SQ22
US Flying A321 On Route PHL-SJU In 2013
Wed Sep 19, 2012 6:01 pm
I was just checking some prices on US between PHL and SJU. According to their website US1077/1078 will be operated by A321 on April 12th/April 14th 2013.
In this thread US A321 Performance (by Xcltflyboy Sep 9 2012 in Civil Aviation) I was asking if they are going to use the A321 on this route replacing the B757 (reply 74).
The answer was that the A321 are not equipped for EOW operations (reply 75).
So will the next deliveries be EOW-equipped? Will some aircrafts be refurbished?
longhauler
RE: US Flying A321 On Route PHL-SJU In 2013
Wed Sep 19, 2012 6:17 pm
It depends on how overwater you want to get.
A great circle route would take you through New York Oceanic, so HF radios are required. Also, depending on US rules, slide/rafts may also be required. (With Canadian rules, you can go up to 400nms without requiring rafts, so they would not be required).
By going south, then about 200nms north of NAS, heading along the islands would add about 200 nms to the flight, but HF radios would not be required.
Life jackets are required on either route.
gigneil
Wed Sep 19, 2012 6:24 pm
With something like 13 A321s being delivered this year and 60+ already in the fleet, I am imagining they could have a few overwater equipped planes either now, or soon enough if they wanted them.
NS
santi319
Wed Sep 19, 2012 6:29 pm
They have used 321s on this route before.
southwest737500
Wed Sep 19, 2012 6:52 pm
Why is this a surprise they use for that
Next flight: TUL-ATL-CLT CRJ900 and MD88
plateman
Wed Sep 19, 2012 9:20 pm
No news here .... I'm flying US SJU-CLT around Thanksgiving and was scheduled as an A321, but switched to B762 and already full
"Explore. Dream. Discover." -Mark Twain
Mainliner
Thu Sep 20, 2012 7:23 pm
I've flown CLT-MBJ on an A321 when they upgraded it from an A320 at the last minute. Can't remember what the exact routing was, but it wasn't very direct.
Every flight counts.
drerx7
Fri Sep 21, 2012 12:53 pm
Quoting southwest737500 (Reply 4):
Because we are trying to understand the routing due to the 321s not Overwater equipped.
HOUSTON, TEXAS
etops1
Fri Sep 21, 2012 1:08 pm
When we fly the A321 to SJU from PHL we usually "hug" the east coast , followBahamian chain , stay close to Hispaniola and on into Puerto Rico from there . It adds a little more time to the flt but its complete doable . I have worked it many times before .
longhauler
Fri Sep 21, 2012 2:57 pm
Quoting Mainliner (Reply 6):
Over-water equipment should have no effect on a CLT-MBJ routing. If your flight was not as direct as optimum, then other factors may have been at play. In that area, my first guess would be weather.
Quoting etops1 (Reply 8):
It adds about 20 minutes to flying time. The routings shown from flightaware comparing the B757 to the A321, make me wonder what over-water equipment is on US's A321s, as it appears to be closer to shore than necessary. Do they even have life jackets?
etops1
Fri Sep 21, 2012 5:55 pm
The A321's are not EOW equipped but they do have life vests . They do not have slide/rafts at the doors . Just regular escape slides . A number of east A319's are EOW . Not all . All East A320's are EOW equipped . I don't know about west based 319's and 20's although I will go as far as saying they are not EOW ( Extended Over Water ) Equipped . Someone correct me if I am wrong .
SQ22
Sun Sep 23, 2012 10:02 am
Wouldn't it be cheaper in the long run to use EOW equipped A321 compared to the higher fuel burn on the current A321 route?
What are the estimated costs for EOW equipment?
[Edited 2012-09-23 03:55:14]
southwest737500
Sun Sep 23, 2012 1:17 pm
Quoting drerx7 (Reply 7):
They've been doing this for years, how does the topic pop up now
phlwok
Sun Sep 23, 2012 5:20 pm
Quoting southwest737500 (Reply 13):
Yup. I recall flying a 321 on PHL-SJU not later than 2007, and they're in the photo database here going back to 2006. I actually think they've been flying them there longer than that.
SQ22
Sun Sep 23, 2012 5:41 pm
Simply because I haven't flown on the route before and I wanted to know what is going to happen if all B757 are gone.
