morrisond
Boeing Eliptical Fuselage 777 Replacement?
Fri Nov 02, 2012 1:35 pm
Now that it seems like Boeing will delay the 777X into the 2020's it's brings a wholescale replacement into the picture.
If they are going to go traditional tube and wing a 10W new Barrel seems like somewhat of a waste seeing that they just designed a perfectly good 9W one (787), so why not go 11W or even 12W.
One of the 737 replacement studies was a 7W twin aisle eliptical fuselage design with roughly the same cross section (maybe 1% more) than A320.
With Boeing starting to master large scale composite construction how attractive would a 11W eliptical cross section be with roughly the same frontal area as the existing 777 barrel?
At 11W how long would a Eliptical Y3 have to be to have 77W capacity? At 80M long what would typical capacity be?
Would 115K engines be enough?
morrisond
RE: Boeing Eliptical Fuselage 777 Replacement?
Fri Nov 02, 2012 1:53 pm
Stitch
Fri Nov 02, 2012 5:18 pm
Depending on how the surface area works out, parasitic drag might be worse with an elliptical fuselage compared to a circular one. It will also need more reinforcement as a pressure vessel (though CFRP will probably help there). You also need to consider how the wings and wingbox integrate since your passenger deck will be closer to the bottom of the fuselage. And you also have a minimum height down below defined by LD3 dimensions.
Airbus has looked at it for a concept as a horizontal double-bubble encased in a larger structure.
Airbus UHCA Concept with "horizontal double-bubble" parallel cabins
XT6Wagon
Fri Nov 02, 2012 5:26 pm
Quoting morrisond (Reply 2):
How would it compare to A350-1000 - could it beat A380-800 or 900 with XWB engines?
Wouldn't this be an exceptional aircraft for EK ?
A 10Y size could compete well against the A351, at 11Y it would be a size class larger atleast as you would need the length to have meaningful cargo space and operating economics. Which might be good if you can keep the trip costs close enough to the smaller plane, it is afterall what we have seen in A380 vs 748i contests. The 748i is cheaper to operate, but the A380 is more than close enough to make its extra size be only an asset.
That said, if you go to 11Y, you may still want a near circular cross section as the potential for taller cargo containers starts to get easier to justify. More volume mean more revenue per flight.
BMI727
Fri Nov 02, 2012 5:28 pm
Quoting Stitch (Reply 3):
A cylinder gives the best volume to surface area, but you might be able to reduce the surface area for a given passenger and cargo space by going elliptical and not have to deal with stuff like the crown space on the 747-8. A circular cross section for ten or more seats is going to have a lot of wasted space in the crown and probably some below the hold too. Also, don't forget that you can probably get some lift from a flatter fuselage if you're smart about it.
DocLightning
Fri Nov 02, 2012 7:29 pm
Quoting Stitch (Reply 2):
The only circular cross-section of which I'm aware is the 777. All others are eliptical, but the long axis is vertical. They are reinforced by the floor beams.
The issue is that the reinforcement must be vertical when the long axis is horizontal. Except that CFRP is a lot stiffer and newer forms might be able to compensate for the structural needs.
I don't think we'll see more than 11Y (3-5-3) because once you get over that, you run into issues with aisle access for safety reasons and number of exits per passenger. Passengers may not be more than two seats from the aisle, so any wider and you'd have to go 3-3-3-3- or 3-4-4-3 or even 3-5-5-3, but at that point you are adding an extra aisle, which takes up yet more cabin width. If you're going to go for that sort of width, you might as well go the whole hog and do a hybrid or full BWB.
But when you go for that sort of width, you now have less surface area per passenger and that becomes a problem for emergency egress. Every exit door adds weight and takes up space and if each aisle has 12, 14, or 16 pax, you need an awful lot of doors per aisle as compared to a narrower fuselage.
Ultimately, I think that's why Airbus went with the double-deck design over a single wide fuselage.
-Doc Lightning-
-Carl Sagan
mafi29
Fri Nov 02, 2012 8:43 pm
Quoting DocLightning (Reply 5):
Not necessarily, 12Y is also possible in a 3-6-3 configuration as not pax is more than two seat from the aisle. If that is a comfortable configuration is an other question
Ncfc99
Fri Nov 02, 2012 8:48 pm
Regarding number of exits, do wider doors offer a solution, more people out of each door in an emergency?
morrisond
Fri Nov 02, 2012 9:03 pm
I would assume the surface area would be the same as the area of the ellipse would be roughly equal to a circle- the Cabin Width would need to be approximately 32" wider to accommodate 11 18" seats in Y, however you could easily take 28" out of the vertical of the fuselage to get the same area - Your dimensions would be roughly 276" wide and 216" high - or only 6" shorter than an A330 fuselage which can accomodate LD3's - meaning 3" taken out of the cargo area - it might have to be a few inches higher - but with the flatter elipse it might work.
Interesting to think about and one of the beauty of composites - non - standard shapes are a lot easier.
bonusonus
Fri Nov 02, 2012 11:12 pm
Quoting ncfc99 (Reply 7):
It might, but a wider door starts to require a significantly stronger/heavier door frame/surrounding structure.
tdscanuck
Sat Nov 03, 2012 12:15 am
Quoting morrisond (Thread starter):
If 10W was the right cross-section for the 777, it's still the right cross section for that market. None of the technology changes have altered the basic relationship there.
You actually work out better (at least on fuel burn) but going even shorter/wider with 8W twin aisle (2-4-2).
They help get exit capacity up but they don't get you out of the rule about being X seats away from an aisle...wider doors don't help if you can't get out of your seat in time. You also have an issue with too many people trying to go down a standard aisle if your seats-to-aisles ratio gets out of whack.
Tom.
DocLightning
Sat Nov 03, 2012 1:23 am
That was the solution for the 747. The issue is that on the 747 each door uses about 1.5 Y rows. The 747 has 5 exits on each side, so that's 7 Y rows or 70 pax that can't be flown because of the exits. OK, in reality the center seats can be left in place, so that's 42 pax (6x7). (I'm not saying safety is unimportant, but these calculations go into the aircraft design and purchasing decisions by the OEM and the customer, respectively.) The wider the doors, the more "wasted" space aboard.
The wider the cabin, the more doors are required to allow for complete evacuation in 90 seconds.
Quoting mafi29 (Reply 6):
Ooh, clever! I hadn't thought of that. Of course, it's Y, so comfort is about the 60th consideration.
-Doc Lightning-
-Carl Sagan
morrisond
Sat Nov 03, 2012 1:25 am
Quoting tdscanuck (Reply 10):
I wouldn't call the ability to be build efficient elliptical cross sections out of composites a immaterial technological change and if you are going wider than 9W(an elliptical 9W may not have enough room for LD3's) you might as well go 11W as per my example above where you have a cross section with the same area as a 777 - still accomodate LD3's but gain an extra seat and possibly go 12W with the same seat width as 777 at it's current 10W width
BE77
Sat Nov 03, 2012 10:10 am
3-5-5-3
3-6-3
Economically going wider makes a world of sense, and it likely will happen as soon as the technology allows it (or a bit sooner like the 380 and 787).
But, when you configure it, I have visions of being in seat 28F on a 10 hour flight connecting to the world Sumo wrestling convention.
Tower, Affirmitive, gear is down and welded
Sasha
Sat Nov 03, 2012 10:18 am
interesting but ugly. also means even smaller window/middle seat ratio. it will be very hard to book a window seat on such a plane
An2/24/28,Yak42,Tu154/134,IL18/62/96,B737/757/767,A310/320/319,F100,BAe146,EMB-145,CRJ,A340-600,B747-400,A-330-300,A-340
BE77
Sat Nov 03, 2012 11:09 am
Quoting Sasha (Reply 14):
Might be the same as booking F or J, which is to say it could be really easy...but expensive.
