morrisond
So If Boeing Was To Pass On 777x And Build Y3....
Fri Sep 28, 2012 1:22 pm
As discussed in other threads it sounds like Boeing is having some second thoughts on 777X at least the 778.
If Boeing was to just do a 777+NEO minimal change for say 2016-17, could they have a 777/748 replacement ready in 2022 (I'm assuming that a re-engine of the 777 family keeps the line busy for another 5 years as it will be good enough).
I'm assuming a launch in 12-18 months. What technology could be available for production by 2022?
How efficient of a design could be made?
Will they be able to move beyond traditional Tube and Wing by then and go BWB - or is there a half step in between?
Personally by then I think they could do something in CFRP that either looks like a twin Ecoliner or do something a little more radical like a single deck 12 W Twin with an Ovalized Fuselage laid on it's side (composite construction should allow this by then - even if it needs to be supported mid-span - there should also be an aero benefit as the fuselage could generate significant lift meaning a smaller wing could be used).
Will the technology by there to at least match match a possible A389 with new engines (I would assume same wing as a new one would be too costly)?
I would assume the small Y3 would be in the 420-440 seat range with huge range and the larger version in about 500 passenger.
Discuss.
Stitch
RE: So If Boeing Was To Pass On 777x And Build Y3....
Fri Sep 28, 2012 1:32 pm
Boeing did have a four-engine, three-aisle, twelve-abreast (2+4+4+2) concept called the 763-246. It would have had the overhead cabin like the one offered on the 747-8. The design was ~274 feet long and 262 feet wide.
kc135topboom
Fri Sep 28, 2012 1:54 pm
Yes, Boeing could also simply abandon the idea of the B-777X altogether, build the B-787-10 as an interium airplane while they design and finalize the Y-3. The Y-3 could be 2, 3, or 4 engines, but I doubt we will see 4 engines as the combined fuel burn is just to high, no matter how efficent the engine is. A BWB design still has some draw bcks like the additional 'ride' passengers seater further from the airplane center get, as well as fewer windows.
Stitch
Fri Sep 28, 2012 2:15 pm
I don't see Boeing being ready to bring a BWB to market and even if they were, I am not sure the public is ready since the experience will be very different than on current "tube" airliners.
PC12Fan
Quoting Stitch (Reply 1):
Boeing did have a four-engine, three-aisle, twelve-abreast (2 4 4 2) concept called the 763-246. It would have had the overhead cabin like the one offered on the 747-8. The design was ~274 feet long and 262 feet wide.
Just when I think you've said the stupidest thing ever, you keep talkin'!
morrisond
Fri Sep 28, 2012 2:30 pm
I would be very surprised with anything more than 2 engines as well - given new efficient high lift wings it seems like existing Engine thrust Levels or a little bump - 115-120=5,000 Lbs should be more than sufficient for 500 Passengers over 8,000NM.
I would be very surprised if they Jumped directly to BWB either - something of a hybrid - My very Ovalized Single Deck 12W twin with wings attached like normal may be the interim step they need (and it should be easier to produce) before they go full BWB which given it's potential efficiency is where were going.
If you look at Boeings development schedule Y3 in the early 2020's makes sense as after 2016/17 (assuming they don't go full 777x but do a 777+) gets pretty quiet after 2017.
Launch Y3 in 2014 for delivery in 2022.
Y1 gets launched in 2020 for Delivery in 2016 (Giving 10 years of MAX Production), using new production techniques (Non-Autoclave CFRP?) developed for Y3 with ovalized 2-3-2 fuselage
787 Gets updated mid 2020's with PIP's and new Engines (not that intensive for Boeing)
787 gets replaced with full BWB early 2030's
art
Fri Sep 28, 2012 3:20 pm
What combined annual production of B787 and A350 can be expected? Given combined B787/A350 orders approaching 1500 at this time, could a 777NEO hold its own through offering faster delivery? Not quite the same but instead of A330 orders tailing off as B787 neared introduction, they rose IIRC. Why not skip a major redesign as suggested and do Y3 next decade?
Zkpilot
Fri Sep 28, 2012 3:52 pm
I just don't see Y3 happening until next decade (possible launch end of this decade however).
That would give the 777X about 6 years of sales before Y3 and then probably another 2 years during Y3 before the line closes. That's enough time for a good 600 777X whilst it would probably have a break even figure of 150.
Y3 is highly unlikely to be a standard tube design. Y3 is replacing the 77W and 748 after all and is aimed at the A380 so needs to be bigger than a 77W and probably the 748. It will likely be less capacity than the A388 but more efficient and lower costs, or it will be much larger (think 600+ in 3 class layout). If it is the larger design then it most certainly has to be BWB as the market is not big enough for 2 competing Supers of standard design. The 7810 will of course fill in the market below Y3 (albeit with a gap which is the A350 sweetspot).
56 types. 38 countries. 24 airlines.
Stitch
Fri Sep 28, 2012 4:13 pm
I would not expect Boeing to take the fight to the A380-800 and A380-900 with Y3.
I can't see a traditional tube greater than 11 abreast, and then only if it can be done with CFRP so that the weights do not exceed the current 777-300ER so that it can use 115k engines. Otherwise, they have to go to four engines and I don't see that working unless it's A380-sized.
Beyond that, we probably need to look at a double-decker option like the Ecoliner.
panais
Fri Sep 28, 2012 4:48 pm
Quoting Stitch (Reply 8):
Which looks like a 787 with a an upper half 737 on top.
http://media.photobucket.com/image/r...eesje_pics/Ecoliner2comparison.jpg
[Edited 2012-09-28 09:50:24]
Stitch
Fri Sep 28, 2012 5:05 pm
Quoting panais (Reply 9):
Indeed, but it may very well be the most structurally-efficient design to seat 350-450 people.
tdscanuck
Fri Sep 28, 2012 5:15 pm
Quoting morrisond (Thread starter):
I think the problem there is that 5 years isn't enough time to recover the cost of the 777+NEO.
Tough to predict that far ahead, but it's safe to assume it would rise to at least 787-A350 levels + about 5% (the engine companies get about 0.5% per year on average).
We're technologically able to move to BWB now. It's the regulations, customers, and airports that aren't anywhere close to understanding how to deal with it.
Tom.
HBGDS
Sat Sep 29, 2012 2:34 am
I like all the speculation I'm reading, but the technology just is NOT there. Airbus had some fancy designs, too, and admitted that designing the dynamics around them required another 20-25 years or so. Not to mention the engines! Same on the Boeing designs. Besides, launching early kills existing programs (others made that point here). nah, sorry, 2014 would be gutsy, but with entry in 2030 at the earliest. In other words, the youngest of us on this list will enter middle age, and I'll be dead or gaga in an oldfolks' home going phhhhhhhhh when I see an airplane fly by.
Aesma
Sat Sep 29, 2012 6:02 am
I see here a lot of mentions of "Y3" and "Y1" while there is nothing of the sort with Airbus. Why is that ? After reading thousands of messages about what Y1 will be and ending up with a 737NGNGNG, I certainly won't hold my breath on Y3 being revolutionary !
astuteman
Sat Sep 29, 2012 8:05 am
Quoting morrisond (Reply 5):
I'm not sure quite how you would organise, or certify 12-across. It would almost certainly have to be triple aisle
For what its worth, I'll put money on Y1 appearing BEFORE Y3
Quoting Zkpilot (Reply 7):
I don't think you'll even see a launch until mid-next decade.....
If I look at the 737MAX, and 777X, 737MAX sticks out as the one that will need replacing first...
(And Boeing aren't going to do Y3 instead of 777X IMO)
Agree.
EPA001
Sat Sep 29, 2012 8:23 am
Quoting astuteman (Reply 14):
I would not be surprised at all if that would turn out to be true.  .
Ruscoe
Sat Sep 29, 2012 8:40 am
Is a 777 replacement based on
787 nose
Wider 787 type fuselage to seat 10 abreast
787 tail
Wing root insertions to extend wing and fuel and allow triple bogie undercarriage
All using 787 based technologies and construction techniques
possible?
Would it be possible and it would seem to be a lot less cost than a new Y3.
Ruscoe
Francoflier
Sat Sep 29, 2012 9:33 am
Quoting tdscanuck (Reply 11):
And maybe the passengers sitting 60 feet from the longitudinal axis who are in for a hell of a roller coaster ride on a tight approach in windy conditions...
To be honest I haven't followed the BWB devlopment lately. I don't know if they've found ways to overcome that problem through FBW software tweaks or other.
AngMoh
Sat Sep 29, 2012 9:51 am
Quoting Ruscoe (Reply 16):
787 nose
787 tail
possible?
This is a brand new plane so what is different to a Y3?
When Airbus did the original A350 Mk1, it got widely criticised by the Airlines for being to big a change with too little benefit. The words of SQ: ''Having gone to the trouble of designing a new tail, and introducing a lot of new composites, and everything else, they might as well go the whole way and design a whole new fuselage as well instead of using something old,''
Airbus Should Redesign A350, SQ Says (by Sq212 Apr 7 2006 in Civil Aviation)
In the end it became a whole new plane and 5 additional years of development as well as billions more in investments.
Boeing has the same problem with the 777-X: how do they improve the 777 without making it a half baked new plane. And a lot of the suggestions raised here, make the 777-X exactly a A350 Mk1. I think it is understandable that Boeing is cautious as they don't want the make the Airbus mistake (which a lot of A.netters feel like doing).
727 732 733 734 735 73G 738 739 739ER 742 743 744 752 762 772 773 77W A300 A310 A319 A320 A321 A332 A333 A343 A345 A346 A359 A388 DC-9 DC-10 MD11 MD81 MD82 MD87 F70 ERJ145 E175 E190 E195 ATR72 CRJ200 CRJ700 CRJ900 BAE146 RJ85
Zkpilot
Sat Sep 29, 2012 10:22 am
Quoting francoflier (Reply 17):
Unlikely.... The passenger compartment would more likely be 70 feet across in total (meaning the furthest seats would be 35 feet (10m) from the logitudinal axis (which isn't massive). It would likely have double decks in places.
Who needs windows? most passengers don't look out them anyway and with technology it would be easy enough to have side facing cameras (via IFE) or even a few on the walls in places for those who really want to look out (there would still be some windows of course particularly around exits).
CXB77L
Sat Sep 29, 2012 10:30 am
They're not having second thoughts. They are building the 777X. The only question is how far those upgrades will go.
Me too. I think that we could see the "Y1" or "NSA" (whatever it may be called) launched in the early 2020s for EIS in the mid to late 2020s, and the "Y3" launched in the mid 2020s for EIS in the early 2030s.
I agree that out of the 737MAX and 777X, the 737MAX will need replacing sooner. Unlike the 777X, the 737MAX is a minimal change upgrade to keep the costs down.
I agree with that too.
That would be the Y3 as you're designing an all new widened fuselage anyway.
Quoting AngMoh (Reply 18):
As far as I'm aware, no airline has told Boeing that the 777X doesn't go far enough (although they risk that happening if they take the "cheaper" upgrade option. Just because SQ told Airbus that the A350 Mk 1 didn't go far enough doesn't mean the same will happen to the 777X.
I happen to think that the A350 Mk 1, had it been built, would've been a terrific aircraft which would have given the 787 a run for its money, although it wouldn't be able to touch the 77W's territory. Perhaps part of the reason why Airbus decided to do the XWB is to get a slice of the 77W's success.
The A350 Mk 1, however, was hindered by the narrower cabin cross section which wouldn't have been able to comfortably fit 9 across in economy, while the 787 could. The 777X, in contrast, has a wider cabin than the A350XWB allowing it to fit one extra row per seat in a bid to reduce its costs per seat to counter the increased weight over the XWB. As such, I do not believe that the success or otherwise of the A350 Mk 1 is any indication of how the 777X will fare. They are different aircraft.
Boeing 777 fanboy
n901wa
Sat Sep 29, 2012 12:05 pm
I wish Lockheed would come back to the Airliner Market and build the Future Airliner they had in the NASA Study done last year.
http://www.nasa.gov/images/content/6...ain_composite_1a_original_full.jpg
VC10er
Sat Sep 29, 2012 12:12 pm
Sorry for my ignorance but what does BWB stand for?
Also, with all the "general" fanfare around the 787 Dreamliner and A380, why does it seem like the A350 get such little play? (except on A.net)
The world is missing love, let's use our flights to spread it!
n901wa
Sat Sep 29, 2012 12:16 pm
BWB is Blended Wing Body design that Boeing, and I think MDC has been floating for awhile. It looks like this
http://www.nasa.gov/images/content/6...eing_concept_original_4x3_full.jpg
HTH
Ychocky
Sat Sep 29, 2012 12:58 pm
Quoting n901wa (Reply 21):
Is that a DL wavy gravy tail?
tdscanuck
Sat Sep 29, 2012 1:03 pm
787 nose
Probably. Maybe not the exact nose but certainly the structure and aerodynamics.
Yes.
787 tail
Yes, although the 787 actually has the 777 tail for all intents and purposes so you've got it backwards.
This is an ugly one...it's possible but hard to justify.
Yes, that's the entire principle of the Y-airplanes...same technology and construction, three families of aircraft.
possible?
Yes.
It *is* Y3. So it's going to cost the same.
Quoting Zkpilot (Reply 19):
If you don't have windows your incidence of air sickness is going to go way up. Cameras and screens don't work to prevent air sickness (your brain is smart, or dumb, enough to tell the difference).
Well, at least that would set the record for most expensive commercial product launch in the history of earth. Not only would they have to catch up on 30 years of neglected commercial technology, they'd have to re-established the entire global support infrastructure that a widebody requires.
Quoting VC10er (Reply 22):
Because Airbus marketed the heck out of the A380, and it was huge so it got lots of press, and Boeing marketed the heck out of the 787, and it was super late so it got lots of press. Boeing also, uncharacteristically for the industry, marketed the 787 directly to passengers for several years. Airbus has taken a much more traditional marketing route with the A350 and, as long as they don't stub their toe, the press seems to be leaving them alone.
Quoting n901wa (Reply 23):
It comes from the heritage MDC side of Boeing. They've been playing with the concept for ages and have had a flying unmanned prototype for several years.
Tom.
Stitch
Sat Sep 29, 2012 1:07 pm
Quoting Aesma (Reply 13):
I see here a lot of mentions of "Y3" and "Y1" while there is nothing of the sort with Airbus. Why is that?
"Y3" for Airbus is the A350-1000 and the A380-800 and "Y2" is the A350-800 and A350-900.
As for "Y1", as soon as Boeing does launch the NSA, Airbus will be forced to launch their NSR.
Ruscoe
Sat Sep 29, 2012 1:16 pm
Quoting CXB77L (Reply 20):
The difference is my proposal is for a 777 replacement, not for a 777/747 replacement, and hence a much lighter structure, and is not a new plane but a modified 787
It is not entirely new because syatems etc would be the same, as would the nose, the wing (except for root insertions), and the tail. I can't see that being more expensive than a radically changes 777.
The 350 situation is different because Airbus initially wanted to base the 350 on technology far older than the 787, but a 777 replacement based on the 787, would use existing technology, equivalent to that of it's competitor the 350-1000.
The question I was asking was it possible to alter the fuselage width on the 787, and make minimal changes to the wing root and undercarriage, and have a viable product.
I cannot see why not myself.
You will recall that Boeing offered to enlarge the fuselage of the 737 for Southwest (if I remember correctly), but thankfully decided not too, because it would increase weight and drag without carrying mor pax, but a larger fuselage 787would use the xtra x section to carry pax.
Ruscoe
CXB77L
Sat Sep 29, 2012 2:00 pm
Quoting Ruscoe (Reply 27):
Boeing hasn't defined a "Y3" as an aircraft yet. It is just a project code name. As such, it could still be anything. Your proposal could become the "Y3".
But it'll only have as much commonality with the 787 as the 767 has with the 757. Once you go about altering the cross section of the fuselage, you're essentially doing a different sized barrel. It's not just a matter of scaling it up; it'll have various individual components that need to be redesigned to fit. It can look like a 787, it can have the same design philosophy as the 787, but it won't be the 787.
Boeing 777 fanboy
