mozart
Will AA's A321 Have The Legs To Fly JFK-LAX/SFO?
Mon Sep 24, 2012 7:53 pm
I read that AA plans to use A321 for the JFK-LAX/SFO routes.
I was wondering whether the A321 has the legs to do these flights without fuel stops all year long? JetBlue often struggles when flying trans-Continent on A320s and so sometimes does VX. The planes that make it no problem are VX' A319.
So what is behind this?
lhcvg
RE: Will AA's A321 Have The Legs To Fly JFK-LAX/SFO?
Mon Sep 24, 2012 8:00 pm
321NEO's will have various improvements (Sharklets, new engines, etc.) that will make it plenty doable. The issue that keeps cropping up is that while both the MAX and NEO large versions will be capable of year-around westbound U.S. transcons, Europe is still probably a bit much for them.
DocLightning
Mon Sep 24, 2012 8:12 pm
Quoting LHCVG (Reply 1):
And with good reason. The 737MAX has similar performance.
Currently, airlines are using 757's on transatlantic routes because 1) they have the 757's and 2) they can fill them. No airline bought the 757 with the idea in mind of using them chiefly on transatlantic routes.
Once the 757 is retired, airlines will stop using NB's across the pond for lack of NB's to use. No major airline's business model revolves around 757's on transatlantic routes.
That said, the inability of the A321 to reliably do an East-West transcon during the winter was one reason why it never sold very well in the US. VX has said that their main reason for buying the A319 was because it could reliably fly JFK-SFO and JFK-LAX during the winter. Winds and weather on that route are such that often the flight path goes over the Dakotas. I was once on a flight that took almost seven hours on that route on an A319. In reality, VX would rather have a larger aircraft that could do the same route reliably.
The 321NEO and 739MAX will be able to perform all but the most extreme 757 missions with a much lighter airframe and a much more efficient engine. They aren't, of course, direct replacements, but then again, direct replacements are very rare.
-Doc Lightning-
-Carl Sagan
Stitch
Mon Sep 24, 2012 8:15 pm
Quoting DocLightning (Reply 2):
I think Lightsaber might be on to something with his belief that the 737-8 and A320-200neo will both replace the 757-200 on existing routes and open new routes across The Pond.
syncmaster
Mon Sep 24, 2012 8:18 pm
I was on a VX A320 that took 7 hours and 15 minutes take off to touchdown on BOS-LAX due to strong headwinds.
DocLightning
Mon Sep 24, 2012 8:22 pm
Quoting Stitch (Reply 3):
That depends on whether it can be done economically. Flying an airliner to its absolute extreme of range usually means sacrificing payload. Also the 737-8 is not a 757-200 equivalent as far as passenger capacity and cargo are concerned.
At present, there is a 737-700ER offered that can easily do transatlantic flights. It's basically the 73J BBJ in a commercial configuration. I don't think it's accrued even a single order.
-Doc Lightning-
-Carl Sagan
seabosdca
Mon Sep 24, 2012 8:42 pm
The A321 already does transcons every day for US, including PHL-SFO and PHL-LAX. There are a few fuel stops (between *all* the flights) every year. AA's configuration won't be as dense as US's. It's not an issue, especially if AA's A321s are delivered with sharklets.
Quoting DocLightning (Reply 5):
When Lightsaber talks about this, he is not referring to the current iterations of the A320neo and 737 MAX 8; he's talking about R&D now being done to significantly extend the range of those two aircraft. I could imagine a variety of measures that could be applied to either one, from wingtip extensions to higher-thrust engines to revised high-lift devices to ACTs, to significantly increase MTOW and fuel capacity and improve field performance for transatlantic missions.
slcdeltarumd11
Mon Sep 24, 2012 9:06 pm
AA will operate these with less passengers therefore less luggage and people weight
AA737-823
Mon Sep 24, 2012 9:15 pm
ANA flies them. Not ALL ANA 73G's are ER's, but they do have a small subfleet.
jfk777
Mon Sep 24, 2012 9:23 pm
AA is going to have only about 100 passengers as they have First, Business and Economy Class. Their seat map is about 80 people less then the standard seat map for an A321. AA is not going to put an airplane that " has to stop" between JFK and LAX.
spiritair97
Mon Sep 24, 2012 10:30 pm
Quoting syncmaster (Reply 4):
Holy Crap! I've heard of headwinds making flights longer, but I'm surprised you didn't have to divert. Do you circle anywhere before landing?
tommy767
Mon Sep 24, 2012 10:32 pm
They will be configured in a low density format so they should be fine doing transcons year round.
"KEEP CLIMBING" -- DELTA
enilria
Mon Sep 24, 2012 11:27 pm
Quoting mozart (Thread starter):
The current A321 could not do it except with a very low density seating configuration.
I think the NEO will be close. Do we know the seating config? If they run a 3 class setup, it'll be fine.
dirtyfrankd
Mon Sep 24, 2012 11:39 pm
3-class setup with 102 passengers, it will be able to handle the route with no problems. Search function is your friend...this has been discussed at length in similar threads.
phlwok
Mon Sep 24, 2012 11:56 pm
Quoting enilria (Reply 12):
I'm having trouble understanding this. I've flown PHL-SFO, 2,521 miles as the crow flies, probably a hundred times on US A321-200s and not diverted once for fuel. JFK-SFO is 2,586 miles, and JFK-LAX is 2,475 miles (PHL-LAX is 2,401 miles, which I've also flown countless times with no diversions). Granted, they likely go out with a cargo penalty at times, but it's not as though they have to top up in RNO, OMA or somewhere else along the way, or are barely making it to SMF on fumes. US does not fly these aircraft in a low density config - F16 Y167 with soon to be 4 or so more Y seats.
AA is planning a low density config with a design that's maybe 15 years newer with better range and fuel efficiency from a variety of evolutionary improvements to aerodynamics and engines. Why are we even discussing them not having the range? I'm not trying to stir the pot here, just genuinely trying to understand why this is even a question.
seabosdca
Tue Sep 25, 2012 12:14 am
Quoting PHLwok (Reply 14):
Me too. Recent A321s in a standard airline configuration have no trouble with transcons except on the very worst edge days. Add a less dense configuration (although heavier seats will cancel some of the benefit) and sharklets, and AA will be in gravy.
The whole A32x/transcon issue is overblown, and the reasons are from the past: 1) UA's original frames had some trouble with their very longest flights, and 2) B6's extremely heavy original A320 configuration had some trouble. Neither presents an issue with a light configuration on a recently built aircraft.
slcdeltarumd11
Tue Sep 25, 2012 12:34 am
Quoting jfk777 (Reply 9):
Also the luggage weight of 80 less passengers can be huge.
USAirALB
Tue Sep 25, 2012 1:36 am
I don't understand why people think the A321 has problems doing transcons.
Old A321s (aka A321-100) had a smaller range than the A320 and was restricted to European flights. The A321-200 that US/AC currently operate on their transcons was specifically designed to handle transcon flights. US has been operating the A321s on transcon routes without any problems for 12 years now...
E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 752, 753, 762, 772, 77W, 319, 320, 321, 332, 333, 343
sunrisevalley
Tue Sep 25, 2012 2:02 am
Quoting USAirALB (Reply 17):
A.net has a number of canards and this is one of them.
jporterfi
Tue Sep 25, 2012 6:33 am
I find it difficult to believe that BA can operate A318s TATL from SNN to JFK westbound and JFK-LCY eastbound, which is about 400 nmi longer than JFK-LAX/SFO while people think that the A321, which has a range of only 100 nmi less than the A318 (and that's the current generation, not A321neos), will have problems doing transcons. AA's 100-seat configuration will be about the same as BA's configuration on the A318s. I don't think AA will have a problem, particularly if they opt for the optional extra fuel tanks on their A321s.
Quoting sunrisevalley (Reply 18):
I looked up the word "canard" and originally thought you meant the aviation definition (a small wing on the front of some aircraft that substitutes for the horizontal stabilizer)!
flybyguy
Tue Sep 25, 2012 6:56 am
But with those hefty business and first class seats (on the order of 300lbs+ per seat pair) as well as the new AVOD system in all classes, I think the aircraft may still be quite heavy despite the lower pax count.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
f4f3a
Tue Sep 25, 2012 7:15 am
If the range is 2400 ish miles that should be no problem
Airlines in uk fly regularly from London to ssh and lux
Which is about the same distance . In fact U2
Operate a320 with 180 PAx on it with out the optional
Long range tanks .
Very rarely do they have to fuel stop . It's much more
Economical to do that than run 757 just to avoid.
Airlines these days are worried by cost that's why they carry
Min fuel . It's cheaper to have less fuel burn the majority of the
Time and occasionally divert
Burkhard
Tue Sep 25, 2012 7:22 am
Quoting jporterfi (Reply 19):
These are not standard A318, but the buisiness jet, and only a few business class seats, no Y. AA will have many Y seats on the A321 I'm sure.
But while the A321-200 is at its EDGE for US coast-coast, the NEO can do it and is almost optimized for that. The TATL I expect to go either wide body 787/A330 oncethe 757 are at EOL, or to become a domain of the A319NEO for direct connections which have significant C and high yield Y demand.
UALWN
Tue Sep 25, 2012 7:38 am
Quoting Burkhard (Reply 22):
Is it? Add me to list of people who has flown many times PHL-SFO on US's A321s, without ever experiencing a diversion. As pointed out above, PHL-SFO is 2521 mi long, that is, only 65 shorter than JFK-SFO, and actually 46 longer than JFK-LAX....
AT7/111/146/Avro/CRJ/CR9/EMB/ERJ/E75/F50/100/L15/DC9/D10/M8X/717/727/737/747/757/767/777/787/AB6/310/32X/330/340/380
Pacific
Tue Sep 25, 2012 8:10 am
From a past A.net thread regarding US Airways A321s:
US A321 Performance (by Xcltflyboy Sep 9 2012 in Civil Aviation)#menu27
Quoting gigneil (Reply 50):
US's A320s were stopping, not their A321s.
The A321 offers two ACTs, just like the 737-900ER. Their ranges are practically identical.
In practice, most deployed 737-900ERs have less range than 737-800s.
NS
Quoting wn676 (Reply 24):
All US A321s (pre- and post-merger aircraft) can carry up to 52,000 lbs of fuel as they have two ACTs installed in the aft cargo bin.
Quoting seabosdca (Reply 47):
The stated 3200 nm range (of the 737-900ER) is with two AFTs. No US airlines are taking their 739ERs with both AFTs
So today's A321 operating in the USA offers similar range to that of the B737-900ER, both of which have no problems doing Transcons except during the rare 200knot headwind. Add in the lower seat density and technological advances that AA's future A321s will have and transcons will be absolutely no problem - provided AA puts in the extra fuel tanks.
[Edited 2012-09-25 01:12:59]
RWA380
Tue Sep 25, 2012 8:49 am
Quoting spiritair97 (Reply 10):
We did 5 1/2 hours on an M80 flying BOS-DEN, we came in pretty quickly when we arrived (no circling) maybe the pilot was tapping the gas gauge and needed in fast, I just flew an NK 319, and I would have slit my wrists had the flight taken as long.
707, 717, 720, 727-1/2, 737-1/2/3/4/5/7/8/9, 747-1/2/3/4, 757, 767-2/3/4, 777, DC-8-5/6/7, DC-9-1/3/5, MD-80/2/3/7/8, DC-10-10/30/40, MD-11, F-27, F-28, SWM, J31, D38, DH7, DH8, DH4 SD-330, B-146, L-1011-2/500, ATR-42/72, VCV, A-300/310/318/319/320, CR2/7
SKAirbus
Tue Sep 25, 2012 9:02 am
It sounds ironic, considering the aircraft on paper is smaller than the 757, but with British Airways at least, there is more capacity on the A321 than they had on the 757s.
If the plane has the legs to do East Coast US to the Europe, maybe with future upgrades to engines and fuel tanks (an A321NEO ER??), it could be a worthy replacement to the 757 on lower capacity routes.
Next Flights: LHR-OSL (738), OSL-CPH (320), CPH-LHR (321), LHR-HEL (359), HEL-LHR (359)
XT6Wagon
Tue Sep 25, 2012 9:08 am
Nah, The 737MAX and A32xNEO both can offset thier smaller size with far smaller operating costs. If an airline wants to, they certainly can operate either frame in a lower density configuration to keep the range up.
rfields5421
Tue Sep 25, 2012 1:21 pm
Wind conditions are completely different on those two routes which can easily make the extra distance from SNN-JFK much easier to cover than JFK-LAX.
While the North Atlantic has some major jet stream issues, the NAT system moves the routes everyday to maximize the wind advantage headed east, and minimize the winds headed west.
However over the central US, the winter jet streams often leave airline route planning with two bad options - several hours against the jet stream, or 500-800 nm diversionary routes.
If the North Atlantic has similar wind issues to the central US on one day, many airlines will cancel flights, and others will plan to make fuel stops in Newfoundland or Nova Scotia.
http://squall.sfsu.edu/gif/jetstream_norhem_00.gif
You can see today that east bound across the Atlantic today - the aircraft will cross a section of the jet stream at about 90 degrees from their course and be routed to avoid the stretch Greenland to Newfoundland and the east coast of Canada.
longhauler
Tue Sep 25, 2012 1:54 pm
When I flew the A320s, I often flew an A321 YYZ-SFO. There was always open weight and only once were we carrying maximum fuel. And ... AC's A321s are only equipped with one ACT. With two ACTs, I would guess that JFK-SFO would be no problems except under extreme wind conditions.
r2rho
Tue Sep 25, 2012 2:13 pm
There was an article in the American Way magazine about the new cabin to be introduced on the - using AA's own words - A321 transcontinental. Hopefully this is enough proof that they will be transcon-capable, since previously stated facts and a.net threads do not ever seem to be enough. An current-build A321 with sharklets, let alone a NEO, will have no issue doing transcons.
kgaiflyer
Tue Sep 25, 2012 2:33 pm
Astraeus Air proved the 737-700 can do it with YQM-LGW service before the airline's demise.
Quoting seabosdca (Reply 15):
AC has been flying the 321 longest in North America with a 20/154 configuration. I've flown the 321 -- both YYC-YYZ and YVR-YYZ in midwinter -- both eastbound and westbound -- without any tech stops. The answer? Obviously Canada doesn't have any winter headwinds
airbazar
Tue Sep 25, 2012 3:07 pm
Maybe with the original A321 but today's A321's are more than capable of flying transcons all year round, save on very few exceptions.
Quoting seabosdca (Reply 6):
And I don't think they have the aux fuel tanks either.
European carriers have been flying longer routes with A321's for years, albeit mostly north-south routes, but with higher density configs.
ROSWELL41
Tue Sep 25, 2012 3:10 pm
A new A321 with ACT's (auxillary center tank) will have no problem on these transcon routes, especially with the low density passenger configuration.
jwhite9185
Tue Sep 25, 2012 6:27 pm
Wow - i was on a VS flight LHR-JFK last week that took only 9 minutes longer!
@mytripreport
kgaiflyer
Tue Sep 25, 2012 8:23 pm
Quoting jwhite9185 (Reply 34):
Yup.
I was on a DTW-ANC 757 that took that long because of 180 knot headwind.
United_fan
Tue Sep 25, 2012 8:38 pm
No offense,but would AA really order an A321 to do trans-cons that couldn't do them without stops?
Champagne For My Real Friends,and Real Pain For My Sham Friends
AA94
Tue Sep 25, 2012 9:32 pm
Did you even read the above responses? AA's A321 will be configured in a three-class, 102-seat configuration. F10J20Y72. That's very low density. I don't consider 72 seats in Y to be very "many."
Quoting United_fan (Reply 36):
Thank you for taking 30 seconds to think about the question logically. AA didn't order 130 A32x family aircraft on a whim. They obviously aren't going to bet a huge order on an aircraft that can't get the job done.
If you can't take the heat, you best get out of the kitchen
syncmaster
Wed Sep 26, 2012 6:09 am
Quoting RWA380 (Reply 25):
No, thankfully, I was ready to get off the plane when we landed. VX is a great airline, but I can only sit so long in one spot.
I would have rather gone that direction! I flew JFK-DUB last summer and it was barely over 6 hours!
Sounds like AA won't be maxing these birds out, which should certainly help.
