usafret
US Airways Moves To STL Concourse C
Tue Nov 13, 2012 12:26 am
A few days ago I returned to my home base airport, STL, on AA and noticed a few US Airways jets at "C" Concourse. At first I thought they were Hurricane Sandy diverts, but then I saw the US Airways logo on the jetway bridges. Interesting, US Airways moved from Concourse "A" where Delta and United are located and moved to the fairly empty "C" with a few AA gates. I wonder if Delta asked for more gate space on "A" or somehow US Airways sees this often talked about merger on the horizon and moved next to the AA gates? Also, our permanent Admiral's Club has been closed for 18 months now, due to the April 2011 tornado and they are saying it will open Summer 2013. I wonder if US Airways will share in the club facilities and perhaps we'll have a pretty nice club. Frontier also has one gate on C as well as does the EAS "Cape Air." Thankfully I'm AA Ex Plat and Pre Check as the TSA lines on "C" are suddenly pretty busy. But it's nice to see more excitement on a fairly empty concourse.
airliner371
RE: US Airways Moves To STL Concourse C
Tue Nov 13, 2012 1:07 am
Quoting usafret (Thread starter):
STL wanted to even traffic in each concourse.
Take a little time and enjoy The View.
n737aa
Tue Nov 13, 2012 3:10 pm
Just aligning things for the merger.....
N737AA
777STL
Tue Nov 13, 2012 5:08 pm
It has nothing to do with any potential merger, they were talking about doing this before the tornado hit. IIRC, it would have happened much sooner, however US wanted Lambert to pay for the move, and Lambert wanted US to cover their own costs. A is probably overutilized, C is obviously drastically underutilized - it makes sense to get one or more airlines out of A, so that the others can expand. As the OP points out, US and AA aren't the only airline on C concourse anyway.
PHX based
ckfred
Tue Nov 13, 2012 5:13 pm
How many gates does AA now use? I was last in STL in 2009, a little before AA officially closed the STL hub. It seemed that AA and Eagle were using around 12 or 14 gates, mainline on the even side and Eagle on the odd side.
BHMNONREV
Tue Nov 13, 2012 5:37 pm
Quoting ckfred (Reply 4):
I believe they are down to four gates on the even (left) side, as soon as you enter the concourse.
DeltaDc8
Tue Nov 13, 2012 5:59 pm
Is there a point in which STL would close Concourse A and just relocate all the carries to Concourse C and even possibly D? It seems like Concourse C could easily fit all the flights that are offered by the airlines in Concourse A.
Clear Skies Above
BHMNONREV
Tue Nov 13, 2012 7:18 pm
Quoting DeltaDC8 (Reply 6):
Personally can't see this happening, especially in light of all of the money spent on A with concourse improvements and security check point upgrades.
I think you will see B and D continue to be shuttered for the time being.
davescj
Tue Nov 13, 2012 8:16 pm
At one point, DL was upping traffic into/out of STL. I think it has since all evaporated....but.....
There was a hope for a SC in STL. Any chance those freed up gates would have given the space for it? (being aware, of course, that it will never happen).
Dave
FWAERJ
Wed Nov 14, 2012 1:25 am
Quoting BHMNONREV (Reply 7):
I don't think B will ever be reopened - I could actually see it bulldozed in the near future.
But if WN keeps growing like it is at STL, I could see the east D gates refurbished and the D/E connector reopened so WN can grow more at STL.
"Did he really need the triple bypass? Or was it the miles?"
BHMNONREV
Wed Nov 14, 2012 12:38 pm
Quoting FWAERJ (Reply 9):
I can't see either B or any part of D being razed in the near future, unless Ms. H-N comes up with some cash from somewhere. I'm sure their operating budget is still tight, cheaper just to keep them intact for the time being.
countrymalenc
Wed Nov 14, 2012 2:06 pm
Several years back there was a plan in STL to build a TSA screening area adjacent to the B , however not sure how far those plans went. The entire bag belt system in the main terminal is very OLD. TSA still have CTX machines in the terminal and after you check a bag you have to take it to TSA. Then it is shuffled to the bag belt which used to be contracted to Huntleigh not sure who has it now. However over in Terminal 2 TSA is remodeling to move up to 4 CTX machines lower lever out of the passenger sight , once this is complete and you check a bag at SWA it will move to TSA for inspection and then move out to be taken to the aircraft. As for SWA expanding it keeps getting rumors but I dont think it will happen anytime soon. Gate E24 was just installed and E29 is used for overflow since E14 is down for the TSA construction. After the first of the year SWA/FL ,( SWA does ground and customer service for FL at this time there are no longer any Airtran employees in STL they were all converted to SWA employees effective Sept 24), will go to 99 flights perday which is one short of being mega station status for STL.
Bobloblaw
Wed Nov 14, 2012 9:00 pm
Is US flying DcA-STL?
PC12Fan
Wed Nov 14, 2012 9:38 pm
Quoting countrymalenc (Reply 11):
You shuold have noticed renovationa are currently being done in terminal one bag make up area.
Just when I think you've said the stupidest thing ever, you keep talkin'!
FWAERJ
Wed Nov 14, 2012 9:41 pm
Quoting bobloblaw (Reply 12):
No, but AX still flies an oddball STL-PIT route for US.
BHMNONREV
Thu Nov 15, 2012 2:17 pm
On topic, this link will show you some shots of the newly renovated Concourse C since the tornado. Looks like they have done a great job.
http://countondowntown.com/2012/04/lambert-airport-c-concourse-opens/
On a Lambert related note, are the plans still in place to remove the rental car counters and the bunker tunnel to the parking garage so the arrivals road can be flattened? This was also to allow a glass facade along the baggage claim area to the arrivals road, allowing for more light into that area.
