dlramp4life
Airline Pit Crews
Fri Nov 23, 2012 10:00 pm
Reposting because I think it is a great topic, especially if you are an airline employee working over the holiday season.
This is the article/video CNN released going behind the scenes of UA operations and ramp in IAH
http://www.cnn.com/2012/11/22/travel...-ground-crews/index.html?hpt=tr_c1
It is nice to see this since most ramp workers go are the unsung heros of the holiday traveling season.
They said ramp crews will work six turns in a day. Is this how it works in hubs like IAH,ATL,ORD,JFK,DTW,etc?
SEA Ramp, wettest place on earth
777ord
RE: Airline Pit Crews
Sat Nov 24, 2012 2:38 am
for the most part, yes. When you consider the average "turn" takes an hour. an 8h shift including 30min lunch doesn't giving much for downtime and delays. So yes, 6 is an accurate number.
HOWEVER, there are times when you are scheduled to do the 40min turns and CAN do 7. Keep in mind, physically that 7 turns in crampt spaces can be quite intense on your body. Tie in weather, time and physical space contraints, this helps prevent wearing/ fatigue and mistakes in the long run.
womenbeshoppin
Sat Nov 24, 2012 3:45 am
An 8 hour shift on a high volume hub station located in Pennsylvania in the domestic concourse would typically see 3 "turns" and a terminator for mainline airbus aircraft, 319/320/321 or 4-5 "turns" and a terminator on a gate with mostly 170/175s. It would rarely differ from that. Unless you were lucky enough to have a plane go Tech on your gate and sit the rest of the day. Loved those days!!!!
Edit, that of course is for the afternoon shifts, because morning shifts were at least 10 years of seniority. But the ot that I worked in the morning saw roughly the same thing give or take an extra flight in lieu of the terminator.
[Edited 2012-11-23 19:47:45]
captainstefan
Sat Nov 24, 2012 4:02 am
My personal 'best' was 5 total flights (one out, 4 turns and one in) in a 5 hour evening shift. Suprisingly, not anytime close to Thanksgiving or Christmas - it was on MLK day this past January (3rd Monday of the month).
Long Live the Tulip!
adh214
Sat Nov 24, 2012 4:12 am
Quoting womenbeshoppin (Reply 2):
If your gate is "closed" by a tech place, why don't they move you to another gate to help out? It seems like a waste to just sit around all day.
Andrew
womenbeshoppin
Sat Nov 24, 2012 12:42 pm
Quoting adh214 (Reply 4):
That is the beauty of a hub and a union. The concourse lead who makes the gate schedule is also a union employee, kinda a avoiding friendly fire situation. You are assigned to that gate and should management choose not to take the plane off your gate, that is their problem not yours. There is also the case when your gate gets slammed. Take the good with the bad. Plus if someone would go to another gate and get injured or have an aircraft damage then that person will be jammed up because they were not assigned to the gate. This is talking hub, not a line station. Much different for a line station.
mhkansan
Sat Nov 24, 2012 1:23 pm
At my outstation, I can pick up a double shift and work all seven operations - two kickoffs, three turns, two terminators - with lots of downtime in between. Altogether about 16 hours and I really enjoy it!
Skd 30 minute turns here, but if we need to we can do a full in full out turn in 14 minutes (our best) and with realistic "obstructions" about 18-22 minutes.
NWAESC
Sat Nov 24, 2012 2:18 pm
Rampers are underrated.
Quoting womenbeshoppin (Reply 5):
Yep.
Often much busier, and a lot less specialization. No units either, of course; if it shows up in your city, you work it.
I see 7 launch (or kickoff) flights, and 4-5 turns on my shift. Mix of M/L and regional A/C.
"Nothing ever happens here, " I said. "I just wait."
dlramp4life
Sat Nov 24, 2012 7:36 pm
I work in a line station and on my shift you either work two over nighters and one turn that have a ground time of two plus hours. Of course we also have a tow crew that moves over night A/C around to open up gate space.
I think some of the nonunion carriers are not like that. Am I right?
womenbeshoppin
Sat Nov 24, 2012 9:23 pm
Maybe like ATS or Servisair or swissport or some contractors could be like that. I think you would be hard pressed to find a us airline regional or not that is not part of a union. I could be wrong though.
dlramp4life
Sat Nov 24, 2012 9:30 pm
Well it rises the question of how the WorldPort operation works in ATL since DL is not union. Also regional airline ground crews like OO are not union as well and they operate a hubs in SLC, DEN, and LAX.
NWAESC
Mon Nov 26, 2012 8:54 am
Quoting dlramp4life (Reply 8):
Must be nice...
Maverick623
Mon Nov 26, 2012 9:24 am
It's about the same for a high volume hub station in Arizona
My personal records for a gate are 6 turns and a terminator in 8 hours (all 733s), and there was one day where I literally did zero flights.
But my specialty (and regular bid) is connecting bags (CONX/ABR). An average mainline-mainline PM shift will have me running 3-4 flights, and about double that if I'm running mainline-express (although it's usually a lot less bags total). AM shifts are a little busier, with the average being upped by 1-2 flights/shift.
Quoting nwaesc (Reply 7):
I think a better term is under-appreciated.
FWIW, I have NEVER heard anyone say they don't miss working the ramp.
"PHX is Phoenix, PDX is the other city" -777Way
delta2ual
Mon Nov 26, 2012 1:47 pm
Quoting Maverick623 (Reply 12):
Isn't that the truth! My very first airline job at 19 was with HP in TUS. We were cross-trained CSR's and I loved my 2 ramp days. I dreaded my ticket counter and gate days! I was in the best shape of my life and I liked the the teamwork on the ramp. Being a F/A had its perks too but nothing beats the ramp. I've thought of hiring back on as a part-time ramper. Since I don't need the money, I think it would be fun.
From the world's largest airline-to the world's largest airline. Delta2ual
