ogshelly
Recommendation For Tracking Flight Apps?
Tue Nov 06, 2012 4:16 am
I will appreciate your recommendations, the one I have is not working properly: flight radar 24. Anything better by chance?
audidudi
RE: Recommendation For Tracking Flight Apps?
Tue Nov 06, 2012 4:21 am
Quoting ogshelly (Thread starter):
Try Planefinder. I use both on my IPhone and Planefinder seems to be closer to actual real time than FlightRadar24.
PHX787
Tue Nov 06, 2012 4:28 am
Flightaware is ok, but it's not always up to date. FR24 works fine for me, when I have the wi-fi working and when I am in a good location. FR24 works in Tokyo so much better than in Phoenix.
ogshelly
Quoting audidudi (Reply 1):
Thanks Audidudi! I'll try that.
3MilesToWRO
Tue Nov 06, 2012 8:42 pm
What's wrong with Flightradar? I have it on Android and it's quite OK as far as I can see.
fn1001
Tue Nov 06, 2012 9:12 pm
I have flightradar24 pro on my iPad3 and it works good when I am in western Europe and have a strong WiFi.
In Moldova and Rumania it depends on the connection to the internet too and the coverage of the sources.
On my phone (Android 2.3.3) I have the free version and it often used to crash, so I uninstalled it.
Mai bine să-ţi fie rău decît să-ţi pară rău.
goosebayguy
Tue Nov 06, 2012 9:14 pm
Plane Finder works well for me too.
capri
Tue Nov 06, 2012 10:24 pm
It all depends on people transmitting the data near the airport and how good their equipments are, and antennas high and clear from obstacle, it's all done by volunteers who enjoy this hobby, in less than decade, us enthusiasts we can listen to endless atc worldwide and track flights, so don't take it for granted, we came a long way
flyingbird
Tue Nov 06, 2012 10:33 pm
FR24 is 100% real time, so I don't see how anything can be "closer to actual real time", than "real time"
vhqpa
Tue Nov 06, 2012 10:35 pm
I hear snowglobes work well
Sorry someone had to do it
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
audidudi
Tue Nov 06, 2012 11:44 pm
Quoting flyingbird (Reply 8):
Well when I see an aircraft flying over my house here in No. California, the Planefinder App will show the aircraft as it is actually flying in the sky. The FlightRadar24 App is delayed about 1-2 mins, so even though both are supposed to be "real time", Planefinder is the more accurate of the two in showing the aircraft's actual position relative to where it is in the sky!
flyingbird
Tue Nov 06, 2012 11:58 pm
Quoting audidudi (Reply 10):
ADS-B data on FR24 is 100% real time. I have checked at least 100 times last 3 years. FAA data on FR24 is delayed by 5 minutes and this delay is made by FAA, so I guess there is not much FR24 can do about it.
ADS-B data on Planefinder is about 10-30 seconds delayed, and planefinder are making some kind of strange position estimations that are far from correct. They continue to plot aircraft in a straight line for about 30 minutes after lost ADS-B coverage. That gives a feeling of Planefinder having better coverage, but it's fake. You can see that on several locations, for example southern Spain, where aircraft bound to Malaga continue their flights for 30 minutes so they end up in Africa. FAA data on Planefinder is delayed 5 minutes as well, but Planefinder is moving aircraft forward 2-3 minutes, so it gives a feeling of the FAA data being almost real time, but once again it's fake. The estimated aircraft positions are not correct, so if you observe FAA data landings on a US airport, the aircraft often jumps around in circles or just continues past the airport, because Planefinder is correcting incorrect position estimations.
So first impression is that Planefinder have more and faster data, but much is just estimations that are not correct. That is why I recommend FR24 that only shows real transponder data, and not incorrect estimations.
flyingbird
Wed Nov 07, 2012 12:18 am
This is an example of the result moving the an aircraft forward (from the 5 minute delayed FAA data) about 3 minutes forward in a straight line, to estimate the current position. The result is that Planefinder draws the aircraft past the airport where it was supposed to land (and still it's on FL78 with 272 kts).
http://i45.tinypic.com/34s57ut.png
And here is a screenshot from FR24 at the same moment. The data is 5 minutes delayed but at least it's correct.
http://i49.tinypic.com/35jmeck.png
