clrd4t8koff
BOS Terminal E - International Ops
Mon Oct 08, 2012 1:04 pm
Was curious about the overall functioning of the international terminal. Progressively over the last few years BOS has seen an uptick in international traffic and was curious if terminal E can support much more growth at it's current state?
Should expansion be necessary, would MASSPORT be more likely to expand E, or would they finally allow FIS at other terminals, A for example, to allow DL/AF/AZ to use those gates for arrivals/departures?
rafflesking
RE: BOS Terminal E - International Ops
Mon Oct 08, 2012 1:54 pm
Great question - I look forward to the discussion.
As it stands right now, DL's AMS and LHR flights deplane in Terminal E and are then towed to Terminal A for enplaning. This helps minimize gate usage in E for at least 3 flights a day (and likely the upcoming addition of a CDG flight on DL metal). None of the domestic terminals could easily handle FIS without considerable overhaul of the terminals as there are no sterile passageways or room for kiosks/baggage claim.
aeroblogger
Mon Oct 08, 2012 2:03 pm
E still has a reasonable amount of space, especially at off-peak hours.
I think moving Southwest would happen before Massport tried to build more facilities (FIS or expansion)
Airports 2012: IXE HYD DEL BLR BOM CCU KNU KTM BKK SIN ICN LAX BUR SFO PHX IAH ORD EWR PHL PVD BOS FRA MUC IST
Thenoflyzone
Mon Oct 08, 2012 2:22 pm
Quoting aeroblogger (Reply 2):
Why does Southwest operate out of terminal E in the first place? Lack of room at the other terminals?
Thenoflyzone
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
clrd4t8koff
Mon Oct 08, 2012 2:34 pm
That was my guess as well. With the rumors of Boston's next new international carrier being a middle east airline (Qatar or Emirates), they'd most likely utilize the gates in the morning, which as stated, is off-peak at current usage.
But during the evening rush, particularly late spring, summer and fall, is the terminal getting tight on space?
jfk777
Mon Oct 08, 2012 2:49 pm
Quoting rafflesking (Reply 1):
It amazes me that Massprt will not build an FIS at terminal B for AA that DL could use too. This would leave T E for the foreign airlines which are plentyful in Boston.
aeroblogger
Mon Oct 08, 2012 3:15 pm
Quoting thenoflyzone (Reply 3):
Right. But with the UA/CO merger, WN/FL merger, and AA shrinking BOS ops significantly, there is a lot of rejigging to do... If done well, there should be no problem with moving domestic carriers out of E.
Quoting jfk777 (Reply 5):
There is no space in any of the other terminals, and Massport isn't exactly rolling in money right now to fund expansions.
SJCMSP
Mon Oct 08, 2012 3:23 pm
Prior to the NW/DL merger, all of NW's operations were out of E, although most of it was down the stairs and around the corner. I believe WN now uses the same gates.
   If you're there around lunchtime, it's pretty much a ghost town. As the afternoon progresses, it really starts to fill up.
jcarv
Mon Oct 08, 2012 3:40 pm
US CBP can't even staff the one FIS facility they have at BOS. Adding another FIS would only stretch their staff thinner and increase already long wait times. CBP is doing nothing about adding staff at BOS. I'm sure other facilities are in same situation.
dfambro
Mon Oct 08, 2012 4:59 pm
It looks like E could be expanded to the west to add a couple of gates. But maybe not required since what BOS should get more of is direct east Asia routes that arrive in the morning and depart midday/afternoon, when the terminal is currently underutilized. PEK? PVG? ICN? HKG when the A350s come on line?
cjpark
Mon Oct 08, 2012 5:29 pm
Not so related question, first time to connect at BOS which is the easiest way to connect between terminals. Terminal B from AA to Terminal E BA. Airport web site mentions two ways the bus and the walk ways. Which method is best?
"Any airline that wants to serve the [region] can go to DFW today and fly anywhere they want," WN spokesman Ed Stewart
apodino
Mon Oct 08, 2012 6:03 pm
Thenoflyzone
Historically, the gates where WN operates out of were the gates that NW used for years until the DL merger, where they consolidated in A which easily had room for the combined operation. WN didn't start service in BOS until right around the same time. With gate space at a premium just about everywhere else, plus given the fact that gates E1A-E1E are not linked to customs and are by nature domrestic gates, this was the logical place for Massport to locate them. Though if Massport came up with a way to link this area to the upper level of C with a TSA checkpoint or something, I would think that WN could take over the UA ticket counter after UA is relocated to B.
Quoting aeroblogger (Reply 6):
The problem is that both UA and AA have spent millions of dollars on their BOS facilities over the years, and AA doesn't want to give up something that they invested money in. Call it gate hoarding if you will..but it does happen. I know people on here would rather the airlines invest in their own facilities, but this is what happens as a result, and its why I think the airports, and not the airlines (Outside of the real major hubs such as ORD, ATL, DFW, etc) should be the ones investing in improvements. LAS shows you exactly how to do it right too.
Quoting cjpark (Reply 10):
Massport shuttle bus 11 leaves from just outside baggage claim and takes very little time. It is walkable, but the walk takes about 20 minutes or so depending on how fast you walk.
Prior to 9-11, the plans for BOS were much different. AA was planning to build an FIS in B and Massport signed off on it. The FIS would going to be approximately where the new UA facility is going to be built. US was going to contribute some money too and the facility was going to be shared by AA and US. However...after 9-11 really hurt the financial situation of many airlines, AA scrapped the project. Given what BOS has become for AA, probably a wise idea as the facility would have likely become a white elephant.
As for DL. The original plan for Terminal A was that terminal A was going to be the SkyTeam terminal in BOS, with all the skyteam airlines consolidating in A after it was built. I do not believe an FIS was ever in the plans (Bad mistake by both DL and Massport), but the plan was that Terminal A was going to be DL, AF, Air Jamaica, and AZ (NW and KLM were not yet part of SkyTeam). The terminal A project nearly got cancelled after 9-11, but Massport cut a deal with DL and the project went forward, however DL shelved BOS plans for a while, and the terminal became half empty because Massport had also just renovated Terminal E, and moving the other SkyTeam airlines to A would have meant that the current E hall would have gotten less use than envisioned, so Massport didn't allow those airlines to move. They also convinced Virgin Atlantic to move to E for the same reason. (Ironically, Virgin America now occupies Virgin Atlantics old space in B)
COERJ145
Mon Oct 08, 2012 7:11 pm
Quoting apodino (Reply 11):
I could have sworn I saw stairs leading to a hall to customs the last time I flew out of E1A on WN. I could be wrong though...
[Edited 2012-10-08 12:11:47]
Dalmd88
Mon Oct 08, 2012 7:54 pm
DL wanted a FIS but Massport shot it down. I bet they wish it would have been put in or at least made easy to retrofit one when the need and money was available.
apodino
Mon Oct 08, 2012 8:25 pm
Quoting COERJ145 (Reply 12):
There are stairs that lead to the rest of the Terminal E departure lounge (E2-E8) from where WN is that is linked on the secure side which is probably what you saw. There is no way with the way the E1 gates are currently desgined to keep International Arrivals segregated from departing pasengers without shutting down the whole departure lounge.
Quoting Dalmd88 (Reply 13):
This doesn't make sense though. Why did massport greenlight a Terminal B project for US and AA and then not do the same for DL? Granted the FIS project in B never got built because of budget cuts post 9-11, but still. The only possible reason is because Massport knew that DL was going to move all the Skyteam airlines to A upon completion of such a project, which would have made the money spent on E wasted. Still....Massport spent so much time and money on 14-32 which has turned out to be a waste of money for the most part since most of the BOS traffic these days cannot even use the runway. (There is still regional traffic in BOS, but it does seem like there is much more mainline traffic there these days)
Two other points I want to make. One is that when Terminal E was rebuilt, Massport talked about adding three gates to E for International Arrivals. These have not been built and theoretically could easily be built with minimal disruption. Also mentioned as part of this is a potential future terminal F. If you did build it now, you could do so many things with it and really make the airport run more smoothly. Secondly is massport had plans to add a people mover (Similar to ORD and JFK) but scrapped it citing cost. I think they need to find a way to get this built. The airport roadways at BOS are near saturation, particularly in terminal B which will only get worse with UA being added there. A people mover would allow Massport to retire the shuttle bus fleet, eliminate the need for Rental Car courtesy buses, and would allow Massport to potentially consolidate where the Logan Express and other buses drop off at the airport, which will free up a lot of congestion curbside, which is a major problem at BOS.
The way BOS is configured these days...the only thing that I think could really help the airport meet its potential is for the entire terminal complex to be gutted and rebuilt. The problem is, that won't happen without major disruptions, something no politician or airline would ever agree to.
jcarv
Mon Oct 08, 2012 8:26 pm
You are correct. There is a door right outside the Gate E1A that would lead to CBP but historically hasn't been used for many years for international purposes. CBP approval would be needed and minor modifications made elsewhere to make it permanent.
LAXintl
Mon Oct 08, 2012 8:33 pm
Quoting jcarv (Reply 8):
Its a nationwide funding issue. Blame Congress.
Multiple customs districts have significant staffing needs, but cannot get funds to cover them.
The Los Angeles port district (covers airport, harbor etc.) has over 200 unfunded positions.
At LAX, we have about 60 immigration booths spread out between 5 terminals but can only staff about 20 continually. Rest require juggling staff from terminal to terminal.
AmricanShamrok
Mon Oct 08, 2012 10:14 pm
Aer Lingus can be moved out of E if push came to shove. Their flights are precleared at Dublin and Shannon so there's no real need for them there. That would free up to three flights ("slots" if you will) per day at the international terminal. The question is, is there room for them to co-locate with JetBlue or United?
clrd4t8koff
Mon Oct 08, 2012 10:25 pm
Quoting AmricanShamrok (Reply 17):
Interesting, they're doing this @ JFK soon, I'm sure terminal C could handle an EI A330, but depends on how maxed out B6 is during the evening rush?
apodino
Mon Oct 08, 2012 11:06 pm
Terminal C would be the most likely for Aer Lingus as it is widebody capable, but likely won't be able to until UA is moved out. TWA used to park widebodies over there for many years.
CBP is a major problem that needs additional funding. I think a creative solution would be that if TSA allowed airports to opt out and use private TSA approved security companies, then money that TSA saves from that could be redirected to hiring more CBP agents at some of these overcrowded airports.
aeroblogger
Mon Oct 08, 2012 11:12 pm
Quoting apodino (Reply 19):
The TSA does allow that. And some airports have taken part - SFO notably.
apodino
Mon Oct 08, 2012 11:44 pm
Quoting aeroblogger (Reply 20):
They do.....but the current administration has made it nearly impossible for new airports to participate in the program. They cite cost concerns but in my opinion it is just the administration protecting union workers. What I am saying is they need to make it easier for more airports to participate, not deny the requests of all these airports that want to participate but can't. SFB found out how hard it is, but fortunately their congressman is John Mica who is very influential in these matters, otherwise they might not have pulled it off.
Before my post sounds too political...I believe of most of the major airports in this country, BOS currently has about 10 or 11 TSA checkpoints, including a whopping 6 in Terminal B alone. I believe of all the major airports in this country, only LAX, JFK, DFW and MCI come close, for various reasons. If they are going to add Customs in other terminals to ease the pressure off of E, wouldn't it make sense to consolidate some of these checkpoints at the same time, that way everyone wins?
airbazar
Tue Oct 09, 2012 2:20 am
For an airport like BOS where no single airline is that dominant, an no airline has a hub there, it makes little sense to build another CBP facility. Lets say they build CBP at another terminal then the airline decides to pull all its international flights, shrink, and/or go bankrupt. Then what?
It's a much better business decision to have one international terminal with common use gates, and improve transfers between terminals. That's exactly what Massport has been doing albeit, very slow for my opinion. I think that during the afternoon international rush hour, they should run dedicated airside shuttle buses between terminals.
Unless you have time to spare and enjoy walking, take the shuttle bus. The walk is all indoors though, but it's at least 20 minutes. Personally I would walk because I like to walk but most people aren't like me
That only tells half the story. FIS is a federal facility, not a Massport facility. The Feds would have had to agree to staff it too, which as I understand it, they didn't wan to.
As far as expanding E. Terminal E is the one terminal at Logan with room to expand but I suspect that the deciding factor won't be congestion but rather aircraft size. If Masport feels that it needs to accomodate the A380 or future generation of Group VI aircraft, they will expand terminal E. As others have said it, terminal E is vastly unused during most of the day. There are plenty of available gates for flights to Asia which JL is taking full advantage of currently.
cjpark
Tue Oct 09, 2012 7:06 pm
Quoting airbazar (Reply 22):
Thank you for the information.
Is the walking route in the secured area? I don't mind the walk I just hate having to go through security again. The bus route definitely means going back through security.
EI320
Tue Oct 09, 2012 7:37 pm
EI133 DUB-BOS clears immigration in BOS.
airbazar
Tue Oct 09, 2012 10:50 pm
Quoting cjpark (Reply 23):
No, you'll need to reclear security. However terminal E security is really easy. I'm sitting at terminal E right now and I had no security line whatsoever.
tharanga
Tue Oct 09, 2012 11:35 pm
I agree with this. If you want to spend less time, take the shuttle bus. However, if you don't mind a longish walk, and if you like this sort of thing, the walk is a much more peaceful way to go, and I enjoy it. You'll get to see parts of the airport you normally wouldn't.
B to E is probably the most awkward, longest walk you have at BOS. A to E has a nice walkway, and I think the 9/11 memorial is there. B to C has a nice section with rocking chairs and views of the ramp. I'm not sure if you should go B-A-E, or B-C-E.
