lat41
If The MD-90 Had Larger Wings
Sat Sep 29, 2012 6:50 pm
It was late in the game for McDonnel Douglas, but if they had the funds, would a larger more modern wing than the MD-80 series have offered, a higher service cieling, more range, better field performance? Might any of those have translated to more sales before Boeing snuffed the model out? The order book was pretty thin by then in any case.
DeltaMD90
RE: If The MD-90 Had Larger Wings
Sat Sep 29, 2012 6:55 pm
I could be wrong, but I think the DC-9 series pitfall was always the 5 abreast seating. Had they gone 3-3 I think the DC-9 would have eaten into the sales a bit more.
Ironically I have never flown a Delta MD-90 :)
quickmover
Sun Sep 30, 2012 1:37 am
I love 5 abreast seating.
Less middle seats. What do you like about 3 by 3 seating?
antoniemey
Sun Sep 30, 2012 3:47 am
Quoting quickmover (Reply 2):
Ah, but see, it's not what we like about 3x3, it's what the airlines like. By widening their base fuselage enough to squeeze in a 6th seat per row, Boeing was able to make an aircraft in the same size class as the competing Douglass/MD model that fit 20% more passengers. This then translated to a per-seat advantage in operating costs... which wasn't an issue until deregulation, but then began the game of counting every single penny for each flight... and passengers have consistently voted with their wallets that they'd rather endure a middle seat than spend the extra 10 dollars for a 2x3 plane to make the same amount per flight as the 3x3 plane.
Still, there is a sweet spot for the 2x3 profile where it works better than a very short 3x3, but MD made the mistake of not improving their models enough to keep them really competitive vs Boeing and Airbus, and eventually lost the battle. In many ways an MD-88 is still the same plane as an early DC-9. The MD-90 and 95 were too little too late.
Make something Idiot-proof, and the Universe will make a more inept idiot.
DeltaMD90
Sun Sep 30, 2012 3:51 am
Quoting Antoniemey (Reply 3):
Was this really why MD lost against the 737? I've read this somewhere before, and it makes sense, but I'm not sure if there were other factors that killed the DC-9 series...
antoniemey
Sun Sep 30, 2012 3:56 am
Quoting DeltaMD90 (Reply 4):
I won't claim to know enough to be able to name every factor, but I know that it was definitely one of them.
TrijetsRMissed
Sun Sep 30, 2012 5:10 am
Quoting lat41 (Thread starter):
Of course it would have made a huge difference. And the unfortunate reality is the funds were there. Contrary to popular a.net belief, MDC were very profitable in the mid-80's through early '90s. The MD C-level simply got complacent with the MD-80's success and didn't allow R&D the investment that was needed to complete the most vital upgrade. Later, funds were poured into trying to save the MD-11, but it was too late.
Classic conservative mismanagement, Ala GM circa 2004-07. Unfortunately, Clinton didn't bailout MD and implement and mandatory corp restructure to save the company.
Not true. The fact is the MD-90 had more firm orders two years after EIS than the MD-80. The MD-80 went on to sell nearly 1,200 frames...
Quoting DeltaMD90 (Reply 1):
I don't think so. There were numerous studies done in the 1980's that concluded that passengers preferred the 2x3 seating arrangement. Some were publicly funded, others were jointly funded by Boeing and McDonnell Douglas. I recall one survey (circa 1983?) where the results on passenger comfort placed the MD-80 at the highest in the industry. Within days MDC adjusted their marketing materials and proposal data. Coincidentally, within the year, MD-80 sales began to take off.
There's nothing quite like a trijet.
DocLightning
Sun Sep 30, 2012 5:11 am
Yes, that is how. The big advantage to rear-mounted engines is FOD protection. When the 727 and DC-9 were being designed, there were still a lot of semi-prepared smaller airports that were in use and FOD was an issue. Also, some of the smaller stations couldn't reach all the way up to a 707 fuselage with their airstairs or unload luggage from a plane that tall, so the DC-9 and 727 were put close to the ground, which meant no under-wing engines (until Boeing figured out how to squeeze them under there on the 737.
But it turns out that 3x3 is more efficient because it gives you 20% more passengers in a plane of the same length for less than 20% extra drag. It also turns out that under-wing engines are the most efficient arrangement. The 737 was just the better design.
-Doc Lightning-
-Carl Sagan
gigneil
Sun Sep 30, 2012 5:47 am
That's not why per se. The MD-90 carries almost as many passengers as a 737-800. It even does so quite efficiently.
The issue is the lack of capability and the crazy systems problems that plagued both the MD-90 and the MD-11.
NS
TSS
Sun Sep 30, 2012 6:00 am
I seem to remember reading more than once that the DC-9 and longer MD-80/MD-90 wings are remarkably efficient as they are, so I'm not sure there is big room for improvement on that front. They are definitely highly loaded which translates to a smoother ride during turbulence.
I've wondered if a bigger problem for McDonnell-Douglas wasn't the hole in their lineup between the DC-9/MD-80 and the DC-10 once the DC-8 began winding down in orders. Picture if you will a DC-8 with redesigned wings and two engines instead of four... the McDonnell-Douglas equivalent of a 757.
TrijetsRMissed
Sun Sep 30, 2012 6:55 am
Quoting TSS (Reply 9):
The wings were very well engineered and ahead of their time. Aerodynamically, the MD-80 wing was superior to the 727 and 737 classic. I remember this being a selling point in MD proposals, which included: wind tunnel data, diagrams with different flight conditions, and various statistical analysis to support the claims.
All that said, if the MD-90 had a newly designed wing as the 737NG had, it's production run may have lasted a lot longer.
Quoting gigneil (Reply 8):
The system problems are a bit exaggerated in the demise of these types. With the MD-11, it was mainly the initial performance shortcomings. AA is really the only airlines that comes to mind that complained on system functionality.
For the MD-90, it was timing. Only 2 years after EIS did Boeing acquire MD. And talks originated while the MD-90 was getting certified. It never had a chance.
But back to the system issues: It's ironic that DL (the airline that worked with MD to design the MD-90) was pained most by it's operational issues; and long after EIS. The level of support dropped to a standstill post-merger, hurting the cause. But it's a wonder TechOps couldn't fine tune the operating procedures a little quicker. Now, it's not even a footnote.
By comparison, JD also had a fleet of 16, of which were operating effectively in 1999.
TomFoolery
Sun Sep 30, 2012 9:03 am
Didn't the proliferation of the A320 series in the late 80's/early 90's have a role in Boeing's advancement of the 737 fleet? I understand that when the 737NG program was launched in order compete with the performance numbers of the 320 series. At this time, the MD 90 series was freshly launched, and was an improvement to the existing 737s (300/400/500), so there was nothing really on the table except for the MD95.
It is not clear to me if MD had their eye on the advancements of AB, or if they were too focused on Boeing. In either event, I don't know how long MD's commercial business would have lasted beyond the 90's.
There were aspects that became the gold standard within aircraft families like commonality and interchangeability (this was both, flight deck and systems- including airframe). A & B were quite advanced in this respect.
Getting out of commercial, MD had a valuable defense portfolio- F-15, F/A-18, C-17, in addition to a number of missiles and other defense articles. While MD was struggling with defense cuts of the 90's, and recession that drove commercial customers to the cheaper A320s, Boeing took advantage of their weakness, and bought them for cheap.
While I am quite fond of the MD planes, Boeing was looking for cheap buys, and MD, and even Rockwell were snapped up pretty cheap. Getting rid or redundancy is the name of the game, and unfortunately, Boeing's commercial products won out.
Paper makes an airplane fly
Bobloblaw
Sun Sep 30, 2012 9:42 am
I dont think the DC-9-30 had a higher CASM than the 737-200. Certainly the 737 was better for cargo or in combi mode. The market in the late 1960s was for a 100 seat aircraft. Making the DC9 have 20% more seats would be pointless in an era where the average load factor was 60 percent. It wasn't what local service carriers wanted. And a shorter fatter DC9 would probably still weigh the same as a thinner longer model. Among second tier carriers the DC9 probably outsold the 737 first gen. The MD-80 certainly sold well versus the 737 Classics of the mid 1980s.
Where MD falls apart is the MD90 isn't much of a competitor to the 737NG even though the MD-90 had a 2-3 year headstart. I think range is the biggest issue versus the 737NG.
lat41
Sun Sep 30, 2012 11:23 am
What accounts for the MD-90's lower service ceiling. I never see them over the mid 30's. Is that where those engines breathe the best or the wing design.
LN-KGL
Sun Sep 30, 2012 12:44 pm
The service ceiling for the DC-9s (DC-9-10 -> MD90) was always 37,000 feet. This is not engine related, but system related. Boeing 737 started up with a service ceiling of 35,000 feet with -100 and -200, but with 737 Classic the service ceiling rose to 37,000 feet (same level at the DC-9s). With the arrival of the Airbus A320 in 1987-88 a new standard was set with a service ceiling of 39,000 feet. MDC tried to equal this service ceiling and to do this they had to get rid of aft stairs on the MD95 (new pressure bulkhead), and that's why today the B712 don't have this real pre of the old DC-9s. With the 737NG Boeing had to get even better than the A320 and ended up with a service ceiling 2,000 feet higher at 41,000 feet. Later Airbus too raised the service ceiling to 41,000 fet, but only for A319CJ.
smittyone
Sun Sep 30, 2012 12:57 pm
Same here. Sitting toward the front of a Maddog is the best ride you can get for your money IMO!
b727fa
Sun Sep 30, 2012 1:36 pm
DL seats 16/144 on both the 737-800 and the MD-90(K)
My comments/opinions are my own and are not to be construed as the opinion(s) of my employer.
CF-CPI
Sun Sep 30, 2012 1:45 pm
Quoting TomFoolery (Reply 11):
I have heard the same thing. I'm told that the real motivator was UA going to Airbus because the A320 could do DEN-east coast nonstop, something that eluded the 737-400.
Oykie
Sun Sep 30, 2012 2:41 pm
Quoting TrijetsRMissed (Reply 6):
Unfortunately true. It reminds me about the book Car Guys vs. Bean Counters from Bob Lutz. He has told how the company used to be run by engineers and not bean counters.
I believe the very same deal happened to MDC. It was started by an aeronautical engineer that built wonderful airplanes.
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
b767
Sun Sep 30, 2012 3:27 pm
How was fuel per seat/mile cost compared to the 737-800 on longer legs?The 737NG had 10 percent more wing area and perhaps a slightly better lift/drag ratio which mean it could cruise at higher altitudes,but then again the 737 had it,s aerodynamic drawbacks with the nose design(perhaps not important since most drag come from wings ,tailplane,engine etc.)When looking at the aircraft data on A.net the range seems similar,so I don,t know if that is the issue.But on the other hand,I have heard the MD90 could not fly US transcontinal non stop. Could the answer why it didnt sell, simply be problems with the electrical system and the IAE in the early days(Delta got mad) and the Boeing MD merger?
masseybrown
Sun Sep 30, 2012 3:51 pm
3x3 narrow bodies were designed to make a LOT of money at 67% load factors. Those middle seat were for surge capacity to accommodate holiday traffic and cancellation rebooks and were not intended to be full routinely.
Time, economics, and unbelievable forbearance by passengers have allowed the airlines to turn them into torture chambers.
PC12Fan
Sun Sep 30, 2012 3:52 pm
I don't know what it is about the Mad Dog 90, it's just basically the -80 with bigger engines but it's one of my favorite birds. Would have loved to see have been the majority in the TWA fleet. (just the fantasy guy talking there)
I am curious though of how a blended winglet application would have contributed to the wing. I have a sneaking suspicion that the wing wouldn't have needed to be reinforced very much.
Just when I think you've said the stupidest thing ever, you keep talkin'!
kc135topboom
Sun Sep 30, 2012 7:39 pm
Quoting TrijetsRMissed (Reply 10):
DL had a lot of problems when the MD-90 was first introduced with them. There were engine and system problems that essentially were not resolved by MDC, and Boeing had no interest in the MD-90. They wanted to sell the B-737NG, not a The MD-90 was initially a reengined MD-88warmed over DC-9. DL ended up cancelling their order after airplane #14. Only about 85 MD-90s were built.
The MD-90 was initially a reengined MD-88, with a higher MTOW, but carrying the same number of pax over the same range.
However DL found ways to fix the airplane on their own and have since been buying every MD-90 they can get their hands on. But DL is only interested in the basic MD-90-30. They have no interest in aquiring the MD-90-30-IGW/-ER/-T versions as there are only one or two versions of these varients each. I believe DL now has about 60 MD-90-30s now.
DeltaMD90
Sun Sep 30, 2012 7:42 pm
Quoting KC135TopBoom (Reply 23):
And a bit of random trivia, DL had orders for over 100. It would be a better trivia fact if I could remember the right number but maybe someone can fill me in
dtw9
Sun Sep 30, 2012 7:55 pm
116 were built
Delta has taken IGW/ER's
Delta has 65 in service or purchased and are looking for 12 to 15 more
Quoting DeltaMD90 (Reply 24):
Delta's original order was for 50 firm and 110 options
Viscount724
Sun Sep 30, 2012 9:58 pm
Quoting dtw9 (Reply 25):
116 were built
Including 2 built in China.
Viscount724
Sun Sep 30, 2012 10:08 pm
Quoting DocLightning (Reply 7):
However rear-mounted engines are more prone to ingesting ice shed from the wings and fuselage, as SAS discovered at ARN in 1991.
Photo © Ola Carlsson
A few have also had engines separate due to ice ingestion, including this NW 727-200.
Photo © Brian Harrison
727forever
Sun Sep 30, 2012 11:13 pm
Not exactly. It is longer and in the DL configuration the MD-90 carries 11 pax more. The electrical system is quite different, which was one of the problems early on in the airplanes existance. It has far better brakes than the MD-80. It has a vacuum lavatory system which is much better. The APU is stronger with larger a/c packs to give better cooling. So, not exactly a warmed over MD-88.
Maybe a few answers to FAQ's in this thread. I've been flying the beast for a few years anyway and will answer what I can.
Was the wing too small?
Yes, this is a problem with the MD-90, though I don't think in and of itself was the reason for so few orders being filled. If the airplane is full and it is to fly a 4 hour flight, the initial max altitude will be around 30,000' due to G load/mach buffet. It has the power to go higher, but not enough wing margin. As it burns off fuel it can climb to as high as 33,000'. The thing is with the IAE engines, the MD-90 fully loaded at 33,000' has basically the same fuel burn as a CFM powered A320 at 35,000' or 36,000'.
Was the lack of coast to coast range why it didn't sell well?
I don't think so. It was designed as a 727 replacement which was a 4 hour airplane as well. The MD-90 does the same roll on 45% less fuel burn. From the start of the MD-90 design there was an MD-90-50T to come after the initial MD-90-30. Unfortunately, the MD-90-50T which would have had additional fuel tanks in the belly like the MD-83 and would be capable of coast to coast, was never built as orders dried up.
Was the 2x3 seating the reason it didn't sell well?
2x3 is narrower than the 3x3 which has a lower parasite drag. However, being that the MD-90 has tail mounted engines it must have a longer fuselage ahead of the center of gravity to counter the weight of the engine. To counter this weight, the horizontal stabilizer does more work to balance out the weight which adds more drag. Based on the fact that the MD-90 and A320 have basically the same fuel burn at the same altitude with the same engines, I'd say that it's a wash so no, the 2x3 seating didn't have a negative effect.
Rear mounted engines and ice FOD?
Really? This is a stretch. If crews use proper procedure for anti-ice use, this is again not a factor. I've flown the MD-90 into some of the worse icing I've ever seen. It was so bad we could hear the ice hitting the airplane and had nearly an inch of mixed ice on the nose and forward fuselage. We had no problem with FOD or even the wing hanging in there. While slick on landing, the carbon brakes and very effective and reverse thrust did a good job getting us stopped on a poor runway.
727forever
727forever
akelley728
Mon Oct 01, 2012 5:08 am
Quoting KC135TopBoom (Reply 22):
Wrong. The T version are the 2 built in China and are both with Delta now. As was stated earlier, they took the ERs/IGWs as well.
The MD-90s that DL is NOT interested in are the ex-Saudia ones due to cockpit differences.
DocLightning
Mon Oct 01, 2012 5:13 am
Quoting MasseyBrown (Reply 20):
Do you know what my solution to this has been? I pay up. Seriously. I pay for advance seat selection. I pay for Y+ if it's reasonable (it usually comes with some perks). Flying isn't quite so miserable that way.
-Doc Lightning-
-Carl Sagan
TrijetsRMissed
Mon Oct 01, 2012 5:29 am
   Agreed, both A & B were better versed in commonality. MDC was headed in that direction. The MD-90 and MD-95 were to each to have a family of three. From 1995, MDC's goal was to have commonality between 6 sub-types in operation by 2000. The MD-90 was also offered with the MD-88-like EFIS, to provide commonality with MD-80 series as well. All but one client chose this option.
Quoting Bobloblaw (Reply 12):
I don't have the numbers handy, but the MD-90's fuel tank is significantly smaller than the 737NG. (Much like a 717 vs an A319). The MD90-30ER is more comparable and was offered from the beginning. But at the time airlines didn't feel it was needed. Having a 737 or A320 on near trans-cons was not common in 1995, as it is today.
KC135TopBoom, I was there in the spring of 1997 when MDC deployed resources to DFW to shore-up the dispatch reliability issues... And things started to improve, but as I noted earlier, the level of support went into the ground once Boeing's acquisition of MD was complete. Thus, DL's issues were elongated into the early 2000's, largely because TechOps tried to use the MD-88 book, if you will. History shows the DL MD-90 problem was more of a DL problem, than the MD-90. Not unlike AA and the A300.
Incorrect. DL cancelled the MD-90 order in Q4 1997. Once the merger was approved, Boeing sold DL on the 738 and convinced them to cancel the MD-90 order, as production was to be ceased.
Quoting dtw9 (Reply 24):
   Correct. But the order was revised prior to first delivery. The final order was 31 firm plus 116 options. From 05/97, DL planned to convert 50-70 options, with deliveries into 2003.
Quoting 727forever (Reply 27):
   DL ordered the MD-90 specifically to replace the 727 fleet.
XFSUgimpLB41X
Mon Oct 01, 2012 5:30 am
An interesting note on the MD-90- at a heavy takeoff weight, it can require up to 265 (ish) knots to retract the slats for manuevering margin. It is one of the few narrowbodies to be able to go above 250 knots below 10,000 feet!
Chicks dig winglets.
PHX787
Mon Oct 01, 2012 5:49 am
I made sure I booked a seat on the 2-seat side of the plane on my flight to MSP.
Or what about the C-series and E-series, with 2 abreast on each side?
Quoting TrijetsRMissed (Reply 30):
Where are they typically based from now?
TrijetsRMissed
Mon Oct 01, 2012 6:12 am
Quoting PHX787 (Reply 32):
ATL and MSP. ATL has the highest number of daily MD-90 departures, whereas the MD-90 at MSP makes up a higher percentage of the total DL departures. Previous bases included DFW (95-05) and SLC (05-10).
TrijetsRMissed
Mon Oct 01, 2012 6:19 am
Looking to come to an agreement on price and timeline for the next 12-15. The specific frames to be acquired have been determined.
kc135topboom
Mon Oct 01, 2012 11:26 am
Quoting XFSUgimpLB41X (Reply 31):
Actually, no. Most commerical airliners are capable of exceeding 250 knots below 10,000', but the speed restriction is regurlatiory. The first several years I flew the KC-135, initial climb airspeed was 285 knots, but that changed to 250 knots by the FAA in the mid to late 1970s. In that same regulation change, landing lights were also required to be left on until 10,000'. It was thought the lights and slower airspeed would help reduce the possibility of bird strikes. That has since been proven wrong but the 250 knot speed restriction remains, as well as the lighting.
After passing 10,000' the speed restiction goes away and airplanes can climb out at their best performance airspeed.
Alnicocunife
Mon Oct 01, 2012 12:33 pm
[quote=Viscount724,reply=26]However rear-mounted engines are more prone to ingesting ice shed from the wings and fuselage, as SAS discovered at ARN in 1991.
Ice ingestion is NOT an issue with MD-90's The V2500 circulate warm fuel back to the tank. No ice or frost build up from cold soaking, humidity.
MD Never improved anything! MD-88, 90 and B717 are all DC-9's with "modern" cockpits and engines. The MD-90 is a "fly by wire" aircraft but MDC used piano wire. Structurally almost all of the same repairs are in the Structural Repair Manual for all types. Some of the pages still have DC-9 on them. Just adding a repair to the MD-90 manual is not improving the aircraft. Same cracks, same repairs, same location. Delta had great plans for the MD-90 until the first year of service when the dispatch reliability was about 26%. There were so many issues that took YEARS to correct. Now the MD-90 is in the 98% dispatch reliability.
Pros of the MD-90
Both engines running are quieter than the APU. And the ride in the front of the cabin is quiet. On takeoff you cannot hear the engines, you just get pushed into your seat. For Delta they are cheap, fuel efficient and can fly hot and heavy from the western states to MSP
727forever
Mon Oct 01, 2012 1:12 pm
Quoting KC135TopBoom (Reply 35):
You misunderstood his point. What he was saying is that the MD-90 may exceed 250 knots below 10,000' because at high weights it's minimum clean configuration speed to maintain stall margin is in excess of 250 knots indicated. In fact at 168,000 lbs min clean speed is 272 knots. There are places that the speed limit is not waived due to airspace restrictions such as MDW, HOU, DFW, etc. When this occurs the pilots will leave the slats extended to be able to maneuver at around 210 up to min clean or leave the takeoff flaps extended and fly down to V2+20 if less than 200 knots is needed.
Quoting Alnicocunife (Reply 36):
I think he was referencing airframe environmental ice, but I could be wrong. The cold fuel soaked wing issue was a problem in the early days of the MD-80, but that was fixed with the electric heating blankets on the MD-80 and the Fuel Return to Tank System (FRTT) on the MD-90 and B-717. Boeing could have used a system like this on it's widebodies as the polar routes are altitude restricted due to cold fuel issues. FRTT would fix that.
727forever
727forever
b727fa
Mon Oct 01, 2012 4:54 pm
Quoting Viscount724 (Reply 25):
Point of clarification please. As we know, a statement of the location of final assembly of an a/c must be available for pax. I usually only see this on the safety card. For those two off shore builds (the Chinese ones), shouldn't the safety cards for those planes say, "Final assembly of this aircraft was completed in China." ???
KingAir200
Mon Oct 01, 2012 5:08 pm
Quoting B727FA (Reply 38):
They do. That's what the black stripe MD-90 cards are for.
PHX787
Mon Oct 01, 2012 5:11 pm
Quoting KingAir200 (Reply 39):
What's the reg and serial numbers of those two built in China?
dtw9
Mon Oct 01, 2012 5:16 pm
Quoting PHX787 (Reply 40):
N964DN and N965DN. S/N 60001 and 60002 C/N 4001 and 4002
MaverickM11
Mon Oct 01, 2012 5:23 pm
I don't think it was coast-to-coast range that was the issue; I've heard AA was uninterested in the M90 because it couldn't consistently make DFWBOS/SEA, particularly in light of the M11 shortcomings. I think DL was similarly unimpressed--at the time
E pur si muove -Galileo
justinlee
Mon Oct 01, 2012 6:21 pm
116 were built
Chinese have built 4 more! Just look at ARJ21
[Edited 2012-10-01 11:23:10]
TrijetsRMissed
Mon Oct 01, 2012 8:25 pm
Alnicounife, pure comedy.   Your first point on ice ingestion proves there were improvements! The FRTT 727forever noted is another example.
As for the piano wire joke, the MD-90 incorporates hydraulics with it's pitch control. The MD-80's control column only moves control tabs on the flight surfaces, giving the aircraft a heavy feel. With hydraulics, the MD-90 controls are more balanced and require less trimming.
Lastly, I know you may have fixed many MD-90s in your day, and how frustrating that was for a new airplane. But if we're going to exaggerate dispatch reliability, or lack thereof, let's at least make it somewhat believable.
b727fa
Mon Oct 01, 2012 8:55 pm
Thanks, King. I've only ever seen the yellow (overwater) and the purple. I'll have to keep my eyes peeled!
milesrich
Tue Oct 02, 2012 1:29 am
I hope this wasn't said before, there were a lot of responses, but the reason the DC-9 first outsold the 737 was earlier delivery dates and no Flight Engineer requirement. The DC-9-30 was available a fully year before the 737-200. But the use of airstairs had nothing to do with it. The Boeing line of aircraft door sills were no higher than that of a DC-4, 6, or 7. The 737 had a built in front airstair.
As far as FOD, Foreign Object Damage, the 737 was certified to operate from gravel runways with certain modifications, even though the engines were much closer to the ground. The T-Tail design was used because until the 737, the T-Tail was thought to create better short field takeoff characteristics. Hence, the Caravelle, the Trident, the 727, the BAC-111, and the DC-9. The cabins, except in the very rear seats next to the engines were also quieter. The 737 Advanced improvement, after the elimination of the 3rd crew member requirement, is what really jumpstarted the 737. While Boeing was improving it's product, McDonnell Douglas, with the emphasis on McDonnell was sitting on its laurels and not investing as much in improving it's design. The DC-9-50 was a stretch of the DC-9-30, and carried more passengers. The MD-80's, 81's, 82's and 83's were all DC-9's. The MD 8- designation was a marketing ploy.
Then Boeing came out with the first "NG" 737, the -500, -300, and -400, all with hi bypass engines. They are called classics but had a different tail assembly and different engines. In the meantime, MD was still depending on low bypass JT-8D's that powered the 737-200's. Look at the airlines that operated the 737 vs the DC-9 and reorders. TW got Series 10 DC-9's, sold them off, then acquired -82's, then acquired Ozark and became a large MD operator, until they shut down. AA acquired neither but bought BAC-111's but then in 1982 started acquiring the MDD product and became the largest user of any DC-9 series aircraft. EA never purchased advanced twins except the 757 before they shut down.
UA didn't buy DC-9's but opted for the 737 operating their DC-6's and Viscounts for another year or two longer than other carriers, waiting for deliveries in early 1968, and then purchased -300, and -500's.
DL was a DC-9 carrier, and MD-88 and MD-90 carrier but acquired a smaller fleet, as I remember 36 frames, 737-232A's in a financing deal where they traded in excess initial delivery L-1011's for leased 737's. Then they bought Western and acquired more 737-200's, the next year in 1987. The original non advanced -247's were soon disposed of, before the last DC-9-32's which were traded in on new MD-88's in 1992 when the 9-32's were 25 years old. They never bought any more new 737's until they bought the NG -800's.
NW never acquired either, until they bought Republic, and never flew any 737's. Braniff I flew BAC-111's for a few years, and never bought any more twins from the factory before their shut down in 1982.
NA never had any twin jets, and Pan Am only acquired 737's third hand. (they had some original UA -222's that came via Air Florida).
AL got some 737-200A's but acquired most of their 737's from PI.
CO had both DC-9's and 737's but it is difficult to really discern what "equipment" decisions they made until after Lorenzo was gone as they acquired most of the aircraft from airline acquisitions. The original DC-9-15's were sold off by Bob Six, and he didn't by any other twins. The 737's came from Peoples Express, DC-9's from NY Air.
NE had DC-9-31's that Delta sold off as they were different than their -32's and at the time, DL believed the 727-232A was the key aircraft to operate.
I believe most of the European carriers that acquired the 737-200 bought Advanced models, other than LH with their -100's, and replaced Caravelles, or British aircraft.
qqflyboy
Wed Oct 03, 2012 5:56 pm
I cant' help but think of these any time I see/think of an MD-90:
Photo © AirNikon Collection-Pima Air and Space Museum
The views expressed are mine alone and do not necessarily reflect my employer’s views.
northstardc4m
Wed Oct 03, 2012 7:26 pm
Quoting milesrich (Reply 46):
CO has DC-9s from Texas International before NYAirs came in.
If you don't count the A300...
They also depending what sources you believe, possibly had an order for 737-300s near the end of the Lorenzo era. (reasoning I heard for this: order was for NYA originally, diverted to EA as part of Lorenzo taking over EA and being forced to sell NYA's shuttle ops to PA, PA got EA 722s instead of NYA MD-80s or 733s. 733s would of replaced those aircraft, instead EA just retasked 727s to Shuttle and cut flying elsewhere)
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
B757Forever
Wed Oct 03, 2012 11:39 pm
DL had an order for 50 737-332 aircraft. The first five were delivered but AFAIK, none were operated. They were sold off and the remaining 45 orders were rolled into the -800NG order.
The Rolls Royce Dart. Noise = Shaft Horsepower.
