boeingkid
Walk And Run At ORD On The Runway
Sat Sep 29, 2012 8:14 pm
Just thought I would post this I think that this is really neat and I dont know of any other major airports that have done this
http://chicagoevents.com/event.cfm?eid=272
B595
RE: Walk And Run At ORD On The Runway
Sat Sep 29, 2012 8:47 pm
Man, I'd do that in a heartbeat if I was in the neighborhood. Very cool.
But I wonder which runway it will be? They don't give any hints.
aircanada014
Sat Sep 29, 2012 8:53 pm
YYZ Toronto is the other airport does this too..usually Air Canada or fire fighter department
lightsaber
Crew
If I had time to go to ORD, I would do this!
Quoting B595 (Reply 1):
I too wonder. Is ORD constructing runways currently?
Lightsaber
Viscount724
Sat Sep 29, 2012 9:13 pm
Quoting aircanada014 (Reply 2):
http://www.torontopearson.com/runwayrun/#
steex
Sat Sep 29, 2012 9:39 pm
The following is a quote from the marketing e-mail they sent out with the link included in the OP.
On October 20, O'Hare International Airport's northernmost runway will take a brief rest from handling aircraft and instead welcome thousands of runners and walkers to raise money for a very important cause.
Based on that, I would imagine it is 9L-27R. This makes sense given that it is the most detached from the remainder of the field, so it shouldn't be too difficult to keep the 5K participants away from the active operations.
boeingkid
Sat Sep 29, 2012 9:46 pm
That also means that they have to close 14L-32R because of the runway safety area. So 2 runways will be affected
steex
Sat Sep 29, 2012 9:54 pm
Quoting boeingkid (Reply 6):
I believe they could still use 32L since the displaced threshold on the north end gives approximately 2,000 feet of RSA beyond the end of the runway.
planeguy727
Sat Sep 29, 2012 9:57 pm
I'm going to try and get there. Would be cool to have an a.net informal gathering.
I want to live in an old and converted 727...
boeingkid
Sat Sep 29, 2012 10:03 pm
But I think the city willl close 32R anyway I dont think that they want aircraft flying that close over head. Just in case
Mir
Sat Sep 29, 2012 10:07 pm
Quoting steex (Reply 7):
Last thing you want is an airplane going off the end of 32L and into the runners. So I'd imagine that runway will be closed as well.
-Mir
boeingkid
Sat Sep 29, 2012 10:11 pm
Remember we are talking about 32R not 32L......Easy Mistake ORD is HUGE
steex
Sat Sep 29, 2012 10:16 pm
Quoting boeingkid (Reply 11):
That was a typo on my part, I was indeed referring to 32R.
I'm certain 14R-32L would remain in use since it doesn't even intersect 9L-27R. I would imagine they'll also avoid using 14L-32R simply to keep all traffic away from the runway being used for the 5K - my point was merely that it would be out of an abundance of caution, and not because of RSA or any other specific reduction in the necessary clearances for 14L-32R.
Acey559
Sat Sep 29, 2012 11:20 pm
Very cool. If I have the day off I just might do it.
mikect
Sat Sep 29, 2012 11:46 pm
JFK does the annually as well.
http://www.jfkrunwayrun.org
DiscoverCSG
Sun Sep 30, 2012 2:10 am
I got a kick out of the line that says participants must follow strict security procedures because the event will be on an "active runway."
Really?
Now THAT would be a thrilling experience.
spiritair97
Sun Sep 30, 2012 2:28 am
I do a run every year at ISP that runs on two of the runways. Can't remember which ones though. I would do this one if I could get there!
aznmadsci
Sun Sep 30, 2012 2:35 am
Quoting boeingkid (Thread starter):
I don't know if IAH did one this year, but they have done Mutt Strut.
http://www.fly2houston.com/0/3917001/0/0/
JAAlbert
Sun Sep 30, 2012 3:44 am
How does security keep folks from spilling over onto active areas?
flyinryan99
Sun Sep 30, 2012 4:27 am
Quoting Acey559 (Reply 13):
I've already signed up and got the plane reservation...well decided to make Friday a work day in the area and happened to stay the night for the race the next day
rwy04lga
Sun Sep 30, 2012 4:33 am
LGA is having a runway run October 14. More info at: www.LGArunwayrun.com
Just accept that some days, you're the pigeon, and other days the statue
n797mx
Sun Sep 30, 2012 4:34 am
Quoting JAAlbert (Reply 18):
I'd imagine they have some kind of barrier up so people just don't wally around all willy-nilly.
Clear skies and strong tail winds.
KAUST
Sun Sep 30, 2012 5:52 am
KAUS did it once upon a time on 17R. It is a two-strip airport with the 9K' 17L/35R remaining open, so all was not too lost.
It was really foggy out with low visibility, which made it doubly awesome, as people were praying out loud that the a/c not land on the incorrect runway; and on a side note: due to the fog they may have not noticed the unique slope up on the last 2K' of the northern end of 17R, for which it is partially renowned.
I just wish they'd have it again. The waking up ludicrously early and driving clear across town in dense fog was worth it, for obvious reasons!
KAUST
"Houston, this is Apollo 8. We are now in Lunar orbit."
chrisair
Sun Sep 30, 2012 9:41 am
Quoting discoverCSG (Reply 15):
Really?
People would certainly run fast if that was the case. The term "run fast or lose your ass" comes to mind...
strandedinbgm
Sun Sep 30, 2012 10:58 am
4R-22L stopping short of 28. Use the high speed turn-offs to create a loop on Sierra.
It's 737s, 747s and 380s. Not 737's, 747's and 380's. Learn to use the apostrophe for crying out loud.
kc135topboom
Sun Sep 30, 2012 11:14 am
http://chicagoevents.com/event.cfm?e...d=272
Quoting MikeCT (Reply 14):
Quoting spiritair97 (Reply 16):
Quoting aznmadsci (Reply 17):
Quoting rwy04lga (Reply 20):
I believe DFW was the first airport to do a "run the runway" event. We did it in September 1995, just a few days before we opened the then new Rwy 17L/35R on Oct. 1, 1995.
deltaguy767
Sun Sep 30, 2012 12:55 pm
Sounds cool! A friend of mine did the one at FRA in the summer of 2011 right before they opened up the new runway and had a blast. Hopefully traffic won't get stymied too much by taking a runway out of commission for the morning.
A Good Landing is one you walk away from!
novak500
Sun Sep 30, 2012 1:07 pm
Quoting n797mx (Reply 21):
I've done the run at YYZ a few times. They have police and security spread out about 50ish meters down the runway. Someone could make a "run" for the active runway but i don't think they would get too far
Goldenshield
Sun Sep 30, 2012 1:22 pm
SGU has done it with the old, now closed airport. Granted, it was no longer an airport when it the event was held, the infrastructure was (and is) still there.
ORDJOE
Sun Sep 30, 2012 2:42 pm
Just signed up if anyone is doing this and up for a meetup PM me.
tjwgrr
Sun Sep 30, 2012 3:59 pm
"The course will feature the display of a United Airlines aircraft. The day's festivities will begin with a brief program to start the race. Following the conclusion of the race, a portion of the course will be open to the community for viewing and photo opportunities in front of the United aircraft."
Wonder if UAL will have the 787 on display?
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
CWAFlyer
Sun Sep 30, 2012 4:48 pm
Back in my younger days, our high school cross country team had a yearly meet that was at the old Richards-Gabaur AFB south of Kansas City in Grandview.
ORDfan
Sun Sep 30, 2012 5:06 pm
Quoting steex (Reply 5):
Yep I believe so too. This will actually be the 2nd time the city has organized this. I remember I went to the first one in the fall of 2008 when 9L-27R just opening and we able to walk/run down approximately half way down the runway. Starting point was parking lot G as well, and 4L was still active for take-offs! It was a great day and, at the time, I thought a once in a lifetime experience. So glad the city is doing this again!
777ord
Sun Sep 30, 2012 9:51 pm
I'll be there! I'm very excited for it, and even more glad to see it being in support of a wonderful foundation that helps countless fellow servicemen, and women!!!
