JerseyFlyer
New A380 Weight Variants
Tue Nov 20, 2012 4:24 pm
FG indicates 3 new weight variants. One at 575t is I think the version to EIS with BA. The lowest at 490t is for low noise.
But there is also an intriguing 573t version:
"the documentation also shows a 573t variant, WV007, with respective landing and zero-fuel weights of 395t and 373t."
This is obviously for a sprcific niche - can anyone help explain it?
http://www.flightglobal.com/news/art...ewest-a380-weight-variants-379235/
Stitch
RE: New A380 Weight Variants
Tue Nov 20, 2012 4:29 pm
As I expected, WV006 is the 573t MTOW variant announced in 2010 and being introduced with British Airways.
WV007 looks to be for high-density regional missions as it has the lowest MTOW (492t) and ties for the highest MZFW (395t).
The 575t WV008 equals the RTO test with 16 main braking units, so to go any higher they will need to add the final four, which would then support TOWs of upwards of 625t.
kaitak
Tue Nov 20, 2012 8:27 pm
Quoting Stitch (Reply 1):
I wonder is this is directed towards EK's need for an acft that can do DXB-LAX n/s with minimal capacity constraints.
Stitch
Tue Nov 20, 2012 8:34 pm
Quoting kaitak (Reply 2):
The 4t boost in TOW for WV006 was worth 190km of range, so this 2t boost would be worth an additional 80km, kicking maximum range to 15,440km on an MTOW-limited mission.
DXB-LAX is 13,420km direct Great Circle, but there would be winds aloft, routings, ambients at DXB and such. Still, it certainly can't hurt.
I also think WV007 might be appealing to EK for their future "Model One" regional (11-Hour Endurance) two-class configuration.
CM
Tue Nov 20, 2012 9:04 pm
Will Airbus have an Extended Service Goal program for the A380? I believe the current LOV for the airframe is 19,000 cycles, which is not going to work well for an A380 in a high cycle operation.
TWA772LR
Tue Nov 20, 2012 9:36 pm
EK has also said they want to fly the A380 to IAH as well. Could these lower weight variants mean more service by more airlines to more airports? E.G. EK and QR flying to IAH, EK flying to LAX and SFO, QR to ORD, etc...
And for my next miracle, I'm gonna turn water into funk!
mffoda
Tue Nov 20, 2012 9:49 pm
Quoting CM (Reply 4):
Hey CM,
What is the difference now between the A380 and 748 in terms of cycles and hour limits?
thanks,
harder than woodpecker lips...
CM
Wed Nov 21, 2012 12:55 am
Quoting mffoda (Reply 6):
I don't believe Boeing has pulished an LOV for the 747-8 yet. For the 747-400 they are:
Flight Cycles - 35,000
Flight Hours - 165,000
For the the 747-400D, the cycles limit was bumped up to 40,000
I believe the LOV Airbus has publised for the A380 are:
Flight Cyces - 19,000
Flight Hours - 140,000
I'm looking back to find the source where I first found these numbers. It is also worth noting Airbus has at times gone back and later certified extended service goals for their aircraft, having recently just done this for the A320.
Wed Nov 21, 2012 1:11 am
Quoting CM (Reply 7):
and A300, A310, A330, A340 ............
Qantas744er
Wed Nov 21, 2012 1:47 am
They just did,
LOV for -8i/F is:
So the same as -400/M/F
BTW, the -400D kept the 35,000 Flight Cycles, so no change to 40k.
Straight from boeing: http://www.boeing.com/commercial/aeromagazine/articles/2012_q4/2/
[Edited 2012-11-20 17:48:40]
You live and you die, by the FMA
BoeingVista
Wed Nov 21, 2012 3:54 am
They have progressively introduced new more efficient brakes and breaking materials, why cant they certify new MTOW by computer simulations?
BV
KC135Hydraulics
Wed Nov 21, 2012 4:02 am
Messier-Bugati brakes on those A380s, by chance? I know they make good brakes! I overhaul C-17 and KC-135 brakes back home and they're both made by Messier-Bugati. A typical C-17 brake can stay on an aircraft for up to 5 years before its worn beyond limits. Granted, a C-17 isn't flying as many hours per day, but it experiences a significant amount of high energy stops due to assault landings and other assorted practice landings.
Sorry if I went off topic here, I'm just a big fan of French-made aircraft brakes. Their design is outstanding and repair/overhaul on them is very easy.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
Stitch
Wed Nov 21, 2012 4:35 am
Quoting BoeingVista (Reply 10):
That might very well be the case, since they didn't perform the RTO at the A380-800F's MTOW of 590t even though they did do a 596.5t take off and a 590t landing. Last I heard, with 20 main braking units the limit was 625t.
Wed Nov 21, 2012 4:57 am
The certification tests in 2007 were performed at 577 t, the brakes were only absorbing 89 MJ (bit under 75% of their design as they were designed for 120 MJ). Airbus increased the envelope last year beyond 577 t with RTOW tests up to 600 t.
CM
Wed Nov 21, 2012 5:01 am
Quoting zeke (Reply 8):
Thanks Zeke. I was aware of the A300/310, but not the A330/340. Do you know why Airbus takes this approach? At least in the case of the A320, the ESG program was a major undertaking, including puting the fatigue articles back into test. Still underway in persuit of ESG2, as far as I know.
Quoting qantas744er (Reply 9):
They just did,
LOV for -8i/F is:
Thanks for that. I guess no surprises there.
Wed Nov 21, 2012 5:22 am
Quoting CM (Reply 14):
The design load spectrum almost always has been far greater than what the airframe sees in service. They use a combination of the ground fatigue testing and in flight service flight spectrum to extend the life. Additionally the average flight time per cycle often is higher than what was designed. Airbus only had the A300/A310 freighter conversions, that had been their priority for life extension, next came the A320 as they were looking at the P2F conversion for them. The A330/A340 was the lowest priority as it did not have a P2F program until relatively recently.
The first A330/A340 extension happened not long back, it was all part of them getting the heavy maintenance period extended to the same interval as the 787, it eroded one of Boeings marketing advantages. I think it only resulted in a modest increase in cycles to around 10,000 cycles, still a reasonable amount for a long haul aircraft (the 777F correct me if I am wrong was designed for 11000 cycles).
As far as I know Airbus exceeded their 2.5 times design goal on the A380 last year in the fatigue rig, they will continue to test the aircraft to well beyond what it is certified for, and use this data to extend the life of the airframe. Likewise I would expect the 787-8I to have a life beyond what Boeing designed it for, an average 4:42 per cycle is well below what any passenger operator would expect to do with such an airframe, on the freighter this could be a little more representative.
lightsaber
Crew
Wed Nov 21, 2012 5:30 am
While the WV008 was expected, the other two are a little of a surprise. Is there a European airport with significant noise penalties? For DXB-Europe is quite possible at that MTOW. How would it benefit an airline in terms of allowed operations at which airports? (Note: LHR does have noise limits... So there would be one I'd assume it would be useful.)
What are the correct numbers, per the link:
WV008 high MTOW
WV007 high MZFW
WV006 low MTOW for noise.
I just would like to know what is what.
Isn't that WV006? Either way, I think with 97t of fuel with the highest MZFW, it should be able to make it to Europe from the mid-east, so its a little more than regional. Note: I'm tired, so I'm guessing range profiles in my head instead of properly looking at a chart.
Quoting Stitch (Reply 3):
Agreed. Or even as their 11 hour 3-class.
How I see it
WV008 (high MTOW) for 3-class (or 4-class) ULH
WV007 (high MZFW) for 2-class long haul. I agree with the 11 hour. For how could one use the weight with crew rests?
WV006 high MZFW with low MTOW should be a great weight hauler as far as Europe to the mid-east
I see WV006 being EK specific. (They order enough for that privilege.) WV008 will be popular (BA, EK, and I expect future QF, SQ, KE, and others). WV007 is an interest outlier... I wonder who else ordered that variant (other than EK).
Lightsaber
Qantas744er
Wed Nov 21, 2012 6:56 am
Quoting lightsaber (Reply 16):
These are the new anticipated LOV values (pending FAA approval):
777F
Flight Cycles: 37,500
Flight Hours: 160,000
The 777 -200/ER/LR and -300/ER:
Flight Cycles: 60,000
787
Flight Cycles: 66,000
Flight Hours: 200,000
The following LOV's and Service Bulletin schedules will only become effective on Jan. 14, 2016. So plenty of time for Boeing to adjust the LOV values.
[Edited 2012-11-20 23:02:16]
Wed Nov 21, 2012 7:22 am
Quoting qantas744er (Reply 17):
So what are the current ones ? i.e. the ones that are approved.
Qantas744er
Wed Nov 21, 2012 7:45 am
Quoting zeke (Reply 18):
Currently:
777 -200/ER/LR -300/ER
Flight Cycles: 40,000
777F
Flight Cycles: 11,000 (As you correctly stated before Zeke)
As mentioned, the new B777, B787, and A380 LOV's will be determined by latest Jan. 14, 2016.
[Edited 2012-11-20 23:51:26]
Stitch
Wed Nov 21, 2012 2:23 pm
The article has incorrect Weight Variants. My WV's are from the A380 ACAP (November 2012).
lightsaber
Crew
Wed Nov 21, 2012 8:07 pm
Quoting Stitch (Reply 20):
Thank you.
Nitpick, that was Zeke.
777F
787
Since this is an A380 thread, what are the A380 values (current or anticipated LOV)
Lightsaber
CM
Wed Nov 21, 2012 8:23 pm
Quoting lightsaber (Reply 21):
Current LOVs for the A380 are:
