Gonzalo
Triple Loss Of Separation On Approach To BCN
Wed Nov 14, 2012 11:11 am
This sort of "airliner's threesome" is not very common, and frankly it looks like some procedures should be changed for that Approach....
It seems like the ATC controller and the AR crew are blaming each other for this incident...
http://www.avherald.com/h?article=458f61d3&opt=0
Rgds.
G.
Gear Up!!: DC-3 / EMB-110 / Fairchild-227 / Ab318-19-20-21 / B732 / B763 / B789
RE: Triple Loss Of Separation On Approach To BCN
Wed Nov 14, 2012 11:29 am
Looks like AR were first in sequence, they were around a minute in front of the U2 crew. No sure why they were held high for so long, the U2 and IB crew were 2-3000 ft lower when being vectored for the initial.
No mention what aircraft was preceding the AR flight that it needed to slow down for, the AR aircraft had too much energy and could not slow down and descend at the same time, meanwhile the U2 and IB crew are not receiving the requirement to slow down, bringing them closer to the AR aircraft.
We are only getting part of the picture.
Jerseyguy
Wed Nov 14, 2012 11:45 am
Map looks like a game of Flight Control
Webmaster of an unoffical TTN page see profile for details
Qantas744er
Wed Nov 14, 2012 8:25 pm
Anyone actually surprised by this?
Controllers in Spain and particularly BCN are a joke.....
Here a previous incident involving a SN A319 and IB A320.
http://avherald.com/h?article=44c5f743&opt=0
And here some discussion between those who experience it first hand every day.
http://www.pprune.org/rumours-news/500359-bcn-again.html
You live and you die, by the FMA
AR385
Wed Nov 14, 2012 8:31 pm
BA777
Wed Nov 14, 2012 9:23 pm
Doesn't surprise me one little bit. You are statistically most likely to have a TCAS RA in Spain and this is part of the reason why.
N62NA
Thu Nov 15, 2012 2:02 am
Quoting AR385 (Reply 4):
ATC audio of the incident BELOW:
http://www.clarin.com/sociedad/Aerol....html
I thought everyone was supposed to be speaking in English? Is that not a requirement, especially in a major international airport like BCN?
How come I can't upload an avatar photo to my profile?
Thu Nov 15, 2012 2:39 am
Quoting N62NA (Reply 6):
No English is not required, at some fields the plates will say for example Spanish required. The official ICAO languages are English, Spanish , French, Arabic, Chinese and Russian.
The local language if it is ICAO is the primary, English secondary.
hz747300
Thu Nov 15, 2012 2:50 am
Quoting qantas744er (Reply 3):
Don't Spanish controllers receive something like EUR500k / year?
I think the joke's on us.
Keep on truckin'...
Maverick623
Thu Nov 15, 2012 2:59 am
Quoting zeke (Reply 7):
False. The languages you mentioned are the official languages of the UN (of which the ICAO is an agency). The only "official" language for aviation is English.
According to ICAO guidelines, controllers and pilots may use the local language, but at airports and on airways with international service, English must be used if requested.
"PHX is Phoenix, PDX is the other city" -777Way
Thu Nov 15, 2012 5:03 am
Quoting Maverick623 (Reply 9):
I fly through China, Russia, and France on a regular basis, I can assure you that English is not the only official language used in ATC. In Canada as well you can have the ATIS given in English and French, for example 127.5 is the French language ATIS frequency at Montreal - Pierre Elliott Trudeau Int'l Airport- (CYUL).
LONGisland89
Thu Nov 15, 2012 6:23 am
Quoting zeke (Reply 10):
A language simply being used on a radio frequency does not deem it "official." As stated above, English is the official language of aviation telephony. That does not require its use 100% of the time worldwide, as stated above.
Thu Nov 15, 2012 6:42 am
Quoting LONGisland89 (Reply 11):
It is official because it is in the relevant state AIP, in many countries, the AIP is also not in English.
If you think Spanish is not an official ICAO language, why would ICAO have a working group currently developing standard Spanish ATC phraseology ?
http://www.mexico.icao.int/Meetings/RASGPA/RASGPA5/RASGPA05WP08.pdf
How many times have you flown in countries where English is not the native language ?
Passedv1
Thu Nov 15, 2012 8:23 am
Controllers have to be able to speak "English" in all ICAO countries, but the common practice is to speak the local language to all local aircraft and English to the foreigners. It's a dangerous situation but there are no bodies directly attributed to it yet so it is yet to be fixed.
Thu Nov 15, 2012 9:30 am
Quoting PassedV1 (Reply 13):
That is the aim, however it is still not the case. Many countries have filed exemptions to the ICAO SARPs, there are airports around the world where controllers do not speak English. There are also pilots around the world that cannot speak English either.
Honza
Thu Nov 15, 2012 9:37 am
"Triple Loss Of Separation"
..if I count correctly, this was double loss, not triple, right?
Honza
Rara
Thu Nov 15, 2012 9:49 am
Can you give a source for this? Rhetorical question, because I'm pretty sure there is none.
Not quite.. if the local language is not an ICAO language, English is used instead. One example is Germany, where only VFR traffic may be handled in German, but IFR traffic may not. The way I understand the situation, non-ICAO languages could theoretically be used for ATC (if stipulated in the AIP), but I'm not aware of any example for that.
As to whether it's dangerous and needs to be fixed... well... I would find it much more dangerous to suddenly force all pilots and controllers all across, say, South America or China to suddenly speak English instead of their local language. Imagine you've been a regional pilot in China for 20 years. You're supposed to be fluent in English and you passed some test on it 20 years ago, but you've been speaking Chinese on the radio ever since. Forcing you to speak English all of a sudden, on airports where no foreign pilot usually flies into, is just asking for disaster.
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
Gonzalo
Thu Nov 15, 2012 11:03 am
A First Officer of a Shorts 360 Cargo aircraft died years ago in France ( cockpit was sliced by the wingtip of a departing aircraft accelerating on the runway ). IIRC the fact of the ATC and the local pilots speaking each other in French was the main factor for the loss of situational awareness of the Shorts 360 crew, they didn't have a clue about the movements around them and the result was a tragedy for a family.
Quoting Rara (Reply 16):
You are right and wrong. In the small local airports all around big countries ( i.e. Russia, China, Indonesia, Brazil, Germany, India ), with zero or very few international operations every day, obviously the use of English instead the local language will be stupid, and probably will have the effect of more incidents/accidents.
But we are talking about major airports like CDG,FRA, MAD, BCN, HKG, all places where you have a very big portion of the daily flights coming from a mix of countries with diverse languages. In this places, the use of English should be mandatory without exception, just because that allows a better situational awareness for all the crews in the area.
In this particular case, you have two crews ( IB and AR ) and one controller speaking each other in Spanish, with information about speeds and altitudes, issuing instructions and explanations, and one third crew ( EasyJet ) involved which probably never get the full picture of what the h**** was happening around them. Not good at all IMHO.
Rgds.
G.
BA777
Thu Nov 15, 2012 11:13 am
I completely agree English should be the sole language. I am lucky to have an understanding of Spanish but I am much more relaxed when flying in Spain with a Spanish captain sat next to me, although it can lead to distractions when we have to discuss what's going on around us if I haven't understood.
mad99
Thu Nov 15, 2012 12:24 pm
Quoting hz747300 (Reply 8):
Yes
and even more so the jokes on me!
http://waynefarley.com/aviation/2010.../air-traffic-controllers-salaries/
http://www.dailymail.co.uk/news/arti...0--replaced-automatic-systems.html
cyeg66
Thu Nov 15, 2012 2:06 pm
Quoting Gonzalo (Reply 17):
Ever hear of Tenerife? How did English "help" in that situation? More than a few families affected. Or USAir 1493? Fact of the matter is, as sad as it may be, mistakes will continue to happen, some more serious than others, regardless of the language spoken on the frequency. It is but one of the many levels upon which humans may err when tragedy unfortunately strikes.
slow to 160, contact tower, slow to 160, contact tower, slow to....ZZZZZZZ......
LONGisland89
Thu Nov 15, 2012 7:54 pm
Quoting zeke (Reply 12):
I'm not trying to push American or British exceptionalism or anything of the sort, but English is the mandated international language of aviation. That's all I was meaning to say. I'm well aware that controllers around the globe do not speak English when working traffic. If countries have filed exemptions with the ICAO because not all their controllers are proficient in English, then what are they filing exemptions for if English is not internationally mandated?
That's being disingenuous, don't you think? I'm not an airline pilot. Air traffic is my business.
Maverick623
Thu Nov 15, 2012 9:21 pm
Hows about we cut the attitude?
ICAO Annex 1:
"Language to be used:
The air-ground radiotelephony communications shall be conducted in the language normally used by the station on the ground or in the English language.
Note 1.— The language normally used by the station on the ground may not necessarily be the language of the State in which it is located. A common language may be agreed upon regionally as a requirement for stations on the ground in that region.
The English language shall be available, on request from any aircraft station, at all stations on the ground serving designated airports and routes used by international air services.
The languages available at a given station on the ground shall form part of the Aeronautical Information Publications and other published aeronautical information concerning such facilities."
UALWN
Thu Nov 15, 2012 10:03 pm
Quoting Maverick623 (Reply 22):
So where exactly does it say that Spanish can't be used and English must be used at all times, even when IB or AR pilots speak to the BCN ATC?
AT7/111/146/Avro/CRJ/CR9/EMB/ERJ/E75/F50/100/L15/DC9/D10/M8X/717/727/737/747/757/767/777/787/AB6/310/32X/330/340/380
Maverick623
Thu Nov 15, 2012 10:21 pm
Quoting UALWN (Reply 23):
I think we got confused... I was never trying to claim that (although looking back, it may have been interpreted that way).
IB and AR pilots could speak French when flying into CDG if they wanted to.
They can even continue speaking Spanish with ATC even when another aircraft comes on frequency and speaks English... but ATC must respond to the English-speaking airplane in English, even if they switch back to Spanish to respond to the IB or AR plane. In fact, that's exactly what happens in many countries (Spain, Mexico, France, certain parts of Canada...)
But remember, that requirement only extends to airways and airports with scheduled international air service.
rcair1
Crew
Thu Nov 15, 2012 10:52 pm
That is probably a result of national legislation about "official languages" including french.
Quoting cyeg66 (Reply 20):
Oh come on - Trolling?
Because something was not a factor in an accident does not mean that we should ignore that factor in safety or that it could not be a factor in others.
Let's see here - icing in fuel was not a factor in AF442 - so should we ignore that it was in the Pilates incident in Montana?
rcair1
UALWN
Fri Nov 16, 2012 7:57 am
Quoting Maverick623 (Reply 24):
That's exactly what happened during this incident in BCN: ATC spoke English to the U2 crew and Spanish to the IB and AR crews.
cedarjet
Fri Nov 16, 2012 12:16 pm
Barcelona is legendary for having awful ATC, crews even having to speak to each other directly to sort out a mess.
And here is a YouTube classic, Barcelona ATIS for you (1m02s long), says it all!
http://www.youtube.com/watch?v=0bDOZooUUNE
Users browsing this forum: ACDC8, ARNPEK, Baidu [Spider], Bing [Bot], catiii, CONTACREW, dennypayne, EA CO AS, FergYVR, Google Adsense [Bot], ha763, Luamax, matthew11, Max Q, octubre299, packsonflight, PlanesNTrains, QuarkFly, redzeppelin, rookie00, ScroogeMcDuck, seat1a, TNST3B, wedgetail737, ZK-NBT, zkeoj and 13 guests
