DocLightning
Will Airbus Respond To The Sky Interior?
Mon Sep 24, 2012 8:19 pm
So one area in which I feel that Airbus does tend to lag behind Boeing is in their aircraft interior design. I'm not talking about cabin comfort, which I've found to be excellent, but rather the overhead design.
Since the 777, Boeing has tended for curving, swept, sculpted overhead surfaces that conceal large storage volumes. Airbus did introduce a similar design on the A380, but many airlines seem to have switched to a more traditional architecture. That said, on a widebody, this becomes much more of an aesthetic issue than a functional one.
What I'm wondering is whether Airbus plans on responding to the narrowbody interior that Boeing has introduced. The Boeing interior does offer larger bins while also increasing headroom and dramatically improving the general appearance of the cabin.
Does anyone know if they are working on this over in Tolouse?
-Doc Lightning-
-Carl Sagan
Viscount724
RE: Will Airbus Respond To The Sky Interior?
Mon Sep 24, 2012 8:32 pm
Quoting DocLightning (Thread starter):
I don't think many passengers choose an airline based on the design of the ceiling. I find Airbus overhead bins on narrowbodies as large as Boeing bins, and easier to access, That's probably at least in part due to the wider Airbus fuselage.
The new Boeing pivot bins also have more moving parts and I expect that will involve higher maintenance expenses. I have been on a couple of BA 777s where several bins were jammed and unusable. That rarely happens with a simple hinged door.
Overhead air vents, reading lights and call buttons also seem more more effective and easier to access on Airbus aircraft than with the new Boeing interiors.
AirframeAS
Mon Sep 24, 2012 9:18 pm
If you have flown on any new build Airbuses, they have the enhanced interior. F9 has some of them. 951FR, 952FR, 953FR, 205-216FR has them, just to point out a few aircraft.
B6JFKH81
Mon Sep 24, 2012 11:17 pm
Quoting AirframeAS (Reply 2):
I was trying to get comparison pics from the database on here using my airline as an example....unfortunately all the interior shots are from the "classic" cabin
But you are correct, the "enhanced" cabin was a refresh with some different lighting and most notably the sidewalls which were smoothed out and the foward attendant panel which became a touch screen. It did modernize the look quite a bit.
DocLightning
Mon Sep 24, 2012 11:35 pm
Quoting Viscount724 (Reply 1):
Then why did Boeing go to the trouble? I agree, it isn't all about passengers, but when the plane looks good, passengers notice and might say good things about that airline.
-Doc Lightning-
-Carl Sagan
col
Tue Sep 25, 2012 12:22 am
Leave the Airbus bins/interior as it is, it is much better than Signature. What percentage of 737NG's are supplied with Signature Interiors?
AirframeAS
Tue Sep 25, 2012 12:37 am
Quoting B6JFKH81 (Reply 3):
This was around before the enhanced cabin came about. You can find this on N949FR and all of the A318's that F9 has.
Quoting col (Reply 5):
Signature Interiors
Whats the "Signature Interior"? What's that? You mean the SkyInterior? Boeing just rolled out the SkyInterior this year or at the end of 2011, IIRC.
B6JFKH81
Tue Sep 25, 2012 12:45 am
Quoting AirframeAS (Reply 6):
Yes, I know, but once the enhanced cabin came out it was a standard panel and not an option like in the classic cabin. I know we tried to keep the original panel for commonality purposes and Airbus was not going to do it without it costing us waaaaaaay too much so we upgraded to the touch-screen.
1337Delta764
Tue Sep 25, 2012 12:52 am
Practically almost all of them. The only one I believe who did not is Ryanair.
XT6Wagon
Tue Sep 25, 2012 12:54 am
The A32x series got a new interior before the 737NG did.
FriendlySkies
Tue Sep 25, 2012 1:01 am
It's the previous generation of 737 interior. The Sky Interior replaced it.
col
Tue Sep 25, 2012 1:43 am
Quoting 1337Delta764 (Reply 9):
What about the Chinese carriers?
tullamarine
Tue Sep 25, 2012 2:01 am
Whilst I quite like the Sky Interior, it was undoubtedly more of a necessity for Boeing than Airbus doing anything extensive to the A320 interior.
As well as the bigger bins, the main benefit of BSI is an impression of more space. The higher and wider cabin of the A320 already has this impression which is further enhanced by the higher positioned windows.
717, 721/2, 732/3/4/5/7/8/9, 742/3/4, 752/3, 762/3, 772/E/W, 300,310, 319,320/1, 332/3, 388, DC9, DC10, F28, F100, 142,143, E90, CR2, D82/3/4, SF3, ATR
AirframeAS
Tue Sep 25, 2012 2:13 am
Quoting FriendlySkies (Reply 11):
Oh, right. I forgot they called it that. Brain fart, my bad.
tdscanuck
Tue Sep 25, 2012 2:18 am
Quoting DocLightning (Reply 4):
1) It's considerably lighter.
2) The new LED lighting throws less heat, simplifying cooling issues, and it lets airlines play with the interior color scheme without having to alter the sidewalls.
3) It ties in with the improved cabin experience branding that Boeing really started to push with the 787.
Tom.
United1
Tue Sep 25, 2012 2:34 am
Quoting col (Reply 12):
AFAIK all of the NG 737's (including the FR aircraft) have either the Boeing Signature interior or the Sky Interior.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
roseflyer
Tue Sep 25, 2012 3:36 am
Actually the opposite is true. Pivot bins have the bag being smashed against the top of the bin when someone overstuffs it. This reduces maintenance expenses because the bags get smashed rather than hinges being broken when a door on a self bin is forced shut.
EddieDude
Tue Sep 25, 2012 4:26 am
I recently flew on a very new Interjet A320 and it had the new Airbus A32X interior. I found it very pleasant. It might be less futuristic than the Sky Interior, but it is very clean and handsome.
[Edited 2012-09-25 13:55:06 by srbmod]
ssteve
Tue Sep 25, 2012 4:31 am
I was just on a B6 A320 that had updated PSUs... same thing? Really not much other noticeable difference, other than maybe seat cushioning.
flybyguy
Tue Sep 25, 2012 3:13 pm
The Boeing sky interior was designed in part for aesthetics, but mostly for weight reduction and increased efficient use of cabin space. The pivot bins were designed to carry more bags than the original NG bins. Additionally, the Boeing Sky Interior offers maintenence savings through use of LED lighting, new cabin management system and passenger service interfaces. I'm sure airbus has made incremental changes to cabin furnishings to improve aesthetics and weight savings. The Boeing Sky Interior is an expensive option and neither Boeing or the airlines would sign on to it if it didn't provide benefits that went beyond asthetics.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
TWA772LR
Tue Sep 25, 2012 7:40 pm
One thing I've noticed on the A319 is the condensation fog coming out of the AC vents, which looks really cool. But the actual interior was kind of bland even though it was sUA. But from photos I have seen on here, it seems all A320 family aircraft look that way, minus the seat choice.
"The only man who never makes mistakes is the man who never does anything." ~~Theodore Roosevelt
AirPacific747
Tue Sep 25, 2012 8:28 pm
This year I've flown with both a brand new DY 737-800 and a brand new AB A320. They were both very nice aircraft as a passenger. The Airbus has the nicest cabin since it is wider, but the sky interior is nice as well.
