I know where that was, but WOW, connecting from USAir to/from Allegheny Commuter wasn't easy.
N202PA
RE: This US@DCA Pic
Thu Sep 13, 2012 7:53 pm
Quoting 727LOVER (Reply 7):
Nope, it probably wasn't. There WAS a Commuter Terminal building located in the area of the parking lot on that old map - it was to the north of the gates at the very end of the North Terminal (if I remember right, that's where Piedmont had their gates). Allegheny Commuter and Henson flew out of there, in addition to a few other small-time operators. The CT was demolished sometime before US/DL ops moved over to the Interim Terminal.
