727LOVER
What's Going On @ MCO?
Fri Dec 07, 2012 8:55 pm
I did a thread about 4 1/2 years ago asking about MCO's proposed new Intl terminal:
Is MCO Still Building An Int'l Terminal? (by 727LOVER Aug 11 2008 in Civil Aviation)
Is this STILL on hold?......if so why? There has been a big uptick in intl flights recently.
Photo © Tong Xian
Photo © Tong Xian
Photo © Ozell Stephens Jr
Photo © Zach Lautzenheiser
With WN/FL consolidation, is there an opening for NK? Seems like a perfect market for them to expand greatly including TATL. Would there be around 6 or 7 gates available to them?
And isn't Diz about to open some new big thing?
The west runways seem to have been closed a lot recently, my understanding is for taxiway stuff, unusually long periods, why?
Any new INTL carriers on the way?
Photo © Justin Cederholm
Photo © Misha Tyukin
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
mcoatc
RE: What's Going On @ MCO?
Sat Dec 08, 2012 12:04 am
Ok, I'll have a go at this as best I can.
1. There is nothing official yet on the new terminal. I keep hearing that GOAA is getting closer to pulling the trigger, but I've also been hearing that for 2 years or so. I think they may be waiting for a larger uptick in domestic travel as well. The airport still has a fair amount of open gate space.
2. NK has expanded here a bit recently, with the new ORD, DFW, Latrobe, and now IAH. I think FLL will continue to be their intl gateway.
3. Disney just opened the expanded Fantasyland yesterday, but I don't think there is any really effect on the airport.
4. The west runways have been closed for a number or different reasons, and 18R/36L just closed for 90 days as of two weeks ago. B2, which was just built between the parallels, is now being constructed west of 18R. The bigger reason for the closure is the re-alignment of taxiway A and A1, which no longer meets FAA design code. Apparently the 45 degree angle that A1 meets the runway at must be changed to a 90 degree angle.....and there's a retention pond in the area that complicates the project. After the runway opens, something else will undoubtedly close. I've heard there are 3 years of projects lined up, dependent upon funding. We're lucky to have extra pavement to work with.
5. I haven't heard about any new intl service. AF pulled out in September and I believe GOL is starting something via SDQ, but that's it.
xjramper
Sat Dec 08, 2012 12:20 am
People don't seem to understand that most FL (the state) markets make little money if not at a loss for all airlines. Most travelers are usually on holiday or conventions. This is partly the reason why DL scaled MCO back so far and downgauged a lot of aircraft (ie 777s, MD11s, 764s, and more recently 763s) to the 757 variants and 737s. Similar things happened to TPA/FLL/MIA/PBI, although there are occasional 767s randomly thrown in from time to time.
While you have B6 and to a lesser extent WN flying some short-medium haul international flights, there just isn't much point to build an international terminal when the FIS/CBP facilities that exist today work just fine. My guess is that they decided to reallocate the funds from building a new terminal to making improvements on the airfield instead. Probably a smart move by the GOAA.
Look ma' no hands!
Dazed767
Sat Dec 08, 2012 12:28 am
Give it a few more years and I'm sure TAM will have hourly service to MCO and they'll HAVE to open the new terminal
Clipper136
Sat Dec 08, 2012 2:29 am
The new South Terminal is starting to rear its head again in MCO. GOAA is pushing a 2 prong approach to building it. First is the Inter-modal Terminal that will begin construction next year. The Inter-modal Terminal is a definite Go with parts of the project having already gone out for bidding. It will consist of a Rail station with Intercity rail (All Aboard Florida), Commuter Rail (Sunrail) and possibly Light rail or a Maglev train on a local run (i.e. Florida Mall, Convention Center, International Drive); a bus station (Lynx local service to South Orange and Osceola County) and a multi story parking garage. The parking garage will service Inter-modal Terminal and the new South Terminal.
The Airport is at the point that they will have to make a decision soon on the South Terminal....which the first phase will be a 16 gate international terminal. The North Terminals maximum throughput capacity is 45 million passengers per year. The airport is roughly at 36 million now. Total passenger growth has been flat ( domestic down slightly, international up strongly) At 40 million passengers the North Terminal will start to effect "Customer Service Satisfaction" and have a diminishing rate of return. The balancing question is ....as growth returns...forecasting when we will hit the 40 million mark, and when to begin construction so that it is complete just before you hit the mark that you will need it.
Quoting mcoatc (Reply 1):
Although true, the load factor and average size of aircraft have been on the increase. Although airlines have cut back on leased gates, the passengers numbers have not followed suit. Also the greatest demand right now is the international gates (FIS). International growth has been strong, but we have run short on FIS capacity and Gates especially when majority of the International widebodies all want to arrive and depart in a relatively short time span.
I think that 2013.... with an improving economy...the expansion of WDW (Fantasy Land), Animal Kingdom (Avatar Land), Universal (Harry Potter expansion and Transformers), Sea World and Lego land expanding..add to that the opening of the VA Hospital in Medical City....passenger numbers will be on the rise.
Quoting xjramper (Reply 2):
See Above (when 2 wide-body aircraft have to sit and wait 60-90 minutes to deplane because the FIS is full.....you have a problem. International growth has been a very bright spot for MCO.
BTW the size of the equipment DL operates has little to do with the numbers of passengers DL carries to MCO over ATL where those WB operated.. Point to point service may have been scaled way back but DL has made up the difference by operating those 757s and 737s on 16-18 daily ATL flights. Those WB better served DL on the tatl and tpac they now operate.
MCO is in talks with several international airlines for new or increased serve. Nothing concrete yet outside of service increases, some seasonal, of airlines already operating (JJ, AV, EI, CM, TA, BA, AC and WS)
There is always a list of airfield projects to tackle. We have been fairly constant with taxiway re-hab for the past 3 years. Now there are a few runway rehab projects that are on the horizon so you are probably right.
You can't beat the Experience.
mcogator
Sat Dec 08, 2012 5:18 am
The DL gates are always extremely crowded in the morning rush, and the afternoon rush. Since I believe that FL already moved, I wish DL would take a couple of those empty gates.
“Traveling – it leaves you speechless, then turns you into a storyteller.” – Ibn Battuta
xjramper
Sat Dec 08, 2012 6:07 am
Quoting Clipper136 (Reply 4):
At the peak of DL's reign in MCO, the carrier operated from gates 60-99. I cannot find any information or timetables from pre-1996, but from MCO-ATL alone they had 15-17 flights daily to ATL, none of which were narrow bodies during the weekdays (weekends saw 757s and 72S). L-10-11s, MD-11s, 777s, 764s, 763s were the only aircraft flying. I vividly remember watching those widebodies on depart on the hour to ATL. Today DL operates mainly 70-79, and depending on the time of day also uses some gates in the 80s.
As I stated and you confirmed without realizing it in the above quoted text, the wide bodies (while the L-10-11s and MD-11s were phased out) have been allocated to markets that will make them money. Enplanements are way down, but it shows that money is not to be made in MCO, which is why they allocated the larger aircraft to alternate, more yielding routes.
As a side note, I did not realize it was that bad at the FIS/CBP arrivals area. I arrived on a BA flight 2.5 years ago right behind a VS777 and another BA747. We didn't have to wait to deplane, and while it took us almost an hour to get out of FIS area, it wasn't nearly as bad as LHR/ICN/HKGs arrival waits. And yes, when we arrived into MCO it was split evenly as far as I could tell. So either the customs officials were extremely quick or it was just a one off fluke.
Either way, I would like to see MCO expand. That was my home airport for about 5 years. Nothing like the TSA checkpoint there, especially between 15-1800 heading towards the DL/FL gates.
Look ma' no hands!
NASCARAirforce
Sat Dec 08, 2012 10:56 pm
Quoting 727LOVER (Thread starter):
Come on now, you know who to contact for those questions...
There hasn't really been an uptick in international flights other than some temp charter ones like LAN in January. The uptick was last year and I thought maybe they would bump up the terminal.
If there are it will be out of S. America, not Europe due the Euro value dropping closer to the dollar, where flights to USA won't be as cheap for Euro tourists.
Of course you know the terminal was delayed due to 9/11. It got pushed off to the earliest ground breaking around 2020.
What is being done however in the meantime (at least when I was still at MCO) was to make a couple of the ex Air Tran gates into International gates and somehow get people from the 90s wing down to Customs. On busy days the ex Air Tran gates were being used by Virgin - once they unloaded, they would tow their plane to a 90s gate to load pax so they could free up an 80s gate for the next flight. Customs does need to be expanded but a lot of the problem is that CBP has been understaffed and would be a nightmare between 5p-6:30p back when AF was still here as they arrived at same time as TAM, LH, a couple VS and sometimes the second BA flight - you could have 2000 pax waiting in immigration lines, where maybe there were only 12 lines open.
NK is expanding. They are adding flights to IAH, recently added some to DFW and a few places up north. Frontier has really been expanding too with a lot of new destinations that SWA cut from TRS. With Frontier getting rid of the E190s, they will all be done with A319s
They are opening an expanded Fantasy Land. I don't see a major rush of new service like they would if they opened a whole new theme park like they did back in 1995 with Animal Kingdom. Some of the more hardcore Disney fanatics will check out the new fantasy land right away but its not enough to draw additional flights.
Sea World is also going through a major expansion with a new section in Discovery Cove, new Antarctica exhibit and Turtle Trek. Lego Land opened a couple years back but that didn't really change MCO traffic much
MCOATC answered the runway question.
Let me ask MCOATC this question. Since Runway 18L doesn't have ILS and Runway 18R does and is closed - Runway 36R has ILS but 36L doesn't - does that mean in low visibility conditions if winds are relatively light that the 35s and 36s will be the prefered runway even if there is a south wind? I thought I read in a recent NOTAM that 17R ILS is out of service too - which would leave MCO down to one runway if the winds are out of the south in IFR conditions.
New international carriers - LAN has those charter flights again this Jan to Santiago Chile once or twice a week. GOL will be flying from Brazil with a stop at Santo Domingo SDQ, thought I read it was going to daily. Aer Lingus recently went to 3 X weekly, of course you know about TAM adding RIO back in Oct. Nothing expected from Europe.
SCL767
Sun Dec 09, 2012 8:54 am
Quoting NASCARAirforce (Reply 7):
LA508/LA509 operate as seasonal flights during January and February.
It's interesting to note TAM's growth at MCO. TAM initially launched one daily non-stop service between GRU and MCO. Now TAM operates GRU-MCO 2x daily (A332) and GIG-MCO daily (A332).
readytotaxi
Sun Dec 09, 2012 11:36 am
While on this subject what is the contruction on right next to the shuttle as I arrive in from gate 80?
mco
Click on image for bigger picture.
It appears to be another tramway but does not seem to lead anywhere?
mcoatc
Sun Dec 09, 2012 12:34 pm
Quoting readytotaxi (Reply 9):
This is the tram bridge for the future international terminal to the south. I believe money existed for it years ago and, at that time, the new terminal seemed imminent.
Luckily, this time of year usually dictates a north operation.....of course this is the time of the year that also involves foggy mornings. We're actually operating with a slight tailwind on a north op as I write this, for much the exact reason you mention. It's also easier with the B1/B2 closure, in that west ramp departures don't have to cross 18L at Juliet or take the intersection.
The radar guys like the north op because it's easier for them too. Even when the 17R ILS is back, approach stagger requirements make 36R/35R a bit simpler than 17L/17R.
NASCARAirforce
Sun Dec 09, 2012 1:38 pm
Quoting mcoatc (Reply 10):
It sucks for us spotters though hahaha. I been looking forward to morning 18L operations since late November and it seems every morning there are north operations even though the winds are out of the south - but it did dawn on me that there is no ILS on 18L and like today there is a lower than desireable ceiling and since I can't see the planes as they depart over my place 4 miles north I am assuming the field is IFR.
I am curious if you have the stats of south operations since late October. It seems like after Hurricane Sandy passed by to the east of us we have been on an almost continuous north flow - all during NBAA late Oct/early Nov. I am thinking maybe we had 5-6 days since late Oct that were a south flow, which is very unusual as it usually is 50/50 this time of the year.
And before anyone asks why is there no ILS on 18L, it is because there is ILS on 18R. There was no point on putting ILS on both runways from the same direction since they are less than 2000 ft apart. FAA Standards dictate that 2 ILS approaches have to be a minimum of 4300 ft apart. Especially since ILS is a costly system. It has been taking forever to set up at ORL on Runway 25. Had they put ILS on Runway 36L and not on 36R, MCO would be a mess right now with only 2 useable runways in all these foggy mornings we have had lately.
Well I hope at least next weekend it is sunny with south winds in the morning so I can see 18L in use again.
phatfarmlines
Sun Dec 09, 2012 3:32 pm
Will Airside 2 ever get their third wing to replace the current botanical garden in place? As I understand, a potential interference to a nearby ILS system shelved this project. Was there any work done to mitigate the impact to the ILS system?
727LOVER
Sun Dec 09, 2012 3:53 pm
Quoting NASCARAirforce (Reply 11):
Mostly north wind is typical for November across Florida
NASCARAirforce
Sun Dec 09, 2012 10:22 pm
Quoting 727LOVER (Reply 13):
yeah but not like it has been, where runway useage has been continuous 35s and 36s at MCO. Since Late October Runway 17s and 18s have probably only been used 4-5 times where it lasted all day, never more than for 2 days straight. In most other years it is usually pretty 50/50 even where you get 4-5 days straight of north winds after a front but then it goes back to south for a few days
dlramp4life
Mon Dec 10, 2012 12:02 am
So what is going on with the old OH gates?? Does DL still use them for regional operations?
SEA Ramp, wettest place on earth
NASCARAirforce
Mon Dec 10, 2012 12:40 am
Quoting dlramp4life (Reply 15):
Nada
The only Delta regional ops are the occassional CRJ9 or E175 that goes to an actual gate.
dlramp4life
Mon Dec 10, 2012 12:51 am
Quoting NASCARAirforce (Reply 16):
Aww thanks for that.. That is alot of empty gate space isn't it?
PITrules
Mon Dec 10, 2012 1:58 am
I figured some of you would find these pics of former MCO int'l ops interesting. I took them in the mid 90's.
http://i644.photobucket.com/albums/uu162/JDawgphoto/SCAN0007-2.jpg
http://i644.photobucket.com/albums/uu162/JDawgphoto/SCAN0009-2.jpg
http://i644.photobucket.com/albums/uu162/JDawgphoto/SCAN0008-2.jpg
http://i644.photobucket.com/albums/uu162/JDawgphoto/SCAN0010-2.jpg
FLYi
Clipper136
DL (and FL when they were in the 90s gates) use the area as RON stands. The old OH ops office is now used by an airport contract company. The holdroom will soon become part of the up comming FIS renovations
727LOVER
Mon Dec 10, 2012 3:21 am
Quoting PITrules (Reply 18):
What airline is the last one?
PITrules
Mon Dec 10, 2012 4:22 am
Quoting 727LOVER (Reply 20):
Leisure International Airways, which evolved from Air UK's charter subsidiary.
FLYi
NASCARAirforce
Mon Dec 10, 2012 1:57 pm
Quoting Clipper136 (Reply 19):
Is that the ELS gate contractor office? I knew they were in Airside 4 somewhere
I am still trying to figure how they are going to bring pax down from the 90s gates to the FIS, if they do decide to convert 2 of the gates to International over there. The 90s wing, if lined up with the FIS would be behind the Immigration stations and would be near the FIS baggage claim where people would be coming down (I don't remember if that is claim #1 or 4). I know the hold room has been closed for a couple years, which was why people were being held on planes for up to 2 hours during peak periods when AF, LH, BA 2039, JJ and a couple VS would all arrive within the same hour. It seems like they would almost have to build on some sort of exterior hallway to the terminal that would bring the pax down maybe to the old hold room area?
winGl3t
Mon Dec 10, 2012 3:27 pm
Gol will start daily flights from GRU to MCO and from GIG to MIA next saturday (December 15th).
Both flights with 737-800 via SDQ.
globalflyer
Mon Dec 10, 2012 3:34 pm
I remember when SV served MCO. I was at a convention at the Renaissance by SeaWorld and the crew were staying there (I had no idea that SV served MCO so I was very curious at the time). I think that flight either stopped at IAD or JFK before heading to the KSA?
flyjoe
Mon Dec 10, 2012 3:44 pm
Looking at the schedules on US in late Dec and into Jan, there are now 5 wide body flights, three 767s out of PHL and a 767 and A-332 from CLT.
NASCARAirforce
Tue Dec 11, 2012 1:14 am
Another question for MCOATC:
If the IFR conditions weren't too bad - ceiling at least 1,000 ft or so - The aircraft could line up with 18R ILS, then when they had a visual of 18L they could swing over and line up for 18L couldn't they?
I am assuming during the construction 18R ILS is inactive (although I did not see it OTS in the NOTAM), but I would think construction equipment would be in the ILS critical areas that would interfere with it).
Basically 10 min before I wrote this there was a thunderstorm going on at MCO and by my place 4 miles north around 8pm and I noticed two military aircraft shooting the approach to 18L basically 500 ft behind each other (it was dark but looked and sounded like F-18s). They seemed to have no problem landing on a non ILS runway in the rain.
atct
Tue Dec 11, 2012 9:09 pm
Quoting NASCARAirforce (Reply 26):
Most aicraft flying into MCO are /Q and Id expect you could use the RNAV 18L.
atct
Trikes are for kids!
Clipper136
Wed Dec 12, 2012 12:45 am
Quoting NASCARAirforce (Reply 22):
There will be 4 gates on the 90s wing ( 90, 92, 94 and 96) that will be converted to FIS swing gates. The hub, between gates 90 and 81, will be bumped out to accommodate a ramp level corridor to the FIS.
The FIS is in the middle stages of a redesign. GOAA is working with CBP and Disney to improve the processing and queuing management. The GOAA is also deciding on how much of a renovation to do in Airside 4. After the renovation of Airsides 1 & 3 a couple of years ago, 4 is now the least modern Airside.
NASCARAirforce
Wed Dec 12, 2012 4:31 am
Quoting Clipper136 (Reply 28):
I would assume Avcon Inc Planners are also involved as they have done a lot of MCO terminal projects like the Jumbo Mode markings in the 80s wing. The last I heard it was 2 gates, but that is cool that it is going to 4 - the more the merrier - except it seems like everyone has been moving to the 20s wing in the past couple years - JBU, TAM, AMX
