miaintl
Will AZ Ever Re-establish Its MXP Hub?
Thu Nov 15, 2012 1:33 am
What is the status of AZ as an airline right now? I think it was a mistake to dehub MXP and focus on FCO. MXP is better located geographically to be a hub and spoke airport. FCO just involves backtracking for most people in Italy and Europe. Plus all the premium traffic is in Northern Italy. With everything being said what do you think the chances are for AF/KL to allow the MXP hub to be reestablished? I think MXP will compliment skyteam and CDG/AMS much better than FCO. I still dont know what purpose FCO plays in the skyteam system.
flyyul
RE: Will AZ Ever Re-establish Its MXP Hub?
Thu Nov 15, 2012 2:44 am
Linate would need to close to FCO-LIN flights only
FSDan
Thu Nov 15, 2012 2:50 am
Quoting miaintl (Thread starter):
They are still an airline.
This is my signature until I think of a better one.
qfvhoqa
Thu Nov 15, 2012 3:03 am
MXP may be better located than FCO for an intra-EU hub, but FCO has higher O&D than MXP. MXP was doomed to fail when airlines were permitted to fly to LIN from within the EU. Now that the LCCs have taken over MXP, it may be too late to re-establish MXP as an AZ hub.
FCO is useful for EU-Africa flights (though I don't know how many it supports) in the same way that MAD is a better hub for EU-Africa flights than LHR is for oneworld.
miaintl
Thu Nov 15, 2012 3:31 am
Quoting QFVHOQA (Reply 3):
I dont think its too late to establish an MXP hub. The LCCs can have LIN completely to themselves and MXP can handle all the AZ and scheduled airlines operations. Plus skyteam has no need for AZ's africa flights, AF and KL both operate to all those destinations and even more. Keep in mind that the idea to close MXP came from AF, who wanted to steal AZ's northern Italian and continental Europe clientele.
MaverickM11
Thu Nov 15, 2012 3:45 am
Europe has too many hubs as it is, so adding another one, particularly one that wasn't viable before, is a challenge.
E pur si muove -Galileo
miaintl
Thu Nov 15, 2012 4:13 am
Quoting MaverickM11 (Reply 5):
MXP was very viable when it was a hub, it failed because AZ tried to keep FCO open and focus on a joint-hub system which was inappropriate for AZ at the time. But now that AZ has its finances in check it certainly make a MXP hub work.
qfvhoqa
Thu Nov 15, 2012 5:44 am
Quoting miaintl (Reply 6):
I'm not so sure AZ could make a MXP hub work. According to the old AZ, more than 50% of pax in Milan / Northern Italy did not use MXP as their gateway for flights. They instead used LIN to connect to other hubs like FRA or CDG.
Alitalia's Milan decision could destabilise sale process
Avianca
Thu Nov 15, 2012 5:53 am
Quoting miaintl (Reply 4):
well - what sence would make to change LIN from a high yield airport - near of the city to a LCC (who are normally not willing to pay fees etc the same way the legancy carriers are doing? btw LCC have as well scheduled operations.
Well if not for Africa (its the only real region were most European origins would need to to backtrack) - what other need would have skyteam from AZ flights?
I think NorthItaly is in general an complicate market - LH has tons of feederflights to MUC, FRA, and to all other "LH Group memmber" hubs. AF / KL to their hubs, BA to LHR/LGW, IB to MAD for SouthAmerica etc
LH was always successfull with feeding their traditional hubs with passengers from north Italy, but they failed establishing an own hub as LH Italy in MXP
JU068
Thu Nov 15, 2012 5:56 am
Well there is also Air One in MXP which I think can do a better job than Alitalia (cost-structure). Air One had recently launched new flights and currently they operate internationally to Prague, Munich, Kiev, Belgrade, Tirana and Warsaw. They also have a total of six domestic routes. That is not that bad.
Also from what I could see you can fly from Belgrade to Milan on Air One and then connect to one of Alitalia's intercontinental flights. I guess that this will be the model used in the future.
miaintl
Thu Nov 15, 2012 6:50 am
Are AZ's long-haul flights even profitable out of FCO? I doubt they get any premium traffic plus little to no feed which is the main reason the ORD and EWR routes failed. When MXP was a hub it was a gateway to Eastern Europe and the Balkans, it gave VIE a run for its money for gateway to eastern europe. Keep in mind that Skyteam is relatively weak in Eastern Europe so MXP could be skyteam's answer to VIE. I know that some people will mention PRG and CZ, but PRG does not have any long-haul traffic to feed its Eastern Europe flights, AZ on the other the hand does.
OOer
Thu Nov 15, 2012 10:15 am
MXP is just too far outside of Milan. People don't want to drive 1-1.5 hours to get to MXP when LIN is right there. Unless LIN is reduced to intra-Italy flights only MXP will remain the airport of use for international flights (outside of Europe) and for LCC's.
Is there any room to expand LIN?
AirGAbon
Thu Nov 15, 2012 10:40 am
Quoting miaintl (Reply 10):
Well, with OK at PRG being the biggest airport for pax number in Eastern Europe, plus RO at OTP and SU at SVO with more than 100 Airbus in fleet, I don't call that, weak...
kyrone
Thu Nov 15, 2012 11:04 am
Quoting JU068 (Reply 9):
I'm lost... didnt Air One and Alitalia merge like three years ago?
JU068
Thu Nov 15, 2012 1:35 pm
Quoting kyrone (Reply 13):
They did but Air One kept its brand and operates as a lowcost airline.
MaverickM11
Thu Nov 15, 2012 2:36 pm
Airlines don't close profitable hubs. Particularly ones that are a distant second in terms of preferred local airport.
Rara
Thu Nov 15, 2012 4:12 pm
Quoting MaverickM11 (Reply 15):
Neither FCO nor MXP were profitable for AZ as hubs, because two hubs weren't viable for the airline. Of the two, MXP was in the stronger position to be successful in a one-hub network, but political pressure did not allow AZ to pull its long-range flights from Rome.
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
jfk777
Thu Nov 15, 2012 4:19 pm
Linate is teh favorite feeder airport for every long haul airline in Europe. FCO is great for Rome but lousy for Italy.
Avianca
Thu Nov 15, 2012 4:27 pm
FCO may have lower yield than NorthItaly but that they dont get any premium traffic? well I highly doubt this...
Anyhow I think AZ made the correct decicion to change their main operations to FCO - as they simply can not compete in a same page with the Big European carriers.
MaverickM11
Thu Nov 15, 2012 6:07 pm
Quoting Rara (Reply 16):
FCO is much larger, and MXP is riddled with LCC capacity since LIN is preferred by far. If LIN was closed MXP may have had a shot at working, otherwise FCO was and is the best option.
delta2ual
Thu Nov 15, 2012 6:30 pm
Quoting AirGabon (Reply 12):
From the world's largest airline-to the world's largest airline. Delta2ual
lisbonbearuk
Thu Nov 15, 2012 7:41 pm
Where do AZ serve intercontinentally from MXP? Do they have a long haul crew vase there still?
YULWinterSkies
Thu Nov 15, 2012 9:56 pm
Backtracking depends where one is coming from. Certainly no backtracking involved for fellows flying from Africa and most of Asia going towards N and Central Europe.
MXP may be "ok" as a hub, but it just sucks in terms of o&d as it is beaten flat by LIN, which however cannot ever become a hub. AZ simply could not rely on this at MXP, while they can for FCO. Proof that a hub in the middle of nowhere (which is what MXP is, due to poor transportation options) does not work well.
Quoting jfk777 (Reply 17):
I do not agree about FCO being lousy for Italy. FCO has a much better location for most Italians and Europeans for:
-Africa
-Middle East
-S and SE Asia
=where the money is being made on long haul flights. I see no reason to think of Europe - NAm as the milk cow and the strategic market anymore. If anything, it is where losses are being generated. Furthermore, AZ already indirectly has two hubs that serve that purpose better than MXP would ever do, for obvious geographical reasons: these are CDG and AMS, thanks to the JV with AF-KL and DL. No point having yet another one, which is a smaller airport, less conveniently located for most Europeans, and awful for o&d.
FCO is a chance for AZ, as long they don't focus on N Am (key routes can certainly work of course but that's it), and I certainly hope they eventually see FCO has a chance for expansion towards the markets mentioned above. They have nothing to win by serving overserved N Am from a mediocre (at best) hub : MXP, or a poorly located one : FCO. I see this a much better strategy than trying to expand out of MXP yet again.
When I doubt... go running!
Viscount724
Thu Nov 15, 2012 10:06 pm
Quoting lisbonbearuk (Reply 21):
JFK, MIA, NRT, CAI.
lisbonbearuk
Thu Nov 15, 2012 10:15 pm
To describe MXP as poorly connected and in the middle of nowhere is just rubbish. It sits on several major motorway corridors and has a fast connection (30 minutes or so) from downtown Milan by train. That's comparable to LHR, LGW, STN, BRU, CDG, ORY, MAD, BCN and many others.
LINATHJNX
Thu Nov 15, 2012 10:49 pm
Maybe AZ will have better chances in FCO but saying that MXP is in the middle of nowhere it's totally not correct.
It is in the middle of a big industrial area that goes from Milan to Turin, there are railways and motorways that connect it to Milan easily. Of course, it is not as near to the city as LIN is, but the big problem for MXP is LIN still open.
HB-IWC
Sat Nov 17, 2012 5:14 am
Quoting Viscount724 (Reply 23):
JFK, MIA, NRT, CAI
And MXP MIA service will apparently end S13.
