EWRkid1990
AA From NY To DFW
Tue Oct 16, 2012 2:54 pm
I recently did a search on AA for flights from JFK to DFW. The only non-stop is a 737 leaving around 4:30 PM. EWR, has SIX nonstop flights. JFK is supposedly an AA hub, so why so little hub to hub flights?
-EWRkid1990
Longhornmaniac
RE: AA From NY To DFW
Tue Oct 16, 2012 3:04 pm
There are very few reasons that one would need to connect in JFK coming from DFW, or vice versa. A smattering of secondary destinations in Europe. Traffic to NYC would use LGA or EWR.
ORD also only has 1 flight, and it is timed as well for the few European connections JFK offers that neither ORD nor DFW do. JFK is not a domestic hub, and doesn't funnel a huge amount of feed through it.
Cameron
Cameron
flymia
Tue Oct 16, 2012 3:22 pm
Quoting Longhornmaniac (Reply 1):
Exactly. People travelling domestic prefer LGA and even EWR. JFK is also slot controlled so that one DFW flight will be used for some connections but they would rather save the slots for better flights.
On the other hand AA does MIA-JFK 6 times a day. But that is a huge market NYC-Miami.
spiritair97
Tue Oct 16, 2012 5:29 pm
Quoting EWRkid1990 (Thread starter):
I have always wondered this as well. I just assumed that instead of aplitting the flights between JFK and LGA, they used LGA as to hold their slots.
jfk777
Tue Oct 16, 2012 6:15 pm
Any passenger needing a connection a JFK from DFW could be flown to LHR and connected to BA.
Josh32121
Tue Oct 16, 2012 8:07 pm
Quoting flymia (Reply 2):
LGA and EWR are also slot controlled, so that point falls a little flat. And whether it's held out as a domestic hub or not, JFK sits in the middle of millions of people (in Brooklyn and Queens) for whom it's more convenient to get to JFK than LGA. I agree it's bizarre to have only a single JFK-DFW flight each day. But I certainly wouldn't call AA's current route network optimized, so this is probably one of several possible oversights/idiosyncrasies in the their network.
Who else flies this route anyway? B6? That may be the answer right there. JFK-ATL is a similar int'l hub to fortress hub route, but it has four or five flights a day. It also has no competition from other airlines.
spiritair97
Tue Oct 16, 2012 8:30 pm
Quoting Josh32121 (Reply 5):
The only other competition on the route DL with a single CRJ-900. I'm surprised neither airline has added more frequencies and/or capacity on the route. Granted, DL probably has less brand recognition nowadays down there so maybe less people think of them when flying internationally, but still, I think that they could fill more than a daily CRJ-900.
Yes, but JFK-ATL at least has some sizable aircraft on it.
Today, there were/are:
Flight # Departure Time (from JFK) Equipment:
DAL73 Tue 06:55PM EDT B763
DAL2143 Tue 03:55PM EDT B752
DAL2043 Tue 01:50PM EDT MD88
DAL1843 Tue 08:15AM EDT MD88
DAL1743 Tue 06:10AM EDT B752
Not huge aircraft, but definitely ones of a respectable size. Not saying that the capacity of a 738 isn't respectable, but only one a day on a hub-to-hub route is a bit dissappointing.
lweber557
Wed Oct 17, 2012 3:24 am
I've thought about that too but it kinda makes sense. What doesn't make sense to me is that Jet Blue flies DFW-BOS but does not offer DFW-JFK yet JFK is the main hub for B6. You have to connect in Boston. Anyone have an explanation?
FAA Licensed Aircraft Dispatcher
usairways787
Wed Oct 17, 2012 3:27 am
Quoting spiritair97 (Reply 6):
Very true, and this flight is always a pig to work, and we usually ask ourselves why not use bigger aircraft. However, last I checked we are more focused on LGA, and offer 6X daily LGA-DFW.
US787
"Pre departure walk around complete, all doors closed, ready for pushback"
flymia
Wed Oct 17, 2012 4:21 am
JFK has international flights. LGA does not. AA would rather use 3-4 slots on international flights than flights to DFW. While LGA is a domestic focus for AA so DFW makes sense and for business and visitors LGA is usually better than JFK. Why waste JFK slots to DFW when you can use them to LHR or BCN. That is the point I am trying to make.
Quoting lweber557 (Reply 7):
Good question. I am guessing they do not have a slot they want to use for it?
JAAlbert
Wed Oct 17, 2012 5:05 am
I think the question is - isn't there more O&D traffic between JFK and DFW? Dallas/Ft Worth is a huge population center and a center for commerce. So is NYC obviously. You'd think there'd be a lot of people wanting to travel to and from NYC and DFW. So why does AA, which is the giant in Dallas/Ft. Worth not flying most of the passengers?
alfa164
Wed Oct 17, 2012 5:31 am
Quoting JAAlbert (Reply 10):
AA is flying them - but they are flying them into LGA.
foppishbum
Wed Oct 17, 2012 12:46 pm
Quoting flymia (Reply 9):
WestJet flies to YYZ from LGA, Air Canada flies LGA to YUL and YYZ quite frequently in a day. DL also flies to YOW but is ending soon I think. DL goes to NAS now and will fly to BDA soon.
[Edited 2012-10-17 05:56:33]
Taiwanese-American :D
flymia
Wed Oct 17, 2012 1:18 pm
Quoting foppishbum (Reply 12):
All pre-clearance destinations as LGA does not have custom facilities. All those flights arrive as "domestic" flights. So yes technically you are right but we are not going to say LGA is an international airport when compared with JFK.
They do fly those flights just out of LGA and EWR. 10x a day LGA-DFW, 6x a day on EWR-DFW, and once a day from JFK. So 17 flights day between between NYC and DFW is not enough?
JAAlbert
Wed Oct 17, 2012 2:36 pm
Quoting alfa164 (Reply 11):
Quoting flymia (Reply 13):
Ah! So the original question - why so few to JFK? I suppose AA is hording its slots for international travel?
spiritair97
Wed Oct 17, 2012 2:50 pm
Just 10? I'm showing 15 flights from LGA-DFW today! almost hourly flights.  Wow!
As for why they aren't running more on the JFK-DFW route, just remember, it may be a hub-to-hub route, but it's still the same market. They offer more reasonable connections to DFW through LGA than JFK.
jfklganyc
Wed Oct 17, 2012 3:14 pm
AA has always done this. So did DL up until a few years ago. So did UA when they had a big operation at JFK.
Left the door wide open for a new airline called Blue Jet (or whatever they're going to call themselves...it will never last) to waltz right into JFK and become the largest carrier at the airport. Also allowed them to become the third largest carrier in the region behind UA and DL and ahead of AA.
Good move boys! Keep up the good work
DLD9S
Wed Oct 17, 2012 4:25 pm
It could be because of saturation in the market... When looking at DFW to LGA/JFK/EWR, AA has 21 nonstops, DL has 7, UA has 5, NK has 1 and US has 3 direct flights. BOS on the other hand has 8 nonstop flights on AA and sometimes 1 on NK.
717 727 737 747 757 767 777 DC9 DC10 M80 M90 M11 L10 AB6 333 340 319 320 321 ARJ CRJ EM2 EMJ SF3 146 100 BE1...
rfields5421
Wed Oct 17, 2012 5:12 pm
My experience which is based on working for an international company HQ in Dallas -
As mentioned above - heading to Dubai, South Africa, Pakistan, or most of Europe - the AA flights from DFW to LHR, FRA or CDG was a good connection point.
If AA puts several DFW-JFK flights into their schedule - they are going to lose some of that international business. Maybe not much - but if it is premium front end customers - it will hurt the profitability of their international flights.
modesto2
Thu Oct 18, 2012 12:21 am
1x daily DFWJFK on AA is sufficient for connecting traffic to international routes. I would imagine that much of AA's DFW to Europe traffic flows via DFWLHR or some of the airline's other DFW to Europe non-stops. Those passengers connect in Europe via LHR or MAD to points beyond on BA and IB. Therefore, 1x daily DFWJFK is enough as most of the local traffic prefers LGA.
flymia
Quoting JAAlbert (Reply 14):
That is the only reason I can think of.
spiritair97
Thu Oct 18, 2012 2:02 am
Quoting modesto2 (Reply 19):
AA (and all carriers at LGA for that matter) should thank their lucky stars that most people prefer low prices over convenience, because LGA in infamous in the NYC area for it's delays. Many people try to avoid LGA (as far as I know) and choose JFK or even EWR if it's possible. Sadly, however, it is not possible all the time. Personally, I try to fly out of JFK or ISP whenever I fly, partially because they are both closer to me than LGA, but mostly because I want to get to my destination on time!
FlyASAGuy2005
Thu Oct 18, 2012 2:28 am
This should tell you that the local market is fairly small (AA only flying a single 737) and even onward international connections is very thin (DL only offering a large RJ alongside American's 738). The real traffic between Dallas and NYC is to Manhattan (LGA).
On the flip, Delta is 7x E170/175s to LGA with AA's hourly mainline service.
[Edited 2012-10-17 19:30:35]
What gets measured gets done.
DLD9S
Thu Oct 18, 2012 5:23 am
Considering the prices AA commands on DFW-LGA - with an hourly departure no less - they must be doing something right with the market.
Even Spirit often gets away with higher fares to LGA than most of their other destinations from DFW.
