propilot83
Tailored Arrivals Video Of Boeing 787 Dreamliner
Thu Oct 25, 2012 6:46 am
Now this is what I really love, when it comes to keeping a "green planet," clean environment for everyone, fuel efficiency, conservation, eliminating waste, and providing friendly skies for everyone. I'm a green person myself, but you gotta check out this video put out by Boeing, you know its amazing what technology can really do, when it comes to the array of sophisticated computers, electronics, and machines flying the Boeing 787 Dreamliner with great autopilot precision. Enjoy folks. I loved this video, go Boeing, green forever baby!
http://www.boeing.com/stories/videos/vid_11_tailored_arrivals.html
BA777
RE: Tailored Arrivals Video Of Boeing 787 Dreamliner
Thu Oct 25, 2012 7:44 am
This is otherwise known as continuous descent arrivals which many airlines in Europe are using now, but certainly a great idea although not possible in all airports yet.
IAHFLYR
Thu Oct 25, 2012 1:20 pm
Otherwise known these days in the U.S. as Optimized Profile Descents (OPD). OPD's are showing up around the country in places like Memphis, coming to an airport near you!
JAAlbert
Thu Oct 25, 2012 2:52 pm
I wonder if this procedure is possible at SAN given the hills and buildings in the flight path?
IAHFLYR
Thu Oct 25, 2012 3:23 pm
Quoting JAAlbert (Reply 3):
IIRC they attempt to use a standard 3 degree path. The RNAV (GPS) RWY 27 at SAN has a slightly higher path at 3.14 degrees due to the obstacles, but at least from TOD to the PFAF a optimized decent path of 3 degree should be feasible.
traindoc
Thu Oct 25, 2012 10:00 pm
Is this the same as RNP (required navigation precision) which is being adopted by the airlines to expedite and simplify landing approaches?
mel
Thu Oct 25, 2012 10:22 pm
among the most inefficient descent profiles / standard terminal arrival procedures I have ever experienced are in Japan. For instance - flying Seoul-Tokyo usually requires descending towards a point nearly 70 miles due north of Tokyo, then turning right to heading 180 and continuing from there... a remarkably inefficient routing. If I can dig up a photo, i'll post it.
Some of these inefficient "staircase-type" arrival procedures are probably still required to curb airspace congestion or vertical obstacles (mountains)... and probably won't be improved for a long time.
In my experience, whenever you arrive into an airport that is not constrained by congestion or obstacles, you usually do get an efficient descent by ATC already.
NO URLS in signature
tdscanuck
Fri Oct 26, 2012 1:05 am
Quoting traindoc (Reply 5):
Not exactly. Although you do need RNP to do these kinds of descents properly, RNP is just a standard for position determination, accuracy, and notifications of deviation of same.
What they're talking about here is a specific class of descent procedures that allow you to keep the engines at/near flight idle the entire way down. It's much more a change in ATC approach procedures than an inherent capability like RNP.
Tom.
IAHFLYR
Fri Oct 26, 2012 1:26 am
Quoting tdscanuck (Reply 7):
With the most respect Tom, I have to slighty disagree. The ODP's in MEM have conventional routes that mirror the RNAV routes. While I agree an aircraft and crew that is RNP certified will certainly tighten up the lateral and vertical path, they can still be accomplished and be almost as if not as efficient without RNP capabilities.
Just a guess, but MEM probably had to consider the conventional overlays due to the remaining Delta DC9's and FedEX 72's.
