flightsimer
AA 777-300ER, Minus Vertical Stab?
Fri Nov 30, 2012 2:46 am
What is the reason behind this? I have never heard of or seen pictures of a plane being on the flight line in such an unfinished condition like this ( and the 787 doesn't count).
I'm assuming that there had to be some sort of issue with the vertical. Does anyone know if it was found prior to or after assembly?
http://www.flickr.com/photos/microvolt/8231546866/in/photostream
[Edited 2012-11-29 19:34:35]
Commercial / Airline Pilot
tonytifao
RE: AA 777-300ER, Minus Vertical Stab?
Fri Nov 30, 2012 3:14 am
They took it out for a wash
Have no clue!
rj777
Fri Nov 30, 2012 3:30 am
OR.................... maybe they're going to use it to unveil the new AA corporate logo!
as739x
Fri Nov 30, 2012 3:31 am
They need to take it off to apply their fancy new livery??
Seriously though, I have to agree, this is not a common sight.
FI642
Fri Nov 30, 2012 3:34 am
I've seen DC-8's in the same situation on the production line
737MAX, Cool Planes for the Worlds Coolest Airline.
flightsimer
Fri Nov 30, 2012 3:36 am
Quoting FI642 (Reply 4):
But this is on the flight line.
tonytifao
Fri Nov 30, 2012 3:37 am
might be for the special livery. That means the body might just be a solid color and the vertical have the slick design
SXDFC
Fri Nov 30, 2012 4:44 am
Is this 717AN or 718AN?
liftsifter
Fri Nov 30, 2012 4:53 am
^ 718AN.
Something tells me they want to apply some special coat but are holding back.
A300 A310 A319 A320 A321 A332 A333 A342 A343 A346 A380 B736 B737 B738 B744 B763 B77L B77E B77W B788 E190
deltaflyertoo
Fri Nov 30, 2012 5:11 am
Quoting liftsifter (Reply 8):
Agreed. There was article out this morning from local Dallas news station confirming new livery but saying that AA refuses to say when or how it will be revealed. My guess is they planned on doing it already but w/ the pilot contract out for vote they want to make double sure the labor issues have settled down first, i.e. last thing they need is to unveil new livery/logo/77W roll out along w/ commercials and such w/ backdrop of another major slowdown and media circus.
brilondon
Fri Nov 30, 2012 1:15 pm
Or maybe it is a conspiracy, they are going to paint it like every other AA aircraft and end all the speculation about a new livery. Just saying.
Rush for ever; Yankees all the way!!
baldwin471
Fri Nov 30, 2012 1:26 pm
Quoting brilondon (Reply 10):
I can't fathom how ghastly the 77W would look in the Current AA livery. Maybe as bad as their 772's.
RyanairGuru
Fri Nov 30, 2012 1:31 pm
Quoting deltaflyertoo (Reply 9):
I think it has more to do with the delay in 77W deliveries, although I see you point about avoiding a labor showdown after the "birth of the new American", or however they spin it.
So they went and wasted a massive amount of money painting a 77W white and grey just to entertain ANetters?
Quoting baldwin471 (Reply 11):
I agree, but it'll be much worse because there is so much more empty metal.
Worked Hard, Flew Right
A388
Fri Nov 30, 2012 1:46 pm
I join the ones who say that it is strange that the vertical stabilizer is taken off completely on the flight line. Even if they wanted to keep the new tail logo a secret, it shouldn't have been necessary to take the vertical stabilizer completely off like this.
In the mean time we are all awaiting the new livery AA will be introducing
A388
TC957
Fri Nov 30, 2012 2:24 pm
This strikes me as being a quite drastic move just to hide the new logo, why not leave it on and paint it all white instead.
After all, the rest of the aircraft still has teo be painted.
So what's happening to AA 77W's on the FAL in production now ? Presumably the third one is there or thereabouts by now. Is it being built without the vertical stab ?
Stitch
Fri Nov 30, 2012 2:43 pm
Isn't 717AN still out on the flight line with no logo on her vertical stabilizer?
Plus 718AN hasn't even had her fuselage painted, so why would Boeing slap the logo on her tail? And even if they had for some reason, easy enough to cover it up in the paint hangar before they rolled it out.
The only way this makes sense to me as a logo-related issue is if they're painting the vertical stabilizer separately, but if that was the case you think they would have pulled it off of 717AN, as well.
So I'm guessing there was an issue with the tail that requires fixing. Maybe they banged it into something and damaged it?
row44seatk
Fri Nov 30, 2012 3:00 pm
It's the newest in liveries - "See-through Tails"
Somebody has to sit on that seat.
JAAlbert
Fri Nov 30, 2012 3:13 pm
How did they remove the tail? Did they do it outside, or move it into the factory and use a crane? I thought that balance of the tail is so critical that manufacturers must handle it very carefully. Yanking it off outside doesn't seem to fall within the handling protocol if that is the case.
tdscanuck
Fri Nov 30, 2012 3:23 pm
Quoting JAAlbert (Reply 18):
They would have had to use a crane, whether it was inside or outside. Given that the factory has overhead cranes everywhere, it would seem very likely that this was done inside.
That's true, although it's really only the rudder that has a major balance concern.
Even if done outside, nobody is "yanking" anything. If you ding it, you've got to repair it regardless of the balance. So you don't ding it.
Tom.
Fri Nov 30, 2012 3:31 pm
My guess would be a production holdup, or possible damage.
lostsound
Fri Nov 30, 2012 3:37 pm
Quoting zeke (Reply 20):
Agreed. Traditionally, when an airline is introducing a new design that is not ready for reveal, they "tape" white sheets over the design to hide the painted artwork. We saw this with many carriers including JetBlue, a couple years back now when they introduced the blueberry tail design and new upsized logo.
The removal or non-attachment of the the vertical stab. is too extreme of a move to be related to the new livery in my opinion. There are much less dramatic, and cheaper, options to hiding the colours.
Ychocky
Fri Nov 30, 2012 3:46 pm
Any precedent for this occurring on any other programs?
Maybe?
Navion
Fri Nov 30, 2012 3:50 pm
Actually it is none of the speculation listed above. This aircraft is testing a new 777X feature which does not have a vertical stabilizer (saving a ton of weight) but instead uses fly-by-wire controlled split ailerons and differential computer controlled thrust asymmetry to achieve directional control resulting in significant fuel savings. If thrust control plus split-ailerons doesn't result in satisfactory yaw control, they will also use a control vane in the APU exhaust to supplement the authority.
135mech
Fri Nov 30, 2012 3:53 pm
Vertical fins, are hinged and are folded to one side before they are removed. This can be done outside or inside with the use of cranes.
As Stitch said, there probably was some damage as this is usually the only reason you ever remove a vertical fin. The Rudder is the only thing that gets removed for new livery applications (most of the time), due to the need to "balance" it after the new paints are applied.
135Mech
135Mech
Someone83
Fri Nov 30, 2012 4:13 pm
Since the aircraft had its tail on when it was flying last week it can't be the first one...
pwdalmech
Fri Nov 30, 2012 4:49 pm
With AA 77W production delayed, this vertical stabilizer was probably swapped to another aircraft in final assembly.
Pure Power
brilondon
Fri Nov 30, 2012 4:50 pm
Quoting RyanairGuru (Reply 12):
Yes, and LH, AF and Swiss are so much better, not having any thing but a billboard style name on a blank white surface. Give me a break...
kanban
Fri Nov 30, 2012 5:03 pm
Quoting 135mech (Reply 24):
I believe they stopped doing that with the 707.. originally it was to allow the plane into low clearance hangers.
As I recall all vertical fins are installed vertically and attached with pins laterally not fore and aft.
I seem to recall that the paint delay is due to a seat problem so no new paint until mid January.
[Edited 2012-11-30 09:05:06]
phxa340
Fri Nov 30, 2012 5:05 pm
Quoting pwdalmech (Reply 26):
I think this is the most plausible. Why have inventory sitting around when you can put it in another plane that will be delivered soon ?
Fri Nov 30, 2012 5:10 pm
Quoting Someone83 (Reply 25):
It can, just like the engines, they may belong to another airframe.
IAD787
Fri Nov 30, 2012 5:55 pm
Okay, this made me laugh.
Quoting Navion (Reply 23):
But I can say definitively it has absolutely nothing to do with the new colors.
Former FlightBlogger turned Wall Street Journal Aerospace Beat Reporter
Dtw757
Fri Nov 30, 2012 5:57 pm
I think the delay which is due to "seat issues" is smoke and mirrors. I think Q1 2013 you will see AA emerge from bankruptcy with a completely new rebranding top to bottom. You will not see the new branding until the day they emerge however. Carefully timed with the delivery of the 777-300. They aren't ready yet to emerge so they aren't ready to paint the 77W. It would be hard to keep that secret once it's completely painted. I think this white you're seeing on the gray plane is also a mule much the way they disguise new cars before they are released. In the end the tail will not be white but perhaps all blue. Just my
721,2,732,3,4,5,G,8,9,741,2,3,4,752,3,762,3,4,772,3,788,D93,5,M80,D10,M11,L10,100,AB6,319,20,21,332,3,346,388,146,CR2,7,
baldwin471
Fri Nov 30, 2012 6:09 pm
Quoting brilondon (Reply 27):
I never said that was better. Although in those cases yes they do look better than shiny tacky metal. Look at TG or EY and their liveries, no-one is saying you either have to have euro-white or tacky metal. AA's looks horrible. Look at AM if you want to see polished metal done correctly.
strandedinbgm
Fri Nov 30, 2012 6:25 pm
It's there. It's painted in AA's new invisible livery.
It's 737s, 747s and 380s. Not 737's, 747's and 380's. Learn to use the apostrophe for crying out loud.
brilondon
Fri Nov 30, 2012 6:36 pm
Quoting strandedinbgm (Reply 34):
Quoting iad787 (Reply 31):
They have the technology but have never put into use. WONDER WOMAN'S AIRPLANE!
Kempa
Fri Nov 30, 2012 7:58 pm
Waiting for a polished metal stab perhaps? Can't remove paint if the new logos are on AA polished metal background. Possibly getting a new stab that is polished with only the logo painted.
Stitch
Fri Nov 30, 2012 8:29 pm
Quoting Kempa (Reply 35):
The 777 vertical stabilizer is CFRP, not Al, so it can't be polished.
718AN flew on 16 November with an unpainted vertical stabilizer (I can't tell if the rudder is white or grey in the ambient light).
ckfred
Fri Nov 30, 2012 8:36 pm
Having spent a lot of time on AA, as well as sitting at ORD, I love the look of the 772 in the bare metal finish.
Considering the number of planes that are all white or mostly white, including UA, US, and DL, the bare metal finish can't be mistaken, especially on a sunny day.
If you think AA's bare metal is ghastly, what do think of the old Hughes Air West scheme, bright yellow with purple trim. That was ghastly, especially if they hadn't been washed for some time.
Stitch
Fri Nov 30, 2012 8:41 pm
Quoting ckfred (Reply 37):
If (one) think(s) AA's bare metal is ghastly, what do(es one) think of the old Hughes Air West scheme, bright yellow with purple trim?
Have to say I was a fan.
But I was also like 7 when I saw them at BUR.
Viscount724
Fri Nov 30, 2012 8:48 pm
Quoting kanban (Reply 27):
The Boeing 377 Stratocruiser tail could be folded to fit low hangars. I've never heard of any jets with that capability.
http://i1117.photobucket.com/albums/k593/pilot852/hangar.jpg
AZA330
Fri Nov 30, 2012 9:57 pm
Please do not tell me that AA cannot afford to buy the tails for their new 77Ws...
rc135x
Fri Nov 30, 2012 11:26 pm
Quoting Viscount724 (Reply 39):
I believe both the B-52 and the KC-135 had this capability. Photos of early B-52 roll out show the folded tail. This capability saw little (if any) use in routine operations.
KC-135A, A(RT), D, E, E(RT), Q, R, EC-135A, C, G, L, RC-135S, U, V, W, X, TC-135S, W
KC135Hydraulics
Fri Nov 30, 2012 11:32 pm
The vertical stabilizer on the KC-135 can be folded down, but it's a major production to do it so there has to be a good reason for it, IE serious maintenance, damage, or..... dropping a wrench down the stabilizer while changing a rudder compensator, perhaps....... .. not that I'd know about that, of course.....
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
rj777
Sat Dec 01, 2012 12:16 am
Quoting Navion (Reply 22):
I don't believe a word of this. No airplane can fly without a vertical stabilizer. It's a matter of simple physics. Every airplane from the Wright Flyer all the way to the present has had some form of a vertical stabilizer.
etoile
Sat Dec 01, 2012 12:18 am
Quoting rj777 (Reply 43):
The B-2 doesn't, but Navion is jk anyway.
[Edited 2012-11-30 16:19:25]
American 767
Sat Dec 01, 2012 1:10 am
The B-2 Stealth doesn't have a vertical stabilizer, like etoile said.
But, with all due respect to Navion, I think that he was just kidding in what he was saying. Of course this 777 won't fly like that. As other have said, it was taken away by cranes to fix an issue, before continuing building the airplane. I think that the reason the airplane is not kept inside the hangar in Paine Field is not to block the production line.
Ben Soriano
Ben Soriano
tdscanuck
Sat Dec 01, 2012 2:17 am
Really?
http://upload.wikimedia.org/wikipedia/commons/4/47/B-2_Spirit_original.jpg
http://upload.wikimedia.org/wikipedia/commons/d/d7/Dark_Star_USAF.jpg
http://www.richard-seaman.com/Aircraft/AirShows/Chino2004/Sampler/N9mbFlyingWing.jpg
http://upload.wikimedia.org/wikipedia/commons/a/a9/X-31_Quasi-Tailless_over_Edwards_AFB.jpg
maxpower1954
Sat Dec 01, 2012 2:23 am
Yes, Navion was trying to be funny. The nuances of humor can be difficult to convey through the printed word.
Speaking of aircraft with no vertical tail, check this out..
http://www.britishpathe.com/video/tailless-bomber-trail
RobK
Sat Dec 01, 2012 2:28 am
Oh dear... Whoosh parrot anyone?
amccann
Sat Dec 01, 2012 4:35 am
For curiosity sake and somewhat unrelated;
Was the X31 ever actually flown without the vertical stabilizer? It appears the photo above is an edited photo. I thought the X31 performed "quasi tailless flight test," utilizing intentionally destabilizing control inputs in roll and yaw and then controlled the destabilizing inputs via three dimensional thrust vectoring.
What one person receives without working for, another person must work for without receiving. - Ronald Reagan
