YYZatcboy
What's Going On In JFK/BOS?
Tue Sep 25, 2012 6:48 am
Getting all of these TMI's flashing up... Anyone know what's going on out there?
ATCSCC ADVZY 002 DCC 09/25/2012 JFK DEEZZ3 DEPARTURE UNAVAILABLE_FYI
MESSAGE:
THIS REPLACES ADVZY 019. NO CHANGES.
THE JFK DEEZZ3 DEPARTURE IS UNAVAILABLE UNTIL 09/25 1815Z DUE TO
SPECIAL ACTIVITY AT Macedonian Airlines (Greece)">IN THE NY AREA. DEPARTURES NORMALLY FILED THE
DEEZZ3 NEED TO FILE VIA RBV..ETX.J60 OR RBV.J64
ATCSCC ADVZY 004 DCC 09/25/2012 - SPECIAL OPS_RQD
RAW TEXT:
ATCSCC ADVZY 004 DCC 09/25/12 - SPECIAL OPS_RQD
***REPLACES ADVZY 22 --
DUE TO ONGOING SPECIAL OPERATIONS THROUGHOUT THE COUNTRY,
AIRCRAFT MAY BE REROUTED TO AVOID HIGHLY SENSITIVE AREAS.
THESE REROUTES AND OLD: Guangzhou - Baiyun (CAN / ZGGG) (closed), China">CAN BE DYNAMIC WITH LITTLE LEAD TIME DUE TO
SECURITY PROCEDURES. USERS SHOULD BE AWARE OF THESE CONSTRAINTS
AND THE POSSIBILITY OF TRAFFIC BEING REROUTED AIRBORNE.
IMPACTED ROUTE: ZBW ARRIVALS FROM/THRU ZDC
ASSIGNED REROUTE:
BOS... IF AT OR ABOVE ** FL260 ** VIA NORMAL ROUTES
... IF BELOW ** FL260 ** VIA J121 J174 ZIZZI DRIFT
CCC ORW ORW5 BOS
MHT... IF AT OR ABOVE ** FL260 ** VIA RBV ALB EEN MHT
... IF BELOW ** FL260 ** VIA FAK MICAH J220 J49 ALB
EEN MHT
FOR ZBW ARRIVALS TO ALB/BDL/HFD/SWF/POU
FROM OR THROUGH ZJX/ZDC/ZMA/ZTL VIA:
ALB... VIA J51 FAK AML J220 MICAH CFB RKA ALB
BDL... VIA J174 ZIZZI DRIFT CCC MAD MAD341 BRISS BDL
HFD... VIA J174 ZIZZI DRIFT CCC MAD MAD341 BRISS HFD
SWF... VIA J174 ZIZZI DRIFT CCC MAD MAD341 BRISS PWL TRESA SWF
POU... VIA J174 ZIZZI DRIFT CCC MAD MAD341 BRISS PWL TRESA POU
(/A ACFT VIA...J174 EMJAY CCC...THEN AS ABOVE)
THE ABOVE ROUTES ENTER ZBW AOB FL 250
FROM IAD/DCA/BWI:
ALB... VIA AML J220 MICAH CFB RKA ALB
BDL... VIA SIE J121 DRIFT CCC MAD MAD341 BRISS BDL
HFD... VIA SIE J121 DRIFT CCC MAD MAD341 BRISS HFD
SWF... VIA SIE J121 DRIFT CCC MAD MAD341 BRISS PWL TRESA SWF
POU... VIA SIE J121 DRIFT CCC MAD MAD341 BRISS PWL TRESA POU
FOR ZBW ARRIVALS TO ORH/BED
ORH... VIA J174 ZIZZI DRIFT CCC ORW V14 GRAYM ORH
BED... VIA J174 ZIZZI DRIFT CCC ORW GRAYM2 BED
THE ABOVE ROUTES ENTER ZBW AOB FL 290
FROM IAD/DCA/BWI VIA:
ORH... VIA SIE J121 DRIFT CCC ORW V14 GRAYM ORH
BED... VIA SIE J121 DRIFT CCC ORW GRAYM2 BED
PVD ARRIVALS USE PREF ROUTING VIA: J174 HTO V268 JORDN MINNK PVD
(IAD/DCA/BWI USE NORMAL ROUTES)
FLIGHTS TO BED AND BOSTON NORTH SATELLITE AIRPORTS
(OTHER THAN THROUGH ZDC/ZTL/ZJX/ZMA) VIA:
...JHW J82 ALB GDM LOBBY BED DESTINATION
IMPACTED ROUTE: HPN ARRIVALS VIA BOUNO*****
FROM ZTL/ZJX/ZDC VIA...
JETS ...ORF J121 SIE BOUNO4 HPN
PROPS ...ORF J121 SIE V139 RICED RICED4 HPN
ASSIGNED ROUTE: FROM ZFW/ZHU/ZME/ZID TO HPN/BDL:
...J29 JHW J82 MEMMS RKA STELA1 BDL
...J29 JHW J82 WILET DNY VALRE4 HPN
FACILITIES INCLUDED: ZFW/ZHU/ZME/ZID/ZOB/ZNY/ZBW/ZDC
ADDITIONAL NOTES:
NOTE: PHL DEPARTURES AND OLD: Guangzhou - Baiyun (CAN / ZGGG) (closed), China">CAN EXPECT:
ALB...PTW PTW320 SARAA J64 RAV FQM DNY ALB
BDL...PTW PTW320 SARAA J64 RAV FQM HNK STELA1 BDL
BED...PTW PTW320 SARAA J64 RAV FQM HNK ALB GDM V431 LOBBY BED
BOS...DITCH V312 DRIFT J121 HTO ORW5 BOS
BTV...PTW PTW320 SARAA J64 RAV FQM HNK BTV
MHT...PTW PTW320 SARAA J64 RAV FQM HNK ALB POPPP1 MHT
YUL...PTW PTW320 SARAA J64 RAV FQM DNY ALB CAM J222 PLB ABCOT1
CYUL
ALSO PHL TO THE FOLLOWING: ALTITUDES ARE ZNY TO ZBW
SWF..PTW PTW320 J64 RAV SEG FQM CFB RKA DNY V483 FILPS..AOB230
YOW..PTW PTW320 J64 RAV SEG FQM CFB SYR ART DEANS7..AT ALT
NOTE: ISP DEPARTURE ROUTES VIA RBV ARE UNAVAILABLE, EXPECT CDRS
TO THE NY NORTH GATES.
VALID: ZDC BOUNDARY CROSSING TIME UNTIL 251800Z
ZBW BOUNDARY CROSSING TIME UNTIL 251800Z
PROBABILITY OF EXTENSION: LOW
250300-251815
12/09/25 03:04 DCCOPS./nfs/lxstn20
ATCSCC ADVZY 005 DCC 09/25/2012 FCA RQD
RAW TEXT:
ATCSCC ADVZY 005 DCC 09/25/12 FCA RQD
CONSTRAINED AREA: LENDY
REASON: OTHER
INCLUDE TRAFFIC: CZU/CZY/UNKN/ZAB/ZAU/ZBW/ZDV/ZFW/ZHU/ZID/ZKC/ZLA/ZL
C/ZME/ZMP/ZOA/ZOB/ZSE/ZTL DEPARTURES TO FRG/ISP/JFK
FACILITIES INCLUDED: CZU/CZY/ZAB/ZAU/ZBW/ZDC/ZDV/ZFW/ZHU/ZID/ZKC/ZLA
/ZLC/ZME/ZMP/ZNY/ZOA/ZOB/ZSE/ZTL
FLIGHT STATUS: ALL_FLIGHTS
VALID: FCA ENTRY TIME FROM 250300 TO 251815
PROBABILITY OF EXTENSION: NONE
REMARKS: THIS REPLACES ADVISORY #13. SEE DYNAMIC LIST FOR UPDATES.
ASSOCIATED RESTRICTIONS: SEE NTML
MODIFICATIONS:
ROUTES:
ORIG DEST ROUTE
UNKN(THROUGH: ZDC) FRG >BKW J42 MOL J24 HCM HCM090
SAWED J121 SIE CAMRNBKW J42 MOL J24 HCM HCM090
CAMRN4BKW J42 MOL J24 HCM HCM090
SAWED J121 SIE V139 SARDI
CCCRKA V433 PWL BDR DPKPWL LOVES V44 DENNA BDR
DPKALB NELIE NELIE2ALB LOVES2HNK NELIE2JHW J82 ALB PWL LOVES V44
ZLC ZDV ZMP ZFW DENNA BDR DPKJHW J82 ALB PWL LOVES V44
ZLC ZDV ZMP ZFW DENNA BDR DPKDNY LOVES2RKA LOVES2ALB LOVES2
DH1/3/4 MD11/88 L1011 A319/20/21/30/80 717 727 735/6/7/8/9 744 762/3 77E/W E40/75/90 CRJ/700/705 CC150
J/S DH8D 736/7/8
slcdeltarumd11
RE: What's Going On In JFK/BOS?
Tue Sep 25, 2012 6:54 am
I dont know what you posted its hard to follow but maybe is it cause of the UN assembly?
LOWS
Tue Sep 25, 2012 7:59 am
Probably UN Assembly.
How these people are flying into JFK when it is already slot restricted, I don't understand.
YYZatcboy
Tue Sep 25, 2012 10:00 am
Well it looks like the UN General assembly is part of it but something is also affecting BOS arrivals. I suppose it could all be for the same thing though.
ATCSCC ADVZY 006 DCC 09/25/2012 OPERATIONS PLAN
RAW TEXT:
ATCSCC ADVZY 006 DCC 09/25/12 OPERATIONS PLAN
VALID 10Z AND LATER
TERMINAL CONSTRAINTS:
SFO/LAX/SAN-LOW CIGS
JFK-VIP MOVEMENT
DEN-RWY 16L/34R CLSD UNTIL OCT 15
BWI-RWY 10/28 CLSD UNTIL NOV 01
EN ROUTE CONSTRAINTS:
ZKC/ZID-TSTMS
ZNY-SPECIAL OPS/UNGA
ZDC-QVR (OCEANA) RADAR OTS 1200-2300
1. ROUTES
UNTIL 1815 -SPECIAL OPS FOR ZBW ARRIVALS
UNTIL 1815 -NO GA'S VIA LENDY TO N90
AFTER 1100 -ORD PLAYBOOK PROBABLE
2. ZOA
AFTER 1500 -SFP GDP POSSIBLE
NEXT PLANNING TELCON: 1115Z
251000-251159
12/09/25 09:30 DCCOPS./nfs/lxstn35
J/S DH8D 736/7/8
LOWS
Tue Sep 25, 2012 10:46 am
Quoting YYZatcboy (Reply 3):
Maybe also POTUS or VPOTUS in the area for the campaign or fundraisers?
jfklganyc
Tue Sep 25, 2012 12:13 pm
Odd config yesterday.
All arrivals on 22L and 22R.
All departures 31L KE
In this config, all deps need to be southwest fixes usually
Probably associated with UN traffic
TS-IOR
Tue Sep 25, 2012 1:28 pm
The Tunisian president en-route to New-York was diverted to Boston... Any relation with that ?!
