waly777
Boeing Reduces 747-8 Weight By 2.5tons
Wed Dec 05, 2012 5:25 pm
The test of first-rate intelligence is the ability to hold 2 opposed ideas in the mind concurrently, and still function
Stitch
RE: Boeing Reduces 747-8 Weight By 2.5tons
Wed Dec 05, 2012 5:44 pm
747classic pegged the OEW excess for the earlier-built frames at between 1.8 and 2.7 tons, so this 2.5 ton reduction should pretty much bring the 747-8 on-target.
So with the 7.7 ton increase in MTOW, that should help recover a fair bit of payload for the freighter. And once the GE PiPs are in place to address the SFC miss...
astuteman
Wed Dec 05, 2012 5:58 pm
Quoting Stitch (Reply 1):
Agree. Cargolux seem to think the improvements get the plane pretty much to its original spec
"The performance, with [the improvements] all in mind, is quite close to what Boeing had in mind," Germeaux added.
sweair
Wed Dec 05, 2012 6:03 pm
Nice to see the grand old lady still has some improvement in her. Will the freighter ever be eclipsed? The passenger model will fade with time, but will the freighter model live on?
na
Wed Dec 05, 2012 6:40 pm
Quoting sweair (Reply 3):
The suggested A380F, if it ever becomes reality, is a different concept that apparently doesnt work for most customers. I dont think it´ll fly. The same is the case for a possible re-engineered and vastly modernised AN124.
There is no serious competition, nothing even remotely visible on the horizon to take the 747Fs place so I say chances are high that will see new Jumbo Jet freighters rolling of the line after 2025. Even another new 747F variant with more efficient engines seems possible beyond the mid-20s. Chances are the 747 will become the aircraft type with the longest production run ever.
sweair
Wed Dec 05, 2012 6:45 pm
The A380 has no nose loading possibility, sure it could carry heavier weights but it could not do what the 747 does. It will probably be the only civilian freighter with a nose cargo door. A unique feature so far for civilian freighters?
Stitch
Wed Dec 05, 2012 6:47 pm
I know some pundits like to point out that "nobody" uses the nose door for cargo handling (even though the Photo database continues to add new pictures of operators using the nose door for cargo handling), but if that was truly the case, one would think Boeing would not have engineered it into the 747-8F as it adds weight and complexity.
[Edited 2012-12-05 10:57:47]
sweair
Wed Dec 05, 2012 6:53 pm
Yeah the pictures of the first 748F delivered had it loaded through the nose. I would guess a nose loading is faster?
N14AZ
Wed Dec 05, 2012 6:55 pm
Quoting sweair (Reply 5):
A unique feature ?
Nope, Bristol 170
Stitch
Wed Dec 05, 2012 6:58 pm
Quoting sweair (Reply 7):
Yes.
The disadvantage to nose loading is pallets cannot be dimensioned as high as those loaded through the side door.
Extra300
Wed Dec 05, 2012 7:01 pm
Don´t forget the utterly cool ATL-98 Carvair
CM
The main reason for using the nose door is for cargo which cannot go through the cargo door. Often it is very long items.
rwy04lga
Wed Dec 05, 2012 7:04 pm
And the Me-323 Gigant
Just accept that some days, you're the pigeon, and other days the statue
Wed Dec 05, 2012 7:40 pm
Quoting Stitch (Reply 6):
A very small percentage of our freighter flights use nose loading in HKG, and that is normally for long items like yacht masts. The shape of most freighter aprons does not cater for nose loading, often these bays have structures for guidance onto the bay erected in-front of the pilots to tell them left/right and when to stop. Wingtip clearance is the issue.
With the longer length of the 747-8F again, nose loading takes up taxi/apron space, or the vehicular access road. As previously mentioned, the pallets if nose loaded are restricted to 8' high due to the cockpit, where they can go to 10' high with a larger footprint via the main door.
I have never seen any of the express carriers load via the nose at HKG, they would not most time sensitive carriers. Loading/unloading only via the nose would not be that smart from a W&B point of view, sounds like a good way for this to potentially happen
Photo © Morris Biondi
Quoting N14AZ (Reply 8):
Bristol 170
Armstrong Whitworth Argosy, Antonov (various), Beluga, Super Guppy are some others. For long bulky items, an aircraft the size of a 747 in most cases is an overkill for the payload length, volume, or mass.
PlanesNTrains
Wed Dec 05, 2012 7:46 pm
Quoting zeke (Reply 13):
Like airlines using long haul aircraft on regional routes, some operators would probably prefer to have the capability built into their 747's and have it when needed. Or, I guess, they could tell the customer to pound sand. I'm sure if someone is loading through the nose that no one is holding a gun to their head - they could always turn the business away if it isn't profitable, so I'm guessing that it's a least a useful feature at times.
-Dave
-Dave
sweair
Wed Dec 05, 2012 7:50 pm
The nose door would be gone if customers did not want it, I am sure it is a benefit for many operators other than Zekes employer.
DocLightning
Wed Dec 05, 2012 8:02 pm
Returning to the OT (heaven forbid   ), what did Boeing to do shave off 2.5T of weight? And what did they do to the ailerons? Is it the same slight downward deflection to improve the wing twist as on the 77L/W vs the 772?
Is the 748i now fully FBW or are only some surfaces FBW?
-Doc Lightning-
-Carl Sagan
Stitch
Wed Dec 05, 2012 8:08 pm
Quoting DocLightning (Reply 16):
What did Boeing to do shave off 2.5T of weight?
As I understand it, the airframe was over-engineered / over-built - especially the parts handled by the Moscow Design Center ( they must have been building to Soviet spec.   ). This was why they could raise the MTOW almost 8 tons. So I expect they have subsequently engineered out some of that extra structure.
I believe only the spoilers and outboard ailerons are FBW. They do droop the ailerons to allow for low speed performance and tune low-speed roll response. They also are used to counter the flutter effect generated by certain flight conditions.
[Edited 2012-12-05 12:24:23]
Wed Dec 05, 2012 8:16 pm
Quoting sweair (Reply 15):
There is a benefit, however it is small.
Have a look for yourself at the worldwide freighter fleet (all sizes) and see how many aircraft have nose loading, and ask yourself if there was a considerable benefit, why the majority of freighters do not have it.
Ask yourself what sort of customer needs to send something by air that cannot fit on a standard pallet, and how often that demand would arise. The answer is not zero, however it is not as great as the the demand for shipping engines, or electronics. Airlines survive by having consistent loads which are boxes and pallets, ad-hoc charters for over size items are great of you can get them, and if the spare capacity is there in your fleet at the time.
PlanesNTrains
Wed Dec 05, 2012 8:32 pm
Quoting zeke (Reply 18):
True. But you can't get those needing a nose-loading capability if you don't have nose-loading capability. You don't need every freighter in your fleet to have the ability but having it on one type will benefit some operators. I guess the question is if it would make sense to have it only be an option, but apparently Boeing decided that it wasn't. Thus, a moot point.
-Dave
-Dave
CM
Wed Dec 05, 2012 8:47 pm
This depends highly on the operator. There are some 747F operators with contracts to carry goods which require the nose door (again, primarily because of length). The 747 is the only viable freighter with this capability and many carriers would have been hurt by a 747F which did not offer it. The weight of the nose door easily buys its way onto the airplane for these operators; they often charge up to a 50% premium for this cargo (as I am sure CX does for carrying masts, etc).
PlanesNTrains
Wed Dec 05, 2012 9:04 pm
Quoting CM (Reply 20):
If they didn't, I'm sure they wouldn't be carrying it. Unless, of course, they have two much capacity, but then why take additional 748F's?
-Dave
-Dave
redflyer
Wed Dec 05, 2012 9:27 pm
Small, but commercially viable from an aircraft manufacturing standpoint. Which says it all.
And that's all that really matters.
A government big enough to take away a constitutionally guaranteed right is a government big enough to take away any guaranteed right. A government big enough to give you everything you need is a government big enough to take away everything you have.
PlanesNTrains
Wed Dec 05, 2012 9:30 pm
Quoting redflyer (Reply 22):
Somehow I think it will never really matter.
-Dave
-Dave
ATA L1011
Wed Dec 05, 2012 9:56 pm
Quoting na (Reply 4):
Will be interesting to see if it can/will surpass the C-130 Hercules which has been in continuous production since 1954, which has 14 or 15 years on it......
Treat others as you expect to be treated!
columba
Wed Dec 05, 2012 9:57 pm
Can existing planes be retrofitted so that they benefit from that weight reduction as well. I believe LH will be very keen to get some lighter planes.
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
kl671
Wed Dec 05, 2012 10:14 pm
And the Airbus A300-600ST Beluga.
flightsimer
Wed Dec 05, 2012 11:22 pm
Quoting kl671 (Reply 26):
The beluga is NOT nose loading. It's forehead loading.
Commercial / Airline Pilot
Viscount724
Wed Dec 05, 2012 11:29 pm
Quoting Extra300 (Reply 10):
And the Bristol 170 Freighter.
speedbird128
Thu Dec 06, 2012 12:04 pm
Quite... I worked at an airport supporting 3 or 4 cargo airlines which used their 747s there... not once in 4 years did i see the nose opened... all loaded through the sides...
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
parapente
Thu Dec 06, 2012 12:26 pm
Which in a sense rules this factor out as to why the 380F failed. One reason was that they were so far behind schedule at the time.However the big one (as I recall) was that whilst the 380 offered volume it did not offer payload to match (ie ligher bulky stuff).But it was a while ago could be wrong. However...
Over the past 2 years Airbus has been ramping up the weight the 380 can use if I am not mistaken (and this is with the "lighter" wing) . Perhaps - just perhaps it may one day make a comeback when/if the payload numbers become acceptable?
na
Thu Dec 06, 2012 12:34 pm
Quoting parapente (Reply 30):
Perhaps that impression is influenced because many of the 747Fs you see are BCFs? In FRA I regularly see 747Fs with open nose. If airlines wouldnt need the (surely expensive) nose door, they would force Boeing to be able to order the 747F without it. Simple as that.
DarkSnowyNight
Thu Dec 06, 2012 12:47 pm
My office happens to be adjacent to a cargo loading bay at LAX. We see mostly Southern, Asiana, CX, & NCA on this side. Discounting the ones that don't actually have the front-loader, I would say they open that nose about once a fortnight. So not much, but I'll bet it's worth it when they have it.
The CX 744 & 8fs that come here all use a tail stand to prevent just that. In fact, most 747 operators do that as well.
Much like a GE90, I'm a huge fan of Big Twins...
Stitch
Thu Dec 06, 2012 2:44 pm
I fully believe that the lack of nose-loading played zero impact in the A380-800F not finding strong interest in the general cargo market. And the A380-800F was not lacking in terms of raw payload weight (142t not including tare weight for general cargo).
What hurt the A380-800F was it's high OEW in relation to it's revenue payload. For each kilogram of revenue cargo you flew, you flew 1.7 kilograms of empty structure (150t payload with 251t OEM OEW). Compare that to a 747-400ERF, which flew 1.3kg of structure (126t payload with OEM OEW of 164t).
Now that extra structure allowed the A380-800 to load significantly more fuel - with a 150t payload, the A380-800F could fly twice as far as a 747-400ERF with a 126t payload (10,000km vs. 5,000km), however shorter hops allow more payload to be carried and can end up burning less fuel then the non-stop.
The express carriers liked the A380-800F because they run out of space before they run out of weight. And they ship high-value product that can command the fees to cover the extra fuel necessary to make the trip non-stop.
na
Thu Dec 06, 2012 2:51 pm
Quoting Stitch (Reply 33):
If I remember right the only interest in the A380F came from package carriers, Fedex etc. I doubt that Airbus would ever build it for just a handful of clients ordering a few dozen over a decade. If UPS and Fedex would order 15 each plus options, and DHL maybe 10, ok, thats a start. But otherwise, no.
Stitch
Thu Dec 06, 2012 3:04 pm
Quoting na (Reply 34):
EK ordered the first two in 2001 (my joke was they were to carry back all the shopping that wouldn't fit in the hold of the passenger A380s). ILFC also added 5 in 2001, followed by FedEx with 10 in 2002 and UPS with 10 in 2005.
EK and ILFC both converted their freighters to passenger models in 2006 and FedEx cancelled their order that same year. At that point, Airbus put the A380-800F on hold and UPS subsequently cancelled in 2007.
Thu Dec 06, 2012 3:05 pm
You might think so, even with our large 747F fleet, working out of the airport with the most amount of international air freight in the world, we would not even have the work for one 747F that requires nose loading.
Quoting PlanesNTrains (Reply 21):
They are parking/scrapping all the older 744s, including the BCFs. Another member on the orders thread stated that it was their view that the 77Fs have been traded in for 77Ws.
Kind of, you cannot buy a 747F without one.
The biggest problem with the A380F was the misinformation put into the market by people with a vested interest in another platform, a bit like the original A350. All of the scare tactics regarding what the A380F could and could not do in practice have been shown to be baseless.
astuteman
Thu Dec 06, 2012 3:20 pm
The big one was the schedule slippage, which caused 2 customers to convert to pax models.
The freight specialists (FX and 5X) insisted that Airbus give them a timeline for their freighter deliveries, which Airbus signally, and deliberately, failed to do. Their focus was on rescuing the passenger model.
In effect, Airbus gave these carriers no choice but to cancel.
I'm not convinced that "hurt" the A380F all that much. A bit perhaps.
I was (and am) amongst those who wanted to see the MZFW go up at least 20t to counter this weakness, though.
I think Airbus could have traded that for 20t of fuel. Speaking as an expert of course ....
Not strictly true. EK and ILFC also ordered.
What is interesting is that, back then, David Sutton, Exec VP of fleet planning at FX suggested that we would see over 200 A380F's flying 2 decades after its EIS.
What would he know eh?
True, he did claim that many of these would be ex pax conversions, but was quite clear that the early pax conversions would have nothing like the capability of the dedicated freighter (they have a 30 tonnes lower MTOW for a start)
747classic
Thu Dec 06, 2012 3:21 pm
It all depends what kind of freight your sales department is able to attract and also how flexible your flight scheduling department is .
Having operated a few years 747 freighters with a nose cargo door with MP, I noticed that approx. 3-5% of all flights needed the use of the nose cargo door.
However the revenue of these "nose loading " flights was much higher, because the over-sized cargo part multiplied the yield of the entire flight. It's a niche market , but very profitable.
In our fleet we had 3 x 747-200F/C's with cargo door and one converted 747-200(SUD)SF without cargo door.
The aircraft without nose door was rescheduled to another destination when over-sized cargo had to be transported to another destination (aircraft rotation was altered).
IMHO , a new 747-8F version, without nose cargo door (3-4 tons lower OEW), could be a very economical option for parcel transport companies and for freight forwarders, that already have several "nose door "747-8 freighters in their fleet.
Perhaps an idea for Boeing in this difficult cargo times. Every pound (or kilo) less OEW counts these days and it's a minimum investment (almost a paperwork-certification) to produce a 747-8F, without nose door.
And remember this : the first f 747 -200 freighters were delivered with only the nose door installed.
Soon the side cargo door was added.
[Edited 2012-12-06 08:07:04]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
airbazar
Thu Dec 06, 2012 3:39 pm
So what's keeping the "twin engine revolution" from eventually making its way to the freighter business? It's not like range is a benefit in this business. Is it simply because there are way too many capable pax aircraft available for freighter convertions which keeps manufactures from developing more capable dedicated twin freighter planes?
Quoting na (Reply 31):
It's even simpler than that. Boeing has no financial incentive to do the job so anyone who wants a new 747F has no other choice. The alternative is a BCF.
Stitch
Quoting astuteman (Reply 37):
That certainly explains why the package carriers walked, but we both know that Airbus didn't develop the A380-800F to only appeal to package carriers.
My...interest...is why the general cargo companies didn't order it, but continued to order 747-400Fs (and then 747-8Fs).
The cargo density figures for the A380-800 are all over the place depending on the source, but I wonder if the A380-800F really could have utilized that extra 20t of MZFW (which would have been 422t) based on floor loadings/cargo densities.
Quoting airbazar (Reply 39):
You could argue it already has. In terms of payload weight, the latest specification 777 Freighters are within about 5% of the 747-400F (107t vs. 113t). The 767-300F offers more volume and payload weight than the DC-8F family.And the A330-200F can match the payload weight and volume of the DC-10-30F with significantly better efficiency.
[Edited 2012-12-06 08:31:43]
CM
Thu Dec 06, 2012 5:48 pm
Quoting zeke (Reply 36):
I'm not sure this is really a fair assessment of the situation. Every competitor casts doubt on the competition (see past Leahy comments about the 787-8 being too small, too risky, too much technology, and more recently the 787-10 being too expensive to compete with the A333-300). This does not prevent intelligent airlines from assessing the performance of an airplane independent of either OEM's assessment.
In truth, the A380F made a great package freighter, but lacked the floor strength and MZFW to enable the higher density loads, which the 777F, 747F, A330F and even older freighters could handle. This complicated interlining and meant less revenue per trip than the A380F's volume would have otherwise implied.
This is what is required. There is speculation we will see the A380F again, but not until the A380-900 has entered service. At that point, a shrink of the A389 into an A388-sized freighter would make a potent airplane. This is precisely what Boeing did with the 777F - essentially a -200 size freighter with the structural payload of a 777-300ER. Also, the 777F required the same floor strengthening the A380F would require, in order to take heavy enough pallets.
PlanesNTrains
Thu Dec 06, 2012 6:32 pm
Really? Carriers didn't buy the freighter model because of misinformation? That was the biggest problem?
What a sad and awkward statement about the talent at these carriers if it were true.
-Dave
-Dave
kc135topboom
Fri Dec 07, 2012 2:08 am
Boeing has had the design for the nose door since the B-747-200F, and continued through the B-747-400F/-400ERF.
Cargo airlines use it a lot at DFW.
Yes, but that would happen even if all the cargo is loaded through the aft side cargo door, if cargo is not moved foreward. The B-747F uses a tail stand for cargo loading/inloading operations to prevent that from happening.
UPS ordered their new build B-744Fs back in 2008 (2007?) specifically for the nose cargo loading door. Unfortunately they lost one, and more iportantly the crew in the UPS accident in DXB.
No, only a few control surfaces are FBW now.
FedEx had a small fleet of worn out B-742Fs for a few years after they aquired Flying Tigers, but I don't ever recall them needing to use the nose cargo door.
JoeCanuck
Fri Dec 07, 2012 2:17 am
Quoting 747classic (Reply 38):
I bet that if someone was willing to put a down payment on a few, Boeing would be willing to make a 748F without the nose door. I doubt they would have much effort certifying it since I suspect the nose of the 748i would basically bolt right on.
A few tons more cargo capacity and a few million cheaper might appeal to some operators.
What the...?
